VWVortex.com - How-To: Throttle Body Alignment
    Page 2 of 2 FirstFirst 12
    Results 26 to 49 of 49
    Thread: How-To: Throttle Body Alignment
    1. Member hares1370's Avatar
      Sep 27th, 2009
      Greensboro North Carolina
      1997 jetta
      10-19-2010 06:23 PM #26
      ok ill try and remove the cable then try to adapt it. i remember having to adjust it because it idled high
    2. Member hares1370's Avatar
      Sep 27th, 2009
      1997 jetta
      10-23-2010 04:26 PM #27
      Quote Originally Posted by Dana @ Ross-Tech View Post
      Yes, that is a DBC engine so you would use the 098 procedure: Throttle Body Alignment (TBA)
      If 098 says Error, or Not Available you should have a fault code and the TB is not able to be calibrated. This can happen for several reasons, including the T cable is over adjusted, vehicle voltage is too low, the TB is dirty or faulty, the Ecm is faulty or the wiring is damaged.
      Please post the Auto-Scan from this vehicle.
      Friday,22,October,2010,17:04:09:49189
      VCDS Version: Release 10.6.1 (x64)
      Data version: 20100831
      Chassis Type: 1H - VW Golf/Vento III
      Scan: 01 02 03 08 12 15 25 41 56
      Address 01: Engine Labels: 021-906-259.lbl
      Part No: 021 906 259 K
      Component: MOTRONIC M5.9 HS V04
      Coding: 00000
      Shop #: WSC 00066
      VCID: 1D2CCF98BDC3
      5 Faults Found:
      16509 - Coolant Temperature Too Low for Closed Loop Fuel Control
      P0125 - 35-10 - - - Intermittent
      16885 - Vehicle Speed Sensor: Implausible Signal
      P0501 - 35-00 - -
      16684 - Random/Multiple Cylinder Misfire Detected
      P0300 - 35-10 - - - Intermittent
      16689 - Cylinder 5: Misfire Detected
      P0305 - 35-10 - - - Intermittent
      16686 - Cylinder 2: Misfire Detected
      P0302 - 35-10 - - - Intermittent
      Readiness: 0000 0100
      Address 15: Airbags Labels: 6N0-909-60x-VW2.lbl
      Part No: 6N0 909 603 D
      Component: AIRBAG VW2 V00
      Coding: 00068
      Shop #: WSC 00066
      VCID: 337809202B47
      2 Faults Found:
      00588 - Airbag Igniter; Driver Side (N95)
      32-10 - Resistance too High - Intermittent
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      End ---------------------------------------------------------------------
    3. 01-16-2011 02:06 PM #28
      Hey everyone,
      Total noob question but found this thread after an uber search.
      Have a wee 1997 Audi a3 1.6 petrol that is now idling at 2000 rpm after I cleaned the throttle body with carb cleaner. I don't see an iacv on this model.
      Would the above process have to be carried out after such a simple clean and is this high idle a likely symptom?
      Thanks
      Andy
    4. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      01-16-2011 05:14 PM #29
      That depends on the use of the mentioned Idle Stabilization Valve (ISV) -or- Throttle Body that's controlled by the Ecm. We didn't get the A3 until the newer 8P body and the 1.6 wasn't available in the US on the other (similar) models.
      Can you post the engine code?
      Dana Marie
      P.S. No Scan = No Soup
    5. 01-17-2011 03:55 AM #30
      Hi Dana,
      I will indeed when I get it, had to call it a day yesterday so they are driving the car with the higher idle for now.
      I had a good look for an ISV and couldnt see one on the TB housing, just the wire controlled butterfly part and a big plastic housing on the opposite side.
      When i was playing with the throttle and looking at the tb to see what was going on, i could feel it being pulled/clicked or moved by something, thats what led me here.
      Looking at wikipedia, its the following but ill get the exact code tonight.
      1.6 8v
      1,595 cc (97 cu in)
      AEH/AKL/APF
      101 PS (74 kW; 100 hp) @5600 rpm
      145 N·m (107 lb·ft) @3800 rpm
      1996–2000
      Thanks
      Andy
    6. 01-17-2011 06:29 PM #31
      Hey,
      Ok, tried to connect it to VAG-COM tonight but it wouldnt connect at all. I just wanted to even check for error codes for a start.
      The car is an 8L Audi A3, still dont know the engine code.
      I also took a few pictures to see if it helps to identify the engine but i see we cant upload them here, not too sure where to find the engine code as it isnt on the vehicle document.
      Where would i find the engine code of the car?
      ANy thoughts on not being able to connect?
      Regards
      Andy
    7. 01-17-2011 06:54 PM #32
      Okey dokey.
      Engine code is AEH010284
    8. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      01-17-2011 08:06 PM #33
      Hi,
      As per the repair manual this Ecm (Simos vendor) supports the TBA in group 098 as shown on the Wiki page for DBC engines.
      Cable-Throttle Engines
      What are the details about the VCDS system you're using? The Interface model (i.e. KEY-USB), VCDS software version and PC details would be helpful.
      Do any other installed control modules communicate with VCDS as listed here: Audi A3/S3 (8L) ?
      Dana Marie
    9. 01-18-2011 03:35 AM #34
      Hey Dana,
      Ok, so in theory this wee car should work.
      Its the basic connection thats not working, it just wont connect at all. Any time i try, the wee window in the top left babbles about baud rates etc etc.
      Not sure about versions Dana, its a skanky looking connector tbh.....in fact the USB connector is rusty
      Most certainly does not look like the £200 ones on your site, its transparent blue etc.
      Regarding the software, I think its 4.09.
      Its OOOOOOOOOOOLD but surely should do the job.
      Thanks
      A
    10. n00b
      Feb 4th, 2011
      Oregon
      2000 VW Jetta
      02-04-2011 08:46 PM #35
      I have a 2000 VW Jetta, 2.0 NON TD. I was just getting ready to spend the money to replace the throttle body but then I came across this forum. How do I know which adjustment to use and how do i do it?
    11. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02-06-2011 02:47 PM #36
      Quote Originally Posted by sdbiddle View Post
      If this is a US/Canadian 2000 Jetta 2.0L AEG engine code you would use the Cable-Throttle Engines procedure.
      If you aren't sure, post the complete Auto-Scan and we'll see what's installed.
      Dana Marie
    12. 10-13-2011 03:57 AM #37
      Hi, i have a 1997 VW Vento, 2.0 petrol AGG engine.
      What blocks do i need to perform TBA?
      Thanks
    13. 03-20-2012 02:10 PM #38
      Hi, I've been looking at your post about realligning the Throttle body (I changed my battery and it seems to have thrown out the allignment)
      Your post explained everything, except what tool I should use to do the job. what scan tool would you recommend? I don't have one, and would like to buy one, but I don't want to get one that won't work. Thanks
    14. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      03-20-2012 03:02 PM #39
      How about the company which sponsors this forum? That's the company that Dana works for, and the company which created with site in the link that you thanked Dana for posting. That company makes a tool....
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
    15. n00b
      Oct 30th, 2012
      Thompson CT
      2003 vw jetta 1.8t
      10-31-2012 10:44 PM #40
      I cannot manage to reset the throttle position even after the pedal was changed and removed the throttlebody and freed up the spring to close the throttle. should i just buy a brand new throttlebody or change the parts from an audi throttlebody i have? could it be the computer, because before i got the car the kid put an aftermarket exhaust on it and he ended up changing the front 02 sensor.
    16. Junior Member
      Sep 8th, 2012
      Sycamore, IL
      2012 A4
      11-03-2012 09:25 PM #41
      So here is the $ 64,000 question. How do we keep our cars running nicely like we had just done a TBA without constantly having to do a TBA?
    17. 11-03-2012 09:41 PM #42
      RTFB or find a professional.
      64K will get you some good service.
    18. n00b
      Mar 27th, 2013
      Colorado
      2003 vw jetta
      05-18-2013 12:33 PM #43
      Ive removed, cleaned and reinstallel mk4 2.0 2002 jetta throttle body and ecm,and tcm with no adaptation post cleaning and the car ran fine I did disconnect battery prior to cleaning throttle body and ecm and tcm with electrical contact cleaner ....so vagcom not nessasary!
    19. 05-18-2013 04:28 PM #44
      That I can tell you is a completely ignorant and incorrect assumption.
      RTFB says you need a scanner to ADP the TV anytime it is replaced or the battery is disconnected.
      When your trans grenades prematurely for poor learned angles or kick down.
      Please sir you come on back now ya hear?
      Post your scan later when you finally capitulate.
      Happy trails!
    20. 06-08-2014 08:36 PM #45
      Hi,
      Hi. I don't know if this thread is still active but i'll give it a try.
      I have just bought an audi a3 that seems to have throttle problems so I figured a tba should do the trick. I'm using a friends vcds which should be 4.09 registered on a win xp laptop. When we try to do a tba as per the instructions on channel 098 we get "bin. bit" in the two last boxes and nothing happened. What does this mean? Are we doing something wrong or is the tb busted?
    21. Member
      Apr 5th, 2010
      Blackheath, Sth London, UK
      '06 UK B6 BWA 3c0 SEL estate
      06-09-2014 01:59 PM #46
      If you post your Autoscan that'll tell what modules you have, their current settings, and if there's any fault codes stored
    22. Junior Member
      Dec 18th, 2000
      2013 Audi S4
      07-16-2014 03:24 PM #47
      I posted this over on the 2.8 12 v forum but figured would ask here as well.
      I have a VAG-COM and performed the steps for the TBA. All went well. Problem is, it doesn't seem to take hold. Every damn time I turn the key to the accessory position, I can hear the throttle body doing its little dance and performing an adaption which I don't think is normal. Anyone have any ideas as to why this is happening? Vehicle is a 98 GTI Vr6 by the way.
      Thanks for the help!
    23. Member
      Apr 5th, 2010
      07-17-2014 05:03 AM #48
    24. 05-07-2015 01:54 PM #49
      Noob here...proh'lems galore. '97 A6 2.8 stammers and shakes - particularly bad when placed in gear. Battery has been disconnected/reconnected. Throttle body has been off. Was trying to perform a TBA - to no avail.
      Address 01: Engine Labels: 8D0-906-266.lbl
      Part No: 8D0 906 266 B
      Component: 2,8l V6/2V MPI OBD2 D03
      Coding: 10242
      Shop #: WSC 02324
      VCID: 2B5542C8D90E5279EBD-5140
      No fault code found.
      Readiness: N/A
      Address 02: Auto Trans Labels: None
      Part No: 4A0 927 156 AL
      VCID: 70EF95A430A871A19EF-4A22
      2 Faults Found:
      00296 - Kick-Down Switch (F8)
      29-10 - Short to Ground - Intermittent
      00526 - Brake Light Switch (F)
      27-00 - Implausible Signal
      Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
      Part No: 4D0 907 379 L
      Component: ABS/EDS BOSCH 5 4171
      Shop #: BB 34171
      VCID: 377D6EB81546E6999F5-FFFF
      No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
      Address 08: Auto HVAC Labels: 4A0-820-043.lbl
      Part No: 4A0 820 043 K
      Component: Klima-Vollautomat D05
      Coding: 00162
      Shop #: WSC 02324
      VCID: 2149A0E0ABC28829411-257A
      Address 15: Airbags Labels: 8A0-959-655.lbl
      Part No: 8A0 959 655 D
      Component: Airbag V AUDI D01
      Coding: 00127
      Shop #: WSC 02324
      VCID: 346759B404300D81BA7-5210
      1 Fault Found:
      Address 17: Instruments Labels: 4Ax-919-03x-17.lbl
      Part No: 4A1 919 035 CN
      Component: C4-KOMBIINSTRUMENT D30
      Coding: 00262
      Shop #: WSC 06412
      VCID: 72EB9FAC3EA443B168B-1DEA
      No Faults Found
      Address 35: Centr. Locks Labels: 8D0-862-257.lbl
      Part No: 8LO 862 257 B
      Component: CV-Pump,Alarm, RC
      Coding: 12172
      Shop #: WSC 65535
      VCID: 53A53A28A1FE2AB983D-4ECE
      16 Faults Found:
      01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
      35-00 - -
      01371 - Alarm triggered by Door Contact Switch; Driver's Side
      35-00 - -
      01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
      35-00 - -
      01374 - Alarm triggered by Terminal 15
      35-00 - -
      01370 - Alarm triggered by Interior Monitoring
      35-00 - -
      01369 - Alarm triggered by Hood Switch
      35-00 - -
      01368 - Alarm triggered by Luggage Compartment Switch
      35-00 - -
      01373 - Alarm triggered by Radio Ground Contact
      35-00 - -
      01366 - Opened Due to Crash Signal
      35-00 - -
      01361 - Switch for Anti-Theft Alarm; Close
      29-00 - Short to Ground
      01360 - Switch for Anti-Theft Alarm; Open
      01362 - Close Switch for Tailgate/Trunk (F124)
      01363 - Switch for Central Locking; Driver's Door (F59)
      01364 - Switch for Central Locking; Passenger Door (F114)
      01365 - Lock/Unlock Switch; Interior
      28-00 - Short to Plus
      End-------------------------(Elapsed Time: 02:00)--------------------------
