VWVortex.com - How does twin engine cars work?
    The Car Lounge
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 27
    Thread: How does twin engine cars work?
    1. 12-12-2003 01:46 AM #1
      I mean like if you have one engine powering the rear wheels and one powering the front wheels. How do you keep the engine in sync as to prevent the rear from revving quicker than the front or vis versa. Even if the engine is exactly the same...won't you have slight variation power? So is the power split determine by the differential like in an AWD system? Same with cars with electric motor on all four wheel. What if motors on one side is weakened, would that not make the car have "torque steer." Wouldn't trying to keep all the engine/motor in sync cap the max power potential? Whats the advantage of multiple engine over a single large or super powerful engine?
    2. 12-12-2003 01:53 AM #2
      I wanna know how things like throttle and shifter cables are managed... I've never been close enough to a twin engine car to see for myself.
    3. 12-12-2003 02:01 AM #3
      I'm pretty sure they have one pedal linked to two throttle cables and the shifter has linkages to both gearboxes?
      -Andrew
    4. 12-12-2003 02:10 AM #4
      So it's a dual gearbox setup with twice the alternator, waterpump, etc..? Man that would be mad heavy...how is that an advantage over a single engine with AWD system like the EVO? In what circumstance would u even want a dual engine?
    5. 12-12-2003 02:16 AM #5
      Quote, originally posted by 87GolfKart »
      just for kicks
    6. 12-12-2003 02:16 AM #6
      when you can't fit in a bigger engine and you can't get any more power out of it, the only option is to put a second one in! instant power doubling!
    7. 12-12-2003 02:23 AM #7
      Quote, originally posted by GTiTOM »
      ahh yeah i thought that might be the case...split a v12 into dual v6's
    8. 12-12-2003 02:40 AM #8
      Ian Birch(?) of DubSport(?) in England built a few of those including a twin-vr6 Rallye and twin 16v Rabbit... also a mid-engine turbo rabbit with rwd.
      One of the problems he had with the Rallye is the engine cooling/heating. Basically you can run the car on just one engine and then fire up the other one when you feel like racing or sumtin'. Problem is the other engine is cold at that point so it gets really trashed if you go hard right away. So in the the 2x16v Rabbit he built after that he ran the cooling hoses from one engine to the other so the hot coolant would warm the non-active motor before use...
      At least that's what I remember from some old PerformanceVW magazines...
    9. 12-12-2003 02:46 AM #9
    10. Member Triumph's Avatar
      Nov 27th, 2000
      Northern VA
      '09 GTI
      12-12-2003 10:10 AM #10
      two engined cars are dumb, imo.
      -Triumph, the Insult Comic Dog
      I saw this in a movie about a bus that had to speed around the city, keeping its speed over fifty, and if its speed dropped, the bus would explode! I think it was called, "The Bus That Couldn't Slow Down."
    11. 12-12-2003 10:19 AM #11
      Car and Driver built a twin engined CRX. They used the road to synchronize the front and rear engines. To make things easier, they used automatic transmission... they only had to duplex the throttle and shifter cables.
      BMC made a twin engined version of the Mini Moke, a Mini powered utility vehicle that looked like the VW Thing, for a UK military contract proposal. It was a quick cheap way of getting 4WD. You could turn on/off either engine. They had manual transmissions and that they could be shifted independently... you could have on engine in 4th gear and the other in 2nd. I don't know how specifically how the controls worked.
    12. Geriatric Member Obin Robinson's Avatar
      Oct 20th, 2000
      Jacksonville, Florida
      2001 Boxster, 2012 Kia Soul
      12-12-2003 10:21 AM #12
      Mosler Twinstar owns all!
      http://www.moslerauto.com/mosa...e.htm
      obin
    13. 12-12-2003 10:22 AM #13
      MTM bi-moto [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Member MEIN_VW's Avatar
      Jul 29th, 2000
      Bradford, Ontario
      2014 Golf TDI wagon, 2003 Passat 1.8T
      12-12-2003 10:34 AM #14
      And a big weight increase too.
      I don't understand. So many people here moan that new cars are too heavy but praise a car with 2 engines
    15. 12-12-2003 10:36 AM #15
      Quote, originally posted by Triumph »
      Here... let me give you your click back since you really didn't want to read in here anyways.
      Back on topic, IIRC, the twin-engine Tiburon used automatic transmissions, which eliminated the issue of having to shift both transmissions simultaneously.
      Bowtie wearing, tattooed, Mini driver
      Quote Originally Posted by JalopnikMatt View Post
      Yeah, I've bypassed y'all and go straight to r/cars.
    16. Member Triumph's Avatar
      Nov 27th, 2000
      Northern VA
      '09 GTI
      12-12-2003 02:45 PM #16
      Quote, originally posted by cougar »
      i'm still interested in how they work, i just think they're a dumb idea.
    17. 12-12-2003 02:59 PM #17
      Quote »
      i still don't understand how you distribute the torque between the two engine...what if one engine pushes harder then the other in acceleration...like the rear would push faster than the front...and the car acually accelerate at the speed of the rear...wouldn't this be a waste of the secod engine? the front slower engine would actually slow the car down?
    18. Member
      Nov 24th, 2002
      CA Bay Area
      66'KG, 69' KG, 94' Miata, 06' Exige
      12-12-2003 03:01 PM #18
      Ummm...2 engine = more power.
    19. Member
      Oct 20th, 2001
      London, Ontario
      2017 Subaru BRZ, 2006 A4 2.0T Avant
      12-12-2003 03:06 PM #19
      No that's not quite what would happen. Think about you and a buddy pushing a car. Lets say that you are stronger than your buddy. Which is faster: you pushing on your own, or both of you working together? Obviously both of you working together.
      Unless the more powerful engine was accelerating the car more quickly than the second engine could accelerate with no load then they are both contributing.
    20. 12-12-2003 04:20 PM #20
      mosler's twinstar actually encountered this problem, as one engine was the 275hp northstar from the elc, and the other was the 300hp version from the etc. So when accelerating hard, each transmission would have different shift points, and as one engine shifted, and other assumed full responsibility for power.
    21. 12-12-2003 05:46 PM #21
      <troll>
      twin engine, quad engine... no matter, a chipped 1.8t still ownz it all!
      </troll>
    22. Member matt007's Avatar
      May 15th, 2001
      portlandia
      65 Mustang 289, 81 SLC500, 84 911LS1
      12-13-2003 08:26 AM #22
    23. Member Merc-MarkO's Avatar
      Nov 21st, 2001
      Great State of Oregon
      a '98 [on life support] and a '07
      12-13-2003 09:03 AM #23
      Quote, originally posted by MEIN_VW &raquo;
      Use bike engines .....
      Where is Kyron ??? http://www.bringkyronhome.org/
      Support our troops, bless the fallen.
      Quote Originally Posted by genjy View Post
      Yes, there is a high chance that the tractor trailer was the one going 160MPH, not the Porsche GT2 RS.
    24. 12-13-2003 09:46 AM #24
      Citroën build like 700, IIRC, BiMotor CV2's. I think they were called Safari.
      I don't think synchronizing is much of a problem. If one engine is stronger than the other, the other one will just get a little push in the back. Just like driving downhill gives your engine a little push in the back.
      The gears need to be chosen so that both engines max out at the same time. Otherwise you have to shift when one engine reaches its peak, in doing so not using the full potential of the other engine.
      Bi-motor cars are interesting, and a way to make a balanced supercar out of a FWD chassis. But it'll never beat the single mid/rear engine.
    25. Member Spindle's Avatar
      Oct 2nd, 2000
      In the room where the giant fire puffer works..
      12-13-2003 11:04 AM #25
      Here's one way it's been done...
      (Click on pic for more info)
      I would imagine that these days engine sync could be electronically controlled. I know that multi-engined piston aircraft have that capability.
