VWVortex.com - Snow screen?
    Results 1 to 18 of 18
    Thread: Snow screen?
    1. 09-27-2001 02:07 AM #1
      Hi guys. Has anyone actually ever seen a snow screen in a Beetle? I took the fender apart on a 2liter and a Turbo, but nothing!
      Pete S
    2. Moderator silverspeedbuggy's Avatar
      Aug 8th, 2001
      Cleveland Heights OH
      2015 GTI, 2006 GLI, 1987 Scirocco 16V, 1989 Jetta GL
      09-27-2001 12:35 PM #2
      I hate to sound dumb, but what the heck is a snow screen?
    3. 10-04-2001 11:44 PM #3
      Snow screens are screens like your laundry drier has. VW installed them in the airducts infront of the actual intake airboxes on Golfs, Jettas and Passats. Someone that frequents this board told me this summer at a Wisconsin VW show that he removed his snowscreen from his Turbo Beetle.
      Seems like an over-engineering thing from VW. They're clogging up like crazy (imagine your drier after not cleaning the screen for a dozen loads!).
      Anyway, not enough air into the engine eventually causes a "lean code".
      Seems like the Beetles do not have snow screens.
      Pete S.
    4. 10-05-2001 03:49 AM #4
      I'm lost.
    5. 10-05-2001 04:02 AM #5
      no snow in sunny south florida
    6. 10-05-2001 02:20 PM #6
      I took mine out of my 2000 TDI Beetle.
    7. 10-05-2001 06:58 PM #7
      Removed mine as well.
      The snow screen is just a fine meshed piece of screen that is half-way up your air intake plumbing. It tends to get clogged up with pieces of leaves and bugs and crap after a while. Stuff that could not make it through your air filter anyway. A utility knife solves the problem in 3 seconds. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. 10-07-2001 08:27 AM #8
      But if you are careful, and use a bunch of little screwdrivers to release the plastic clips holding the lower airbox together, you can take it apart and remove the snow screen undamaged. Just in case the unlikely event you want to put it back in.
    9. 10-07-2001 01:26 PM #9
      If the "snow screen" gets blocked and prevents air from getting in the engine, It would run rich, not lean.
    10. 10-10-2001 06:26 PM #10
      Correct. Then the O2 sensor sends this info to the ECU, which in turn leans things out to the point where a "lean" code is set.
      Anyway, I guess some have these screens and some do not.
      BTW, ("half-way up your air intake plumbing") is this accessible through the fender or the engine bay?
      Thanks
      Pete S
    11. 10-10-2001 07:22 PM #11
      The fender.
    12. 01-06-2004 08:29 PM #12
      So, would an '03 Beetle 1.8T have one and if it does - where is it located? I clean the one in my '02 Jetta TDI - is there any similarities? What is the procedure for cleaning the Beetle snow screen?
    13. Member CK98Beeetle's Avatar
      Oct 19th, 2002
      Nashville
      07 90% Escalade
      01-06-2004 08:34 PM #13
      GEt rid of that snow screen, its worthless. I took mine out, ran fine ever since. You take off the front drivers side wheel, and remove the black fender liner, it right there, really easy to see, its a box piece of black plastic poorly put together with a screen and a flap on it. Its really weird.
      Quote Originally Posted by PoorHouse View Post
      He can't even find a mechanic on his own. Probably better he isn't working on the brakes of his 2.5
      ton vehicle.
    14. Member Kevin Rowley's Avatar
      Sep 6th, 1999
      Georgia
      1987 Cabriolet
      01-07-2004 09:42 AM #14
      Here's a how-to found on the web:
      http://www.bugmod.com/snowbox.htm
      And no, I didn't write it. Good luck!
      2005 MINI Cooper S
      2004 Volvo C70 LPT
      1987 Cabriolet Bestseller
    15. 01-07-2004 12:19 PM #15
      Thanks for all the inf.. I just might remove it if it is too much of a pain to get at on a regular basis.
    16. 01-07-2004 01:06 PM #16
      just remove the SNOWBOX all together and the snorkel and put in an intake system, and it'll run even better....or, you could go the CAI route as well....
    17. 05-13-2012 02:53 PM #17
      Does the 99 Jetta have a snow screen?
    18. 05-13-2012 03:06 PM #18
      Quote Originally Posted by Pete S View Post
      Thanks
      Pete S
      Does the 99 Jetta 2.0 have a snow screen?
