VWVortex.com - How to fix a broken headlight adjuster?
    Results 1 to 12 of 12
    Thread: How to fix a broken headlight adjuster?
    1. 02-09-2004 06:45 PM #1
      My passenger headlight fine, but drivers won't go up even though being turned. any help
    2. 02-10-2004 03:28 AM #2
      nevermind i fixed it.....the ball joint popped out of the adjusting cup.
    3. 02-11-2004 07:33 AM #3
      that same problem left me boggled for days...stupid ball joint
    4. 04-11-2004 04:30 AM #4
      anyone got a pic of this?? tia!
    5. 04-12-2004 05:28 PM #5
      bump! i would love to know how this ball joint look like since its been a few months that ive been trying to fix this thing w/o any luck...pls. somebody post a pic of this..thanks!
    6. 04-13-2004 12:26 AM #6
      sorry don't have a digital camera.....but the way i put the ball back in the little cup was to tie a little string around the cup and put up on it towards the ball...you have to use alot of force to pop it back in, but when you do you'll know
      ps----by the way it took two people to do this, one to hold the housing (removed whole thing from car) and me to pop the ball back into the cup
      hope this helps, good luck
      Feb 16th, 2003
      Binghamton, NY
      2012 PB TTRS
      05-19-2004 10:18 PM #7
      Wow...I had the same thing happen to me. It took a while before I figured out what even happened. I left the headlight in the car. I was able to extend the ball out as far as it goes, and then using the string method (before I even read this post...great minds think alike) I was able to snap it back in place. But when I went to adjust the headlight, it popped back out of the socket again.
      I'm afraid that the socket may be broken, but it seems unlikely considering the force needed to put the ball in. The "pop" also led me to believe it was well-seated. I wonder if the assemble was "caught" on something, thus prohibiting it from adjusting freely. Any ideas?
      2012 Phantom Black TTRS (Tech Pack, Sport Exhaust Titanium Pack, Heated Seats)
      2017 Rhodium Silver Jaguar F-Pace
    8. 05-20-2004 02:58 AM #8
      just make sure your not going to the very extreme of the adjustment....what i did when i adjusted to make sure i went the opposite direction when i popped it out of the socket...then to do a adjust the lights according....using some electrical tape and my friends garage door. Search the net for this
      Feb 16th, 2003
      Binghamton, NY
      2012 PB TTRS
      05-20-2004 07:31 PM #9
      I let the dealer take care of it. Gotta love the warranty.
    10. Member Lams's Avatar
      Jun 16th, 2003
      Brisbane Australia
      07 Eos 07 Caddy Camper 76 Bug 56 Bug
      05-20-2004 07:57 PM #10
      an easy way I found of doing this is open the back cover, and take out the turn signal bulb. then shove your fingers in the turn signal hole and pull it until it the ball joint pops back into the cup!
    11. Member
      Feb 16th, 2003
      Binghamton, NY
      2012 PB TTRS
      05-22-2004 10:43 AM #11
      That's a cool idea. The dealer actually took my bumper off, removed the headlight unit, and replaced the adjuster ball. At least that's what they say.
      Nov 7th, 2008
      Stamford, CT
      2001 (AWD engine) GTI :: 2011 Shadow Blue GTI
      03-18-2011 04:35 PM #12
      Quote Originally Posted by Lams View Post
      I own you a beer.....was getting pissed and sore hands. This worked with it set all the wayone direction and pulling inside the light along with needlenose on the studry part of the plastic piece...tried string on my own, took off shoe and unlaced and pulled hard...it kept slipping. Turn + needlenose ftw )
