Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 73
Thread: ENTIRE DTC (Diagnostic Trouble Code) LIST FOR ALL VEHICLES
  1. 01-25-2004 01:15 PM #1
    For all vehicles manufactured after 10/01/1988
    Interior Codesets: (ECMA adds last 2 of VIN to complete codeset)
    DTC 01 General Sensor Fault
    DTC 02 Instantaneous Battery Voltage Out of Range
    DTC 03 Filtered Battery Voltage Out of Range
    DTC 04 Compressor Relay Short to Ground/Open
    DTC 05 Compressor Relay Short to Battery
    DTC 06 Exhaust Valve Short to Ground/Open Circuit
    DTC 07 Exhaust Valve Short to Battery
    DTC 08 Warning Lamp Short to Ground/Open Circuit
    DTC 09 Warning Lamp Short to Battery
    DTC 10 Inside Air Temperature Sensor Voltage Low
    DTC 10 Intake Accumulator Fault
    DTC 11 Driver Seat Forward/Backward Motor Inop
    DTC 11 Exhaust Accumulator Fault
    DTC 11 Inside Air Temperature Sensor Open Circuit
    DTC 11 Transponder Key Problem
    DTC 12 Consecutive Intake Malfunction
    DTC 12 Driver Seat Recliner Motor Inoperative
    DTC 12 LH Air Outlet Sensor Voltage Low
    DTC 12 Wrong Transponder Key
    DTC 12 Diagnostic System Check (Escalade)
    DTC 13 Driver Air Bag Deployment Loop Short to GND
    DTC 13 Immobilizer Not Programmed
    DTC 13 LH Air Outlet Sensor Open Circuit
    DTC 14 Coolant Temp Voltage Low
    DTC 14 Driver Pretens Deployment Loop Short to GND
    DTC 14 No Transponder Key Programmed
    DTC 14 RH Air Outlet Sensor Voltage Low
    DTC 15 Driver Air Bag Deploy. Loop Short to V
    DTC 15 RH Air Outlet Sensor Open Circuit
    DTC 15 Vehicle Speed Signal Voltage Low
    DTC 16 Driver Pretens Deploy Loop Short to Voltage
    DTC 16 Driver Seat Front Height Motor Inoperative
    DTC 16 Int Air Mix Door Mtr Volts Low/Open Circuit
    DTC 16 Vehicle Speed Signal Voltage High
    DTC 17 Driver Seat Rear Height Motor Inoperative
    DTC 17 Interior Air Mix Door Motor Voltage High
    DTC 17 No Engine Request Received
    DTC 18 Driver Side Mirror Circuit
    DTC 18 LH Air Mix Door Mtr Volts Low/Open Circuit
    DTC 18 MIL Circuit
    DTC 19 Inside Mirror Circuit
    DTC 19 LH Air Mix Door Motor Voltage High
    DTC 20 Passenger Side Mirror Circuit
    DTC 20 RH Air Mix Door Mtr Volts Low/Open Circuit
    DTC 21 Driver Seat Adjuster Switch Inoperative
    DTC 21 No Speed Signal
    DTC 21 RH Air Mix Door Motor Voltage High
    DTC 21/31 Courtesy Lamps Feed Shorted to Ground (Escalade)
    DTC 22 Floor Air Mix Dr Mtr Voltage Low/Open CKT
    DTC 22 Solenoid Circuit Short to Ground/Open
    DTC 22/32 Courtesy Lamps Return Shorted to Battery (Escalade)
    DTC 23 Floor Air Mix Door Motor Voltage High
    DTC 23 Pass. Air Bag Deployment Loop Short to GND
    DTC 23 Power Steering Control Module Malfunction
    DTC 23/33 RAP Feed Shorted to Ground or Battery (Escalade)
    DTC 24 Def Air Mix Door Mtr Volts Low/Open Circuit
    DTC 24 Pass. Pretens Deployment Loop Short to GND
    DTC 24/34 Seatbelt Indicator Shorted to Ground or Battery (Escalade)
    DTC 25 Defrost Air Mix Door Motor Voltage High
    DTC 25 Pass. Air Bag Deploy. Loop Short to Voltage
    DTC 25/35 Security Indicator Status (Escalade)
    DTC 26 Pass. Pretens Deploy. Loop Short to Voltage
    DTC 27 Blower Motor Voltage Low or Open Circuit
    DTC 28 Air Circ. Valve Voltage Low or Open CKT
    DTC 29 Air Circulation Valve Voltage High
    DTC 30 Heating Cut-Off Valve Volts Low or Open CKT
    DTC 31 Driver Air Bag Deploy. Loop Resistance High
    DTC 31 Heating Cut-Off Valve Voltage High
    DTC 32 Driver Air Bag Deploy. Loop Resistance Low
    DTC 32 Rear Window Defog Signal Voltage Low
    DTC 33 Pass. Air Bag Deploy. Loop Resistance High
    DTC 33 Rear Window Defog Signal Voltage Open CKT
    DTC 34 Pass. Air Bag Deploy. Loop Resistance Low
    DTC 34 Rear Window Defogger Open Circuit
    DTC 35 A/C Request Signal Voltage High
    DTC 35 Driver Pretens Deploy. Loop Resistance High
    DTC 36 A/C Request Signal Voltage Low
    DTC 36 Driver Pretens Deploy. Loop Resistance Low
    DTC 37 Heater and A/C Control Switch Stuck
    DTC 37 Pass. Pretens Deploy. Loop Resistance High
    DTC 38 Pass. Pretens Deploy. Loop Resistance Low
    DTC 38 Solar/Twilight Sensor Supply Voltage Low
    DTC 39 Solar/Twilight Sensor Supply Voltage High
    DTC 40 Solar/Twilight Sensor GND Short to Voltage
    DTC 41 Last Message Received Valid (Escalade)
    DTC 42 Last Message Received Invalid (Escalade)
    DTC 43 Last Message Received with Sumcheck Error (Escalade)
    DTC 43 Warning Lamp Circuit Short to Voltage
    DTC 44 Warning Lamp Circuit Open or Short to GND
    DTC 44 Last Message Received with Encryption Error (Escalade)
    DTC 45 Receiver Processing in 20 Second Lockout (Escalade)
    DTC 50 Seat Adjuster Memory Module Malfunction
    DTC 50, 51, or 55 Sunroof Actuator Malfunction
    DTC 51 Replace Heater and A/C Control
    DTC 51 Reprogram Cluster or Cluster Malfunction
    DTC 52 Heater and A/C Control Not Programmed
    DTC 52 Reprogram Cluster
    DTC 52 SDM Not Configured
    DTC 53 Configuration Mismatch
    DTC 55 Internal SDM Failure
    DTC 55 Replace Heater and A/C Control
    DTC 55 Seat Adjuster Memory Module Malfunction
    DTC 55 Theft Deterrent Module Malfunction
    DTC 55 Begin Configuration Display (Escalade)
    DTC 56 SDM Not Reusable
    DTC 65 Passenger Air Bag Deployment Commanded
    DTC 66 Driver Air Bag Deployment Commanded
    DTC 67 Pretensioner Only Deployment Commanded
    DTC 68 Driver Side Air Bag Deployment Commanded
    DTC 69 Pass. Side Air Bag Deployment Commanded
    DTC 71 Driver Side Impact Sensor Comms Invalid
    DTC 73 Driver Side Impact Sensor Short to Voltage
    DTC 74 Driver Side Impact Sensor Short to Ground
    DTC 75 Driver Side Air Bag Short to Ground
    DTC 76 Driver Side Air Bag Short to Voltage
    DTC 77 Driver Side Air Bag Deploy Loop Resist High
    DTC 78 Driver Side Air Bag Deploy Loop Resist. Low
    DTC 81 Pass. Side Impact Sensor Comms Invalid
    DTC 83 Pass. Side Impact Sensor Short to Voltage
    DTC 84 Pass. Side Impact Sensor Short to Ground
    DTC 85 Pass. Side Air Bag Short to Ground
    DTC 86 Pass. Side Air Bag Short to Voltage
    DTC 87 Pass. Side Air Bag Deploy. Loop Resist High
    DTC 88 Pass. Side Air Bag Deploy. Loop Resist. Low
    DTC 97 ONSTAR DCO Link Open or Short to Voltage
    DTC 98 ONSTAR DCO Link Short to Ground
    DTC 167 Fuel Gauge Voltage Low
    DTC 168 Fuel Gauge Voltage High
    DTC 169 Outside Temperature Sensor Voltage Low
    DTC 171 Outside Temperature Sensor Open Circuit
  2. 01-25-2004 01:16 PM #2
    Body Codes: (BCM default return code sets to ECMA or BCU/ECMA combo)
    DTC B0001 PCM Discrete Input Speed Signal Error
    DTC B0004 PCM Discrete Input Speed Signal Not Present
    DTC B0005 In Park Switch Circuit Malfunction
    DTC B0016 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
    DTC B0017 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open
    DTC B0018 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
    DTC B0022 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
    DTC B0024 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
    DTC B0026 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open
    DTC B0028 RF/Passenger Side Deployment Loop Resistance Low
    DTC B0029 RF/Passenger Side Deployment Loop Open
    DTC B0030 RF/Passenger Side Deployment Loop Short to Ground/Voltage Out of Range
    DTC B0035 ADS Closed/Shorted to Ground
    DTC B0036 ADS Open/Missing/Shorted to Battery
    DTC B0037 AUX switch closed/shorted to ground
    DTC B0038 AUX switch open/shorted to battery
    DTC B0040 LF/Driver Side Deployment Loop Resistance Low
    DTC B0041 LF/Driver Side Deployment Loop Open
    DTC B0045 LF Side Deploy Loop Short to Ground/Voltage Out of Range
    DTC B0051 Deployment Commanded
    DTC B0053 Deployment Commanded with Loop Malfunctions Present
    DTC B0057 RF/Passenger Pretensioner Deployment Loop Resistance Low
    DTC B0058 RF/Passenger Pretensioner Deployment Loop Open
    DTC B0059 RF/Passenger Pretensioner Deployment Loop Short to Ground/Voltage Out of Range
    DTC B0064 LF/Driver Pretensioner Deployment Loop Resistance Low
    DTC B0065 LF/Driver Pretensioner Deployment Loop Open
    DTC B0066 LF/Driver Pretensioner Deployment Loop Short to Ground/Voltage Out of Range
    DTC B0073 Supplemental Deployment Loop #1 Resistance Low
    DTC B0074 Supplemental Deployment Loop #1 Open
    DTC B0075 Supplemental Deployment Loop #1 Short to Ground/Voltage Out of Range
    DTC B0077 LF/Driver SIS Malfunction
    DTC B0078 RF/Passenger SIS Malfunction
    DTC B0079 Incorrect LF/Driver SIS Installed
    DTC B0080 Discard LF/Driver SIS
    DTC B0081 Incorrect RF/Passenger SIS Installed
    DTC B0082 Discard RF/Passenger SIS
    DTC B0086 Supplemental Deployment Loop #2 Resistance Low
    DTC B0087 Supplemental Deployment Loop #2 Open
    DTC B0088 Supplemental Deployment Loop #2 Short to Ground/Voltage Out of Range
    DTC B0090 Active switch voltage out of range
    DTC B0091 Active switch: wrong state
    DTC B0092 PPS passenger detection error
    DTC B0093 PPS/CPS self-test malfunction
    DTC B0094 CPS childseat detection error
    DTC B0095 SDM-PPS/CPS mismatch malfunction
    DTC B0126 Right Panel Discharge Temperature Fault
    DTC B0131 Right Heater Discharge Temperature Fault
    DTC B0159 Outside Air Temperature Sensor Circuit Range/Performance
    DTC B0164 Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance
    DTC B0169 In-car Temp Sensor Failure (passenger -not used)
    DTC B0174 Output Air Temperature Sensor #1 (Upper; Single or LH) Circuit Range/Performance
    DTC B0179 Output Air Temperature Sensor #2 (Lower; Single or LH) Circuit Range/Performance
    DTC B0184 Solar Load Sensor #1 CKT Range
    DTC B0189 Solar Load Sensor #2 CKT Range
    DTC B0248 Mode Door Inoperative Error
    DTC B0249 Heater/Defrost/AC Door Range Error
    DTC B0268 A/I Door Inoperative Error
    DTC B0269 Air Inlet Door Range Error
    DTC B0408 Temperature Control #1 (Main/Front) Circuit Malfunction
    DTC B0409 Air Mix Door #1 Range Error
    DTC B0419 Air Mix Door #2 Range Error
    DTC B0423 Air Mix Door #2 Inoperative Error
    DTC B0428 Air Mix Door #3 Inoperative Error
    DTC B0429 Temperature Control #3 Rear Circuit Range/Performance
    DTC B0510 RH Panel Discharge Temp Sensor Failure
    DTC B0515 RH Heater Discharge Temp Sensor Failure
    DTC B0520 Rear Discharge Temp Sensor Failure
    DTC B0530 Fuel Level Sensor Stuck
    DTC B0532 Fuel Sensor Shorted To Ground
    DTC B0533 Fuel Sensor Open/Shorted To B+
    DTC B0688 Security System Indicator Circuit High
    DTC B0768 Service Indicator Circuit High
    DTC B0846 +5 Volt Reference Out of Range
    DTC B0856 Battery 2 Out of Range
    DTC B1000 ECU Malfunction
    DTC B1001 Option Configuration Error
    DTC B1004 Keep Alive Memory (KAM)
    DTC B1007 EEPROM Write Error
    DTC B1009 EEPROM Checksum Error
    DTC B1013 ROM Checksum Error
    DTC B1014 Program ROM Checksum Error
    DTC B1015 Passenger Deploy. Loop Resistance High
    DTC B1016 Passenger Deployment Loop Resistance Low
    DTC B1017 Passenger Deployment Loop Open
    DTC B1018 Passenger Deployment Loop Short to GND
    DTC B1019 Passenger Deploy. Loop Short to Voltage
    DTC B1021 Driver Deployment Loop Resistance High
    DTC B1022 Driver Deployment Loop Resistance Low
    DTC B1024 Driver Deployment Loop Short to Ground
    DTC B1025 Driver Deployment Loop Short to Voltage
    DTC B1026 Driver Deployment Loop Open
    DTC B1035 Discr. Sensor Closed or Short to GND
    DTC B1036 Discr. Sensor Open or Short to Voltage
    DTC B1051 Frontal Air Bag and Preten Deployment
    DTC B1053 Deployment Commanded w/Loop Malfunction
    DTC B1054 Infl Rst IP Module Switch CKT Failure
    DTC B1061 Lamp Circuit Failure
    DTC B1071 Internal SDM Failure
    DTC B1115 Passenger Deploy. Loop Resistance High
    DTC B1116 Passenger Deploy. Loop Resistance Low
    DTC B1117 Passenger Deployment Loop Open
    DTC B1121 Driver Deployment Loop Resistance High
    DTC B1122 Driver Deployment Loop Resistance Low
    DTC B1124 Driver/Pass. Deploy. Loop Short to GND
    DTC B1125 Driver/Pass Deploy Loop Short to Voltage
    DTC B1126 Driver Deployment Loop Open
    DTC B1131 Pass. Pretensioner Loop Resistance High
    DTC B1132 Pass. Pretensioner Loop Resistance Low
    DTC B1134 Passenger Pretensioner Loop Open
    DTC B1135 Discr. Sensor Closed or Short to GND
    DTC B1136 Discr. Sensor Open or Short to Voltage
    DTC B1141 Driver Pretensioner Loop Resistance High
    DTC B1142 Driver Pretens. Deploy. Loop Res. Low
    DTC B1144 Driver/Pass Pretens. Loop Short to GND
    DTC B1145 Driver/Pass Pretens. Loop Short to Volt
    DTC B1146 Driver Pretensioner Loop Open
    DTC B1147 Driver Side Air Bag System Malfunction
    DTC B1148 Pass. Side Air Bag System Malfunction
    DTC B1151 Deployment Commanded - Frontal
    DTC B1152 Data Area Full
    DTC B1153 Deployment Commanded w/Loop Malfunction
    DTC B1155 SDM Calibration Mismatch
    DTC B1159 Loss of Serial Data-Key Not Received
    DTC B1160 Loss of Serial Data - VIN Not Received
    DTC B1161 Lamp Circuit Failure
    DTC B1163 Loss of Serial Data-No Lamp Response
    DTC B1171 Internal SDM Failure
    DTC B1245 CD Changer Not Responding
    DTC B1271 Theft Lock Enabled
    DTC B1310 Ambient Air Temperature Sensor Failure
    DTC B1311 Outside Air Temp Sensor Short Circuit
    DTC B1312 High Side Temp Sensor Open Circuit
    DTC B1313 High Side Temp Sensor Short Circuit
    DTC B1314 Evaporator Inlet Temp Sensor Open CKT
    DTC B1315 Evaporator Inlet Temp Sensor Short CKT
    DTC B1316 In Car Temperature Sensor Open Circuit
    DTC B1317 In Car Air Temperature Sensor
    DTC B1318 LH Sun Load Sensor Fault
    DTC B1319 Sunload Sensor Short Circuit
    DTC B1321 A/C Low Side Temperature Sensor Fault
    DTC B1324 A/C Refrigerant Overpressure
    DTC B1327 Device Power Circuit Low
    DTC B1328 Device Power Circuit High
    DTC B1328 RH Sun Load Sensor Fault
    DTC B1330 Left A/C Discharge Sensor Fault
    DTC B1331 Right A/C Discharge Sensor Fault
    DTC B1332 Left Heater Discharge Sensor Fault
    DTC B1333 Right Heater Discharge Sensor Fault
    DTC B1340 Air Mix Door One Movement Fault
    DTC B1341 Air Mix Door Two Movement Fault
    DTC B1343 Air Inlet Door Movement Fault
    DTC B1344 HTR/DEF/AC Door Movement Fault
    DTC B1347 Very Low A/C Refrigerant Warning
    DTC B1348 Very Low A/C Refrigerant Pressure
    DTC B1350 Engine Coolant Over-Temperature
    DTC B1390 Device Voltage Reference Input CKT Malf
    DTC B1396 Device Voltage Reference Output 1 Circuit Range Performance
    DTC B1399 Loss of KDD Communications
    DTC B1422 Device Power Moding Malfunction
    DTC B1438 IPC High Voltage Output Overcurrent to IPM
    DTC B1513 Charging System Volts Low
    DTC B1514 Charging System Volts High
    DTC B1552 Keep Alive Memory (KAM) Error
    DTC B1556 IPC EEPROM Odo/Configuration Error
    DTC B1557 EEPROM Calibration Error
    DTC B1558 BCM EPROM Checksum Error
    DTC B1586 Mirror Horiz. Pos Sensor-Out of Range/Open
    DTC B1591 Mirror Vert. Pos Sensor-Out of Range/Open
    DTC B1652 Loss of Keep Alive Memory (KAM)
    DTC B1656 EEPROM Write Error
    DTC B1658 EEPROM Checksum Error
    DTC B1697 Mirror Switch Input Shorted to Ground
    DTC B1698 Mirror Switch L Up Input Stuck High
    DTC B1702 Mirror Switch Input Shorted to Ground
    DTC B1703 Mirror Switch L Down Input Stuck High
    DTC B1707 Mirror Switch Input Shorted to Ground
    DTC B1708 Mirror Switch R Up Input Stuck High
    DTC B1712 Mirror Switch Input Shorted to Ground
    DTC B1713 Mirror Switch R Down Input Stuck High
    DTC B1717 Mirror Power Fold Control Switch Shorted Low
    DTC B1718 Power Folding Mirror Switch Input Circuit High
    DTC B1735 Driver Seat Front Up Switch CKT Malf
    DTC B1740 Driver Seat Front Down Switch CKT Malf
    DTC B1745 Driver Seat Rear Up Switch CKT Malf
    DTC B1750 Driver Seat Rear Down Switch CKT Malf
    DTC B1755 Driver Seat Asm Forward Switch CKT Malf
    DTC B1760 Driver Seat Asm Rearward Switch CKT Malf
    DTC B1760 CD Changer Not Responding
    DTC B1780 Theft Lock Enabled
    DTC B1805 Ignition Switch Problem
    DTC B1815 Driver Recline Forward Switch CKT Malf
    DTC B1820 Driver Recline Rearward Switch CKT Malf
    DTC B1825 Driver Recline Sensor CKT Malfunction
    DTC B1830 Driver Lumbar Forward Switch CKT Malf
    DTC B1835 Driver Lumbar Rearward Switch CKT Malf
    DTC B1840 Driver Lumbar Up Switch CKT Malf
    DTC B1845 Driver Lumbar Down Switch CKT Malf
    DTC B1850 Driver Lumbar Horiz Sensor CKT Malf
    DTC B1860 Driver Lumbar Vert Sensor CKT Malf
    DTC B1870 Driver Belt Tower Up Switch CKT Malf
    DTC B1875 Driver Belt Tower Down Sw CKT Malf
    DTC B1900 Driver Belt Tower Vert Sen CKT Malf
    DTC B1910 Generator L-Terminal Open Circuit
    DTC B1911 Generator L-Terminal Problem
    DTC B1913 Heated Seat Switch - Mode Input Shorted to Battery
    DTC B1918 Heated Seat Switch - Temperature Input Shorted to Battery
    DTC B1970 Exterior Lamp Power
    DTC B1971 Inadvertent Power
    DTC B1972 Low Power Driver Fault
    DTC B1973 High Power Control Fault
    DTC B1981 Battery Voltage Low
    DTC B1982 Device Power Circuit High
    DTC B1983 Device Power Circuit Low
    DTC B2101 Recline Aft Switch Failed
    DTC B2102 Recline Forward Switch Failed
    DTC B2103 Rear Vertical Down Switch Failed
    DTC B2104 Rear Vertical Up Switch Failed
    DTC B2105 Horizontal Aft Switch Failed
    DTC B2106 Horizontal Forward Switch Failed
    DTC B2107 Front Vertical Down Switch Failed
    DTC B2108 Front Vertical Up Switch Failed
    DTC B2109 Lumbar Aft Switch Failed
    DTC B2110 Lumbar Forward Switch Failed
    DTC B2111 Lumbar Down Switch Failed
    DTC B2112 Lumbar Up Switch Failed
    DTC B2115 Recline Sensor Failed
    DTC B2116 Rear Vertical Sensor Failed
    DTC B2117 Horizontal Sensor Failed
    DTC B2118 Front Vertical Sensor Failed
    DTC B2119 Lumbar Forward/Aft Sensor Failed
    DTC B2120 Lumbar Up/Down Sensor Failed
    DTC B2130 Driver Memory 1 Select Switch Circuit Malfunction
    DTC B2131 Driver Memory 2 Select Switch Circuit Malfunction
    DTC B2132 Driver Memory Exit Exit/Off Switch Circuit Malfunction
    DTC B2133 Driver Memory Set Switch Circuit Malfunction
    DTC B2140 Mirror Up Control Switch Circuit Malfunction
    DTC B2141 Mirror Down Control Switch Circuit Malfunction
    DTC B2142 Mirror Left Control Switch Circuit Malfunction
    DTC B2143 Mirror Right Control Switch Circuit Malfunction
    DTC B2144 Left Front Mirror Vertical Position Sensor Circuit Low
    DTC B2145 Left Front Mirror Vertical Position Sensor Circuit High
    DTC B2146 Left Front Mirror Horizontal Position Sensor Circuit Low
    DTC B2147 Left Front Mirror Horizontal Position Sensor Circuit High
    DTC B2148 Right Front Mirror Vertical Position Sensor Circuit Low
    DTC B2149 Right Front Mirror Vertical Position Sensor Circuit High
    DTC B2150 Right Front Mirror Horizontal Position Sensor Circuit Low
    DTC B2151 Right Front Mirror Horizontal Position Sensor Circuit High
    DTC B2175 Tilt/Telescope Module Manual Switch Fail
    DTC B2200 LF Window Switch Stuck in Up Position
    DTC B2201 LF Window Switch Stuck in Down Position
    DTC B2202 RF Window Switch Stuck in Up Position
    DTC B2203 RF Window Switch Stuck in Down Position
    DTC B2204 LR Window Switch Stuck in Up Position
    DTC B2205 LR Window Switch Stuck in Down Position
    DTC B2206 RR Window Switch Stuck in Up Position
    DTC B2207 RR Window Switch Stuck in Down Position
    DTC B2212 RF Switch on LF Door Stuck Up Position
    DTC B2213 RF Switch on LF Door Stuck Down Position
    DTC B2214 LR Switch on LF Door Stuck Up Position
    DTC B2215 LR Switch on LF Door Stuck Down Position
    DTC B2216 RR Switch on LF Door Stuck Up Position
    DTC B2217 RR Switch on LF Door Stuck Down Position
    DTC B2220 LF Door Lock/Unlock Switch Stuck in Lock
    DTC B2221 LF Door Lock/Unlock Switch Stuck UnLock
    DTC B2222 RF Door Lock/Unlock Switch Stuck in Lock
    DTC B2223 RF Door Lock/Unlock Switch Stuck UnLock
    DTC B2224 LR Door Lock/Unlock Switch Stuck in Lock
    DTC B2226 RR Door Lock/Unlock Switch Stuck in Lock
    DTC B2240 Memory 1 Switch Failed
    DTC B2241 Memory 2 Switch Failed
    DTC B2242 Memory Exit Switch Failed
    DTC B2243 Memory Set Switch Failed
    DTC B2310 Hand Set Failure
    DTC B2311 TRU Failure
    DTC B2312 Software Failure
    DTC B2355 Driver Front Vertical Sensor Malf
    DTC B2365 Driver Rear Vertical Sensor Malf
    DTC B2375 Driver Seat Asm Horiz Sensor CKT Malf
    DTC B2419 Twilight Photocell Circuit Problem
    DTC B2420 Twilight Delay Pot Failure
    DTC B2422 Interior Lamp Rheostat Failure
    DTC B2460 Navigation Antenna Selector Circuit High Current
    DTC B2461 Navigation ECU Synchronous Signal Error
    DTC B2462 GPS Signal Error
    DTC B2463 Navigation CD Player - No Disk
    DTC B2464 Navigation CD Player - Decoding Error
    DTC B2465 Navigation CD Player - Data Error
    DTC B2466 Navigation VICS Memory Error
    DTC B2468 Navigation Display Head (NDH) Malfunction
    DTC B2470 Daytime Running Lamps Fault
    DTC B2471 Interior Lamp Fault
    DTC B2472 Low Beam Fault
    DTC B2473 High Beam Fault
    DTC B2474 Navigation Display Head (NDH) Back Lighting Malfunction
    DTC B2475 Navigation Display Head (NDH) Auxiliary Input Malfunction
    DTC B2476 Cellular Phone Select Service Switch Malfunction
    DTC B2476 Parklamp Fault
    DTC B2477 Reverse Lamp Relay Shorted to Ground
    DTC B2478 Reverse Lamp Shorted to Battery
    DTC B2502 Auto Trans Shift Lock Control Shorted to Ground
    DTC B2503 Park Gear (Auto Trans Shift Lock Control) Relay Shorted to Batt
    DTC B2510 Steering Wheel Controls HVAC Key Stuck
    DTC B2511 Steering Wheel Controls Conv Key Stuck
    DTC B2512 Strng Wheel Controls Illegal A/D Values
    DTC B2515 Strg Whl Cont Illegal Resistance Value
    DTC B2550 Storage Mode Entered
    DTC B2556 Interior Lamp Rheostat Circuit Range
    DTC B2560 RKE Message Validation Error
    DTC B2641 Delayed Exterior Lighting Ctrl CKT Range
    DTC B2646 Ambient Light Sensor Circuit Range
    DTC B2710 PASSKey Open/Shorted Pellet
    DTC B2711 PASSKey Open/Shorted Pellet After Good Key
    DTC B2719 CTD-Trunk Tamper Switch Fault
    DTC B2725 ATC Mode Switch Circuit Malfunction
    DTC B2734 Coded Key Controller Memory Failure
    DTC B2750 PASSKey Data Communication Failure
    DTC B2757 Driver Memory 1 Select Switch CKT Low
    DTC B2762 Driver Memory 2 Select Switch CKT Low
    DTC B2767 Memory Set Switch Failed Low
    DTC B2772 Driver Memory Exit Switch Circuit Low
    DTC B2780 Wrong Resistor Before Good
    DTC B2781 Wrong Resistor After Good
    DTC B2782 PASSKey Pellet Resistance Not Programmed
    DTC B2783 Key Code/Password Corrupted in Memory
    DTC B2805 Steering Whl Controls HVAC Sw CKT Malf
    DTC B2810 Steering Whl Ctrl Entertainment CKT Malf
    DTC B2853 Telescope Forward Switch Circuit Malfunction
    DTC B2858 Telescope Rearward Switch Circuit Malfunction
    DTC B2860 Telescope Position Sensor Range
    DTC B2862 Telescope Position Sensor Low
    DTC B2873 Tilt Up Switch Circuit Malfunction
    DTC B2878 Tilt Down Switch Circuit Malfunction
    DTC B2880 Tilt Position Sensor Range
    DTC B2882 Tilt Position Sensor Low
    DTC B2891 Tilt/Telescope Motor Over Current
    DTC B2904 Tilt/Telescope 4-way Position Switch Circuit Malfunction
    DTC B2947 Security System Sensor Power CKT Low
    DTC B2948 Security System Sensor Power CKT High
    DTC B2955 Security System Sensor Data CKT Malf
    DTC B2957 Security System Sensor Data Circuit Low
  3. 01-25-2004 01:17 PM #3
    Chassis Codes: (ECMA adds $ sign for unknown fault set)
    DTC C0000 Vehicle Speed Information Circuit Malfunction
    DTC C0035 LF Wheel Speed Circuit Malfunction
    DTC C0040 RF Wheel Speed Circuit Malfunction
    DTC C0045 LR Wheel Speed Circuit Malfunction
    DTC C0050 RR Wheel Speed Circuit Malfunction
    DTC C0060 LF ABS Solenoid #1 Circuit Malfunction
    DTC C0065 LF ABS Solenoid #2 Circuit Malfunction
    DTC C0070 RF ABS Solenoid #1 Circuit Malfunction
    DTC C0075 RF ABS Solenoid #2 Circuit Malfunction
    DTC C0080 LR ABS Solenoid #1 Circuit Malfunction
    DTC C0085 LR ABS Solenoid #2 Circuit Malfunction
    DTC C0090 RR ABS Solenoid #1 Circuit Malfunction
    DTC C0095 RR ABS Solenoid #2 Circuit Malfunction
    DTC C0110 Pump Motor Circuit Malfunction
    DTC C0121 Valve Relay Circuit Malfunction
    DTC C0141 Left TCS Solenoid #1 Circuit Malfunction
    DTC C0146 Left TCS Solenoid #2 Circuit Malfunction
    DTC C0151 Right TCS Solenoid #1 CKT Malfunction
    DTC C0156 Right TCS Solenoid #2 CKT Malfunction
    DTC C0161 ABS/TCS Brake Switch Circuit Malfunction
    DTC C0221 RF Wheel Speed Sensor Circuit Open
    DTC C0222 RF Wheel Speed Signal Missing
    DTC C0223 RF Wheel Speed Signal Erratic
    DTC C0225 LF Wheel Speed Sensor Circuit Open
    DTC C0226 LF Wheel Speed Signal Missing
    DTC C0227 LF Wheel Speed Signal Erratic
    DTC C0229 Drop Out of Front Wheel Speed Signals
    DTC C0235 Rear Wheel Speed Signal Circuit Open
    DTC C0236 Rear Wheel Speed Signal Circuit Missing
    DTC C0237 Rear Wheel Speed Signal Erratic
    DTC C0238 Wheel Speed Mismatch
    DTC C0241-C0254 EBCM Control Valve Circuit
    DTC C0245 Wheel Speed Sensor Frequency Error
    DTC C0265 or C0266 EBCM Relay Circuit
    DTC C0267 or C0268 Pump Motor Circuit Open/Shorted
    DTC C0269 or C0274 Excessive Dump/Isolation Time
    DTC C0271-C0273 EBCM Malfunction
    DTC C0281 Brake Switch Circuit
    DTC C0286 ABS Indicator Lamp Circuit Shorted to B+
    DTC C0288 Brake Warning Lamp Circuit Shorted to B+
    DTC C0300 Rear Speed Sensor Malfunction
    DTC C0305 Front Speed Sensor Malfunction
    DTC C0308 Motor A/B Circuit Low
    DTC C0309 Motor A/B Circuit High
    DTC C0310 Motor A/B Circuit Open
    DTC C0315 Motor Ground Circuit Open
    DTC C0323 T-Case Lock Circuit Low
    DTC C0324 T-Case Lock Circuit High
    DTC C0327 Encoder Circuit Malfunction
    DTC C0357 Park Switch Circuit High
    DTC C0362 4LO Discrete Output Circuit High
    DTC C0367 Front Axle Control Circuit High
    DTC C0374 General System Malfunction
    DTC C0376 Front/Rear Shaft Speed Mismatch
    DTC C0387 Unable to Perform Shift
    DTC C0472 Steering Handwheel Speed Sensor Signal V Low
    DTC C0473 Steering Handwheel Speed Sensor Signal V High
    DTC C0495 EVO Tracking Error
    DTC C0498 Steering Assist Control Actuator Feed Circuit Low
    DTC C0499 Steering Assist Control Solenoid Feed Circuit High
    DTC C0503 Steering Assist Control Solenoid Return Circuit Low
    DTC C0504 Steering Assist Control Solenoid Return Circuit High
    DTC C0550 ECU Malfunction
    DTC C0559 EEPROM Checksum Error
    DTC C0563 Calibration ROM Checksum Error
    DTC C0577 Left Front Solenoid Circuit Low
    DTC C0578 Left Front Solenoid Circuit High
    DTC C0579 Left Front Solenoid Circuit Open
    DTC C0582 Right Front Solenoid Circuit Low
    DTC C0583 Right Front Solenoid Circuit High
    DTC C0584 Right Front Solenoid Circuit Open
    DTC C0587 Left Rear Solenoid Circuit Low
    DTC C0588 Left Rear Solenoid Circuit High
    DTC C0589 Left Rear Solenoid Circuit Open
    DTC C0592 Right Rear Solenoid Circuit Low
    DTC C0593 Right Rear Solenoid Circuit High
    DTC C0594 Right Rear Solenoid Circuit Open
    DTC C0611 VIN Information Error
    DTC C0615 Left Front Position Sensor Malfunction
    DTC C0620 Right Front Position Sensor Malfunction
    DTC C0625 Left Rear Position Sensor Malfunction
    DTC C0628 Level Control Position Sensor Circuit High
    DTC C0630 Right Rear Position Sensor Malfunction
    DTC C0635 Left Front Normal Force Circuit Malfunction
    DTC C0638 Left Front Normal Force Circuit High
    DTC C0640 Right Front Normal Force Circuit Malfunction
    DTC C0643 Right Front Normal Force Circuit High
    DTC C0655 Level Control Compressor Relay Malfunction
    DTC C0657 Level Control Compressor Circuit Low
    DTC C0658 Level Control Compressor Circuit High
    DTC C0660 Level Control Exhaust Valve Circuit Malfunction
    DTC C0662 Level Control Exhaust Valve Circuit Low
    DTC C0663 Level Control Exhaust Valve Circuit High
    DTC C0665 Chassis Pitch Signal Circuit
    DTC C0690 Damper Control Relay Circuit Malfunction
    DTC C0691 Damper Control Relay Circuit Range
    DTC C0693 Damper Control Relay Circuit High
    DTC C0695 Position Sensor Overcurrent (8 volt supply)
    DTC C0696 Position Sensor Overcurrent (5 volt supply)
    DTC C0710 Steering Position Signal Malfunction
    DTC C0800 Device Power #1 Circuit Malfunction
    DTC C0896 Device Voltage Range/Performance
    DTC C1211 ABS Indicator Lamp Circuit Malfunction
    DTC C1214 System Relay Contact or Coil Circuit Open
    DTC C1217 Pump Motor Shorted to Ground
    DTC C1218 Pump Motor Circuit Shorted to Voltage or Motor Ground Open
    DTC C1221 LF Wheel Speed Sensor Input Signal is 0
    DTC C1222 RF Wheel Speed Sensor Input Signal is 0
    DTC C1223 LR Wheel Speed Sensor Input Signal is 0
    DTC C1224 RR Wheel Speed Sensor Input Signal is 0
    DTC C1225 LF Excessive Wheel Speed Variation
    DTC C1226 RF Excessive Wheel Speed Variation
    DTC C1227 LR Excessive Wheel Speed Variation
    DTC C1228 RR Excessive Wheel Speed Variation
    DTC C1232 LF Wheel Speed Circuit Open or Shorted
    DTC C1233 RF Wheel Speed Circuit Open or Shorted
    DTC C1234 LR Wheel Speed Circuit Open or Shorted
    DTC C1235 RR Wheel Speed Circuit Open or Shorted
    DTC C1236 Low System Supply Voltage
    DTC C1237 High System Supply Voltage
    DTC C1238 Brake Thermal Model Exceeded
    DTC C1241 Variable Effort Steering Circuit Malfunction
    DTC C1242 Pump Motor Circuit Open
    DTC C1243 BPMV Pump Motor Stalled
    DTC C1246 Brake Lining Wear Circuit Open
    DTC C1248 EBCM Turned the Red Brake Warning Indicator On
    DTC C1251 RSS Indicated Malfunction
    DTC C1252 LF Normal Force Malfunction
    DTC C1253 RF Normal Force Malfunction
    DTC C1254 Abnormal Shutdown Detected
    DTC C1255 EBCM Internal Malfunction
    DTC C1256 EBCM Internal Malfunction
    DTC C1261 LF Inlet Valve Solenoid Malfunction
    DTC C1262 LF Outlet Valve Solenoid Malfunction
    DTC C1263 RF Inlet Valve Solenoid Malfunction
    DTC C1264 RF Outlet Valve Solenoid Malfunction
    DTC C1265 LR Inlet Valve Solenoid Malfunction
    DTC C1266 LR Outlet Valve Solenoid Malfunction
    DTC C1267 RR Inlet Valve Solenoid Malfunction
    DTC C1268 RR Outlet Valve Solenoid Malfunction
    DTC C1271 LF TCS Master Cylinder Isolation Valve Malfunction
    DTC C1272 LF TCS Prime Valve Malfunction
    DTC C1273 RF TCS Master Cylinder Isolation Valve Malfunction
    DTC C1274 RF TCS Prime Valve Malfunction
    DTC C1276 Delivered Torque Signal Circuit Malfunction
    DTC C1277 Requested Torque Signal Circuit Malfunction
    DTC C1278 TCS Temporarily Inhibited By PCM
    DTC C1281 VSES Sensors Uncorrelated
    DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction
    DTC C1283 Excessive Time to Center Steering
    DTC C1284 Lateral Accelerometer Sensor Bias Malfunction
    DTC C1285 Lateral Accelerometer Sensor Circuit Malfunction
    DTC C1286 Steering Sensor Bias Malfunction
    DTC C1287 Steering Sensor Rate Malfunction
    DTC C1288 Steering Sensor Circuit Malfunction
    DTC C1291 Open Brake Lamp Switch Contacts During Deceleration
    DTC C1293 Code C1291 Set in Previous Ignition Cycle
    DTC C1294 Brake Lamp Switch Circuit Always Active
    DTC C1295 Brake Lamp Switch Circuit Open
    DTC C1297 PCM Indicated Brake Extended Travel Switch Failure
    DTC C1298 PCM Class 2 Serial Data Link Malfunction
    DTC C1326 Battery Out of Range
    DTC C1650 RSS Control Module Fault
    DTC C1658 RSS Control Module Calibration Fault
    DTC C1710 LF Damper Actuator Short CKT to Battery
    DTC C1711 LF Damper Actuator Short CKT to Ground
    DTC C1712 LF Damper Actuator Open CKT
    DTC C1715 RF Damper Actuator Short CKT to Battery
    DTC C1716 RF Damper Actuator Short CKT to Ground
    DTC C1717 RF Damper Actuator Open CKT
    DTC C1720 LR Damper Actuator Short CKT to Battery
    DTC C1721 LR Damper Actuator Short CKT to Ground
    DTC C1722 LR Damper Actuator Open CKT
    DTC C1725 RR Damper Actuator Short CKT to Battery
    DTC C1726 RR Damper Actuator Short CKT to Ground
    DTC C1727 RR Damper Actuator Open CKT
    DTC C1735 Compressor Relay Short to Battery
    DTC C1736 Compressor Relay Short to GND/Open CKT
    DTC C1737 Exhaust Solenoid Valve Short to Battery
    DTC C1738 Exhaust Solenoid Valve Short to GND
    DTC C1743 Speed Signal Fault
    DTC C1744 Lift/Dive Signal Discrete Fault
    DTC C1760 LF Position Sensor Input Fault
    DTC C1761 RF Position Sensor Input Fault
    DTC C1762 LR Position Sensor Input Fault
    DTC C1763 RR Position Sensor Input Fault
    DTC C1768 Position Sensor Supply Fault
    DTC C1780 Loss of Steering Position Signal
    DTC C1782 ICCS2 DL Left Output Short CKT to Bat
    DTC C1783 ICCS2 DL Left Output Short CKT to GND
    DTC C1784 ICCS2 DL Right Output Short CKT to Bat
    DTC C1785 ICCS2 DL Right Output Short CKT to GND
    DTC C1786 Damper Control Relay Fault
    DTC C1787 Damper Control Relay Short to GND
    DTC C1788 Damper Control Relay Short to Bat
  4. 01-25-2004 01:19 PM #4
    Powertrain Codes: (Add level x 3.225)
    DTC P0030 HO2S Heater Control Circuit Bank 1 Sensor 1
    DTC P0031 HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
    DTC P0032 HO2S Heater Circuit High Voltage Bank 1 Sensor 1
    DTC P0036 HO2S Heater Control Circuit Bank 1 Sensor 2
    DTC P0037 HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
    DTC P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2
    DTC P0050 HO2S Heater Circuit Bank 2 Sensor 1
    DTC P0051 HO2S Heater Circuit Low Voltage Bank 2 Sensor 1
    DTC P0052 HO2S Heater Circuit High Voltage Bank 2 Sensor 1
    DTC P0056 HO2S Heater Circuit Bank 2 Sensor 2
    DTC P0057 HO2S Heater Circuit Low Voltage Bank 2 Sensor 2
    DTC P0058 HO2S Heater Circuit High Voltage Bank 2 Sensor 2
    DTC P0100 MAF Sensor Ckt. Insufficient Activity
    DTC P0101 Mass Air Flow (MAF) Sensor Performance
    DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
    DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
    DTC P0104 Mass Air Flow Circuit Intermittent
    DTC P0105 MAP Sensor Circuit Insufficient Activity
    DTC P0106 Manifold Absolute Pressure (MAP) System Performance
    DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
    DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
    DTC P0109 Manifold Absolute Pressure Circuit Intermittent
    DTC P0110 Intake Air Temperature (IAT) Sensor Circuit
    DTC P0111 Intake Air Temperature (IAT) Sensor Performance
    DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
    DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
    DTC P0114 Intake Air Temperature Circuit Intermittent
    DTC P0115 Engine Coolant Temperature (ECT) Sensor Circuit
    DTC P0116 Engine Coolant Temperature (ECT) Sensor Performance
    DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
    DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
    DTC P0119 Engine Coolant Temperature Circuit Intermittent
    DTC P0120 TP System Performance
    DTC P0121 TP Sensor Circuit Insufficient Activity
    DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
    DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage
    DTC P0124 Throttle Position Sensor 1 Circuit Intermittent
    DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
    DTC P0126 Insufficient ECT for Stable Operation
    DTC P0128 Coolant Thermostat
    DTC P0130 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
    DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
    DTC P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
    DTC P0133 HO2S Slow Response Bank 1 Sensor 1
    DTC P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
    DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
    DTC P0136 HO2S Circuit Bank 1 Sensor 2
    DTC P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
    DTC P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
    DTC P0139 HO2S Slow Response Bank 1 Sensor 2
    DTC P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
    DTC P0141 HO2S Heater Performance Bank 1 Sensor 2
    DTC P0142 HO2S Circuit Bank 1 Sensor 3
    DTC P0143 HO2S Circuit Low Voltage Bank 1 Sensor 3
    DTC P0144 HO2S Circuit High Voltage Bank 1 Sensor 3
    DTC P0145 HO2S Circuit Bank 1 Sensor 2 Slow Response
    DTC P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
    DTC P0147 HO2S Heater Performance Bank 1 Sensor 3
    DTC P0150 HO2S Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
    DTC P0150 HO2S Circuit Bank 2 Sensor 1
    DTC P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
    DTC P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
    DTC P0153 HO2S Slow Response Bank 2 Sensor 1
    DTC P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
    DTC P0155 HO2S Heater Performance Bank 2 Sensor 1
    DTC P0156 HO2S Circuit Bank 2 Sensor 2
    DTC P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
    DTC P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
    DTC P0159 HO2S Slow Response Bank 2 Sensor 2
    DTC P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2
    DTC P0161 HO2S Heater Performance Bank 2 Sensor 2
    DTC P0162 HO2S Circuit Bank 2 Sensor 3
    DTC P0163 HO2S Circuit Bank 2 Sensor 3 Low Voltage
    DTC P0164 HO2S Circuit Bank 2 Sensor 3 High Voltage
    DTC P0165 HO2S Circuit Bank 2 Sensor 3 Slow Response
    DTC P0166 HO2S Circuit Bank 2 Sensor 3 No Activity Detected
    DTC P0167 HO2S Heater Circuit Bank 2 Sensor 3
    DTC P0169 Fuel Composition Sensor
    DTC P0170 Fuel Trim Bank 1
    DTC P0171 Fuel Trim System Lean Bank 1
    DTC P0172 Fuel Trim System Rich Bank 1
    DTC P0173 Fuel Trim Bank 2
    DTC P0174 Fuel Trim System Lean Bank 2
    DTC P0175 Fuel Trim System Rich Bank 2
    DTC P0176 Fuel Composition Sensor Circuit
    DTC P0177 Fuel Composition Sensor Circuit Performance
    DTC P0178 Fuel Composition Sensor Circuit Low Voltage
    DTC P0179 Fuel Composition Sensor Circuit High Voltage
    DTC P0180 Fuel Temperature Sensor 1 Circuit
    DTC P0181 Fuel Temp. Sensor 1 Circuit Performance
    DTC P0182 Fuel Temperature Sensor Circuit Low Voltage
    DTC P0183 Fuel Temperature Sensor Circuit High Voltage
    DTC P0184 Fuel Temperature Sensor 1 Circuit Intermittent
    DTC P0185 Fuel Temperature Sensor 2 Circuit
    DTC P0186 Fuel Temp. Sensor 2 Circuit Performance
    DTC P0187 Fuel Temperature Sensor 2 Circuit Low Voltage
    DTC P0188 Fuel Temperature Sensor 2 Circuit High Voltage
    DTC P0189 Fuel Temperature Sensor 2 Circuit Intermittent
    DTC P0190 Fuel Rail Pressure Sensor Circuit
    DTC P0191 Fuel Rail Pressure Sensor Circuit Performance
    DTC P0192 Fuel Rail Pressure Sensor Circuit Low Voltage
    DTC P0193 Fuel Rail Pressure Sensor Circuit High Voltage
    DTC P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    DTC P0195 Engine Oil Temperature Sensor
    DTC P0196 Engine Oil Temperature Sensor Performance
    DTC P0197 Engine Oil Temperature Sensor Low Voltage
    DTC P0198 Engine Oil Temperature Sensor High Voltage
    DTC P0199 Engine Oil Temperature Sensor Intermittent
    DTC P0200 Injector Control Circuit
    DTC P0201 Injector 1 Control Circuit
    DTC P0202 Injector 2 Control Circuit
    DTC P0203 Injector 3 Control Circuit
    DTC P0204 Injector 4 Control Circuit
    DTC P0205 Injector 5 Control Circuit
    DTC P0206 Injector 6 Control Circuit
    DTC P0207 Injector 7 Control Circuit
    DTC P0208 Injector 8 Control Circuit
    DTC P0209 Injector 9 Control Circuit
    DTC P0210 Injector 10 Control Circuit
    DTC P0211 Injector 11 Control Circuit
    DTC P0212 Injector 12 Control Circuit
    DTC P0213 Cold Start Injector 1
    DTC P0214 Cold Start Injector 2
    DTC P0215 Engine Shutoff Control Circuit
    DTC P0216 Injection Timing Control Circuit
    DTC P0217 Engine Overtemp Condition
    DTC P0218 Transmission Fluid Overtemperature
    DTC P0219 Engine Overspeed Condition
  5. 01-25-2004 01:20 PM #5
    DTC P0220 APP Sensor 2 Circuit
    DTC P0221 APP Sensor 2 Circuit Performance
    DTC P0222 APP Sensor 2 Circuit Low Voltage
    DTC P0223 APP Sensor 2 Circuit High Voltage
    DTC P0224 Throttle Position Sensor 2 Intermittent
    DTC P0225 APP Sensor 3 Circuit
    DTC P0226 APP Sensor 3 Circuit Performance
    DTC P0227 APP Sensor 3 Circuit Low Voltage
    DTC P0228 APP Sensor 3 Circuit High Voltage
    DTC P0229 Throttle Position Sensor 3 Intermittent
    DTC P0230 Fuel Pump Relay Control Circuit
    DTC P0231 Fuel Pump Feedback Circuit Low Voltage
    DTC P0232 Fuel Pump Feedback Circuit High Voltage
    DTC P0233 Fuel Pump Secondary Circuit Intermittent
    DTC P0234 TC Engine Overboost Condition
    DTC P0235 Turbocharger Boost Sensor 1 Circuit
    DTC P0236 TC Boost System
    DTC P0237 TC Boost Sensor Circuit Low Voltage
    DTC P0238 TC Boost Sensor Circuit High Voltage
    DTC P0239 Turbocharger Boost Sensor 2 Circuit
    DTC P0240 Turbocharger Boost Sensor 2 Performance
    DTC P0241 Turbocharger Boost Sensor 2 Circuit Low Voltage
    DTC P0242 Turbocharger Boost Sensor 2 Circuit High Voltage
    DTC P0243 Turbocharger Wastegate Solenoid 1
    DTC P0244 Turbocharger Wastegate Solenoid 1 Performance
    DTC P0245 Turbocharger Wastegate Solenoid 1 Low Voltage
    DTC P0246 Turbocharger Wastegate Solenoid 1 High Voltage
    DTC P0247 Turbocharger Wastegate Solenoid 2
    DTC P0248 Turbocharger Wastegate Solenoid 2 Performance
    DTC P0249 Turbocharger Wastegate Solenoid 2 Low Voltage
    DTC P0250 Turbocharger Wastegate Solenoid 2 High Voltage
    DTC P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    DTC P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    DTC P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    DTC P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    DTC P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    DTC P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    DTC P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
    DTC P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    DTC P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    DTC P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    DTC P0261 Cylinder 1 Injector Circuit Low
    DTC P0262 Cylinder 1 Injector Circuit High
    DTC P0263 Cylinder 1 Contribution/Balance Fault
    DTC P0264 Cylinder 2 Injector Circuit Low
    DTC P0265 Cylinder 2 Injector Circuit High
    DTC P0266 Cylinder 2 Contribution/Balance Fault
    DTC P0267 Cylinder 3 Injector Circuit Low
    DTC P0268 Cylinder 3 Injector Circuit High
    DTC P0269 Cylinder 3 Contribution/Balance Fault
    DTC P0270 Cylinder 4 Injector Circuit Low
    DTC P0271 Cylinder 4 Injector Circuit High
    DTC P0272 Cylinder 4 Contribution/Balance Fault
    DTC P0273 Cylinder 5 Injector Circuit Low
    DTC P0274 Cylinder 5 Injector Circuit High
    DTC P0275 Cylinder 5 Contribution/Balance Fault
    DTC P0276 Cylinder 6 Injector Circuit Low
    DTC P0277 Cylinder 6 Injector Circuit High
    DTC P0278 Cylinder 6 Contribution/Balance Fault
    DTC P0279 Cylinder 7 Injector Circuit Low
    DTC P0280 Cylinder 7 Injector Circuit High
    DTC P0281 Cylinder 7 Contribution/Balance Fault
    DTC P0282 Cylinder 8 Injector Circuit Low
    DTC P0283 Cylinder 8 Injector Circuit High
    DTC P0284 Cylinder 8 Contribution/Balance Fault
    DTC P0285 Cylinder 9 Injector Circuit Low
    DTC P0286 Cylinder 9 Injector Circuit High
    DTC P0287 Cylinder 9 Contribution/Balance Fault
    DTC P0288 Cylinder 10 Injector Circuit Low
    DTC P0289 Cylinder 10 Injector Circuit High
    DTC P0290 Cylinder 10 Contribution/Balance Fault
    DTC P0291 Cylinder 11 Injector Circuit Low
    DTC P0292 Cylinder 11 Injector Circuit High
    DTC P0293 Cylinder 11 Contribution/Balance Fault
    DTC P0294 Cylinder 12 Injector Circuit Low
    DTC P0295 Cylinder 12 Injector Circuit High
    DTC P0296 Cylinder 12 Contribution/Range Fault
    DTC P0300 Engine Misfire Detected
    DTC P0301 Cylinder 1 Misfire Detected
    DTC P0302 Cylinder 2 Misfire Detected
    DTC P0303 Cylinder 3 Misfire Detected
    DTC P0304 Cylinder 4 Misfire Detected
    DTC P0305 Cylinder 5 Misfire Detected
    DTC P0306 Cylinder 6 Misfire Detected
    DTC P0307 Cylinder 7 Misfire Detected
    DTC P0308 Cylinder 8 Misfire Detected
    DTC P0309 Cylinder 9 Misfire Detected
    DTC P0311 Cylinder 11 Misfire Detected
    DTC P0312 Cylinder 12 Misfire Detected
    DTC P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    DTC P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    DTC P0322 IC Module 4X Reference CKT No Frequency
    DTC P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    DTC P0325 PCM Knock Sensor Circuit
    DTC P0326 Knock Sensor CKT Excessive Spark Retard
    DTC P0327 Knock Sensor Circuit Low Voltage
    DTC P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    DTC P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    DTC P0330 Knock Sensor (KS) Circuit Bank 2
    DTC P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    DTC P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    DTC P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    DTC P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    DTC P0335 CKP Sensor A Circuit Performance
    DTC P0336 Crankshaft Position (CKP) Sensor A Performance
    DTC P0337 Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle
    DTC P0338 Crankshaft Position (CKP) Sensor Circuit High Duty Cycle
    DTC P0339 Crankshaft Position (CKP) Sensor Circuit Intermittent
    DTC P0340 Camshaft Position (CMP) Sensor Circuit
    DTC P0341 Camshaft Position (CMP) Sensor Performance
    DTC P0342 Camshaft Position Sensor Circuit Low Input
    DTC P0343 Camshaft Position Sensor Circuit High Input
    DTC P0344 Camshaft Position Sensor Circuit Intermittent
    DTC P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    DTC P0351 Ignition Coil 1 Control Circuit
    DTC P0352 Ignition Coil 2 Control Circuit
    DTC P0353 Ignition Coil 3 Control Circuit
    DTC P0354 Ignition Coil 4 Control Circuit
    DTC P0355 Ignition Coil 5 Control Circuit
    DTC P0356 Ignition Coil 6 Control Circuit
    DTC P0357 Ignition Coil 7 Control Circuit
    DTC P0358 Ignition Coil 8 Control Circuit
    DTC P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    DTC P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    DTC P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    DTC P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    DTC P0370 Timing Reference High Resolution Signal A Malfunction
    DTC P0371 IC 24X Reference CKT Too Many Pulses
    DTC P0372 IC 24X Reference Circuit Missing Pulses
    DTC P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
  6. 01-25-2004 01:21 PM #6
    DTC P0374 Timing Reference High Resolution Signal A No Pulses
    DTC P0375 Timing Reference High Resolution Signal B Malfunction
    DTC P0376 Timing Reference High Resolution Signal B Too Many Pulses
    DTC P0377 Timing Reference High Resolution Signal B Too Few Pulses
    DTC P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    DTC P0379 Timing Reference High Resolution Signal B No Pulses
    DTC P0380 Glow Plug/Heater Circuit "A" Malfunction
    DTC P0381 Glow Plug/Heater Indicator Circuit Malfunction
    DTC P0382 Exhaust Gas Recirculation Flow Malfunction
    DTC P0385 Crankshaft Position (CKP) Sensor B Circuit
    DTC P0386 Crankshaft Position (CKP) Sensor B Performance
    DTC P0387 Crankshaft Position Sensor B Circuit Low Input
    DTC P0388 Crankshaft Position Sensor B Circuit High Input
    DTC P0389 Crankshaft Position Sensor B Circuit Intermittent
    DTC P0400 Exhaust Gas Recirculation Flow Malfunction
    DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
    DTC P0402 Exhaust Gas Recirculation Flow Excessive Detected
    DTC P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
    DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
    DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
    DTC P0406 Exhaust Gas Recirculation Sensor A Circuit High
    DTC P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    DTC P0408 Exhaust Gas Recirculation Sensor B Circuit High
    DTC P0410 Secondary Air Injection (AIR) System
    DTC P0411 Secondary Air Injection (AIR) System
    DTC P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1
    DTC P0413 Secondary Air Injection System Switching Valve A Circuit Open
    DTC P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    DTC P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    DTC P0416 Secondary Air Injection System Switching Valve B Circuit Open
    DTC P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    DTC P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1
    DTC P0419 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2
    DTC P0420 Catalyst System Low Efficiency
    DTC P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    DTC P0422 Catalyst System Low Efficiency Bank 1
    DTC P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    DTC P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    DTC P0430 Catalyst System Low Efficiency Bank 2
    DTC P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    DTC P0432 Catalyst System Low Efficiency Bank 2
    DTC P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    DTC P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    DTC P0440 Evaporative Emission (EVAP) System
    DTC P0441 Evaporative Emission Control System Incorrect Purge Flow
    DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
    DTC P0443 EVAP Purge Solenoid Valve 1 Control CKT
    DTC P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    DTC P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    DTC P0446 EVAP Vent Solenoid Valve Control System
    DTC P0447 Evaporative Emission Control System Vent Control Circuit Open
    DTC P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
    DTC P0450 Fuel Tank Pressure Sensor Circuit
    DTC P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
    DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
    DTC P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    DTC P0455 Evaporative Emission (EVAP) System Leak Detected
    DTC P0460 Fuel Level Sensor Circuit
    DTC P0461 Fuel Level Sensor Performance
    DTC P0462 Fuel Level Sensor Circuit Low Voltage
    DTC P0463 Fuel Level Sensor Circuit High Voltage
    DTC P0464 Fuel Level Sensor Circuit Intermittent
    DTC P0465 Purge Flow Sensor Circuit Malfunction
    DTC P0466 Purge Flow Sensor Circuit Range/Performance
    DTC P0467 Purge Flow Sensor Circuit Low Input
    DTC P0468 Purge Flow Sensor Circuit High Input
    DTC P0469 Purge Flow Sensor Circuit Intermittent
    DTC P0470 Exhaust Pressure Sensor Malfunction
    DTC P0471 Exhaust Pressure Sensor Range/Performance
    DTC P0472 Exhaust Pressure Sensor Low
    DTC P0473 Exhaust Pressure Sensor High
    DTC P0474 Exhaust Pressure Sensor Intermittent
    DTC P0475 Exhaust Pressure Control Valve Malfunction
    DTC P0476 Exhaust Pressure Control Valve Range/Performance
    DTC P0477 Exhaust Pressure Control Valve Low
    DTC P0478 Exhaust Pressure Control Valve High
    DTC P0479 Exhaust Pressure Control Valve Intermittent
    DTC P0480 Cooling Fan Relay 1 Control Circuit
    DTC P0481 Cooling Fan Relay 2 Control Circuit
    DTC P0482 Cooling Fan 3 Control Circuit Malfunction
    DTC P0483 Cooling Fan Rationality Check Malfunction
    DTC P0484 Cooling Fan Circuit Over Current
    DTC P0485 Cooling Fan Power/Ground Circuit Malfunction
    DTC P0500 Vehicle Speed Sensor (VSS) Circuit
    DTC P0501 Vehicle Speed Sensor Range/Performance
    DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
    DTC P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
    DTC P0505 Idle Control System Malfunction
    DTC P0506 Idle Speed Low
    DTC P0507 Idle Speed High
    DTC P0510 Closed Throttle Position Switch Malfunction
    DTC P0512 Start Switch Circuit
    DTC P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    DTC P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    DTC P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    DTC P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
    DTC P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    DTC P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    DTC P0532 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
    DTC P0533 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
    DTC P0534 Air Conditioner Refrigerant Charge Loss
    DTC P0550 Power Steering Pressure (PSP) Switch Circuit
    DTC P0551 Power Steering Pressure Sensor Circuit Range/Performance
    DTC P0552 Power Steering Pressure Sensor Circuit Low Input
    DTC P0553 Power Steering Pressure Sensor Circuit High Input
    DTC P0554 Power Steering Pressure Sensor Circuit Intermittent
    DTC P0560 System Voltage
    DTC P0561 System Voltage Unstable
    DTC P0562 System Voltage Low
    DTC P0563 System Voltage High
    DTC P0565 Cruise Control On Signal Malfunction
    DTC P0566 Cruise Control Off Signal Malfunction
    DTC P0567 Cruise Control Resume Signal Malfunction
    DTC P0568 Cruise Control Set Signal Malfunction
    DTC P0569 Cruise Control Coast Signal Malfunction
    DTC P0570 Cruise Control Accel Signal Malfunction
    DTC P0571 Cruise Control Brake Switch Circuit
    DTC P0573 Cruise Control/Brake Switch A Circuit High
    DTC P0574 Vehicle Speed Too High - Cruise Control Disabled
    DTC P0575 Cruise Control Related Malfunction
    DTC P0576 Cruise Control Related Malfunction
    DTC P0578 Cruise Control Related Malfunction
    DTC P0579 Cruise Control Related Malfunction
    DTC P0580 Cruise Control Related Malfunction
    DTC P0600 Serial Communication Link Malfunction
    DTC P0601 Control Module Read Only Memory (ROM)
    DTC P0602 Control Module Not Programmed
  7. 01-25-2004 01:22 PM #7
    DTC P0603 Control Module Long Term Memory Reset
    DTC P0604 Control Module Random Access Memory (RAM)
    DTC P0605 Control Module Programming Read Only Memory (ROM)
    DTC P0606 Control Module Internal Performance
    DTC P0608 Control Module VSS Output "A" Malfunction
    DTC P0609 Control Module VSS Output "B" Malfunction
    DTC P0615 Starter Relay Control Circuit
    DTC P0620 Generator Control Circuit Malfunction
    DTC P0621 Generator L-Terminal Circuit
    DTC P0622 Generator F-Terminal Circuit
    DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit
    DTC P0654 Engine RPM Output Circuit Malfunction
    DTC P0655 Engine Hot Lamp Output Control Circuit Malfucntion
    DTC P0656 Fuel Level Output Circuit Malfunction
    DTC P0700 Transmission Control System Malfunction
    DTC P0701 Transmission Control System Range/Performance
    DTC P0702 Transmission Control System Electrical
    DTC P0703 Brake Switch Circuit Malfunction
    DTC P0704 Clutch Switch Input Circuit Malfunction
    DTC P0705 Trans Range Switch Circuit
    DTC P0706 Trans Range Switch Performance
    DTC P0707 Transmission Range Sensor Circuit Low Input
    DTC P0708 Transmission Range Sensor Circuit High Input
    DTC P0709 Transmission Range Sensor Circuit Intermittent
    DTC P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    DTC P0711 TFT Sensor Circuit Range/Performance
    DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
    DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
    DTC P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    DTC P0715 Input/Turbine Speed Sensor Circuit Malfunction
    DTC P0716 Input Speed Sensor Circuit Intermittent
    DTC P0717 Input Speed Sensor Circuit Low Input
    DTC P0718 Input/Turbine Speed Sensor Circuit Intermittent
    DTC P0719 Brake Switch Circuit Low Input
    DTC P0720 Output Speed Sensor Circuit Malfunction
    DTC P0721 Output Speed Sensor Range/Performance
    DTC P0722 Output Speed Sensor Circuit Low Input
    DTC P0723 Output Speed Sensor Intermittent
    DTC P0724 Brake Switch Circuit High Input
    DTC P0725 Engine Speed Input Circuit
    DTC P0726 Engine Speed Input Circuit Range/Performance
    DTC P0727 Engine Speed Circuit No Signal
    DTC P0728 Engine Speed Input Circuit Intermittent
    DTC P0730 Incorrect Gear Ratio
    DTC P0731 Incorrect 1st Gear Ratio
    DTC P0732 Incorrect 2nd Gear Ratio
    DTC P0733 Incorrect 3rd Gear Ratio
    DTC P0734 Incorrect 4th Gear Ratio
    DTC P0735 Gear 5 Incorrect ratio
    DTC P0736 Reverse incorrect gear ratio
    DTC P0740 TCC Enable Solenoid Circuit Electrical
    DTC P0741 TCC System Stuck Off
    DTC P0742 TCC System Stuck On
    DTC P0743 TCC Enable Solenoid Circuit Electrical
    DTC P0744 Torque Converter Clutch Circuit Intermittent
    DTC P0745 Pressure Control Solenoid Malfunction
    DTC P0746 Pressure Control Solenoid Performance or Stuck Off
    DTC P0747 Pressure Control Solenoid Stuck On
    DTC P0748 Pressure Control Solenoid Circuit Electrical
    DTC P0749 Pressure Control Solenoid Intermittent
    DTC P0750 Shift Solenoid A Malfunction
    DTC P0751 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear
    DTC P0752 1-2 Shift Solenoid Valve Performance - No Second or Third Gear
    DTC P0753 1-2 Shift Solenoid Circuit Electrical
    DTC P0754 Shift Solenoid A Intermittent
    DTC P0755 Shift Solenoid B Malfunction
    DTC P0756 2-3 Shift Solenoid Valve Performance - No First or Second Gear
    DTC P0757 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
    DTC P0758 2-3 Shift Solenoid Circuit Electrical
    DTC P0759 Shift Solenoid B Intermittent
    DTC P0760 Shift Solenoid C Malfunction
    DTC P0761 Shift Solenoid C Performance or Stuck Off
    DTC P0762 Shift Solenoid C Stuck On
    DTC P0763 Shift Solenoid C Electrical
    DTC P0764 Shift Solenoid C Intermittent
    DTC P0765 Shift Solenoid D Malfunction
    DTC P0766 Shift Solenoid D Performance or Stuck Off
    DTC P0767 Shift Solenoid D Stuck On
    DTC P0768 Shift Solenoid D Electrical
    DTC P0769 Shift Solenoid D Intermittent
    DTC P0770 Shift Solenoid E Malfunction
    DTC P0771 Shift Solenoid E Performance or Stuck Off
    DTC P0772 Shift Solenoid E Stuck On
    DTC P0773 Shift Solenoid E Electrical
    DTC P0774 Shift Solenoid E Intermittent
    DTC P0780 Shift Malfunction
    DTC P0781 1-2 Shift Malfunction
    DTC P0782 2-3 Shift Malfunction
    DTC P0783 3-4 Shift Malfunction
    DTC P0784 4-5 Shift Malfunction
    DTC P0785 3-2 Shift Solenoid Circuit Electrical
    DTC P0786 Shift/Timing Solenoid Range/Performance
    DTC P0787 Shift/Timing Solenoid Low
    DTC P0788 Shift/Timing Solenoid High
    DTC P0789 Shift/Timing Solenoid Intermittent
    DTC P0790 Normal/Performance Switch Circuit Malfunction
    DTC P0801 Reverse Inhibit Control Circuit Malfunction
    DTC P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    DTC P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    DTC P1031 HO2S Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
    DTC P1032 HO2S Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
    DTC P1105 Secondary Vacuum Sensor Circuit
    DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
    DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
    DTC P1108 BARO to MAP Sensor Comparison Too High
    DTC P1109 Secondary Port Throttle System
    DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
    DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
    DTC P1113 Intake Resonance Switchover Solenoid Control Circuit
    DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
    DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
    DTC P1116 ECT Signal Unstable or Intermittent
    DTC P1117 Engine Coolant Temp. Signal Out-Of-Range Low
    DTC P1118 Engine Coolant Temp. Signal Out-Of-Range High
    DTC P1119 ECT Signal Out-Of-Range With TFT Sensor
    DTC P1120 Throttle Position (TP) Sensor 1 Circuit
    DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
    DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
    DTC P1125 APP System
    DTC P1130 HO2S Circuit Low Variance Bank 1 Sensor 1
    DTC P1131 HO2S Circuit Low Variance Bank 1 Sensor 2
    DTC P1132 HO2S Circuit Low Variance Bank 2 Sensor 1
    DTC P1133 HO2S Insufficient Switching Bank 1 Sensor 1
    DTC P1134 HO2S Transition Time Ratio Bank 1 Sensor 1
    DTC P1135 HO2S Lean Mean Bank 1 Sensor 1
    DTC P1136 HO2S Rich Mean Bank 1 Sensor 1
    DTC P1137 HO2S Bank 1 Sensor 2 Lean System or Low Voltage
    DTC P1138 HO2S Bank 1 Sensor 2 Rich or High Voltage
    DTC P1139 HO2S Insuff. Switching Bank 1 Sensor 2
    DTC P1140 HO2S Transition Time Ratio Bank 1 Sensor 2
    DTC P1141 HO2S Heater Control Circuit Bank 1 Sensor 2
    DTC P1143 HO2S Bank 1 Sensor 3 Lean System or Low Voltage
    DTC P1144 HO2S Bank 1 Sensor 3 Rich or High Voltage
    DTC P1145 HO2S Cross Counts Bank 1 Sensor 3
    DTC P1153 HO2S Insufficient Switching Bank 2 Sensor 1
    DTC P1154 HO2S Transition Time Ratio Bank 2 Sensor 1
    DTC P1155 HO2S Lean Mean Bank 2 Sensor 1
    DTC P1156 HO2S Rich Mean Bank 2 Sensor 1
    DTC P1157 HO2S Bank 2 Sensor 2 Lean System or Low Voltage
  8. 01-25-2004 01:23 PM #8
    DTC P1158 HO2S Bank 2 Sensor 2 Rich or High Voltage
    DTC P1159 HO2S Cross Counts Bank 2 Sensor 2
    DTC P1161 HO2S Heater Control Circuit Bank 2 Sensor 2
    DTC P1163 HO2S Bank 2 Sensor 3 Lean System or Low Voltage
    DTC P1164 HO2S Bank 2 Sensor 3 Rich or High Voltage
    DTC P1165 HO2S Cross Counts Bank 2 Sensor 3
    DTC P1170 Bank to Bank Fuel TrimOffset
    DTC P1171 Fuel System Lean During Acceleration
    DTC P1185 Engine Oil Temperature Circuit
    DTC P1186 EOT Circuit Performance
    DTC P1187 EOT Sensor Ckt. Low Voltage
    DTC P1188 EOT Sensor Ckt. High Voltage
    DTC P1189 Engine Oil Pressure (EOP) Switch Circuit
    DTC P1190 Engine Vacuum Leak
    DTC P1191 Intake Air Duct Air Leak
    DTC P1200 Injector Control Circuit
    DTC P1201 (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
    DTC P1202 (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
    DTC P1203 (Alt. Fuel) Gas Mass Sensor Circuit High Frequency
    DTC P1211 Mass Air Flow Circuit Intermittent High
    DTC P1212 Mass Air Flow Circuit Intermittent Low
    DTC P1214 Injection Pump Timing Offset
    DTC P1215 Ground Fault Detection Indicated
    DTC P1216 Fuel Solenoid Response Time Too Short
    DTC P1217 Fuel Solenoid Response Time Too Long
    DTC P1218 Injection Pump Calibration Circuit
    DTC P1219 Throttle Position Sensor Reference Voltage
    DTC P1220 Throttle Position (TP) Sensor 2 Circuit
    DTC P1221 Fuel Pump Secondary Circuit Low
    DTC P1222 Injector Control Circuit Intermittent
    DTC P1225 Injector Circuit Cylinder 2 Intermittent
    DTC P1228 Injector Circuit Cylinder 3 Intermittent
    DTC P1231 Injector Circuit Cylinder 4 Intermittent
    DTC P1234 Injector Circuit Cylinder 5 Intermittent
    DTC P1237 Injector Circuit Cylinder 6 Intermittent
    DTC P1240 Injector Circuit Cylinder 7 Intermittent
    DTC P1243 Injector Circuit Cylinder 8 Intermittent
    DTC P1245 Intake Plenum Switchover Valve
    DTC P1250 Early Fuel Evaporation Heater Circuit
    DTC P1257 Supercharger System Overboost
    DTC P1258 Engine Coolant Overtemperature - Protection Mode Active
    DTC P1260 Last Test Failed Failed SCC ENTER:More Info.
    DTC P1270 Accelerator Pedal Position Sensor A/D Converter Error
    DTC P1271 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
    DTC P1272 Accelerator Pedal Position Sensor 2
    DTC P1273 "Accelerator Pedal Position Sensor 1
    DTC P1274 Injectors Wired Incorrectly
    DTC P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit
    DTC P1276 Accelerator Pedal Position Sensor 1 Circuit Performance
    DTC P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage
    DTC P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage
    DTC P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit
    DTC P1281 Accelerator Pedal Position Sensor 2 Circuit Performance
    DTC P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
    DTC P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage
    DTC P1285 Accelerator Pedal Position Sensor 3 Circuit
    DTC P1286 Accelerator Pedal Position Sensor 3 Circuit Performance
    DTC P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage
    DTC P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage
    DTC P1300 Ignitor Circuit
    DTC P1305 Ignition Coil 2 Primary Feedback Circuit
    DTC P1310 Ignition Coil 3 Primary Feedback Circuit
    DTC P1315 Ignition Coil 4 Primary Feedback Circuit
    DTC P1320 IC 4X Reference Circuit Intermittent
    DTC P1321 Electronic Ignition System Fault Line
    DTC P1322 EI System or Ignition Control Extra or Missing
    DTC P1323 IC 24X Reference Circuit Low Frequency
    DTC P1324 Crank RPM Too Low
    DTC P1335 CKP Circuit
    DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
    DTC P1345 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
    DTC P1346 Intake Camshaft Position [CMP] Sensor System Performance
    DTC P1350 Ignition Control System
    DTC P1351 Ignition Coil Control Circuit High Voltage
    DTC P1352 IC Output High/Pulse Detected when GND_Cyl. 2
    DTC P1353 IC Output High/Pulse Detected when GND_Cyl. 3
    DTC P1354 IC Output High/Pulse Detected when GND_Cyl. 4
    DTC P1355 IC Output High/Pulse Detected when GND_Cyl. 5
    DTC P1356 IC Output High/Pulse Detected when GND_Cyl. 6
    DTC P1357 IC Output High/Pulse Detected when GND_Cyl. 7
    DTC P1358 IC Output High/Pulse Detected when GND_Cyl. 8
    DTC P1359 Ignition Coil Group 1 Control Circuit
    DTC P1360 Ignition Coil Group 2 Control Circuit
    DTC P1361 Ignition Coil Control Circuit Low Voltage
    DTC P1362 IC Cylinder 2 Not Toggling After Enable
    DTC P1363 IC Cylinder 3 Not Toggling After Enable
    DTC P1364 IC Cylinder 4 Not Toggling After Enable
    DTC P1365 IC Cylinder 5 Not Toggling After Enable
    DTC P1366 IC Cylinder 6 Not Toggling After Enable
    DTC P1367 IC Cylinder 7 Not Toggling After Enable
    DTC P1368 IC Cylinder 8 Not Toggling After Enable
    DTC P1370 IC 4X Reference Circuit Too Many Pulses
    DTC P1371 IC 4X Reference Circuit Too Few Pulses
    DTC P1372 Crankshaft Position (CKP) Sensor A-B Correlation
    DTC P1374 3X Reference Circuit
    DTC P1375 IC 24X Reference Circuit High Voltage
    DTC P1376 Ignition Ground Circuit
    DTC P1377 IC Cam Pulse To 4X Reference Pulse
    DTC P1380 Misfire Detected - Rough Road Data Not Available
    DTC P1381 Misfire Detected - No Communication with Brake Control Module
    DTC P1390 Wheel Speed Sensor 1 - G - Sensor Circuit
    DTC P1391 Wheel Speed Sensor 1 - G - Sensor Circuit Performance
    DTC P1392 Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
    DTC P1393 Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
    DTC P1394 Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
    DTC P1395 Wheel Speed Sensor 2 - G - Sensor Circuit
    DTC P1396 Wheel Speed Sensor 2 - G - Sensor Circuit Performance
    DTC P1397 Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
    DTC P1398 Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
    DTC P1399 Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
    DTC P1403 Exhaust Gas Recirculation System Valve 1
    DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
    DTC P1405 Exhaust Gas Recirculation System Valve 3
    DTC P1406 EGR Valve Pintle Position Circuit
    DTC P1407 EGR Air Intrusion in Exhaust Supply to EGR Valve
    DTC P1408 Intake Manifold Pressure Sensor Circuit
    DTC P1409 EGR Vacuum System Leak
    DTC P1410 Fuel Tank Pressure System
    DTC P1415 Secondary Air Injection (AIR) System Bank 1
    DTC P1416 Secondary Air Injection (AIR) System Bank 2
    DTC P1418 Secondary Air Injection System Relay A Control Circuit High
    DTC P1420 Intake Air Low Pressure Switch Circuit Low Voltage
    DTC P1421 Intake Air Low Pressure Switch Circuit High Voltage
    DTC P1423 Intake Air High Pressure Switch Circuit High Voltage
    DTC P1431 Fuel Level Sensor 2 Circuit Performance
    DTC P1432 Fuel Level Sensor 2 Circuit Low Voltage
    DTC P1433 Fuel Level Sensor 2 Circuit High Voltage
    DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
    DTC P1442 EVAP Vacuum Sw. High Voltage During Ign. On
    DTC P1450 Barometric Pressure Sensor Circuit
    DTC P1451 Barometric Press. Sensor Performance
    DTC P1460 Cooling Fan Control System
    DTC P1460 Misfire Detected With Low Fuel Level
    DTC P1480 Cooling Fan 1 Control Circuit High
    DTC P1483 Engine Cooling System Performance
    DTC P1500 Starter Signal Circuit
    DTC P1501 Theft Deterrent System
    DTC P1501 Vehicle Speed Sensor Circuit Intermittent
    DTC P1502 Theft Deterrent Fuel Enable Signal Not Received
    DTC P1503 Theft Deterrent Fuel Enable Signal Not Correct
    DTC P1504 Vehicle Speed Output Circuit
    DTC P1508 Idle Speed Low - Idle Air Control (IAC) System Not Responding
    DTC P1509 Idle Speed High - Idle Air Control (IAC) System Not Responding
    DTC P1510 Throttle Control System Performance - Throttle Limitation Active
    DTC P1511 Throttle Control System - Backup System Performance
    DTC P1514 Airflow to TP Sensor Correlation High
    DTC P1515 Electronic Throttle System Throttle Position
    DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
    DTC P1517 Electronic Throttle Module
    DTC P1518 Electronic Throttle Module to PCM Communication
    DTC P1519 Throttle Actuator Control (TAC) Module Internal Circuit
    DTC P1520 Transmission Range Switch Circuit
    DTC P1521 Transmission Engaged at High Throttle Angle
    DTC P1522 Park/Neutral to Drive/Reverse at High RPM
    DTC P1523 Throttle Closed Position Performance
    DTC P1524 Throttle Closed Position Performance
    DTC P1525 Throttle Body ServiceRequired
    DTC P1526 Minimum Throttle Position Not Learned
    DTC P1527 Transmission Range to Pressure Switch Correlation
    DTC P1528 Governor
    DTC P1529 Heated Windshield Request Problem
    DTC P1530 Throttle Actuator Control (TAC) Module Internal Circuit
    DTC P1531 A/C Low Side Temperature Sensor Fault
    DTC P1532 A/C Evaporator Temp. Sens. Ckt. Low Voltage
    DTC P1533 A/C Evaporator Temp. Sens. Ckt. High Voltage
    DTC P1534 A/C High Side Temp. Sensor Low Voltage
    DTC P1535 A/C High Side Temperature Sensor Circuit
    DTC P1536 Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
    DTC P1537 A/C Request Circuit Low Voltage
    DTC P1538 A/C Request Circuit High Voltage
    DTC P1539 A/C Clutch Status Circuit High Voltage
    DTC P1540 Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
    DTC P1541 A/C High Side Over Temperature
    DTC P1542 A/C System High Pressure High Temperature
    DTC P1543 A/C System Performance
    DTC P1544 A/C Refrigerant Condition Very Low
    DTC P1545 Air Conditioning (A/C) Clutch Relay Control Circuit
    DTC P1546 A/C Clutch Status Circuit Low Voltage
    DTC P1547 A/C System Performance Degraded
    DTC P1548 A/C Recirculation Circuit
    DTC P1554 Cruise Control Feedback Circuit
    DTC P1555 Electronic Variable Orifice Output
    DTC P1558 Cruise Control Servo Indicates Low
    DTC P1559 Cruise Control Power Management Mode
  9. 01-25-2004 01:23 PM #9
    DTC P1560 Transaxle Not in Drive - Cruise Control Disabled
    DTC P1561 Cruise Vent Solenoid
    DTC P1562 Cruise Vacuum Solenoid
    DTC P1563 Cruise Vehicle Speed/Set Speed Difference Too High
    DTC P1564 Vehicle Acceleration Too High - Cruise Control Disabled
    DTC P1565 Cruise Servo Position Sensor
    DTC P1566 Engine RPM Too High - Cruise Control Disabled
    DTC P1567 Active Banking Control Active - Cruise Control Disabled
    DTC P1568 Cruise Servo Stroke Greater than Commanded in Cruise
    DTC P1569 Cruise Servo Stroke High While not in Cruise
    DTC P1570 Traction Control Active - Cruise Control Disabled
    DTC P1571 Traction Control Torque Request Circuit
    DTC P1572 ASR Active Circuit Low Too Long
    DTC P1573 PCM/EBTCM Serial Data Circuit
    DTC P1574 Stoplamp Switch Circuit
    DTC P1575 Extended Travel Brake Switch Circuit
    DTC P1576 BBV Sensor Ckt. High Voltage
    DTC P1577 BBV Sensor Ckt. Low Voltage
    DTC P1578 BBV Sensor Ckt. Low Vacuum
    DTC P1579 P/N to D/R at High Throttle Angle - Power Reduction Mode Active
    DTC P1580 Cruise Move Circuit Low Voltage
    DTC P1581 Cruise Move Circuit High Voltage
    DTC P1582 Cruise Direction Circuit Low Voltage
    DTC P1583 Cruise Direction CircuitHigh Voltage
    DTC P1584 Cruise Control Disabled
    DTC P1585 Cruise Control Inhibit Output Circuit
    DTC P1586 Cruise Control Brake Switch 2 Circuit
    DTC P1587 Cruise Control Clutch Control Circuit Low
    DTC P1588 Cruise Control Clutch Control Circuit High
    DTC P1599 Engine Stall or Near Stall Detected
    DTC P1600 TCM Internal Watchdog Operation
    DTC P1601 Serial Comm. Problem With Device 1
    DTC P1602 Knock Sensor (KS) Module Performance
    DTC P1603 Loss of SDM Serial Data
    DTC P1604 Loss of IPC Serial Data
    DTC P1605 Loss of HVAC Serial Data
    DTC P1606 Serial Communication Problem With Device 6
    DTC P1607 Serial Communication Problem With Device 7
    DTC P1608 Serial Communication Problem With Device 8
    DTC P1609 Loss Of TCS Serial Data
    DTC P1610 Loss of PZM Serial Data
    DTC P1611 Loss of CVRTD Serial Data
    DTC P1612 Loss of IPM Serial Data
    DTC P1613 Loss of DIM Serial Data
    DTC P1614 Loss of RIM Serial Data
    DTC P1615 Loss of VTD Serial Data
    DTC P1617 Engine Oil Level Switch Circuit
    DTC P1619 Engine Oil Life Monitor Reset Circuit
    DTC P1620 Low Coolant Circuit
    DTC P1621 Control Module Long Term Memory Performance
    DTC P1622 Cylinder Select
    DTC P1623 Transmission Temp Pull-Up Resistor
    DTC P1624 Customer Snapshot Requested - Data Available
    DTC P1625 TCM System Reset
    DTC P1626 Theft Deterrent Fuel Enable Signal Not Received
    DTC P1627 A/D Performance
    DTC P1628 ECT Pull-Up Resistor
    DTC P1629 Theft Deterrent System - Cranking Signal
    DTC P1630 Theft Deterrent Learn Mode Active
    DTC P1631 Theft Deterrent Start Enable Signal Not Correct
    DTC P1632 Theft Deterrent Fuel Disable Signal Received
    DTC P1633 Ignition 0 Switch Circuit
    DTC P1634 Ignition 1 Switch Circuit
    DTC P1635 5 Volt Reference Circuit
    DTC P1636 PCM Stack Overrun
    DTC P1637 Generator L-Terminal Circuit
    DTC P1638 Generator F-Terminal Circuit
    DTC P1639 5 Volt Reference 2 Circuit
    DTC P1640 Driver-1-Input High Voltage
    DTC P1641 Malfunction Indicator Lamp (MIL) Control Circuit
    DTC P1642 Vehicle Speed Output Circuit
    DTC P1643 Engine Speed Output Circuit
    DTC P1644 Traction Control Delivered Torque Output Circuit
    DTC P1645 Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
    DTC P1646 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
    DTC P1647 Driver 1 Line 7
    DTC P1650 Control Module Output B Circuit
    DTC P1651 Fan 1 Relay Control Circuit
    DTC P1652 Powertrain Induced Chassis Pitch Output Circuit
    DTC P1653 Oil Level Lamp Control Circuit
    DTC P1654 Cruise Control Inhibit Output Circuit
    DTC P1655 EVAP Purge Solenoid Control Circuit
    DTC P1656 Driver 2 Line 6
    DTC P1657 1-4 Upshift Solenoid Control Circuit
    DTC P1658 Starter Enable Relay Control Circuit
    DTC P1660 Cooling Fan Control Circuits
    DTC P1661 MIL Control Circuit
    DTC P1662 Cruise Lamp Control Circuit
    DTC P1663 Oil Life Lamp Control Circuit
    DTC P1664 1-4 Upshift Lamp Control Circuit
    DTC P1665 Driver 3 Line 5
    DTC P1666 Driver 3 Line 6
    DTC P1667 Reverse Inhibit Solenoid Control Circuit
    DTC P1669 ABS Unit Expected
    DTC P1670 Driver 4
    DTC P1671 Driver 4 Line 1
    DTC P1672 Low Engine Oil Level Lamp Control Circuit
    DTC P1673 Engine Hot Lamp Control Circuit
    DTC P1674 Tachometer Control Circuit
    DTC P1675 EVAP Vent Solenoid Control Circuit
    DTC P1676 Driver 4 Line 6
    DTC P1677 Driver 4 Line 7
    DTC P1680 Driver 5
    DTC P1681 Driver 5 Line 1
    DTC P1682 Driver 5 Line 2
    DTC P1683 Driver 5 Line 3
    DTC P1684 Driver 5 Line 4
    DTC P1685 Driver 5 Line 5
    DTC P1686 Driver 5 Line 6
    DTC P1687 Driver 5 Line 7
    DTC P1689 Delivered Torque Circuit Fault
    DTC P1690 ECM Loop Overrun
    DTC P1691 Coolant Gage Circuit Low Voltage
    DTC P1692 Coolant Gage Circuit High Voltage
    DTC P1693 Tachometer Circuit Low Voltage
    DTC P1694 Tachometer Circuit High Voltage
    DTC P1695 Remote Keyless Entry Circuit Low
    DTC P1696 Remote Keyless Entry Voltage High
    DTC P1700 Transmission Control Module (TCM) Requested MIL Illumination
    DTC P1701 Trans. MIL Request Circuit
    DTC P1705 P/N Signal Output Circuit
    DTC P1740 Torque Reduction Signal Circuit
    DTC P1743 TP Signal from ECM
    DTC P1760 TCM Supply Voltage Interrupted
    DTC P1779 Engine Torque Delivered to TCM Signal
    DTC P1780 Park/Neutral Position [PNP] Switch Circuit
    DTC P1781 Engine Torque Signal Circuit
    DTC P1790 Transmission Control Module Checksum
    DTC P1791 Transmission Control Module Loop
    DTC P1792 Transmission Control Module Reprogrammable Memory
    DTC P1792 ECM to TCM Engine Coolant Signal
    DTC P1793 Transmission Control Module Stack Overrun
    DTC P1795 CAN Bus - Throttle Body Position
    DTC P1800 TCM Power Relay Control Circuit
    DTC P1801 Performance Selector Switch Failure
    DTC P1804 Ground Control Relay
    DTC P1810 TFP Valve Position Switch Circuit
    DTC P1811 Maximum Adapt and Long Shift
    DTC P1812 Transmission Over Temperature Condition
    DTC P1813 Torque Control
    DTC P1814 Torque Converter Overstressed
    DTC P1815 Transmission Range Switch - Start In Wrong Range
    DTC P1816 TFP Valve Position Sw. - Park/Neu. With Drive Ratio
    DTC P1817 TFP Valve Position Sw. - Reverse With Drive Ratio
    DTC P1818 TFP Valve Position Sw. - Drive Without Drive Ratio
    DTC P1819 Internal Mode Switch - No Start\Wrong Range
    DTC P1820 Internal Mode Switch Circuit A Low
    DTC P1822 Internal Mode Switch Circuit B High
    DTC P1823 Internal Mode Switch Circuit P Low
    DTC P1825 Internal Mode Switch - Invalid Range
    DTC P1826 Internal Mode Switch Circuit C - High
    DTC P1831 PC Solenoid Power Circuit - Low Voltage
    DTC P1833 A/T Solenoids Power Circuit - Low Voltage
    DTC P1835 Kick-Down Switch Circuit
    DTC P1836 Kick-Down Switch Failed Open
    DTC P1837 Kick-Down Switch Failed Short
    DTC P1842 1-2 Shift Solenoid Circuit Low Voltage
    DTC P1843 1-2 Shift Solenoid Circuit High Voltage
    DTC P1844 Torque Reduction Signal Circuit Desired By TCM
    DTC P1845 2-3 Shift Solenoid Circuit Low Voltage
    DTC P1847 2-3 Shift Solenoid Circuit High Voltage
    DTC P1850 Brake Band Apply Solenoid Circuit
    DTC P1851 Brake Band Apply Solenoid Performance
    DTC P1852 Brake Band Apply SolenoidLow Voltage
    DTC P1853 Brake Band Apply Solenoid High Voltage
    DTC P1860 TCC PWM Solenoid Circuit Electrical
    DTC P1864 Torque Converter Clutch Circuit
    DTC P1868 Transmission Fluid Life
    DTC P1870 Transmission Component Slipping
    DTC P1871 Undefined Gear Ratio
    DTC P1873 TCC Stator Temp. Switch Circuit Low
    DTC P1874 TCC Stator Temp. Switch Circuit High
    DTC P1875 4WD Low Switch Circuit Electrical
    DTC P1884 TCC Enable/Shift Light Circuit
    DTC P1886 Shift Timing Solenoid
    DTC P1887 TCC Release Switch Circuit
    DTC P1890 ECM Data Input Circuit
    DTC P1890 Throttle Position Signal Input
    DTC P1891 Throttle Position Sensor PWM Signal Low
    DTC P1892 Throttle Position Sensor PWM Signal High
    DTC P1893 Engine Torque Signal Low Voltage
    DTC P1894 Engine Torque Signal High Voltage
    DTC P1895 TCM to ECM Torque Reduction Circuit
  10. 01-25-2004 01:24 PM #10
    Network Codes: (add 2 digits at end of DTC U for BCM unit identification)
    DTC U1000 Class 2 Communication Malfunction
    DTC U1001-U1254 Loss of XXX Communications
    DTC U1002 Loss of serial communications for class 2 devices
    DTC U1003 Loss of serial communications for class 2 devices
    DTC U1004 Loss of serial communications for class 2 devices
    DTC U1005 Loss of serial communications for class 2 devices
    DTC U1006 Loss of serial communications for class 2 devices
    DTC U1007 Loss of serial communications for class 2 devices
    DTC U1008 Loss of serial communications for class 2 devices
    DTC U1009 Loss of serial communications for class 2 devices
    DTC U1010 Loss of serial communications for class 2 devices
    DTC U1011 Loss of serial communications for class 2 devices
    DTC U1012 Loss of serial communications for class 2 devices
    DTC U1013 Loss of serial communications for class 2 devices
    DTC U1014 Loss of serial communications for class 2 devices
    DTC U1015 Loss of serial communications for class 2 devices
    DTC U1016 Loss of Class 2 Communication with VCM
    DTC U1016 Loss of Communications with PCM
    DTC U1017 Loss of serial communications for class 2 devices
    DTC U1018 Loss of serial communications for class 2 devices
    DTC U1019 Loss of serial communications for class 2 devices
    DTC U1020 Loss of serial communications for class 2 devices
    DTC U1021 Loss of serial communications for class 2 devices
    DTC U1022 Loss of serial communications for class 2 devices
    DTC U1023 Loss of serial communications for class 2 devices
    DTC U1024 Loss of serial communications for class 2 devices
    DTC U1025 Loss of serial communications for class 2 devices
    DTC U1026 Loss of ATC Class 2 Communication
    DTC U1027 Loss of serial communications for class 2 devices
    DTC U1028 Loss of serial communications for class 2 devices
    DTC U1029 Loss of serial communications for class 2 devices
    DTC U1030 Loss of serial communications for class 2 devices
    DTC U1031 Loss of serial communications for class 2 devices
    DTC U1032 Loss of serial communications for class 2 devices
    DTC U1033 Loss of serial communications for class 2 devices
    DTC U1034 Loss of serial communications for class 2 devices
    DTC U1035 Loss of serial communications for class 2 devices
    DTC U1036 Loss of serial communications for class 2 devices
    DTC U1037 Loss of serial communications for class 2 devices
    DTC U1038 Loss of Serial Communications for Class 2 Devices
    DTC U1039 Loss of Serial Communications for Class 2 Devices
    DTC U1040 Loss of Class 2 Communications with ABS
    DTC U1041 Loss of EBCM Communication
    DTC U1042 Lost Communications with Brake/Traction Control System
    DTC U1043 Loss of Serial Communications for Class 2 Devices
    DTC U1044 Loss of Serial Communications for Class 2 Devices
    DTC U1045 Loss of Serial Communications for Class 2 Devices
    DTC U1046 Loss of Serial Communications for Class 2 Devices
    DTC U1047 Loss of Serial Communications for Class 2 Devices
    DTC U1048 Loss of Serial Communications for Class 2 Devices
    DTC U1049 Loss of Serial Communications for Class 2 Devices
    DTC U1050 Loss of Serial Communications for Class 2 Devices
    DTC U1051 Loss of Serial Communications for Class 2 Devices
    DTC U1052 Loss of Serial Communications for Class 2 Devices
    DTC U1053 Loss of Serial Communications for Class 2 Devices
    DTC U1054 Loss of Serial Communications for Class 2 Devices
    DTC U1055 Loss of Serial Communications for Class 2 Devices
    DTC U1056 Loss of Communications with RSS
    DTC U1057 Loss of Serial Communications for Class 2 Devices
    DTC U1058 Loss of Serial Communications for Class 2 Devices
    DTC U1059 Loss of Serial Communications for Class 2 Devices
    DTC U1060 Loss of Serial Communications for Class 2 Devices
    DTC U1161 Loss of PDM Serial Data
    DTC U1062 Loss of Serial Communications for Class 2 Devices
    DTC U1163 Loss of RRDM Serial Data
    DTC U1064 Loss of Communications with DIM
    DTC U1065 Loss of Communications with IPM
    DTC U1066 Loss of Communications with RIM
    DTC U1067 Loss of Serial Communications for Class 2 Devices
    DTC U1068 Loss of Serial Communications for Class 2 Devices
    DTC U1069 Loss of Serial Communications for Class 2 Devices
    DTC U1170 Loss of Driver Door Sw Asm Serial Data
    DTC U1071 Loss of Serial Communications for Class 2 Devices
    DTC U1072 Loss of Serial Communications for Class 2 Devices
    DTC U1073 Loss of Serial Communications for Class 2 Devices
    DTC U1074 Loss of Serial Communications for Class 2 Devices
    DTC U1075 Loss of Serial Communications for Class 2 Devices
    DTC U1076 Loss of Serial Communications for Class 2 Devices
    DTC U1077 Loss of Serial Communications for Class 2 Devices
    DTC U1078 Loss of Serial Communications for Class 2 Devices
    DTC U1079 Loss of Serial Communications for Class 2 Devices
    DTC U1080 Loss of Serial Communications for Class 2 Devices
    DTC U1081 Loss of Serial Communications for Class 2 Devices
    DTC U1082 Loss of Serial Communications for Class 2 Devices
    DTC U1083 Loss of Serial Communications for Class 2 Devices
    DTC U1084 Loss of Serial Communications for Class 2 Devices
    DTC U1085 Loss of Serial Communications for Class 2 Devices
    DTC U1086 Loss of Serial Communications for Class 2 Devices
    DTC U1087 Loss of Serial Communications for Class 2 Devices
    DTC U1088 Loss of Communications with SDM
    DTC U1089 Loss of Serial Communications for Class 2 Devices
    DTC U1090 Loss of Serial Communications for Class 2 Devices
    DTC U1091 Loss of Serial Communications for Class 2 Devices
    DTC U1092 Loss of Serial Communications for Class 2 Devices
    DTC U1093 Loss of Serial Communications for Class 2 Devices
    DTC U1094 Loss of Serial Communications for Class 2 Devices
    DTC U1095 Loss of Serial Communications for Class 2 Devices
    DTC U1096 Loss of Communications with IPC
    DTC U1097 Loss of Serial Communications for Class 2 Devices
    DTC U1098 Loss of Serial Communications for Class 2 Devices
    DTC U1099 Loss of Serial Communications for Class 2 Devices
    DTC U1100 Loss of Serial Communications for Class 2 Devices
    DTC U1101 Loss of Serial Communications for Class 2 Devices
    DTC U1102 Loss of Serial Communications for Class 2 Devices
    DTC U1103 Loss of Serial Communications for Class 2 Devices
    DTC U1104 Loss of Serial Communications for Class 2 Devices
    DTC U1105 Loss of Serial Communications for Class 2 Devices
    DTC U1106 Loss of Serial Communications for Class 2 Devices
    DTC U1107 Loss of Serial Communications for Class 2 Devices
    DTC U1108 Loss of Serial Communications for Class 2 Devices
    DTC U1109 Loss of Serial Communications for Class 2 Devices
    DTC U1110 Loss of Serial Communications for Class 2 Devices
    DTC U1111 Loss of Serial Communications for Class 2 Devices
    DTC U1112 Loss of Serial Communications for Class 2 Devices
    DTC U1113 Loss of Serial Communications for Class 2 Devices
    DTC U1114 Loss of Serial Communications for Class 2 Devices
    DTC U1115 Loss of Serial Communications for Class 2 Devices
    DTC U1116 Loss of Serial Communications for Class 2 Devices
    DTC U1117 Loss of Serial Communications for Class 2 Devices
    DTC U1118 Loss of Serial Communications for Class 2 Devices
    DTC U1119 Loss of Serial Communications for Class 2 Devices
    DTC U1120 Loss of Serial Communications for Class 2 Devices
    DTC U1121 Loss of Serial Communications for Class 2 Devices
    DTC U1122 Loss of Serial Communications for Class 2 Devices
    DTC U1123 Loss of serial communications for class 2 devices
    DTC U1124 Loss of serial communications for class 2 devices
    DTC U1125 Loss of serial communications for class 2 devices
    DTC U1126 Loss of serial communications for class 2 devices
    DTC U1127 Loss of serial communications for class 2 devices
    DTC U1128 Loss of Communications with IRC
    DTC U1129 Loss of Communications with AMP
    DTC U1130 Loss of serial communications for class 2 devices
    DTC U1131 Loss of serial communications for class 2 devices
    DTC U1132 Loss of serial communications for class 2 devices
    DTC U1133 Loss of serial communications for class 2 devices
    DTC U1134 Loss of serial communications for class 2 devices
    DTC U1135 Loss of serial communications for class 2 devices
    DTC U1136 Loss of serial communications for class 2 devices
    DTC U1137 Loss of serial communications for class 2 devices
    DTC U1138 Loss of serial communications for class 2 devices
    DTC U1139 Loss of serial communications for class 2 devices
    DTC U1140 Loss of serial communications for class 2 devices
    DTC U1141 Loss of serial communications for class 2 devices
    DTC U1142 Loss of serial communications for class 2 devices
    DTC U1143 Loss of serial communications for class 2 devices
    DTC U1144 Loss of Communications with PHN
    DTC U1145 Loss Of NAV Communications
    DTC U1146 Loss Of Onstar Communiction
    DTC U1147 Loss of serial communications for class 2 devices
    DTC U1148 Loss of serial communications for class 2 devices
    DTC U1149 Loss of serial communications for class 2 devices
    DTC U1150 Loss of serial communications for class 2 devices
    DTC U1151 Loss of serial communications for class 2 devices
    DTC U1152 Loss Of ACM Serial Data Communication
    DTC U1152 Loss of Data HCM
    DTC U1153 Loss of Communications with CCP
    DTC U1154 Loss of serial communications for class 2 devices
    DTC U1155 Loss of serial communications for class 2 devices
    DTC U1156 Loss of serial communications for class 2 devices
    DTC U1157 Loss of serial communications for class 2
    DTC U1158 Loss of serial communications for class 2 devices
    DTC U1159 Loss of serial communications for class 2 devices
    DTC U1160 Loss of Communications with DDM
    DTC U1161 Loss of PASS Door Module SBI
    DTC U1162 Loss of Rear Driver Door Module SBI
    DTC U1163 Loss of Rear PASS Door Module SBI
    DTC U1164 Loss Of DIM Serial Data Communication
    DTC U1165 Loss of serial communications for class 2 devices
    DTC U1166 Loss of Communications with SCM
    DTC U1167 Loss of serial communications for class 2 devices
    DTC U1168 Loss Of TTM Communications
    DTC U1169 Loss of Communications with MMM
    DTC U1170 Loss of Driver Door Switch SBI
    DTC U1171 Loss of serial communications for class 2 devices
    DTC U1172 Loss of serial communications for class 2 devices
    DTC U1173 Loss of serial communications for class 2 devices
    DTC U1174 Loss of serial communications for class 2 devices
  11. 01-25-2004 01:25 PM #11
    DTC U1175 Loss of serial communications for class 2 devices
    DTC U1176 Loss Of RFA Communications
    DTC U1177 Loss of serial communications for class 2 devices
    DTC U1178 Loss of serial communications for class 2 devices
    DTC U1179 Loss of serial communications for class 2 devices
    DTC U1180 Loss of serial communications for class 2 devices
    DTC U1181 Loss of serial communications for class 2 devices
    DTC U1182 Loss of serial communications for class 2 devices
    DTC U1183 Loss of serial communications for class 2 devices
    DTC U1184 Loss of serial communications for class 2 devices
    DTC U1185 Loss of serial communications for class 2 devices
    DTC U1186 Loss of serial communications for class 2 devices
    DTC U1187 Loss of serial communications for class 2 devices
    DTC U1188 Loss of serial communications for class 2 devices
    DTC U1189 Loss of serial communications for class 2 devices
    DTC U1190 Loss of serial communications for class 2 devices
    DTC U1191 Loss of serial communications for class 2 devices
    DTC U1192 Loss of VTD Class 2 Serial Data Com
    DTC U1193 Loss of VIM Class 2 Communication
    DTC U1194 Loss of serial communications for class 2 devices
    DTC U1195 Loss of serial communications for class 2 devices
    DTC U1196 Loss of serial communications for class 2 devices
    DTC U1197 Loss of serial communications for class 2 devices
    DTC U1198 Loss of serial communications for class 2 devices
    DTC U1199 Loss of serial communications for class 2 devices
    DTC U1200 Loss of serial communications for class 2 devices
    DTC U1201 Loss of serial communications for class 2 devices
    DTC U1202 Loss of serial communications for class 2 devices
    DTC U1203 Loss of serial communications for class 2 devices
    DTC U1204 Loss of serial communications for class 2 devices
    DTC U1205 Loss of serial communications for class 2 devices
    DTC U1206 Loss of serial communications for class 2 devices
    DTC U1207 Loss of serial communications for class 2 devices
    DTC U1208 Loss of serial communications for class 2 devices
    DTC U1209 Loss of serial communications for class 2 devices
    DTC U1210 Loss of serial communications for class 2 devices
    DTC U1215 Loss of serial communications for class 2 devices
    DTC U1220 Loss of serial communications for class 2 devices
    DTC U1225 Loss of serial communications for class 2 devices
    DTC U1230 Loss of serial communications for class 2 devices
    DTC U1235 Loss of serial communications for class 2 devices
    DTC U1240 Loss of serial communications for class 2 devices
    DTC U1245 Loss of serial communications for class 2 devices
    DTC U1250 Loss of serial communications for class 2 devices
    DTC U1251 Loss of serial communications for class 2 devices
    DTC U1252 Loss of serial communications for class 2 devices
    DTC U1253 Loss of serial communications for class 2 devices
    DTC U1254 Loss of serial communications for class 2 devices
    DTC U1255 Class 2 Communication Malfunction
    DTC U1255 Serial Data Line Malfunction
    DTC U1300 Class 2 Short to Ground
    DTC U1301 Class 2 Short to Battery
    DTC U1304 Loss Of UART Communications
    DTC U1305 Class 2 Data Link Low or High
    DTC U1500 Inter-Device Dedicated Bus Malfunction
    DTC U2000 Invalid BFC Transmitted SPI Data
    DTC U2001 Invalid IPC Transmitted SPI Data
    DTC U2002 SPI Data-In Low
    DTC U2003 SPI Data-In High
    DTC U2004 SPI Data-Out Low
    DTC U2005 SPI Data-Out High
    DTC U2006 SPI Clock-Out Low
    DTC U2007 SPI Clock-Out High
    DTC U2050 SIR PPS/CPS Communications Link malfunction
    DTC U2100 CAN Bus OFF
    DTC U2100 CAN-BUS Communication Malfunction
    DTC U2102 More Controllers on Bus than Programmed
    DTC U2103 Fewer Controllers On Bus Than Programmed
    DTC U2104 CAN Bus Reset Counter Overrun
    DTC U2105 CAN Bus Error ECM
    DTC U2105 Lost Comm with Engine Control System
    DTC U2106 Lost Comm with Trans Control System
    DTC U2107 Lost Communications with Body Control System
    DTC U2108 CAN Bus Error ABS
    DTC U2108 Lost Comm with ABS Control System
    DTC U2150 Navigation ECU Gateway Communication Error
    DTC U2151 Navigation ECU Communication Malfunction
    DTC U2153 VICS ECU Communication Error
  12. 01-25-2004 01:26 PM #12
    Basic Reply Code Upon Hard Reset of ECMA or Thru-put of Diagnostic Port (allow 3 min. for accurate DTC U codesets to be configured)
    P0100
    Mass or Volume Air Flow Circuit Malfunction
    P0101
    Mass or Volume Air Flow Circuit Range/Performance Problem
    P0102
    Mass or Volume Air Flow Circuit Low Input
    P0103
    Mass or Volume Air Flow Circuit High Input
    P0104
    Mass or Volume Air Flow Circuit Intermittent
    P0105
    Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106
    Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107
    Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108
    Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109
    Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110
    Intake Air Temperature Circuit Malfunction
    P0111
    Intake Air Temperature Circuit Range/Performance Problem
    P0112
    Intake Air Temperature Circuit Low Input
    P0113
    Intake Air Temperature Circuit High Input
    P0114
    P0115
    Engine Coolant Temperature Circuit Malfunction
    P0116
    Engine Coolant Temperature Circuit Range/Performance Problem
    P0117
    Engine Coolant Temperature Circuit Low Input
    P0118
    Engine Coolant Temperature Circuit High Input
    P0119
    P0120
    Throttle/Petal Position Sensor/Switch A Circuit Malfunction
    P0121
    Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
    P0122
    Throttle/Petal Position Sensor/Switch A Circuit Low Input
    P0123
    Throttle/Petal Position Sensor/Switch A Circuit High Input
    P0124
    Throttle/Petal Position Sensor/Switch A Circuit Intermittent
    P0125
    Insufficient Coolant Temperature for Closed Loop Fuel Control
    P0126
    Insufficient Coolant Temperature for Stable Operation
    P0130
    O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    P0131
    O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132
    O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133
    O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134
    O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135
    O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136
    O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137
    O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138
    O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139
    O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140
    O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141
    O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142
    O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143
    O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144
    O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145
    O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146
    O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147
    O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0150
    O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151
    O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152
    O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153
    O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154
    O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155
    O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156
    O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157
    O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158
    O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159
    O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
  13. 01-25-2004 01:27 PM #13
    P0160
    O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161
    O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162
    O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163
    O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164
    O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165
    O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166
    O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167
    O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0170
    Fuel Trim Malfunction (Bank 1)
    P0171
    System too Lean (Bank 1)
    P0172
    System too Rich (Bank 1)
    P0173
    Fuel Trim Malfunction (Bank 2)
    P0174
    System too Lean (Bank 2)
    P0175
    System too Rich (Bank 2)
    P0176
    Fuel Composition Sensor Circuit Malfunction
    P0177
    Fuel Composition Sensor Circuit Range/Performance
    P0178
    Fuel Composition Sensor Circuit Low Input
    P0179
    Fuel Composition Sensor Circuit High Input
    P0180
    Fuel Temperature Sensor A Circuit Malfunction
    P0181
    Fuel Temperature Sensor A Circuit Range/Performance
    P0182
    Fuel Temperature Sensor A Circuit Low Input
    P0183
    Fuel Temperature Sensor A Circuit High Input
    P0184
    Fuel Temperature Sensor A Circuit Intermittent
    P0185
    Fuel Temperature Sensor B Circuit Malfunction
    P0186
    Fuel Temperature Sensor B Circuit Range/Performance
    P0187
    Fuel Temperature Sensor B Circuit Low Input
    P0188
    Fuel Temperature Sensor B Circuit High Input
    P0189
    Fuel Temperature Sensor B Circuit Intermittent
    P0190
    Fuel Rail Pressure Sensor Circuit Malfunction
    P0191
    Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192
    Fuel Rail Pressure Sensor Circuit Low Input
    P0193
    Fuel Rail Pressure Sensor Circuit High Input
    P0194
    P0195
    Engine Oil Temperature Sensor Malfunction
    P0196
    Engine Oil Temperature Sensor Range/Performance
    P0197
    P0198
    P0199
    P0200
    Injector Circuit Malfunction
    P0201
    Injector Circuit Malfunction - Cylinder 1
    P0202
    Injector Circuit Malfunction - Cylinder 2
    P0203
    Injector Circuit Malfunction - Cylinder 3
    P0204
    Injector Circuit Malfunction - Cylinder 4
    P0205
    Injector Circuit Malfunction - Cylinder 5
    P0206
    Injector Circuit Malfunction - Cylinder 6
    P0207
    Injector Circuit Malfunction - Cylinder 7
    P0208
    Injector Circuit Malfunction - Cylinder 8
    P0209
    Injector Circuit Malfunction - Cylinder 9
    P0210
    Injector Circuit Malfunction - Cylinder 10
    P0211
    Injector Circuit Malfunction - Cylinder 11
    P0212
    Injector Circuit Malfunction - Cylinder 12
    P0213
    Cold Start Injector 1 Malfunction
    P0214
    Cold Start Injector 2 Malfunction
    P0215
    Engine Shutoff Solenoid Malfunction
    P0216
    Injection Timing Control Circuit Malfunction
    P0217
    P0218
    P0219
    P0220
    Throttle/Petal Position Sensor/Switch B Circuit Malfunction
    P0221
    Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222
    Throttle/Petal Position Sensor/Switch B Circuit Low Input
    P0223
    Throttle/Petal Position Sensor/Switch B Circuit High Input
    P0224
    Throttle/Petal Position Sensor/Switch B Circuit Intermittent
    P0225
    Throttle/Petal Position Sensor/Switch C Circuit Malfunction
    P0226
    Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227
    Throttle/Petal Position Sensor/Switch C Circuit Low Input
    P0228
    Throttle/Petal Position Sensor/Switch C Circuit High Input
    P0229
    Throttle/Petal Position Sensor/Switch C Circuit Intermittent
    P0230
    Fuel Pump Primary Circuit Malfunction
    P0231
    P0232
    Fuel Pump Secondary Circuit High
    P0233
    P0234
    P0235
    Turbocharger Boost Sensor A Circuit Malfunction
    P0236
    Turbocharger Boost Sensor A Circuit Range/Performance
    P0237
    Turbocharger Boost Sensor A Circuit Low
    P0238
    Turbocharger Boost Sensor A Circuit High
    P0239
    Turbocharger Boost Sensor B Malfunction
    P0240
    Turbocharger Boost Sensor B Circuit Range/Performance
    P0241
    Turbocharger Boost Sensor B Circuit Low
    P0242
    Turbocharger Boost Sensor B Circuit High
    P0243
    Turbocharger Wastegate Solenoid A Malfunction
    P0244
    Turbocharger Wastegate Solenoid A Range/Performance
    P0245
    Turbocharger Wastegate Solenoid A Low
    P0246
    Turbocharger Wastegate Solenoid A High
    P0247
    Turbocharger Wastegate Solenoid B Malfunction
    P0248
    Turbocharger Wastegate Solenoid B Range/Performance
    P0249
    Turbocharger Wastegate Solenoid B Low
    P0250
    Turbocharger Wastegate Solenoid B High
    P0251
    P0252
    P0253
    P0254
    P0255
    P0256
    P0257
    P0258
    P0259
    P0260
    P0261
    P0262
    P0263
    P0264
    P0265
    P0266
    P0267
    P0268
    P0269
    P0270
    P0271
    P0272
    P0273
    P0274
    P0275
    P0276
    P0277
    P0278
    P0279
    P0280
    P0281
    P0282
    P0283
    P0284
    P0285
    P0286
    P0287
    P0288
    P0289
    P0290
    P0291
    P0292
    P0293
    P0294
    P0295
  14. 01-25-2004 01:28 PM #14
    P0296
    P0300
    Random/Multiple Cylinder Misfire Detected
    P0301
    P0302
    P0303
    P0304
    P0305
    P0306
    P0307
    P0308
    P0309
    P0311
    P0312
    P0320
    P0321
    P0322
    Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323
    P0325
    Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326
    Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327
    Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328
    P0329
    P0330
    Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331
    P0332
    P0333
    P0334
    P0335
    Crankshaft Position Sensor A Circuit Malfunction
    P0336
    Crankshaft Position Sensor A Circuit Range/Performance
    P0337
    Crankshaft Position Sensor A Circuit Low Input
    P0338
    Crankshaft Position Sensor A Circuit High Input
    P0339
    Crankshaft Position Sensor A Circuit Intermittent
    P0340
    Camshaft Position Sensor Circuit Malfunction
    P0341
    Camshaft Position Sensor Circuit Range/Performance
    P0342
    P0343
    P0344
    P0350
    P0351
    Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352
    Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353
    Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354
    Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355
    Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356
    Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357
    Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358
    Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359
    P0360
    P0361
    P0362
    P0370
    P0371
    Timing Reference High Resolution Signal A Too Many Pulses
    P0372
    Timing Reference High Resolution Signal A Too Few Pulses
    P0373
    P0374
    P0375
    P0376
    P0377
    P0378
    P0379
    P0380
    P0381
    P0382
    Glow Plug/Heater Circuit "B" Malfunction
    P0385
    Crankshaft Position Sensor B Circuit Malfunction
    P0386
    Crankshaft Position Sensor B Circuit Range/Performance
    P0387
    P0388
    P0389
    P0400
    P0401
    Exhaust Gas Recirculation Flow Insufficient Detected
    P0402
    P0403
    Exhaust Gas Recirculation Circuit Malfunction
    P0404
    Exhaust Gas Recirculation Circuit Range/Performance
    P0405
    Exhaust Gas Recirculation Sensor A Circuit Low
    P0406
    P0407
    P0408
    P0410
    Secondary Air Injection System Malfunction
    P0411
    Secondary Air Injection System Incorrect Flow Detected
    P0412
    Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413
    P0414
    P0415
    P0416
    P0417
    P0418
    Secondary Air Injection System Relay "A" Circuit Malfunction
    P0419
    Secondary Air Injection System Relay "B" Circuit Malfunction
    P0420
    Catalyst System Efficiency Below Threshold (Bank 1)
    P0421
    P0422
    Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423
    P0424
    P0430
    Catalyst System Efficiency Below Threshold (Bank 2)
    P0431
    P0432
    Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433
    P0434
    P0440
    Evaporative Emission Control System Malfunction
    P0441
    P0442
    Evaporative Emission Control System Leak Detected (small leak)
    P0443
    Evaporative Emission Control System Purge Control Valve Circuit Malfunction
    P0444
    P0445
    P0446
    Evaporative Emission Control System Vent Control Circuit Malfunction
    P0447
    P0448
    P0449
    Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    P0450
    Evaporative Emission Control System Pressure Sensor Malfunction
    P0451
    P0452
    Evaporative Emission Control System Pressure Sensor Low Input
    P0453
    Evaporative Emission Control System Pressure Sensor High Input
    P0454
    P0455
    Evaporative Emission Control System Leak Detected (gross leak)
    P0460
    Fuel Level Sensor Circuit Malfunction
    P0461
    Fuel Level Sensor Circuit Range/Performance
    P0462
    Fuel Level Sensor Circuit Low Input
    P0463
    Fuel Level Sensor Circuit High Input
    P0464
    P0465
    P0466
    P0467
    P0468
    P0469
    P0470
    P0471
    P0472
    P0473
    P0474
    P0475
    P0476
    P0477
    P0478
    P0479
    P0480
    Cooling Fan 1 Control Circuit Malfunction
    P0481
    Cooling Fan 2 Control Circuit Malfunction
    P0482
    P0483
    P0484
    P0485
    P0500
    Vehicle Speed Sensor Malfunction
    P0501
    P0502
    Vehicle Speed Sensor Low Input
    P0503
    Vehicle Speed Sensor Intermittent/Erratic/High
    P0505
    P0506
    Idle Control System RPM Lower Than Expected
    P0507
    Idle Control System RPM Higher Than Expected
    P0510
    P0520
    P0521
    P0522
    P0523
    P0530
    P0531
    P0532
    A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533
    A/C Refrigerant Pressure Sensor Circuit High Input
    P0534
    P0550
    Power Steering Pressure Sensor Circuit Malfunction
    P0551
    P0552
    P0553
    P0554
    P0560
    System Voltage Malfunction
    P0561
    P0562
    System Voltage Low
    P0563
    System Voltage High
    P0565
    P0566
    P0567
    P0568
    P0569
    P0570
    P0571
    Cruise Control/Brake Switch A Circuit Malfunction
    P0572
    Cruise Control/Brake Switch A Circuit Low
    P0573
    P0574
    P0575
    P0576
    P0577
    P0578
    P0579
    P0580
    P0600
    P0601
    Internal Control Module Memory Check Sum Error
    P0602
    Control Module Programming Error
    P0603
    Internal Control Module Keep Alive Memory (KAM) Error
    P0604
    Internal Control Module Random Access Memory (RAM) Error
    P0605
    Internal Control Module Read Only Memory (ROM) Error
    P0606
    PCM Processor Fault
    P0608
    P0609
    P0620
    P0621
    Generator Lamp "L" Control Circuit Malfunction
    P0622
    Generator Field "F" Control Circuit Malfunction
    P0650
    Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654
    P0655
    P0656
    P0700
    P0701
    P0702
    P0703
    Torque Converter/Brake Switch B Circuit Malfunction
    P0704
    P0705
    Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706
    Transmission Range Sensor Circuit Range/Performance
    P0707
    P0708
    P0709
    P0710
    P0711
    Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712
    Transmission Fluid Temperature Sensor Circuit Low Input
    P0713
    Transmission Fluid Temperature Sensor Circuit High Input
    P0714
    P0715
    P0716
    Input/Turbine Speed Sensor Circuit Range/Performance
    P0717
    Input/Turbine Speed Sensor Circuit No Signal
    P0718
    P0719
    Torque Converter/Brake Switch B Circuit Low
    P0720
    P0721
    P0722
    Output Speed Sensor No Signal
    P0723
    P0724
    Torque Converter/Brake Switch B Circuit High
    P0725
    Engine Speed input Circuit Malfunction
    P0726
    P0727
    P0728
    P0730
    P0731
    Gear 1 Incorrect ratio
    P0732
    Gear 2 Incorrect ratio
    P0733
    Gear 3 Incorrect ratio
    P0734
    Gear 4 Incorrect ratio
    P0735
    P0736
    P0740
    Torque Converter Clutch Circuit Malfuction
    P0741
    Torque Converter Clutch Circuit Performance or Stuck Off
    P0742
    Torque Converter Clutch Circuit Stuck On
    P0743
    Torque Converter Clutch Circuit Electrical
    P0744
    P0745
    P0746
    P0747
    P0748
    Pressure Control Solenoid Electrical
    P0749
    P0750
    P0751
    Shift Solenoid A Performance or Stuck Off
    P0752
    Shift Solenoid A Stuck On
  15. 01-25-2004 01:29 PM #15
    P0753
    Shift Solenoid A Electrical
    P0754
    P0755
    P0756
    Shift Solenoid B Performance or Stuck Off
    P0757
    Shift Solenoid B Stuck On
    P0758
    Shift Solenoid B Electrical
    P0759
    P0760
    P0761
    P0762
    P0763
    P0764
    P0765
    P0766
    P0767
    P0768
    P0769
    P0770
    P0771
    P0772
    P0773
    P0774
    P0780
    Shift Malfunction
    P0781
    P0782
    P0783
    P0784
    P0785
    Shift/Timing Solenoid Malfunction
    P0786
    P0787
    P0788
    P0789
    P0790
    P0801
    P0803
    P0804
    P1106
    Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
    P1107
    Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
    P1108
    BARO to MAP signal circuit comparison too high
    P1111
    Intake Air Temperature (IAT) sensor intermittent high voltage
    P1112
    Intake Air Temperature (IAT) sensor intermittent low voltage
    P1114
    Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
    P1115
    Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
    P1121
    Throttle Position (TP) sensor inconsistent with MAF Sensor high voltage
    P1122
    Throttle Position (TP) sensor inconsistent with MAF Sensor low voltage
    P1133
    Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank)
    P1134
    Heated Oxygen Sensor (HO2S) transition time ratio bank 1 sensor 1 (Rear Bank)
    P1153
    Heated Oxygen Sensor (HO2S) insufficient switching bank 2 sensor 1 (Front Bank)
    P1154
    Heated Oxygen Sensor (HO2S) transition time ratio bank 2 sensor 1 (Front Bank)
    P1189
    Engine Oil Pressure Switch Circuit
    P1258
    Engine Metal Over Temperature Protection
    P1320
    Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses
    P1323
    Ignition Control (IC) Module 24x Reference Circuit low frequency
    P1350
    P1370
    Ignition Control (IC) Module 4x Reference too many pulses
    P1371
    Ignition Control (IC) Module 4x Reference too few pulses
    P1375
    Ignition Control (IC) Module 24x Reference High Voltage
    P1376
    P1377
    Ignition Control (IC) Module Cam Pulse to 4x Reference Pulse Comparison
    P1380
    EBTCM DTC Detected-Rough Data Unusable
    P1381
    Misfire Detected-No EBTCM/PCM Serial Data
    P1404
    Exhaust Gas Recirculation (EGR) Valve Pintle Stuck Open
    P1441
    Evaporative System Flow During Non-Purge
    P1483
    P1508
    Idle Air Control (IAC) System -Low RPM
    P1520
    Intake Manifold Runner Control (IMRC) circuit malfunction
    P1524
    Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range
    P1527
    Trans Range / Pressure Switch Comparison
    P1554
    Cruise Engaged Circuit High Voltage
    P1560
    Cruise Control System-Transaxle Not in Drive
    P1564
    Cruise Control System-Vehicle Acceleration too high
    P1566
    Cruise Control System-Engine RPM Too High
    P1567
    Cruise Control- ABCS Active
    P1570
    Cruise Control System - Traction Control Active
    P1571
    Traction Control System PWM Circuit No Frequency
    P1574
    EBTCM System- Stop Lamp Switch Circuit High Voltage
    P1575
    Extended Travel Brake Switch Circuit High Voltage
    P1579
    Park/Neutral to Drive/Reverse At high Throttle Angle
    P1599
    P1602
    Loss of EBTCM Serial Data
    P1603
    P1604
    P1605
    Loss of HVACC Serial Data
    P1610
    P1611
    P1617
    P1621
    PCM Memory Performance
    P1626
    Theft Deterrent System - Fuel Enable Circuit
    P1630
    Theft Deterrent - PCM in Learn Mode
    P1631
    Theft Deterrent - Password Incorrect
    P1632
    Theft Deterrent - Fuel Disabled
    P1633
    Ignition Supplement Power Circuit Low Voltage
    P1634
    Ignition 1 Power Circuit Low Voltage
    P1640
    Driver 1 - Input High Voltage
    P1641
    P1642
    P1644
    P1645
    EVAP Solenoid Output Circuit
    P1646
    EVAP Vent Valve Output Circuit
    P1650
    Driver 2 - Input High Voltage
    P1652
    Lift/Dive Circuit
    P1654
    Cruise Disable Output Circuit
    P1660
    Insets and Malfunction Reconfiguration Commands
    DME Version --> M1.x M1.x M3.1 M3.3 M3.3.1
    Malfunction MCU 1 MCU 2
    DME Control Unit 1211 2211 1211 1211 1211
    Air Mass/Volume Sensor 1215 2215 1215 1215 1215
    Throttle Potentiometer 1216 -- 1216 1216 1216
    Output Stage, Group #1 -- -- -- 1218 1218
    Output Stage, Group #2 -- -- -- 1219 1219
    EGO Sensor #1 1221 2221 1221 1221 1221
    EGO Sensor #2 -- -- -- 1212 --
    Lambda Control #1 1222 2222 1222 1222 1222
    Lambda Control #2 -- -- -- 1213 --
    Coolant Temp. Sensor 1223 -- 1223 1223 1223
    Intake Air Temp. Sensor 1224 -- 1224 1224 1224
    Knock Sensor #1 -- -- -- 1225 1225
    Knock Sensor #2 -- -- -- 1226 1226
    Knock Sensor #3 -- -- -- 1227 --
    Knock Sensor #4 -- -- -- 1228 --
    Battery Voltage/DME Main Relay 1231 2231 1231 1231 1231
    Throttle Idle Switch 1232 2232 -- -- --
    Throttle WOT Switch 1233 2233 -- -- --
    Speedometer "A" Signal -- -- -- 1234 1234
    A/C Compressor cut off -- -- -- 1237 1237
    A/C Compressor -- -- -- 1242 1242
    Crankshaft Pulse Sensor -- -- -- 1243 1243
    Camshaft Sensor -- -- -- 1244 1244
    Intervention, AEGS -- -- -- 1245 1245
    Ign. Secondary Monitor -- -- -- 1247 1247
    Fuel Injectors (group #1) 1251 2251 -- -- --
    Fuel Injectors (group #2) 1252 2252 -- -- --
    Fuel Injector #1 -- -- 1251 1251 1251
    Fuel Injector #2 -- -- 1252 1252 1252
    Fuel Injector #3 -- -- 1253 1253 1253
    Fuel Injector #4 -- -- 1254 1254 1254
    Fuel Injector #5 -- -- 1255 1255 1255
    Fuel Injector #6 -- -- 1256 1256 1256
    Fuel Injector #7 -- -- -- 1257 --
    Fuel Injector #8 -- -- -- 1258 --
    Fuel Pump Relay Control 1261 2261 1261 1261 1261
    Idle Speed Actuator 1262 -- 1262 1262 1262
    Purge Valve 1263 2263 1263 1263 1263
    EGO Heater 1264 2264 1264 1264 1264
    Fault Lamp (check engine) -- -- -- 1265 1265
    VANOS -- -- -- -- 1266
    Air Pump Relay Control -- -- -- 1267 1267
    Ignition Coil, #1 -- -- -- 1271 1271
    Ignition Coil, #2 -- -- -- 1272 1272
    Ignition Coil, #3 -- -- -- 1273 1273
    Ignition Coil, #4 -- -- -- 1274 1274
    Ignition Coil, #5 -- -- -- 1275 1275
    Ignition Coil, #6 -- -- -- 1276 1276
    Ignition Coil, #7 -- -- -- 1277 --
    Ignition Coil, #8 -- -- -- 1278 --
    Control Unit Memory Supply -- -- -- 1281 1281
    Fault (code) Memory -- -- -- 1282 1282
    Fuel Injector Output Stage, no cyl # -- -- 1283 1283 1283
    Knock Control Test Pulse -- -- -- 1286 1286
    No Failure 1444 2444 1444 1444 1444
    -2 No faults N/a N/a
    1/1/02 Fault in FI control unit FI module fault None
    1-1-3* Fuel trim (lambda control) too lean or rich Mixture incorrect; O2S wiring fault High fuel consumption
    1-2-1* Faulty signal to/from Air Mass Meter Wiring fault to or in AMM Various driving problems; fuel consumption
    1-2-3* Signal missing to/from coolant temp. sensor Wiring fault to or in ECT sensor Difficult to start engine when cold
    1/3/01 Ignition system RPM signal missing on starting Wiring fault or RPM sensor bad Engine will not start
    1/3/02 Battery voltage too low/high Poor battery or charging system No faults evident
    1/3/03 Throttle switch idle setting faulty or grounding fault TPS failure or maladjusted Above-normal idle speed
    2-1-2* Signal missing/faulty from oxygen sensor Wiring fault to heated O2S sensor High fuel consumption, driving problems
    2/1/03 Throttle switch full load setting faulty or grounding short Wiring fault to TPS or TPS failure No faults evident
    2-2-1* Fuel trim (lambda control) too lean at part load Lean; air leak; low fuel pressure; bad AMM Engine stops when starting from cold; high fuel use
    2/2/03 Signal missing to/from idle air control valve Circuit fault to IAC or faulty IAC valve Engine difficult to start; low idle speed
    2-3-1* Fuel trim (lambda control) too lean or too rich at part load }If too lean: air leaks, low fuel pressure, bad sensor }Engine stops when starting from cold; high fuel use or
    2-3-2* Fuel trim (lambda control) too lean or too rich at idle }If too rich: high fuel press., leaking injector } various driving problems
    3/1/01 Signal missing from speedometer Speedo wiring or instrument cluster wiring faulty Idling problems
    3/1/02 Signal missing for knock-related fuel enrichment Wiring break between EZK terminal 4 and FI #28 No faults evident
    3/2/02 Air Mass Meter wire burn-off signal absent or faulty Wiring break between FI terminal 8 and AMM #4 Various driving problems due to dirty AMM wire
    1/1/01 No fault detected N/a N/a
    1-4-2* Control module fault EZK ignition control module faulty Engine runs in limp-home mode
    1-4-3* Knock sensor signal absent or faulty Faulty wiring to/from/in the knock sensor Poor acceleration, low power, high fuel cons.
    1-4-4* No load signal from fuel injection system Faulty wiring from LH to EZK; bad LH module* Engine lacks power; stalls; doesn't start or is jerky
    1-5-4* EGR system flow too high Faulty EGR valve or controller, wiring; engine thermostat Engine idles unevenly
    2/1/04 RPM sensor signal absent intermittently Faulty RPM sensor, wiring or incorrect installation Engine will not start; runs rough; overheats
    2/2/04 Engine coolant temp (ECT) sensor signal absent or faulty Faulty wiring or ECT sensor No fault symptoms evident
    2/3/04 Throttle Position Switch (TPS) idle signal faulty Faulty wiring or TPS; TPS adjusted incorrectly Poor hot starting; poor idling; limp-home operation
    2-4-1* EGR system flow too low* Faulty wiring, EGR, EGR vacuum or controller; EGR temp sensor Poor idling
    4-1-3* EGR temperature sensor signal faulty or absent Faulty EGR temp sensor or wiring No fault symptoms evident
    3/3/04 Throttle Position Switch (TPS) in idle position (REX 1 only) Faulty wiring or TPS; TPS adjusted incorrectly
    1/1/01 No faults detected; speed has exceeded minimum 35 km/h
    1/1/02 Abnormal speed signal Possible static in speed signal to control
    1/2/02 No speed signal, or has not exceeded minimum 35 km/h Voltage feed (12V between terminals 10 & 11)
    Ground location (0 ohm between terminal 10 and ground)
    Speed signal
    Wiring in circuit (speedo to control unit; speedo to rear axle)
    With rear wheels raised and one rotating slowly,voltage at terminal 13 should oscillate 12V to +1.5V
    2/1/01 Voltage feed or cruise control unit malfunction Minimum 10.5 V at terminal 11
    2/1/02 Malfunction in the circuit to vacuum pump or regulator Test vacuum system first
    12 V between terminal 2 and ground
    12 V between terminal 10 and 11
    Ignition Off, selector On: Check wiring for resistance
    Brake light switch Depress brake pedal for one second 1/3/02 If no code: brake light circuit
    Selector ON and OFF, brake and clutch valve Depress brake then clutch pedal for one second 1/1/03 If no code: brake and clutch valve
    Selector RESUME Press RESUME for one second 1/2/03 If no code: resume button
    Selector SET Press SET for one second 1/3/01 If no code: set button
    Start inhibitor switch Shift transmission to NEUTRAL 2/2/03 If no code: start inhibitor switch
    If code 3-1-1 is reported during any test: 3/1/01 Several simultaneous signals: short in circuits
    11 Int. sensor open circuit, short or 12 Volt connection
    12 Inside temp. sensor open circuit, short or 12 Volt connection
    13 Evaporator sensor open circuit, short or 12 Volt connection
    14 Water temp. sensor open circuit, short or 12 Volt connection
    21 Left solar sensor open circuit, short to - or 12 Volt connection
    22 Righ solar sensor open circuit, short to - or 12 Volt connection
    31 Potentiometer or electric motor for left side air duct Open, short to 12V or to -, blocked motor
    32 id. for right side Open, short to 12V or to -, blocked motor
    33 Mode potentiometer or mode electric motor Open, short to 12V or to -, blocked motor
  16. 01-25-2004 01:30 PM #16
    Alright, that's all of it
    Happy Reading
  17. 01-25-2004 01:35 PM #17
    *** Communications Protocols Supported:
    Ford
    General Motors
    Chrysler
    Asian - Kia, Mazda, Mitsubishi, Nissan, Subaru, Infiniti, Honda, Acura, Lexus, Isuzu, Hyundai, Toyota PWM, Toyota ISO, SAEJ1850PWM,
    SAEJ1850VPW, ISO9141-2, ISO14230Fast Init,
    European - Mercedes-Benz, BMW, Porsche, Audi, Volkswagen, Volvo, Saab, SAEJ1850PWM, SAEJ1850VPW, ISO9141-2,
    ISO14230Fast Init, ISO14230Five Baud
    Please Remember: Unlisted vehicles all fall under one of the communications protocols. Just because you don't see it, don't assume it won't
    work. Usually, vehicles are manufactured by one of the above listed auto makers. For instance, Hummer™ Vehicles are made with parts from
    General Motors. Hummer would fall under General Motors, ect.
  18. 01-25-2004 01:36 PM #18
    O-M-F-G!!!!!!!!!!!!
    mod's can-we-make-this-STICKY?!!!!!!!!
  19. 01-25-2004 01:38 PM #19
    Quote, originally posted by nbrooke23 »
    O-M-F-G!!!!!!!!!!!!
    O-M-F-G What
    That ain't s***
  20. 01-25-2004 01:45 PM #20
    Anyone print this yet
  21. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    2006 GLI, 2008 Rabbit
    01-25-2004 01:49 PM #21
    Give 'em time. They had to get in the car and ride to Wal-Mart because you ran their printer out of ink.
    Ride In: 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
    Ride On: 2009 Fisher Wahoo Disc .:. 2010 Trek 2.1
    MkV Forun New User Information .:. MkV FAQ & DIY Guide
  22. 01-25-2004 01:51 PM #22
    You know what else I could post
    How about the entire BOM (Bill of Material) for the Golf and Jetta. Every single part and part number that makes the entire car up. Everything.
    But what the hell would you do with it?
  23. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-25-2004 01:52 PM #23
    Stare with a dazed look of stupor on my face. At least that's what I'd do. Is that more than 4000 Excel spreadsheet lines?
  24. 01-25-2004 01:54 PM #24
    93,283
    Can't do all of it in one day. Hell, only 20K characters at a time (that's all the forum allows)
  25. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    01-25-2004 01:56 PM #25
    This face can't even express it completely...
  26. Member Fantomasz's Avatar
    Aug 14th, 2001
    NJ/EU
    08 Golf
    01-25-2004 02:01 PM #26
    cool but these are not VAG codes
    vag dtc's have different numbers
    sorry for my english
  27. 01-25-2004 02:02 PM #27
    VAG?
  28. 01-25-2004 02:07 PM #28
    Actually, these codes are for ALL cars based on ISO. See the above list. The definition system is different for each manufacturer, BUT, the code is the same. Meaning your scan tool with translate. These are the internal ECM codes. Your scan tool will translate this code to the manufacturers/dealer code. Same thing though.
  29. 01-26-2004 02:59 AM #29
    so what do we use these for? imma noob!
  30. 01-26-2004 03:15 AM #30
    I'll post how to make a home made DTC scan tool with a simple laptop that has Hyperterminal on it (all versions of windows come with Hyperterminal, look under accessories/communications) and a few pieces of wire. I'll show you how to talk directly to your ECU via a laptop, with no software. Just a computer, and 3 pieces of 18 guage wire
  31. Member atoson's Avatar
    Dec 28th, 2002
    San Jose, Ca. South Bay Area
    00 GTI, 00 NB, 84 Scirocco, 80 Dasher
    01-26-2004 04:28 AM #31
    What about something like this.
  32. Senior Member Jman5000's Avatar
    Nov 8th, 1999
    Columbus Ohio
    VW & Audi
    01-26-2004 08:07 AM #32
    Having these codes is fine and good, but you really need a Bentley to tell you what to do to fix the problem that caused the code.
    One I run into: "Catalyst below threshold"...there's about 8 different things/systems that need checked (because any one of them could be it) to fix it.
  33. Forum Sponsor Uwe's Avatar
    Jan 16th, 2000
    Lansdale, PA
    Too Many
    01-26-2004 04:14 PM #33
    Quote »
    For all vehicles manufactured after 10/01/1988
    Someone has no clue. The only codes from that entire list that correspond to anything VW or Audi uses are the P0xxx codes, which are mandatory per the OBD-II regulations. Everything else in that list is optional (and not supported by VW/Audi) or manufacturer defined like the P1xxx codes. I don't know which manufacturer's P1xxx codes those are, but they are NOT VW's. If anyone wants a current list of standardized generic OBD-II codes, it's available for $59.00 from SAE:
    http://www.sae.org/servlets/pr...00204
    VW uses it's own proprietary codes for everything that isn't emissions related.
    -Uwe-
  34. 01-26-2004 04:47 PM #34
    nice
  35. 01-26-2004 05:31 PM #35
    missed one
Page 1 of 3 1 2 3 LastLast
