VWVortex.com - Tire pressure on 195/65/15
    Results 1 to 8 of 8
    Thread: Tire pressure on 195/65/15
    1. 12-19-2003 08:45 PM #1
      What is the recommended tire pressure on a 04 Jetta GL. The door jam sticker says 33psi in the front and 42 in the rear?!? Does that sound too excesssive or is that normal with the VW?
      Thanks
    2. 12-19-2003 08:47 PM #2
      look on the gas cap
      Forsale: Full screen MFA Euro Cluster :337 BBS RC's mint : Euro Gamma Radio with indash 6 Disc CD Changer : Lots of other misc parts : Parts Located In Canada
      Please search my user name for parts for sale.
    3. 12-19-2003 08:51 PM #3
      i do 32f/30r
      the gas cap has it kinda low if you ask me... to make the ride softer
    4. Member DZCad90's Avatar
      Nov 24th, 2000
      Joliet IL
      2013 Passat SE/Sun, 2014 Passat TDI SEL
      12-20-2003 07:01 PM #4
      I run 39 PSI all around, but I do 90% highway driving.
    5. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      2016 GOLF 1.4 TSI 125hp 7speed DSG
      12-20-2003 07:12 PM #5
      Quote, originally posted by brianpgriset »
      i do 32f/30r
      looks low but it's recommendet by factory
      it's perfect for tire wear.I always put what gas cap say in half load
      I have 16" rims so I keep 28/26.Never got problem with tire wear.
    6. 12-21-2003 12:04 AM #6
      Quote, originally posted by Fantomasz »
      yeah i know, but i actually usually roatate between to high and to low to help try and even it out... its hard to get perfect tire wear
    7. 12-21-2003 12:08 AM #7
      How about in winter? a lot of snow?
    8. Senior Member
      Mar 24th, 2001
      12-21-2003 02:11 AM #8
      Quote, originally posted by tmak26b »
      Doesn't seem too out of line. It may depend on what size tires, or full load versus light load, as well. If that's what is printed on the door jamb or inside the fuel door, that should be the recommended pressure.
      Remember when replacing worn out tires to make sure that the replacement tires can handle the pressure specified for the car.
