VWVortex.com - question on bleeding wilwood or any 4 piston calipers..
    Results 1 to 3 of 3
    Thread: question on bleeding wilwood or any 4 piston calipers..
    1. 11-15-2003 10:33 AM #1
      should i start with the bottom bleeders then do the top of vice-versa? i figure air rises so do the tops last
    2. Member reflexgti's Avatar
      Dec 19th, 2000
      NorCal
      09 335i, 01 GTI 1.8T, 04 Touareg V8, 07 GTI. Gone: 01 BMW M5, 00 Audi A6 Avant, 96 BMW 328is
      11-16-2003 11:03 AM #2
      Bleed only the top. Wilwood has bleeders top and bottom because they are designed to fit on in multiple positions.
    3. 11-16-2003 02:15 PM #3
      You only use the top bleeding holes.
      Start with the rear wheels...right one first, then left one...then for the front Wilwood calipers, you do the outside right nipple first, then the inside. Then on the left caliper, same thing...outside one, then inside.
      Basically you only touch the top two bleeders.
    « Back
