thank you!
does anyone know the specs (measurement, flow specs, filter specs) on the oem unit? i want to see if K&N has an improved version of the OEM.
#1
Did mine today on a 2000 Jetta VR6 @ 50,000mi. Bought the car last month, so I figured I'd start with some general maintenance.Edit: in case this wasn't already clear, this DIY works with all MKIV golfs and jettas
Really, it's as easy as everyone says. It took me about a half hour, because I was running back and forth between the car and the computer
I took some photos because it's not completely clear what everything looks like, and I know some people have problems getting those lines off the original filter.
needed:
7mm socket/wrench
new fuel filter (1J0201511A)
wd40
container for spillage.1) The fuel filter is located right in front of the passenger side rear wheel.
2) I removed the fuse #28, turned on the car, and let the car stall. Then I removed the gas cap to relieve pressure in the fuel lines.
3) Fuel filter is held in place by a bracket. Mine was rusted shut so I sprayed it with some WD40 and waited for a while. The screwdriver started stripping, so I went with the wrench/7mm socket.
4) after removing the bracket, the filter can hang a bit lower for you to get at the clips. You press a small button at the very edge of the clip - the filter should come right off at that point. There's a black strap that's attached to the filter that will come off with it. Remove it and put it on your new filter.
Reference this DIY for a simple method for removing the clips without breaking them.
Edit:^^^ the link above has better photos of the clips!
5) Reverse the steps (make sure the flow is going the right way. arrow should point to the front of the car, and you're set! replace the gas cap and start her up! Took a try or two before the engine would start w/o stalling.
6) check for leaks
Disclaimer: Use this guide at your own risk, I am not responsible for any injuries/deaths or damages to your car! Take it slow and be careful!
Hope this helped.
Modified by alchu at 8:12 AM 3-26-2008
#2
thank you!
#3
Great write up![]()
#5
Great write up--Did mine on Wed. not very hard![]()
#6
Great job. It's nice to see someone else post DIYs for a change.![]()
Gary
#7
Great writeup! One tip to add--take the FRONT hose off of the filter first, then tilt the filter down to let as much gas drain out of it as possible before taking off the rear hose. The rear hose clip is much easier to get to, but if you do it first then the filter will start draining all over the place while you wrestle with the front hose clip. Ask how I know![]()
#8
hmm, I did that without thinking. actually seemed easier to do the front clip over the one in the back. I didn't really know where the button was, so I was sort of feeling by hand. found it, pressed it in, and got a face full of gas. not that much came out, but whatever amount did, I got it full in the face. I let the filter hang down and drain while I went inside and flushed my eyes a bit. heh. be careful!!I _was_ a bit surprised by all the dirty fuel that came out of the filter, though. not sure if the dirt came after I opened the back end and drained from there too, or if my filter wasn't filtering properly anymore.
Anyhow, glad I did it. I'll probably do it every 15 or 20k miles.
Modified by alchu at 12:15 PM 3-10-2004
#9
thaks this will help!
#10
hey how do you know when its time to change them?
#11
VW says never, but I think most people agree to change them every 15 or 20k miles. It's easy and cheap enough to do it every 3rd or 4th oil change, I think.
#12
Really nice write up!I couldn't figure out how to pull those clips off until I read your post.
That little button is hard to find when your under the car.
Thanks,
#14
great write up!
#15
Quote, originally posted by jddaigle » One tip to add--take the FRONT hose off of the filter first, then tilt the filter down to let as much gas drain out of it as possible before taking off the rear hose. Nice you beat me to it. Just be careful when you take off the front line it will spray a bit like when you open a can of soda.But you don't have to unplug the fuse or open the gas cap. Its not nessasary. Just a waste of time
#16
I just did mine a few days ago... really easy to do.
#17
Nicely done![]()
Thanks I need to do this ASAP![]()
#18
Quote, originally posted by CorradoG60 » Nice you beat me to it. Just be careful when you take off the front line it will spray a bit like when you open a can of soda.But you don't have to unplug the fuse or open the gas cap. Its not nessasary. Just a waste of time
maybe. I did and it _hopefully_ got some of the fuel out of the lines, and lowered the amount of gas pressure. at most it's a waste of 45 seconds, so I don't mind that I did it.
Sorry about the pictures, the server crashed not long ago.
#19
Great info...![]()
#20
A useful post.![]()
to you sir. Nice camera shots too.
#21
Nice something to keep in mind in the future![]()
#22
Does anyone know if pulling the fuse and stalling the car does any kind of damage? I'm doing this this weekend and want to know before I get into it. Certainly it would be a good idea to relieve pressure before getting under there and removing lines. TIA
#23
sorry but what is this? and is the fuel line a particular color?
#24
The fuel line looks like any other hose down there. Black, grimy.
That's the little plug that clips the hose to the filter. There's one on each side. The circled area is the rectangular button/clip that you press in to release the hose from the filter.
#25
Good, practical writeup.![]()
Oh and by the way...250th post!
#26
nice diy, I think I will replace mine I am at 27000 miles probably should change the filter![]()
#27
Quote, originally posted by rmbalisa » sorry but what is this? and is the fuel line a particular color?
Quote, originally posted by alchu » after removing the bracket, the filter can hang a bit lower for you to get at the clips. You press a small button at the very edge of the clip - the filter should come right off at that point. There's a black strap that's attached to the filter that will come off with it. Remove it and put it on your new filter. The fuel line is the one going in to the filter.
#28
#29
Is the Filter the same for both VR and 1.8? The invoice order sais 1.8t on it, but Im sure I told the guy I have a VR......So it is better to remove the clips/lines first...... before loosening the filter bracket?
#30
I believe it's the same regardless of engine.I think it's easier to release the bracket FIRST then unclip the filter...
#31
mine was pretty dirty![]()
#33
Damn! What did you use to open it? I replaced mine not too long ago. Actually, Oscar did it for me b/c I couldnt unclip the hose. He did for free the day he replaced my MC.
#34
hacksaw![]()
#35
man it was a pain getting that filter out from behind all those lines.the clamp was hard to get back on too, but yay, my car starts and idles nice n smooth now
