VWVortex.com - How to drive an AUTO/MANUAL Transmission
    The Car Lounge
    Results 1 to 24 of 24
    Thread: How to drive an AUTO/MANUAL Transmission
    1. Member Quattro80's Avatar
      Apr 6th, 1999
      Toronto, ON
      1992 Mercedes-Benz 300E
      03-13-2004 09:22 AM #1
      Ok, I did a search, but I couldn't find anything so I need the forum's help regarding a question I have:
      Basically, my friend picked up her Mazda 3 earlier this week, she ordered it with an Auto/Manual (Tiptronic style) Transmission. When I went to drive it, I considered it to be like a manual transmission car: + to upshift, - to downshift. When I started driving and wanted to increase the gear from 1-2, I tipped it to +, and the car downshifted to 1!
      Does Mazda have it reversed?! Does Volkswagen's Tiptronic behave in a similar fashion!?
      Thanks!
      Modified by Quattro80 at 7:52 AM 3-13-2004
    2. Member MGQ's Avatar
      Apr 16th, 2002
      The City (:-l)
      Fusion Hybrid
      03-13-2004 09:29 AM #2
      Umm I dont' know what you are saying, you were in first, pushed +, and the car downshifted into first?
      you were already in first it couldn't downshift no matter what button you pushed!?
    3. Member Quattro80's Avatar
      Apr 6th, 1999
      Toronto, ON
      03-13-2004 09:57 AM #3
      I see what you're saying... this is what I believe happened:
      I pushed the car to the limit, the CPU must have automatically shifted to 2 just to be on the safe side... I didn't notice this, so when I tipped it to + to go to a higher gear (expecting to go to 2), it DID downshift to one and the engine revved. It was VERY odd.
      But to simplify matters, we'll go with this scenario:
      I'm in 3rd using the Auto/Manual. I want to shift up to 4, but when I tip it in +, it goes down to 2. Is this normal!?
      I think it should be the other way around, where + is to UPSHIFT to a HIGHER gear, and - is to DOWNSHIFT to a LOWER gear.
    4. Senior Member
      Mar 24th, 2001
      03-13-2004 10:03 AM #4
      Read the instructions in the owner's manual. Automatic transmissions can be very complex to operate properly, compared to manual transmissions. Even the non-Tiptronic VW automatic transmission requires about five pages of owner's manual instructions, compared to half a page for the VW manual transmission.
    5. Member Quattro80's Avatar
      Apr 6th, 1999
      Toronto, ON
      03-13-2004 10:14 AM #5
      tjl:
      I don't need to read the manual, its not my car. Further, I have discovered HOW Mazda's transmission in the 3 works, and was driving in the auto/manual mode quite well, again, once I discovered how to upshift and downshift in the Mazda 3:
      + to lower a gear
      - to raise a gear
      The question posed by me, which is clear in my posts above are the following:
      For a car equipped with an Auto/Manual type of transmission, ANY Auto/Manual vehicle, shouldn't it be:
      + to increase a gear
      - to lower a gear
      Do any automakers have the transmission programed in a way that:
      + upshifts
      - downshifts
      Thanks.
      Modified by Quattro80 at 7:15 AM 3-13-2004
    6. 03-13-2004 10:56 AM #6
      Having driven a couple of those "manumatics", I'll contribute this ...
      They usually work best when you slap it in "D" and fuggedaboutit. The thing is an automatic transmission masquerading as something else; let it do its thing.
    7. 03-13-2004 11:04 AM #7
      I have a Mazda 3 with the manumatic and to go up a gear, you pull the lever down (towards the back of the car) - so to go from 1 to 2 you pull the lever down. I don't know if that's considered + or -.
      2016 GTI SE Performance Pack
      2013 Tig SEL
    8. 03-13-2004 11:59 AM #8
      Here's a pic to clarify the Mazda3 setup. Yes, pull back to upshift. Yes, pulling back is towards the + and pushing forward is -
    9. 03-13-2004 12:23 PM #9
      yah that is what he thought to, but he got the opposite results. He said, + is in fact downshift (correct me if I am wrong) ...
    10. 03-13-2004 12:39 PM #10
      Quote, originally posted by prana »
      You're right, that is what he said (my great reading skills ).
      Not sure why that would happen
    11. Member Quattro80's Avatar
      Apr 6th, 1999
      Toronto, ON
      03-13-2004 12:51 PM #11
      Oh man I'm such a loser!
      When I drove the car, it was at 10:00pm and it was dark in the car... I never noticed that the + or - was imprinted in the plastic around the shifter!
      Having driven my friend's Passat, I figured the Mazda 3 would be the same as the Tiptronic where + would be by shifting the transmission knob up and - by pulling it towards you.
      I hate Mazda's setup.
    12. 03-13-2004 12:51 PM #12
      ahh dat explains it
    13. 03-13-2004 01:00 PM #13
      not sure why some car companies switch it around. My Mazda 6 is pull back to upshift, my dad's Acura TL is push up to upshift. I think BMW's system is like mazda's too.
    14. 03-13-2004 02:40 PM #14
      HURRAH, there is a "sequential shifter" that has the shift pattern the correct way around, in production!! I thought they were all backward. Here's the exception that has it the right way, and congrats to Mazda for doing it right.
      Take a look at World Rally cars. Sequential shifters always are pull-back-to-upshift, push-forward-to-downshift. It's the ergonomically correct direction ... Same "sense" as the accelerator pedal ... If you want more forward thrust, move control lever forward; if you want less forward thrust, move control lrver backward.
      The "wrong" direction became imprinted because it's the same sense as the usual P-R-N-D-L shifter - an arrangement that was never intended to cater to enthusiasts.
    15. 03-13-2004 03:35 PM #15
      Yeah, I have to agree.
      Pulling back to upshift is more intuitive for me too. On our Honda, you have to push forward. It felt unnatural at first, but you quickly get used to it.
      I guess it would really get confusing if you had two cars with opposite setups
    16. Geriatric Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      03-13-2004 03:53 PM #16
      Quote, originally posted by Quattro80 »
      Well the tip in our Jetta shifts at redline. I hope that's not the case with your friend's car because that means you are ragging on your friend's new, unbroken-in car.
    17. Geriatric Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      03-13-2004 03:54 PM #17
      Funny, since you obviously didn't know what you were doing.
      With the Jetta, you push forward to shift up and pull back to shift down.
      Modified by Hostile at 3:56 PM 3-13-2004
    18. Senior Member
      Feb 16th, 1999
      03-13-2004 04:32 PM #18
      Only Mazda and BMW use system that push up for downshifts and pull down for upshifts.
    19. 03-15-2004 03:34 PM #19
      My wife has a Jetta with thip and I have a Mazda 3s with manumatic - I get screwed up all the time because the patterns are opposite. I've actually stopped using this feature in the Jetta because I hate how it works - pushing forward to upshift just doesn't make sense to me.
      2013 Tig SEL
    20. Member
      Dec 5th, 2003
      KC
      2005 Nissan Altima
      03-15-2004 03:51 PM #20
      I just test drove one last saturday: + to upshift, - to downshift
    21. Geriatric Member Obin Robinson's Avatar
      Oct 20th, 2000
      Jacksonville, Florida
      2002 Carrera, 2012 Kia Soul
      03-15-2004 03:52 PM #21
      Quote, originally posted by GoFaster »
      with Hewland sequentials, used in CART, rally, and sportscar... you push FORWARD to downshift and pull BACK to upshift
      obin
    22. 03-15-2004 04:13 PM #22
      I have gotten confused simply READING this thread ...
    23. 03-15-2004 08:31 PM #23
      i think for japanese cars that are made in japan (mazda 3) has to be pulling back for upshift, just like the japanese car games i play in the arcade
      TL on the other hand..is not made in japan, maybe thats why is the other way around..
      another example: mr2 spyder
    24. Geriatric Member Obin Robinson's Avatar
      Oct 20th, 2000
      03-15-2004 09:05 PM #24
      so far... this thread pretty much has already thrown down the proof that "manu-matics" with their "F1-inspired transmissions" are NOTHING more than a stupid gimmick.
      instead of a + and -, they should be labeled with David Hannum's famous saying:
      "there's a sucker born every minute"
      obin
