Results 71 to 105 of 111
Thread: Official Cabrio/Cabriolet FAQ
  1. 07-27-2006 12:58 AM #71
    Just found a really good writeup for CV Joint maintnence..
    http://volksweb.relitech.com/cvjoints.htm
  2. Member Legoguy's Avatar
    Sep 17th, 2002
    Spruce Grove, Alberta, Canada
    1988 VW Cabriolet, 16V / 1986 VW Cabriolet / 2008 Rabbit 2.5L
    10-20-2006 07:11 PM #72
    How That Darned Vacuum Distributor Really Works
    So the bentley is wrong in how to hook the vacuum stuff up -- I have the correct hookup and mechanical proof to back it up: http://forums.vwvortex.com/zerothread?id=2883746
  3. Member Legoguy's Avatar
    Sep 17th, 2002
    10-28-2006 08:36 PM #73
    Got a busted HV/AC backlight, one that isn't replaceable (at first glance)?
    See:
    How to: replace the HV/AC backlight in newer (?) style panels with an LED
  4. 09-10-2007 02:45 PM #74
    To lazy to retype everything.....
    http://forums.vwvortex.com/zer...20801
    That thread has info on what will fit (applies to all Cabrios and Cabriolets), also any car based on a MK1, MK2, MK3 chassis (including MK3.5). Horn and turn signal stalks should work with any application as well, with very little to no hassle at all.
  5. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    04-02-2009 10:38 PM #75
    Convertible Top
    How to make your own rain gutters.
    http://volkswagenownersclub.com/vw/s...t-rain-gutters
    "A" pillar gap repair.
    http://volkswagenownersclub.com/vw/s...repair-the-Gap.
    How I install convertible tops.
    http://volkswagenownersclub.com/vw/s...p-Installation
    How to clean your "A" pillar seal.
    http://volkswagenownersclub.com/vw/s...ot-pillar-Seal
    Cabriolet top pad measurements.
    http://volkswagenownersclub.com/vw/s...d-Measurements
    Ez-on top replacement instructions.
    "A" pillar door seal repair, stop the drip.
    http://volkswagenownersclub.com/vw/s...llar-Door-Seal
    Where to oil your top frame.
    http://volkswagenownersclub.com/vw/s...ame-Oil-Points
    Cheaper replacement top struts.
    http://volkswagenownersclub.com/vw/s...t-Replacements
    Top latch removal
    http://volkswagenownersclub.com/vw/s...-Latch-removal
    Installing your top padding kit.
    http://volkswagenownersclub.com/vw/s...d-Installation
    Make your own rear cable.
    http://volkswagenownersclub.com/vw/s...DIY-rear-cable
    Improve and make your own side tension cables.
    http://volkswagenownersclub.com/vw/s...tension-cables
    Electrical
    How to remove your automatic starter.
    http://volkswagenownersclub.com/vw/s...emoval-Install
    Improving your grounds 93 digi.
    http://volkswagenownersclub.com/vw/s...ons-and-ground.
    Electrical Primer
    http://volkswagenownersclub.com/vw/s...lectric-Primer
    Parasitic Drain Video
    http://volkswagenownersclub.com/vw/s...ic-Drain-Video
    My Wipers work, but the washer don't.
    http://volkswagenownersclub.com/vw/s...-Washers-don-t.
    Relaying your headlights.
    http://volkswagenownersclub.com/vw/s...ur-Head-Lights
    Installing a a/c cut-out switch.
    http://volkswagenownersclub.com/vw/s...Cut-out-Switch
    Repairing your flaky water temp gauge.
    http://volkswagenownersclub.com/vw/s...ter-Temp-Gauge
    Removing your non-york Alternator
    http://volkswagenownersclub.com/vw/s...l-Non-York-A-C
    Cabriolet Bulb replacement numbers
    http://volkswagenownersclub.com/vw/s...cement-numbers
    1985-1993 Radio Wiring pairs
    http://volkswagenownersclub.com/vw/s...o-Wiring-Pairs.
    1990-1993 Automatic no crank warn or cold
    http://volkswagenownersclub.com/vw/s...nk-Hot-or-Cold
    1990-1993 Testing your Water temp gauge
    http://volkswagenownersclub.com/vw/s...nt-Water-Gauge
    The smarter fuse:
    http://volkswagenownersclub.com/vw/s...ows-when-blows.
    Engine/cooling:
    How to flush your radiator:
    http://volkswagenownersclub.com/vw/s...-your-radiator
    How to replace your Valve cover gasket 1990-1993
    http://volkswagenownersclub.com/vw/s...t.-90-93-Cabby.
    How to change your water pump 1990-1993 Cabriolet
    http://volkswagenownersclub.com/vw/s...-my-Water-Pump
    How to tighten a squealing a/c belt.
    http://volkswagenownersclub.com/vw/s...eling-a-c-Belt
    Triming your Radiator Shroud easy on/off.
    http://volkswagenownersclub.com/vw/s...adiator-Shroud
    How to change your in-tank fuel pump 1984.5-1993.
    http://volkswagenownersclub.com/vw/s...tank-fuel-pump
    How I change the plug wires.
    http://volkswagenownersclub.com/vw/s...Wires-Digifant.
    How to install a external oil cooler.
    http://volkswagenownersclub.com/vw/s...nal-Oil-Cooler
    Digifant Intake tube repair.
    http://volkswagenownersclub.com/vw/s...ke-Tube-Repair
    Create your own dual down pipe:
    http://volkswagenownersclub.com/vw/s...-down-pipe-1.8
    Exterior:
    How I clean my Cabriolet.
    http://volkswagenownersclub.com/vw/s...I-clean-my-Mk1
    Installing Front windshield videos
    http://volkswagenownersclub.com/vw/s...dshield-Videos
    Saggy door fix.
    http://volkswagenownersclub.com/vw/s...Saggy-Door-Fix
    Factory Paint in a rattle can
    http://volkswagenownersclub.com/vw/s...n-a-Rattle-Can.
    Repair a broken grille mount.
    http://volkswagenownersclub.com/vw/s...n-Grille-mount.
    Using a non-powered door in a 1990-1993 Cabriolet
    http://volkswagenownersclub.com/vw/s...ater-Cabriolet
    How to make a debris guard for the hood.
    http://volkswagenownersclub.com/vw/s...d-Debris-Guard
    How to remove and regrease your door latches.
    http://volkswagenownersclub.com/vw/s...r-Door-Latches
    How to gold leaf your badges.
    http://volkswagenownersclub.com/vw/s...ng-your-Badges
    How to remove your inner lights on a quad grille:
    http://volkswagenownersclub.com/vw/s...i-Beam-Removal
    Interior:
    Cold hand whistleing vents.
    http://volkswagenownersclub.com/vw/s...istleing-Vents
    Rear seat back pull replacement.
    http://volkswagenownersclub.com/vw/s...ll-Replacement.
    How to remove a door card and adjust the window and stop.
    http://volkswagenownersclub.com/vw/s...st-window-stop
    How to repair broken trun card board.
    http://volkswagenownersclub.com/vw/s...runk-Cardboard.
    Where is my trunk leaking:
    http://volkswagenownersclub.com/vw/s...-Trunk-Leaking
    2-door/Cabriolet seat back release cable repair.
    http://volkswagenownersclub.com/vw/s...le-Replacement
    Floppy vent fix.
    http://volkswagenownersclub.com/vw/s...r-floppy-vents
    Replace your chewed roll bar foam
    http://volkswagenownersclub.com/vw/s...-Roll-Bar-Foam
    Seat rocks and is hard to slide.
    http://volkswagenownersclub.com/vw/s...-hard-to-slide
    Cabriolet Fascia mounts broke?
    http://volkswagenownersclub.com/vw/s...nt-hole-repair
    How to safely remove your center and side vents.
    http://volkswagenownersclub.com/vw/s...r-Vent-Removal
    How to replace your slow seat belt retractors.
    http://volkswagenownersclub.com/vw/s...s-in-Cabriolet
    Suspension:
    How to replace your rear struts:
    http://volkswagenownersclub.com/vw/s...ur-Rear-Struts
    How to replace bushings with no press.
    http://volkswagenownersclub.com/vw/s...ithout-a-Press.
    How to replace your front struts, and mounts.
    http://volkswagenownersclub.com/vw/s...uts-and-Mounts
    How to keep the rear lower shock bolt from seizing.
    http://volkswagenownersclub.com/vw/s...t-from-Seizing.
    How to remove a power steering pump.
    http://volkswagenownersclub.com/vw/s...-Steering-Pump
    Transmission:
    How to remove and replace a torque convertor seal.
    http://volkswagenownersclub.com/vw/s...0-transmission.
    How to change a differential seal:
    http://volkswagenownersclub.com/vw/s...ferential-Seal
    How to make a cheap weighted shift rod.
    http://volkswagenownersclub.com/vw/s...ed-Shifter-Rod
    Automatic Transmisison Service guide.
    http://reflectionsandshadows.com/a1-tech/BIGATSG.pdf
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  6. Member
    Feb 11th, 2003
    Winchester, VA
    05-16-2009 08:33 AM #76
    This is a pretty complete DIY I did for those who want to tackle this job:
    Cabrio B-pillar seals and B-pillar cover replacement
  7. Member skydive_007's Avatar
    Oct 3rd, 2007
    Las Vegas
    91 EA Cabby - 02 24V GTI
    08-10-2009 03:41 PM #77
    Refrigerant & Lubricant Specs
    All oil specifications assume that A/C system has been properly cleaned, and new accumulator / filter drier has been installed. Specs are for total system
    capacities. Always refer to under hood decal as the primary source for refrigerant and lubricant information.
    Refrig System Oil Capacity
    Year/Model/Type Oz./Type Oz./Premium Standard
    BEETLE
    03-01 All Eng. .................................................. ............................................ R-134a 26.00 PAG-46 4.50 409503 409888
    00-98 All Eng. .................................................. ............................................ R-134a 24.00 PAG-46 4.50 409503 409888
    CABRIO
    02-01 All Eng. .................................................. ............................................ R-134a 27.00 PAG-46 4.50 409503 409888
    00-95 All Eng. .................................................. ............................................ R-134a 28.00 PAG-46 4.00 409503 409888
    CABRIOLET
    93-86 All Eng. .................................................. ............................................ R-12 32.00 Mineral 4.75 209500 --
    PSN: kookly
    Jan 18th, 2003
    CA
    2011 WRX
    12-06-2009 09:25 PM #78
    I finally have one!
    Cheaper replacement struts for your top,
    http://www.mcmastercarr.com
    strut - 9416K337 110lb force required
    eyelet - 9416K84
    You will need 2 struts @ $12.30 each and 4 eyelets @ $1.41 each for a total of around $38 shipped! Compared to the $40 each charged for the oem replacements.
    Hint, keep the rubber booties that go over the top of your stock ones, they take up the extra space on the stud. I just put these in and the do the job at hand beautifully, popping the top up enough to stay off the snaps.
  9. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    02-18-2010 09:20 AM #79
    Quote, originally posted by sgren737 »
    I finally have one!
    eyelet - 9416K84
    here is a pic of them
  10. Member JPX's Avatar
    Nov 6th, 2005
    San Jose,CA
    1989 Cabriolet
    05-02-2010 10:45 AM #80
    How to get the big green Viton O-ring on the CIS fuel injectors with hats----------
    Remove the old ring (if it didn't already fall apart) by cutting it carefully off the injector.
  11. Member JPX's Avatar
    Nov 6th, 2005
    San Jose,CA
    1989 Cabriolet
    06-01-2010 12:10 AM #81
  12. 09-13-2010 09:48 PM #82
    They DID put the 1.6 in the rabbit convertable I have one and its one of the 1st Its a 1980 Convertable in Ellenville NY ITS FOR SALE MK 1 for sale has Pictures
  13. 10-11-2010 11:29 AM #83
    i try this
  14. Member The Nothing's Avatar
    Oct 9th, 2001
    PDX
    Rabbit Convertible
    03-14-2011 07:14 AM #84
    years ago we all shared this, it seems like a lot of people still need it: The Bentley Manual for Cabriolet & Scirocco 85-93, including 16v. I'd say it covers pretty well, pre-85 cars too, as our cars didn't change much beyond engine size. Self-extracting .exe to save 100megs of download
    edit:
    To make things easier, and so I could load it all onto my iphone, I've divided the manual up into chapters
    Fundamentals.pdf
    Lubrication and maintenance.pdf
    Engine.pdf
    Cooling System.pdf
    Fuel System.pdf
    Exhaust and Emissions.pdf
    Ignition.pdf
    Manual Transmission and Clutch.pdf
    Automatic Transmission.pdf
    Suspension and Steering.pdf
    Brakes.pdf
    Body and Interior.pdf
    Electrical.pdf
    aka PDX Cabby
    You're post makes me wanna because we already talked about this many years ago. Search mf'er
  15. Junior Member RixDub88's Avatar
    Jan 21st, 2007
    Panama City Beach, FL
    1988 Vanagon Wolfsburg; 1992 Cabriolet Carat; 2006 Rabbit
    03-14-2011 06:03 PM #85
    Ummmm, I don't know if this is the right place to ask,.....but: The part I'm looking for is apparently too exotic to find easily, other than maybe from a source other than the usual oem suppliers.
    The car is a 1992 Cabriolet Carat; the part I'm trying to find is called an Air Intake Boot (according to Bentley Manual, pg. 5-23. The part is a very complex molded rubber "hose" coming from the Air Flow Meter, held by two clamps at both ends.
    Is this part so freakin' "unobtainium" or what?
    Oh yeah, it's part of the Digifant II system.
  16. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    '86 Cabriolet G60, '82 280ZX Turbo, '06 325i Problem Child
    03-23-2011 03:09 AM #86
    Quote Originally Posted by The Nothing View Post
    danke!
    It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark... and we're wearing sunglasses.
    -Hit it.
    RooflessVW
  17. Member keeton's Avatar
    Aug 15th, 2010
    Winston Salem, NC
    '84 Jetta, '84 Mustang, '71 F250
    03-28-2011 09:22 AM #87
    Quote Originally Posted by s2kvondeutschland View Post
    Danke!
    +3498745
  18. Member The Nothing's Avatar
    Oct 9th, 2001
    PDX
    Rabbit Convertible
    03-30-2011 07:48 PM #88
    shift linkage adjustment for 020s
    put your car in neutral
    jack it up (use jackstands)
    loosen this bolt
    and grab a cassette tape. if you don't know what a cassette tape is, one is included in the photo.
    the thick part (head) is the proper size for the adjustment. just pin it in the lockout. Then tighten the bolt at the other end of the shaft that you loosened earlier. Put the car on the ground and drive away!
    if you're still unable to find gears, then you've got other problems.
    aka PDX Cabby
  19. Junior Member
    Apr 19th, 2011
    columbus, ohio
    91 - cabby - new black top, white paint, glass pack pipe, 2 boss 1800 watt 10's, 1000 amp, kong rims
    04-20-2011 04:31 AM #89
    Performance upgrades (for those not desiring the ever-popular engine swap)
    Mechanical upgrades:
    Techtonics Tuning* header or dual-downpipe (also: swap to a dual-outlet exhaust manifold)
    o
    Headers tend to be louder
    Techtonics Tuning* hi-flow cat and cat-back system (for those not in emissions testing areas, you can eliminate the cat altogether)
    Larger throttle body (from an Audi 5000 or A2-era CIS Golfs/Jettas)
    Bored intake manifold (this can be a DIY job on your existing manifold with a Dremel-like tool)
    Techtonics Tuning* 288 or 270 camshaft and adjustable cam gear (stock upgrade: cam from a A2-era Digifant II GTI)
    o
    You will need to upgrade the valve springs and such, advance the timing a bit, and use premium gasoline
    o
    For hydraulic heads, use a cam intended for an A3-era 8V ABA engine
    Enlarge the air intake (option: swap to a Scirocco 16V air box) & install K&N air filter
    Install a larger air pipe between air box and throttle body
    Larger valves, 10:1 pistons from a newer 1.8L
    Larger fuel distributor (A2-era CIS Golf/Jetta)
    Lightened flywheel and short-shift kit
  20. 06-22-2011 07:54 PM #90
    maybe the motor has been changed butwhen i buy spark plugs and wires for my 86 cabriolet the wires dont sit down on the plugs due to these heat shield boot things. does anyone knpow what i am talking about and what to do about it?
  21. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    06-28-2011 05:13 AM #91
    Yes you have to remove the little itty bitty top off the end of the plug. It screws on.
    Hold the plug in a pair of pliers by the nut or a deep well socket on the end of the larger ceramic piece (usually has the brand stamped on it) remove the Steel tip by un-screwing it. You will be left with a threaded post and your plugs and wires will be more tighter.
    Please Post in The main chat area, as this is a FAQ's thread or How-to's for frequently answered questions.
    Before you remove the tip:
    After you remove the tip:
  22. Semi-n00b
    Jul 4th, 2011
    Cheshire, UK
    07-04-2011 08:35 AM #92
    Hi,
    First post so sorry if this isn't in the correct sectrion!
    I've searched, but can't find the answer so I'm posting this. I'm looking to fit a US spec front bumper to my UK 00MY MK3.5 cabrio, please could someone point me in the right direction for the part number(s) I need to give the parts guy over here?
    Thanks in advance,
    Andy
  23. 07-26-2011 11:52 AM #93
    I just bought an 88 volkswagon cabriolet and I am looking for parts for it. Not expensive parts. But I want it to look like some of the cars Ive seen on this site. Body moldings, bumpers, headlights, rims and tires, seats, engine components and mods, etc. Somebody help me if ya got information as to where I can get these. Thanks.
  24. 07-28-2011 11:51 AM #94
    Good Morning. Tryna to find out how to check my 88 cabriolet to make sure engine is running well. When I crank it the oil light is flashing. Why is that or what things do i need to check for this. Car seems to get hot after driving certain distance. What to check? It idles kinda high. What could be possible problem? Also after driving and parking again, seems a little hard to crank. Any suggestions or what any of these issues could be? Appreciate any help.
  25. Member keeton's Avatar
    Aug 15th, 2010
    Winston Salem, NC
    07-29-2011 07:14 PM #95
    Post in the main Cabriolet forum. This is an FAQ thread.
    Sent using Tapatalk.
  26. Junior Member oldbluecabby's Avatar
    Nov 22nd, 2009
    WOODSON,TEXAS
    1986 VW CABRIOLET
    08-08-2011 12:52 PM #96
    you can buy them, i have one for sale
  27. n00b
    May 11th, 2011
    VW MK1 1986 Cabriolet Wolfsberg Edition
    12-15-2011 01:19 AM #97
    Hello,
    I have a 1986 Cabriolet. However my motor is a carburated motor, the motor has an H stamp on it from Germany which leads me to believe the car was imported from Germany. It the Wolfsberg/Karmann edition if that helps in Havana Brown with Leather and the steel bumpers. Help?
  28. 05-04-2012 11:24 PM #98
    Who manufactures the best seatcovers for the front buckets>?
  29. Junior Member
    Dec 22nd, 2010
    Corpus Christi, TX
    1993 Collectors Editions Cabriolet
    05-18-2012 05:50 PM #99
    Why do all the links for maintenance from mk1dubs.com lead to ads and not the info as listed on the link/thread. This is very deceptive.
  30. Member
    Oct 18th, 2002
    Bainbridge Is., WA
    '02 V70 T5, '00 Jetta TDI, '86 Cabby
    05-30-2012 06:26 PM #100
    Quote Originally Posted by ch47dr View Post
    It looks like the site has been hijacked somehow. I get a glimpse of the proper site before being redirected, and then I get a malware warning.
  31. 06-04-2012 02:12 PM #101
    I googled it and it looks like the site is now at www.mk1dubz.com. I guess the site is now spelled with a "z" on the end rather than an "s". I am assuming that is the same site, they have a pretty extensive forum there similar to this one.
    Just throwing that out there...
    1987 Cabriolet
    1989 Cabriolet (parts)
    1991 Cabriolet
    1998 Jetta
    2002 Golf
  32. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    06-04-2012 09:41 PM #102
    Quote Originally Posted by cabbys and dirty diesels View Post
    It is most definitely not the same... the "z" site copied the "s" site, which is why the "s" site reverted back to its old domain. What you need to do (and what Brian needs to do), is replace "mk1dubs.com" in each of those links with "the152.com". For example:
    http://mk1dubs.com/modules.php?name=...ewtopic&t=2636 should be
    http://www.the152.com/modules.php?na...ewtopic&t=2636
    Or, just go to http://www.toplessrabbit.com/forums/index.php ; all of briano1234's guides are posted there too.
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  33. 06-05-2012 11:10 AM #103
    Thanks for the clarification, I appreciate that.
    1987 Cabriolet
    1991 Cabriolet
    1998 Jetta
    2002 Golf
  34. Junior Member
    Jun 24th, 2012
    90 Cabriolet Boutique Triple White, 2005 Treg, 2010 Jetta t
    06-24-2012 01:15 PM #104
    thank you...this is spectacular
  35. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    01-10-2013 08:38 PM #105
    Quote Originally Posted by vanaguy View Post
    because the domain no longer exists
    the page displayed is a Filler template...basically an advertisement by the domain to sell you the site or make money by you clicking....
    would be nice if briano fixed his links
    or someone (like me) reposted the whole thing for him
