VWVortex.com - Hesitation on 2000 New Beetle 1.8t Auto
    Results 1 to 13 of 13
    Thread: Hesitation on 2000 New Beetle 1.8t Auto
    1. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      12-30-2003 10:59 AM #1
      Disclaimer: I have been doing a bunch of searches on the 1.8t, New Beetle and transmission forum.
      On to the question.
      I just picked up a 2000 New Beetle 1.8t with the 4 speed auto. First off, it's a great car, except for this nasty hesitation I get when I want to accelerate quickly. At first, I thought it was a tranny problem because it feels like the tranny kicks down all the way to 1st. However, I've been doing searches on the 'tex and I'm coming up with possibilities like the n75 valve or DV is malfunctioning, or the MAF needs to be cleaned/replaced, or I need a throttle body alignment.
      So, I'm looking for opinions and advice on what is happening. I'm very new to the watercooled world, so go easy. Oh, and no auto flames, please. I'm here for help, not ridicule.
      Thanks in advance.
      ///BrooklynAutoRennen
      2014 VW GLI Autobahn/Nav/DSG - Two clutches. Two pedals. Four doors. No apologies.
    2. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      12-30-2003 12:59 PM #2
      bump
    3. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      12-30-2003 05:26 PM #3
      I unplugged my MAF and the difference is amazing. I'll go to a VW dealer and have them scan and reset my ECU and take it from there.
      Lots of fun even with a 4 speed auto. Great combo for me [IMG]http://**********************/smile/emthup.gif[/IMG]
    4. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      12-31-2003 12:16 AM #4
      Bump for the night crowd
    5. 12-31-2003 03:34 AM #5
      Quote, originally posted by Mikes72sb »
      If you unplugged the MAF and the resulting performance was better, that could be a hint that the MAF is on its last leg. You should also check the DV for leaks. Do a search here or newbeetle.org on how to test a DV. After that, check the vacuum lines.
      Btw, many on newbeetle.org are knowledgeable. They could offer helpful opinions.
      Good luck!
    6. 12-31-2003 05:19 AM #6
      Newbeetle.org is a good place to start out. That's were I started. I actually used to hate the vortex...and look at me now!!
    7. 12-31-2003 07:16 AM #7
      Sorry, I don't know about your problem (maybe DV) but the 4 speed auto does great with the 1.8t so don't worry about the 5 speed guys out there too much. We have something called traction.
      Modified by 2OVTurboJetta at 7:52 AM 12-31-2003
    8. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      12-31-2003 09:34 AM #8
      Way ahead of you with the DV check. Found the instructions on .org and tested it out. Checks out fine. I'm going back to the shop where I bought the car on friday for a MAF replacement. If that works, great. If not, then I'll take it to VW and have it scanned.
    9. 12-31-2003 11:43 AM #9
      So when are you getting it chipped?
      I can't remember off the top of my head but I believe the early Beetles need a bit more than a chip to make good hp numbers. I think you can get around 180 with a chip but have to upgrade the fuel system to go higher. I also think you may have the basic K03 (smaller) turbo.
      Modified by 2OVTurboJetta at 10:44 AM 12-31-2003
    10. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      12-31-2003 03:09 PM #10
      Yeah, I'm doing as much research into my particular 1.8t now. Planning all the mods ahead of time. First thing I want to do to the car is lower it, but after that I'll start saving for a chip and exhaust. I'm in no rush and as of right now it's got plenty of around town power, and probably a bit more when I get this MAF thing figured out.
      So far, I'm
    11. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      01-02-2004 02:04 PM #11
      Figured I'd update the post.
      Replaced the MAF today and now I have lots of smooth power. Great engine, great car.
      Can't wait to start modding... [IMG]http://**********************/smile/emthup.gif[/IMG]
    12. 01-02-2004 05:59 PM #12
      First thing I want to do to the car is lower it...
      Check out the Suspension forum first before you lower your car. Depending on how low you want to go, find out first what happens to a Mk4 suspension geometry when it's lowered. If you're not too concerned about handling, then lowering isn't an issue.
      Btw, glad the new MAF fixed it for ya. They tend to go "lazy" before they actually die. That's how mine behaved.
    13. Member Mikes72sb's Avatar
      Oct 27th, 2001
      Brooklyn, NY
      01-02-2004 09:12 PM #13
      Quote, originally posted by Cadenza_7o »
      Thanks for the advice. I'm looking for mostly lowering, but I do want less body roll. I'll keep it at that because this is the 1.8t forum. Research is key, that's what I always say. [IMG]http://**********************/smile/emthup.gif[/IMG]
