VWVortex.com - Vanagon stereo?
    Results 1 to 14 of 14
    Thread: Vanagon stereo?
    1. Member MagicBus's Avatar
      Oct 3rd, 2003
      Worcester, MA
      1991 VW Vanagon, 1983 Mercedes-Benz 240D, 1998 Volvo S70
      12-28-2003 11:39 AM #1
      I've been thinking about updating the stereo in my Vanagon (nothing crazy), but Crutchfield keeps trying to tell me that nothing they have will fit...
      Is the head unit in the Vanagon really such an odd size?
      Feb 9th, 2003
      pottsville, PA
      2004 passat 1.8t manual 4motion wagn,83 rabbit convertable,81 pickup,80 vanagon,95 90 quattro sport,
      12-28-2003 12:13 PM #2
      i think its just that none of the stereos are going to be an easy fit . which means hacking up the dash, just find one you like and make sure the depth is right.
    3. Member Mr Wolf's Avatar
      Feb 18th, 1999
      calgary.ab.ca
      1969 Porsche 912R, 1969 MB 280 SE coupe, 2004 Volvo XC70, 2010 Ford F-150
      12-28-2003 12:59 PM #3
      Yes that's the problem. It's difficult to find a stereo that isn't too deep. Most stereos are about 3/4" too long. I installed a newer stereo from a 2000 Jetta along with a CD changer in the glovebox. I built a 3/4" spacer for the stereo out of MDF (not pretty, but works).
      The back of the stereo otherwise hits the heater housing. I have a friend who put the same radio in his Vanagon, and he just took a heat gun and reformed the heater housing to fit.
      So you can get creative and put just about anything in there. The only other limiting factor with the Vanagon is what size speakers you can fit in the doors.
      -Keith
      The to-do list is over 726 lines long. One day my cars will run again.
    4. Banned Rabbit 16v's Avatar
      Feb 3rd, 2002
      12-28-2003 02:29 PM #4
      Like Mr Wolf stated its the depth that is the problem. The hole is a standard DIN radio hole. I have an older Alpine with the motorized face. I find it is easier to read the display with the face folded out.
    5. Banned Bantastique's Avatar
      Nov 25th, 2003
      12-28-2003 04:49 PM #5
      I have an Alpine in mine with no problems. It's a standard size DIN hole. If your deck has a huge plug type connection in the back I could see how it might be a little tight. You could always take out the ashtray for a little extra clearance. Here's my setup--I have the Alpine head unit
      PPI 5 channel 500 watt amp that fit like a glove under the jump seat bracket
      5 1/4 MB Quart 2 ways in the front ( about the only speaker that was flat enought to work so you could cklose the door without crushing the grill against the dash)
      Infinity 6 1/2 3 ways in the back
      & a 12" Rockford Fosgate sub on the passenger side under the back seat.
    6. Member
      Apr 15th, 2002
      1991 560 SEL, 2001 Passat 1.8T pos
      12-29-2003 12:33 AM #6
      What kind of steering wheel is that? It looks hot, and comfy. I miss my nice, thick, leather Corrado wheel .
      ?id=84 RIP
    7. Banned Rabbit 16v's Avatar
      Feb 3rd, 2002
      12-29-2003 01:03 AM #7
      why dont you just get a corrado steering wheel with the little adapter ring and put it on your van?
    8. Banned Bantastique's Avatar
      Nov 25th, 2003
      12-29-2003 01:22 AM #8
      Quote, originally posted by eve_ill »
      Projektzwo made for the Vanagon. & yes it's nice & comfy
      Apr 15th, 2002
      12-29-2003 03:08 AM #9
      Quote, originally posted by Rabbit 16v »
      The Corrado wheel is smaller and so it would become harder to turn the van than it is now.
      Where did you pick up your Projektzwo wheel?
      Modified by eve_ill at 3:12 AM 12-29-2003
      ?id=84 RIP
    10. Banned Bantastique's Avatar
      Nov 25th, 2003
      12-29-2003 04:21 AM #10
      That's what's nice about the PZ wheel--it's almost the same size as a stock Vanagon wheel so you can still drive with your arms on the armrests. I picked it up from Hillside Imports in Oregon but I don't know if they're still doing PZ stuff since 1552 shut down
    11. Banned Rabbit 16v's Avatar
      Feb 3rd, 2002
      12-29-2003 12:32 PM #11
      I take it your van doesnt have power steering huh?
      i have a VW motorsport one on my 2wd and I like it better than the huge vanagon one. I also have no porblems steering it.
      Apr 15th, 2002
      12-29-2003 01:45 PM #12
      got power but I'd rather have a stock-ish size wheel. Didn't even think about using the armrests but there's that too.
      Don't you all love 1552? O a big feature on the vortex to show that they are alive and kicking. And then they disappear.
      ?id=84 RIP
    13. Banned Rabbit 16v's Avatar
      Feb 3rd, 2002
      12-30-2003 10:27 PM #13
      hmm maybe its the recaro drivers seat that puts me back further so I dont lean on the wheel.
    14. 12-30-2003 10:38 PM #14
      I have heard that depth is an issue as well, but I have installed at least 4 different decks into vanagons (2 different Eclipse models, a Rockford Fosgate and an Alpine) and they all fit fine. They are snug but work just great. I have 6" Kicker mids in the front with seperate tweeters and custom made grilles, and 5 1/4" mids in the back with seperate tweaters and custom grilles and a Kicker 10" Solobaric L7 sub under the back seat. It sounds really good and clean. It did take quite awhile to get everything made though.
      hope this helps,
      Craig
