Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 129
Thread: DIY Addition: Jti/Jolf Getta Swap Step By Step
  1. 03-05-2004 03:56 PM #1
    EDIT: Pictures are currently down (I closed account on my server). If you want them, send me a pm.
    My little addition. If you see any errors post and I will edit them. It has been like 4-5 months since I did the swap, but I think I got everything down perfectly.
    Since everyone has been posting asking how to do the front-end swap for a while, I decided to get up and type something up quickly for you guys/gals. What I have noticed with previous write ups (found this out first hand) is a lot of them provide correct information, but do not give the important details. So I tried to cover everything in this:
    Step 1: Remove the hood
    What you want to do first is simply open the hood. On the far left side you will see plumbing going into the hood for the window washer unit. Pop the rubber cap off and give this a little pull. Next disconnect the sprayers (Pull down from the hood, will pop off with some force) and disconnect the hosing (Warning: if yours have headed nozzles like mine did, we simply cut the wires and reattached them later on. If you have a better way to do it, be my guest). Once the washer units are disconnected it should slide right out of the hood.
    Then simply remove the 4 bolts (13mm) holding the hood on (two on the left, two on the right) and remove the arms on the right that props the hood open (will be a bolt on the top holding it to the hood).
    Step 2: Removing fender lining
    Like the hood, this is another easy removal process (we recommend removing the front wheels to make this step easier). The fender lining is the plastic liner under the fender which keeps dirt from entering the bay. Holding this on is 12 t25 torx bolts holding this on (on each side, 24 total) which can be easily removed. One off the fender liner should simple slide right out.
    Once the fender liners are off you can easily remove the side markers which release by popping them in. I also recommend not removing the turn signals which you remove by pushing the corner in, sliding it forward and it should pop right out. Simply remove the plug from the back and lay these somewhere.
    Step 3: Removing the front grill
    This was most likely the least written about subject and one that gave me the most problems. In order to remove the grill you must snap it out of place (do not be afraid of breaking it).
    On the top left and right of the grill are 4 snaps. Simple pry them off and it will snap lose, same goes for the bottom snaps. Now in order to remove pull tab for the hood (when you pop your hood, the little handle pops out to open the hood)… at the end of the tab (part connected to the actual mech.) you will see a metal clip, pry the clip back and then pull the tab off the two plastic prongs (may take a few tries. we found it best to remove by putting a piece of metal like a small wrench in between the two connectors and turning it to an angle to pry it apart. May take a few minutes to get it off).
    After you do that the grill will slide right off.
    Step 4: Removing the front bumper
    The front bumper is pretty simple to remove. It is held on by 5 bolts found where the grill used to be and 2 bolts found on the bottom of the bumper where the plastic inserts are (located on the outside inserts, no need to remove middle insert). To remove the plastic inserts simply pry the top down until it snaps off. After the bolts are removed the bumper should slide right out.
    Step 5: Removing the lights
    To remove the lights there will be 2 bolts on the top and 1 on the bottom (I cant remember if there are others because I did not do the lights, Kenny did, but I remember there only being 3). The lights should slide right out with ease.
    Step 6: Removing the fenders
    This is the hardest and most time consuming part… Holding the fender on will be 4 10mm bolts on the top of the engine bay where the hood used to rest, 4 bolts behind the bumpers, and 4 inside the wheel well where the fender liner covered.
    The bolts in the wheel well will give you the most trouble. Covering these 4 bolts is a hard dried compound of undercoating which has to first be removed. The most talked about method is heating it up with a hair dyer and then scraping it off. But we decided to just chisel it off (high highly recommended, because it’s fastest and who cares since its all covered by a liner anyways). To chisel it off we used a screwdriver and a hammer. Rest is self-explanatory.
    Step 7: Installation
    Once you have done this to two cars it gets rather easy. So in order to put the car back together you simply reverse the steps. Save the fenders, this is the most time consuming step. Most of the pieces such as the fender, bumper, and hood have to be lined up so it all matches, which tends to be a 2 person job. And we recommend placing some fabric where the hood used to be for when you reinstall it or you may chip a lot of paint.
    Step 8: Enjoy, take pictures
    Unfortunately, every site out there which told you how to do the swap either told it incorrectly or left out major key notes. Hopefully this helps you get it done fast and not become the 5 hour job from hell which it became for me.
    Modified by the six at 4:34 PM 8-27-2004
  2. 03-05-2004 04:00 PM #2
    Ohh yeah, as a little side note post. Last night while driving home I hit a deer... full thread I made is here: http://forums.vwvortex.com/zerothread?id=1274051
    But to summarize, I wad cruising, saw a bunch of deer and pretty much swerved hard into the center grassy area to save my front end. I inturn got the side of my vw rammed and left with a dented door, destroyed side mirror and my window has problems rolling down.
    But my front end is safe. All that matters.
  3. 03-05-2004 05:24 PM #3
    Sweet THANKS!!!!
  4. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    2006 GLI, 2008 Rabbit
    03-05-2004 08:04 PM #4
    Quote, originally posted by the six »
    Gotta love it. At least you are okay, and it seems that your spirits are good about it. I guess you really like your new front end.
    Nothing insults the common man more than infringing on his right to be a dumbass. - PassSedanGLX
    Ride In: 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
    Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    MkV Forum New User Information .:. MkV FAQ & DIY Guide
  5. 03-05-2004 08:24 PM #5
    MUCH appreciated post THANXS!!!
  6. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    West Palm Beach, Florida
    1971 Super Beetle, 2010 Golf TDI, 2012 Jetta TDI
    03-05-2004 09:10 PM #6
    Thanks a lot PERFECT just what we needed
  7. 03-05-2004 09:30 PM #7
    Another great guide, I love a well written DIY!
    Hope the damage from the deer is an easy fix
  8. 03-06-2004 12:31 AM #8
    Thanks so much for this informative "how to" post. I will let you know how mine goes in a week or so. The colors are the same as well. Thanks again!
  9. Member 03rabbitgti's Avatar
    Jun 16th, 2003
    New York, NY
    MKIV R32 - MKIII VR6 GTI Ongoing Endless Project!!
    03-06-2004 12:35 AM #9
    awesome....cant wait
  10. 03-06-2004 02:14 PM #10
    this should got into the mkiv faq
  11. 03-06-2004 02:28 PM #11
    I sent a message to tatge and he said he will add it tomorrow.
  12. 03-10-2004 10:20 PM #12
    One quick question, what tools do you need, are there any special tools you need ? Thanks again for this post.
  13. 03-12-2004 07:05 AM #13
    i heard some place that you have to change the wiring as well, can you show some pics for that too or is it pretty simple?
  14. 03-14-2004 12:59 AM #14
    i hear dfenders need moding is that bull?
  15. 03-14-2004 01:04 AM #15
    Quote, originally posted by VRtripleSIX »
    Nothing on the car needs any modification. It's a straight unbolt, bolt back affair.
  16. 03-14-2004 01:11 AM #16
  17. 03-14-2004 01:13 AM #17
    very nice
  18. 03-17-2004 08:34 PM #18
    sweat
  19. Member 18TVeedubber's Avatar
    Feb 10th, 2003
    Franklin Park, NJ
    2006 Accord Coupe V6 / 2011 Honda Pliot Touring / 2012 Acura TSX Wagon
    03-17-2004 08:44 PM #19
    wow.. silver gettas are soo hot.. nice job dude
  20. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    04-15-2004 12:41 AM #20
  21. 05-02-2004 03:40 PM #21
    Question, after you do the conversion do you have to buy a jetta front bumper for your golf?
  22. 05-04-2004 07:02 PM #22
    Did the conversion a while back..its super easy literaly just swap the parts around. For the "stuff" on the fenders heat gun and gental pulling worked for me.
  23. 05-04-2004 07:06 PM #23
    yay
  24. 05-10-2004 12:10 AM #24
    So if we want instead of the stock bumper we can just install any front bumper that fits a Jetta such as a projektzwo?
  25. 05-10-2004 12:21 AM #25
    Quote, originally posted by KFKMF »
    correct!
  26. Member GTI 3 3 HEAVEN's Avatar
    Jul 6th, 2003
    Baltimore 410
    05-13-2004 08:22 PM #26
    good work nice write up
  27. Member Sputterputz's Avatar
    Mar 19th, 2004
    Chattanooga
    1962 DC, 03 GTI-D, 1986 Golf 24v Swap
    05-21-2004 08:05 PM #27
    SO instead of using a stock golf bumper I am thinking a rieger rs rx any complications forseen?
    TNEUROS Home for all TN EURO enthusiast
    Mk2 24v Westy "24 Karat" Just a grocery getter, with alittle growl.. FS thread!!
  28. 06-06-2004 07:41 PM #28
    To have it professionally done.......How long do you think????
  29. 06-06-2004 07:43 PM #29
  30. 06-12-2004 03:21 AM #30
    awsome
  31. Senior Member Ducky 2.0T's Avatar
    Jun 4th, 2001
    Oaks, PA
    Japanese Toaster
    06-12-2004 04:06 AM #31
    Quote, originally posted by QVB20L8V »
    do it yourself.. But a 2-3 person pro team can do it in under 2 hours..
    Key points to note..
    DON'T DROP BOLTS IN THE ENGINE BAY
    Also the hood is def a two person job.. one to hold it and one to tighten..
    The undercoating can also be sliced with an exacto knife (but we used a torch...)
    Be careful with the hood latch pin, one was broken when we did it..
    and make sure that you have a pad somewhere to set the parts on, so they don't get scratched on the edges..
    i swapped 2.5 years ago and havent looked back
    Also make sure you have lots of
    Modified by DuckyGTI at 4:11 AM 6-12-2004
  32. 06-12-2004 04:16 AM #32
    good stuff
  33. 06-13-2004 12:56 PM #33
    what happens to the lights in the fenders on the jetta. how are they plugged in?
  34. Senior Member Ducky 2.0T's Avatar
    Jun 4th, 2001
    Oaks, PA
    Japanese Toaster
    06-13-2004 12:59 PM #34
    Quote, originally posted by klukfam »
    they snap in just like they do on the GTI
  35. 06-13-2004 01:28 PM #35
    nice, always had a soft spot for jolfs and gettas
