Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 71 to 105 of 300
Thread: FAQ - Carbs
  1. 10-07-2006 02:55 PM #71
    hey i have a golf mk 2 1.6 driver 1991! im looking at geting the most out of the engine and i have been told to go for a twin weber 45 carb! but i dont have a clue and i dont no if it will even fit! so does any one have any ideas? cheers gareth
    Aug 13th, 2006
    Franklin MA
    10-17-2006 10:28 PM #72
    A MSD box will hook up to a magnetic pick up distributor, but what about the hall effect senders in VW distributors? Anyone able to do this without using the stock ECM or Ign. control unit?
    Audi & VW Service
    http://fourwardmotors.com
  3. 10-17-2006 11:06 PM #73
    you need the ICM to boost the signal from the hall effect, it is an amplifier.
  4. Member
    Aug 13th, 2006
    Franklin MA
    10-18-2006 08:27 PM #74
    Thanks for the info. I have a 91 and am trying to eliminate the Motronic harness and ECM. Do any years have ICM's that plug directly into the distributor? I want to keep it as simple as possible.
    Audi & VW Service
  5. 10-27-2006 12:17 AM #75
    buy this here($61): http://store.summitracing.com/...w=sku
    Quote, originally posted by the12for12 »
    We ONLY use the Carter Rotary pumps. They are High Volume (60-70 GPH) but only 4 psi. This is PERFECT for all Weber applications from a Single 32/36 DGV on a Truck, Jeep or Car to a Triple Sidedraft setup on a Road Race car making 300 HP...This pump DOES NOT and SHOULD NOT use a Pressure Regulator for any reason. That is why we use it....
    Carter 4070 Fuel pump with Mounting Bracket
  6. 11-12-2006 09:20 PM #76
    ABF water outlet part number
    037 121 132 j
    water outlet on front of head that gets in the way
    I've got a lovely bunch of coconuts...
  7. Member mark memory's Avatar
    May 12th, 2005
    98 Jetta TDI
    12-05-2006 07:55 PM #77
    What other carbs can be used? Some mikunis or delltoros? And what size? Should they be around the 40-45mm range and side drafts?
  8. 12-14-2006 04:20 PM #78
    Quote, originally posted by mark memory »
    16v's require sidedrafts, 8v's require downdrafts. typical carbs used on VW's are either Weber's or Dellorto's. a lot of people reccommend the Webers because you can still get parts for them, and I would agree with that statement. I haven't seen any carbs much bigger than the range of 40-45mm.
    I used the Dellorto's, and was really impressed with them.
  9. Member g60manny's Avatar
    Feb 6th, 2006
    Santa Ana, Ca
    B8 A4 Audi, 1977 Rabbit
    12-21-2006 10:42 AM #79
    Quote, originally posted by MoGtheMooGle »
    sent im
  10. Member
    Aug 15th, 2000
    Corvallis, OR
    12-21-2006 11:23 AM #80
    Just a correction, 8V's can use sidedrafts just like 16V's. Downdrafts are usually used in factory carb type installations. for performance sidedrafts are the way to go when carbs are concerned on a watercooled VW motor
    '83 GTI 2L Dell 40's (crashed)
    '86 Cabby ABA/SDS - Bitch Basket
    '07 Tundra -DD - more front travel than a Raptor
    West Coast President - Dubsquad Conglomerate International
  11. 12-21-2006 11:57 AM #81
    Quote, originally posted by 2L Bunny »
    for an 8v to use a sidedraft setup, wouldn't you be talking about a x-flow motor where the intake is on the front and the exhaust is on the back? otherwise, if you were mounting carbs on a rear-mounted intake setup, you would have to fab up a manifold so that the carbs would be laying flat.
    if the sidedraft carbs aren't sitting level, the fuel would flow down the venturis incorrectly.
  12. 12-21-2006 04:26 PM #82
    Many manifolds exist for counterflow 8v heads and have been used for years. Also, sidedrafts can function properly at a maximum angle of 7 degrees above horizontal.
  13. Member
    Aug 15th, 2000
    Corvallis, OR
    12-22-2006 12:16 AM #83
    Quote, originally posted by Mk2enthusiast »
    Yup, I've got a set of Dellorto sidedrafts on my Race rabbit with a counterflow 8V. If you're ever up in Corvallis you're welcome to take a look.
  14. 01-17-2007 05:58 PM #84
    You can get parts for the dellortos from the factory in italy if you are prepared to pay some money.
  15. 01-22-2007 04:58 PM #85
    when you guys say that you keep the intank pump as well are you:
    1- using only the oem intank pump?
    2- Using the carter pump and the intank (wired up and pumping)
    3- Using the carter pump only and just leavign the intank pump in the tank and using it as a pickup only for the carter?
    Also on aside note about msd, i have a 6al box, can i either
    1- use my factory digifant dist. with the icm as pictured in this thread
    2- use and older vacuum advance distributer and wire it straight up to the msd box?
    thanks Andy
  16. 01-22-2007 06:09 PM #86
    Quote, originally posted by Red Robertson »
    thanks Andy
    2/3 are the same but people have done all those fuel configurations with success (in conjunction with a regulator).
    If using the stock distributor, the icm only amplifies the signal from the hall effect, allowing a timing comupter (e.g. MSD PN 8980) to deliver an advance curve.
  17. 01-22-2007 06:47 PM #87
    do you think the 8980 would be the best bet? i liked the idea of the adjustable timing controller pn 8680 (knob on the dash) but does it deliver a curve as well or just a straight adjustment?
    would the programable timing controller (pn 8981) be of any benifit over the fixed curve?
    but would a vacuum advance dist. provide an equivlant curve?
  18. Member der hare's Avatar
    Oct 27th, 2001
    Santa Monica
    01-26-2007 11:54 PM #88
    What throttle cable is used when running dcoe on a counterflow 8v?
    I'm guessing stock carbuerated throttle cable?
    Anyone have a good source for the metal air cleaners for a dcoe setup?
    Rando
    DCI - what part of fück off do you not understand?
    RIP Moses
  19. 01-28-2007 06:41 PM #89
    Quote, originally posted by der hare »
    K&N has them listed on their website
  20. Member vdub4life_89's Avatar
    Dec 2nd, 2003
    1961 Bug, 1966 bus, 1964 bug, 2007 Rabbit
    01-29-2007 08:06 PM #90
    WOW...good info.....well im about to jump feet 1st into the carb world.....i have put a 8v together with a set of solex carbs what would i need to know if i pulled my stock 83 rabbit motor and put this built 8v in??? do i need diff. fuel pump....ect.??? im me please if you have the time and thanks agian guys for all the info
    Luke
  21. 01-29-2007 11:09 PM #91
    All the MSD boxes are fairly equivilent, adjustablity within 20 degrees of your mechanically set full advance. The programmable (8981) merely allows adjustment in the slope of advance and initial timing within, again, 20 degrees of your mechanical set.
    Digging around on here, the net, or in a Bentley you should find the curve of an OEM vaccum advance or mechanical advance distributor. I know people have used one from a Saab as well.
    If you're serious about dialing in your own ignition curve, the best route would be a distributorless ignition system like Electromotive for example.
    Based on this and your budget you should be able to settle on something
  22. Banned
    Jan 24th, 2004
    02-13-2007 08:22 PM #92
    So much great info my head is spinning, trying to read as much as possible and have as few questions as possible. Now I'm in need of beer and it's raining ice outside.
  23. Banned
    Jan 24th, 2004
    02-25-2007 12:54 PM #93
    Ok, question.
    It says the carter feul pump needs no fuel pressure regulator but then it suggests one? Which is it, no fpr or with fpr?
  24. 02-25-2007 12:58 PM #94
    Quote, originally posted by OnTheRunDCI »
    Ok, question.
    I would suggest one, people say its not needed because the max psi rating of the carter pump should not hurt most carbs, but if yould always like constant Fuel pressure, id get a regulator
  25. Banned
    Jan 24th, 2004
    02-25-2007 01:40 PM #95
    Thanks, that's what I thought. Just something to make it work bettah.
  26. Member lehr leistung's Avatar
    Mar 8th, 2003
    Upper Saucon , PA
    00 Tropic Orange Gti,98 Elegance Green b5 wagon,96 Cinnabar Cabrio
    04-30-2007 08:12 PM #96
    i recently put a holley 1-4 reg set to 3.5 on mine, i was getting too much fuel in the bowls with just the carter...
    PVW 9/07 , 2/12
    Eurotuner 1/05
    -Lehrmann AutoWerks-
    previous|84gti|85golf2.016v|86.5scirocco16v|87gti1 6v|88jetta|90gtivr6T|90 rado g60|91jetta|92jetta|95cabrio|95GLX|97Jetta Trek|05GLI|
  27. Member VWCR8ZY's Avatar
    May 10th, 2006
    Everett, Wa
    1987 Golf
    05-14-2007 06:26 PM #97
    I am not running a regulator with my set-up, but will be adding one to see if it works.
    btw: 1.8 12.5 comp, 270cam, holley 350 with #57 jets, carter pump.
    I will update and let you know if anything gets better or worse.
  28. Member PNW_Dubbin_Ain't_Easy's Avatar
    May 26th, 2005
    Oak Harbor
    1972 VW Baja
    05-23-2007 11:13 PM #98
    ok guys help me out. Im runnin and 8v with a 2 barrol down draft weber. I have everything hooked up but the throttle cable can i see some pics of how you guys have hooked yours up? also anyone want a wiring question that is killin me>? thanks for your time
  29. Member PNW_Dubbin_Ain't_Easy's Avatar
    May 26th, 2005
    Oak Harbor
    1972 VW Baja
    05-24-2007 11:01 AM #99
    thought of another question... Where does the wire on the elec choke goto?? the one on the front of the carb?
  30. Member vee_dubb_gti's Avatar
    Nov 17th, 2004
    Chicago, IL.
    90 Jetta Coupe 1.8t
    05-25-2007 01:15 AM #100
    the wire goes to 12v key on. (off the coil) if you wnat to see a pic. look in my sig. the one with the webber for sale. that should have a pic of my old one installed.i know it sounds getto, but i used some big nuts as spacers. if you wnat some better pics, let my know.
    ........... \_________
    ..... ,___/ /___l ___\\_____
    ...... l________l____/_____l
    .......\__( o )_______( o )__/
  31. Member PNW_Dubbin_Ain't_Easy's Avatar
    May 26th, 2005
    Oak Harbor
    1972 VW Baja
    05-25-2007 10:44 AM #101
    ya if you could post another pic or 2 of the set up that would be great and thanks for the choke question. now if I could get the damn thing to turn over i'd throw a party!!!
  32. Banned Mike Ngo's Avatar
    Sep 7th, 2002
    06-12-2007 10:03 AM #102
    Quote, originally posted by SilverSLine »
    any answers?
  33. Member Cynical 1's Avatar
    Jan 22nd, 2003
    Dahlonega, GA
    1988 BMW 325 - M52 swapped, 1969 BMW 2002 - soon to be 1.8T swapped
    06-13-2007 06:21 PM #103
    my 81 rocco has a direct-to-distributor icm. may try that model.
  34. Banned
    Jan 24th, 2004
    07-03-2007 01:40 PM #104
    Running a 2L 16V with dual weber 45's and have the carter pump. Which fuel filter should I run? I've heard of a 3 port filter than I can run the nipple on the tank that was for the return line to instead of capping off that nipple.
  35. 07-04-2007 02:21 AM #105
    what about blockin off the frigin injectors how to?
