| Quote, originally posted by Andy@Ross-Tech.com » |
| The answer is in the link I posted. |
Hi Andy. According to your comments, my first value, additive is in spec, pointing away from a vacuum leak. The multi is out of spec, and that would point to bad MAF.
My symptoms are lack of boost, and loss of break assist when cold. While running with a bad MAF would make me think it's not got the power it once had and a bad MAF, it's the second symptom that has me guessing.
I took it in twice, and both times they said there is no vacuum leak. However, the guy at the desk could never tell me how they figured that out, and I think he was looking for a fault code (which I had recently cleared).
I think I'm just going to take it into the VW dealership in town, and have them replace all the rubber vacuum lines ($150), and a new MAF ($300). Unfortunately, a vacuum leak when that only shows during cold may not clearly show in diagnostics? Am I wrong? But, the multi reading makes me think your right about the MAF. And, hopefully, doing both will solve things.
However, if I have no power assist after, I could have a vacuum leak in a more expensive place?
I would love to try to clean the MAF and see if that solves it, it's cheaper, but it's been months now and I haven't found the time to do it! I'm pushing 90k on my little GTI now, and don't want to let this go too long because I'd love to see another 90k!
Once I've fixed this, I'm going to GAIC chip it, and Bailey Motorsport Alloy Diverter Valve. I've held off on that soo long waiting to diagnose this...
Thanks for the tips, let me know if there is anything else you can think of.
Modified by BadlandZ at 5:21 PM 5-24-2004
