VWVortex.com - DASH LIGHTS DON'T WORK....SUGGESTIONS?
    Results 1 to 15 of 15
    Thread: DASH LIGHTS DON'T WORK....SUGGESTIONS?
    1. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      09-08-2003 06:04 PM #1
      My dash lights arent working. this includes the lights on the guages in the center console of my cabby. I checked the fuse and it seems to be ok. I removed the guage cluster on the dash and checked the bulbs...1 was burnt out...this wouldnt be the cause for my "black out" would it?
      a pic...for views....help me light up my night again...
      LUNAR LOUNGE
      MID CENTURY FURNISHINGS AND DESIGN
      www.lunarloungedesign.com
    2. Member rabbitmania's Avatar
      Feb 5th, 2001
      Trenton Ontario
      1962 Volkswagen Beetle
      09-08-2003 06:29 PM #2
      I would check the head light switch itself. Sometimes it can go screwy and put you in the dark. Just replace the switch and see what happens.
    3. Member The Nothing's Avatar
      Oct 9th, 2001
      PDX
      Rabbit Convertible
      09-08-2003 07:48 PM #3
      #1- fuse
      #2- switch
      #3- cluster plug
      be sure that your taillights work... often times if the cluter doesn't work by fault of the switch your tails may not work as well...
      don't ask me how i know
      aka PDX Cabby
      You're post makes me wanna because we already talked about this many years ago.
    4. Member VWtub's Avatar
      Sep 25th, 2001
      H-town NJ
      10 Tig, 13 MCS, 93 Allante, 06 Triumph sprint
      09-08-2003 08:04 PM #4
      when my headlight switch went a lot of things stoped working. tailights, dashlights, head unit, cig lighter... i think i paid $15 for a new switch.
    5. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      09-09-2003 03:34 AM #5
      Quote, originally posted by VWtub »
      My tail lights and cig lighter work...is there any way to test the switch with a current tester?
      LUNAR LOUNGE
    6. 09-09-2003 10:24 AM #6
      On the cabby, check the dimmer on top of the switch. Maybe someone moved it all the way to the right and then your dash lights don't come on. Just a thought! Don't ask me how I know!!!!
    7. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      09-09-2003 12:05 PM #7
      Quote, originally posted by Rabbitgti1984 »
      checked it....feels a bit loose I guess I will try a switch swap.
      LUNAR LOUNGE
    8. 09-09-2003 12:11 PM #8
      i have the same probalem, and also now my turn signals dont work, the green light that is suposto blink jsut stays green when i have the signal leaver on.
    9. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      09-09-2003 12:51 PM #9
      Quote, originally posted by maxypants »
      your problem sounds like a relay...
      everything works in my car except the dash lights..
      LUNAR LOUNGE
    10. Member Scrulnik's Avatar
      Jun 28th, 2003
      NC
      66 AH Sprite
      09-09-2003 01:31 PM #10
      Quote, originally posted by jonny_breakz »
      same here, except my center console guage lights work, and they dim appropriately.
      I think I may have scraped a connection off of the 'film' behind the instrument panel, but I've looked at the current flow diagrams and it seems that they are on the same route as the console lights.
      got me dude.
    11. Member rabbitmania's Avatar
      Feb 5th, 2001
      Trenton Ontario
      09-09-2003 06:51 PM #11
      It could still be the hl switch. Mine was doing it off and on for the longest time. One day dash lights, one day not. Everything was great after I did the Jetta dash conversion.(different switch) [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Member jonny_breakz's Avatar
      Jul 26th, 2002
      Wpg Mb Canada
      99 Ford Ranger XLT
      09-10-2003 12:35 AM #12
      Quote, originally posted by rabbitmania »
      can I swap over a switch from a jetta or rabbit if the wrecker doesnt have one? do the pins line up the same?
      I just got in from a drive..and the turn indicator lights on the guage cluster arnt working now...eish dammit aahh...zuut!!
      LUNAR LOUNGE
    13. Member Scrulnik's Avatar
      Jun 28th, 2003
      NC
      66 AH Sprite
      09-10-2003 12:11 PM #13
      Well, that could be from the 14-pin bracket right behind the dash, which hooks up into the bottom of the intstrument cluster. I was having problems with mine working/not working for a while, because I kept screwing with the stereo.
      Come to think of it, that might be the problem with the inst panel lights...
      I wish Bentley had put in wiring harness diagrams too...
      Anyone got anything else on that?
    14. Member rabbitmania's Avatar
      Feb 5th, 2001
      Trenton Ontario
      09-10-2003 06:07 PM #14
      The switch for your car can be had from any Cabby, Jetta 1 or Scirocco 2. Also Quantums but seeing as how you are from Canada too, you probably won't find too many of them.
    15. Member N_TENSETUNING's Avatar
      Dec 5th, 2001
      CT 06111
      03 jetta tdi wagon
      09-12-2003 12:38 AM #15
      hey....
      i finally have my dash lights working again..... looks like the old switched must have fried.... i also noticed though that one wire was loose off the headlight switch plug.
      Even with the new headlight switch in place, it would only turned on if i pushed in this wire.
      so I unplugged the new headlight switch off the plug, and pushed this wire in all the way in place.... and PRESTO!
      ALL LIGHTS NOW WORK!
      now i can finally see how fast i'm going at night!
      yipee!
      d
