VWVortex.com - Help with a fault code: 17608 - Boost Pressure Control Valve (N249)
    Results 1 to 10 of 10
    Thread: Help with a fault code: 17608 - Boost Pressure Control Valve (N249)
    1. 09-18-2003 10:56 AM #1
      I plugged in my vag-com yesterday for the first time in a few months. I was disturbed to find this code:
      17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
      P1200 - 35-00 - -
      I've seen posts which indicate this is related to my DV. I've noticed it seems a bit louder than usual lately, but then I've been driving a little harder, too. No CEL, though. Should I ignore the fault or just replace my DV?
      Thanks for any info.
      Modified by Calvert1 at 10:05 AM 9-18-2003
    2. Banned
      Nov 23rd, 2000
      09-18-2003 01:06 PM #2
      you may have a torn diaphram in the DV.
    3. 09-18-2003 03:18 PM #3
      I threw that code when my DV was sticking. No codes since the lube job. 9 times out of 10 its going to be related to your DV.Good Luck.
    4. Member Marble's Avatar
      Nov 20th, 2002
      The Double R, TX
      '12 Jetta GLI, '12 EOS Exec
      09-21-2003 11:23 PM #4
      This code will also show if using a BOV, is that correct? Thanks.
      Jason Marble Designs
      hard parkers cc
      SYNDICATE
    5. 09-25-2003 07:39 PM #5
      I just got this code also this week. Anyone come out with a fix??
    6. 09-25-2003 07:45 PM #6
      Quote, originally posted by ATXGTI »
      When I was playing with an HKS BOV, without the recirc kit, I got this code. Got it only during cold startups too. [IMG]http://**********************/smile/emthup.gif[/IMG]
    7. 09-25-2003 08:15 PM #7
      I have the HKS BOV, all this started after I put in an N75 J valve
    8. 09-25-2003 08:17 PM #8
      Double and triple check the hoses for cuts/holes and that it is secured properly.
    9. 09-29-2003 10:19 PM #9
      Could this be a problem with (n249) working properly?
    10. 09-29-2003 10:20 PM #10
      Sorry i meant not working properly.
