Page 1 of 2 1 2 LastLast
Results 1 to 35 of 45
Thread: How-to Replacing wiper blades on aero wipers (save $)
  1. 11-20-2003 12:20 PM #1
    Here is how to save money by replacing just the wiper blades on the aero wipers and not replacing the entire arm, as most people seem you have to do. just about any wiper refill will work so choice what ever you like. The procedure was done by vuvision but reproduced for us mk4 people.
    Tools needed are needle nose pliers and scissors
    Replacement refills, these are from walmart and cost $6.88
    [img][/img]
    Now remove the wiper refill from its holder. Use a needle nose plier to pull off the retaining metal clip and slide out the silicone refill. Discard the metal clip & the plastic holder.
    [img][/img]
    There are two plastic end caps on the Aero Blade, one end has a metal pinch tab that secures the rubber refill, and the other has none. Look for the end with the pinch tab by slide the rubber wiper back & forth, the end that has no movement is the business end. Disregard the free moving end. Another easy way is to look for the end that is near to the notch (see pic below).
    [img][/img]
    Use the pliers and pull of this end of the wiper.
    [img][/img]
    Use the pliers to bend up the metal retaining clip.
    [img][/img]
    The bend clip should look like this.
    [img][/img]
    You are now free to slide out the wiper blade.
    [img][/img]
    Slide in the new blade refill and cut to the proper length.
    Push the metal tab back down to secure the new wiper blade in place.
    [img][/img]
    Replace the end cap and you are all done.
    [img][/img]
    Enjoy
    Modified by Sawdust at 9:14 PM 2-3-2004
    Forsale: Full screen MFA Euro Cluster :337 BBS RC's mint : Euro Gamma Radio with indash 6 Disc CD Changer : Lots of other misc parts : Parts Located In Canada
    Please search my user name for parts for sale.
  2. 11-20-2003 12:41 PM #2
    is the retaining clip the same one one the aero wiper itself? I ask because if it is then that must suck because metal bent back and forth is bound to fall off and the aero's are like $100.
    so then you would have to buy a whole NEW set?
  3. 11-20-2003 12:53 PM #3
    Quote, originally posted by GeneH »
    well first off you are bending it like 1/16" its not going to break. and besides up to now everyone has been replacing the entire wiper blade anyway. the only reason they are 100 bucks is because you are buying a new wiper arm too.
  4. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    2006 GLI, 2008 Rabbit
    11-20-2003 04:59 PM #4
    I knew there was a way to do this, but I could never figure it out. Mine wore out after about 6 months, and I tried to replace just the blade. I ended up ordering new ones for $40 from Impex. I'll remember this for next time.
    Ride In: 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
    Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    Future: 2015 Audi S3
  5. 11-20-2003 06:17 PM #5
    the dealer has them for 25.00 for one side and about thirty for the other side. They have gone down in price. Also if you don't want to replace the wiper blades and you insist on just replacing the rubber inserrts, buy part number 200-955-522 at the dealer. They'll run you about 7.00 for the pair. These inserts are for for the standard blades, but believe me thay fit. VW claims they don't have replacement inserts yet, but these will work just fine.
  6. Banner Advertiser OEMplus.com's Avatar
    May 27th, 2003
    Orange Co, CA, USA
    Lots
    11-20-2003 08:48 PM #6
    Quote, originally posted by urspeedracer »
    thanks...ill keep that in mind!!!
  7. 01-18-2004 12:35 AM #7
    Has anyone tried this? I hope it works because I definitely do not want to pay $40 for new blades.
  8. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-18-2004 02:58 AM #8
    Glad you bumped this up, B. I was just thinking abotu replacing mine while I was driving in the rain tonight. That windshield banner wears the blades out pretty fast.
  9. 01-18-2004 03:08 AM #9
    Quote, originally posted by BRM10984 »
    My wipers skip across the windshield.... very annoying.
  10. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    01 Golf GLS 1.8T, 02 Jetta WGN 2.0, 11 JSW 2.5SE (Wifes)
    01-18-2004 03:38 AM #10
    This cant be right. The wipers are 2 different sizes. They would not offer 1 size blade. I am glad to see the first post, as I will need to replace my aero blade some day. But as for this second part. Get up the other part # and then I will believe.
    Chamber: My Wheels Rub on the Inside|Forgeline Wheels|WRDusa.com|
    FlickR
  11. 01-18-2004 09:31 AM #11
    This is a great write-up cause its getting close to replacement time and I didn't want to pay for a whole new set.
  12. 02-03-2004 09:05 PM #12
    Sawdust,
    Granted you did mention my name twice on your write up. However, I do not recall granting you permission to use my write up & pictures to use as your own. Plagiarism & ripping off someone else's pics and host them as your own are not exactly the cool things to do.
    This write up was originally posted for my friends in Clubb5 Information forum.
    http://www.clubb5.com/forums/viewtopic.php?t=59805
    I do not appreciate you taking my work and post it as your own without my consent.
    Regards,
    Vuvision
  13. 02-03-2004 09:13 PM #13
    Quote, originally posted by VUVW »
    Sawdust,
    Regards,
    Vuvision
    We are talking a car modification here, not rocket science theory essay.
    And i emailed the original poster of this asking if i could use the pictures and never got an answer back. But thats fine the pictures are removed.
  14. 02-03-2004 09:58 PM #14
    we don't need the pics anyway
  15. 02-03-2004 10:29 PM #15
    Quote, originally posted by jayrock711 »
    I will take my own pics this week, and post them up.
  16. 02-03-2004 10:32 PM #16
    how do i get aero blades instead of these generic ones?
  17. 02-25-2004 08:06 PM #17
    Whoo, someone got their panties in a bunch.
    I'm not sure what my chances of getting free ones before I hit 20000 km's is?
  18. 05-17-2004 11:20 AM #18
    Aero blade replacement..I could not get any of the pictures to come through. HELP !! Pictures are nice and I'm gonna "F" it up if I don't have the pics to help me along send to: dterrana@aol.com
  19. 12-02-2004 06:58 PM #19
    Click on the post from VUVW, highlight the body of his post, copy and paste into word. Then you'll have something to work from. It's not plagiarism, it's the dissemination of information to the masses.
  20. 12-02-2004 07:28 PM #20
    Oops, I just realized the date of this thread....holly thread revival! Sorry guys.
    That's what happens when a thread is linked from a different forum
    -b
  21. 12-02-2004 07:57 PM #21
    I just bought new wipers from the dealer not the whole arm but the actual wiper part that unclicks from the arm and paid less then 25.00 for both sides and they had just the refill blades in stock for like 7.00 for both sides but it is a pain to install those refills and get them 100% right so for a little over twenty two click in the parking lot and I am done
  22. 05-14-2005 11:05 AM #22
    Anyone know if there is a new thread for this?
  23. Member hippierob's Avatar
    Apr 20th, 2006
    Miami Beach
    09 NBC
    04-30-2006 11:51 PM #23
    dont care who you are...if you're really gonna cry about someone reposting your stuff, while even giving credit to you as the original poster......damn thats petty.....
    yous a punk....
  24. 05-25-2006 09:35 PM #24
    yep bump for new pics or if there is another thread
  25. Member G-Shock's Avatar
    Jun 14th, 2002
    Chandler, Arizona
    2002 Relex Silver 1.8T VW GTI
    06-15-2006 05:32 PM #25
    Quote, originally posted by attwsdave »
    Do you have the part numbers? I am hoping to find the blades cheaper then the dealer.
  26. Member
    Aug 3rd, 2001
    Tampa
    2001 Jetta Wolfsburg
    06-26-2006 04:53 PM #26
    Looking for updated status on this. Just got the whole AERO wiper assemblies to replace my 2001 stock ones. Any wiper isntall write-ups will help too
  27. 11-13-2006 11:19 PM #27
    Quote, originally posted by tdi2vr6 »
  28. 12-24-2006 06:09 PM #28
    I just purchased a Michelin Premium Wiper blade at Walmart this week for $7, at the suggestion of another member. This too will work well as a replacement to the stock rubber blade..without having to buy the entire arm. I used dish soap along the blade channel and worked it in, then after following the proceedure below ( too bad the photos aren't there) , was able to slide the stock rubber wiper out with ease and insert the new blade, which is almost identical to the VW blade. The best part is that I had a fair amount of chatter from the stock wipers, which has disappeared with the Michelins. What a great way to save about $60 with very little effort. This suggestion was a great Xmas present!
  29. 03-10-2007 10:09 PM #29
    I just stumbled onto this thread through a Google search. Do you have an updated post with working images?
  30. 03-10-2007 10:13 PM #30
    this thread is madd old!
  31. Member Greg_J's Avatar
    Oct 30th, 2005
    Grand Bend ON Canaduh
    Montana Green '92 GTI w/ OBD2 ABA swap - '03 Jetta Wagon TDI 6spd
    03-21-2007 02:24 PM #31
    reload the pictures please!
    edit: nevermind, i got it to work
    Modified by Greg_J at 7:09 PM 3-21-2007
    Quote Originally Posted by ennui_delphian View Post
    Don't anger canadiun lesbian...
  32. Member
    Oct 9th, 2004
    Houston
    2003 GTI 1.8T
    05-27-2007 12:12 PM #32
    Walmart used to sell the Luxor B series wiper inserts (the rubber part that wears out), but stopped selling them at least 14 months ago. They worked great and were cheap. Now Walmart and all the auto parts stores in my area only sell wiper blades, and it is stupid to replace the whole blade (which should last the life of the car in most cases) when you just need the insert. And I have not found a passenger side wiper blade that is curved like the original. I guess I will have to go to the dealer now, when they feel like opening the parts department, which is usually when I am at work, to buy the inserts. It surely was convenient to stroll into Walmart at 1 AM and get what I needed cheaply! Since only one part number is mentioned in the posts above, I presume that they are sold long enough to fit the longest blade and I just cut the other ones with scissors to fit the shorter blades (3 blades on my GTI). If not, I will post all the part numbers here.
  33. 06-06-2007 01:32 PM #33
    Hey gtigtigtigtigtigti..you can still get just rubber inserts, granted all stores may not have them. Go to Advance Auto, and get Trico Brand inserts. I don't know the exact number off hand, but I got the ones listed for the 2006 Jetta driver side refill only (seeing I was replacing those on the Aero Blade also) and they are more than long enough (24" I think) to cut to fit other applications. If you still have your stock wiper blades with the curve to them, they are not Aero Blades, but just take the metal inserts out of the rubber with the Trico blades, and put your OEM ones in before sliding it back into the stock blade. The Trico inserts seem to wipe really well also.
  34. 11-19-2007 04:47 PM #34
    bump for updated pics
  35. 11-19-2007 04:51 PM #35
    no pictures
