Results 1 to 12 of 12
Thread: Tire size calculator...
  1. Member Banned wagon's Avatar
    Mar 3rd, 2004
    2013 Model S P85s Outback 89 4Runner 90&89 fox wagons 89 4door fox 89 2Door GL Fox
    03-25-2004 06:43 PM #1
    I found the tire size calculator to be vary helpful when planing a project http://ejelta.com/tiresize/index.html
    now if i could only find a tire the size i want (205/35/17)
    Cheers
  2. 05-05-2004 09:58 AM #2
    I use the one at http://www.dsm.org/tools/tiresize.htm whenever people start asking what tires can go on their car. Very handy tool.
  3. 05-05-2004 10:05 AM #3
    OK, I'll join in... I use THIS one.
  4. Moderator the brit's Avatar
    Jun 23rd, 2003
    Pottstown, PA
    VW Fox 16v
    05-05-2004 12:24 PM #4
    http://www.miata.net/garage/tirecalc.html
    Stock Tire
    195x60x14"
    Sidewall: 4.6"
    Radius: 11.6"
    Diameter: 23.2"
    Circumf: 72.9"
    Revs/mi:869.0
    New Tire
    175x50x13"
    Sidewall: 3.4" (- the 2.5" stretch!)
    Radius: 9.9"
    Diameter: 19.9" (- the 2.5" stretch!) AKA how to lower your car over 3" without touching the suspension.
    Circumf: 62.5"
    Revs/mi:1014.0
    Speedometer reading with non-stock tire is 14.3% fast.
    Wheeeeeeeeeeeeeeeeeeeeeeeeeee!
    Modified by the brit at 12:26 PM 5-5-2004
    | œ Orchid Euro Importation œ |
    Currently driving or working on...
    | '93 Fox 16v - PVW| '03 Sprinter - Build Thread | '99 Polo Greenland Polo - Build Thread | '85 Scirocco Storm RHD - Thread | '85 Polo RHD | '75 Swallowtail - Build Thread |
    | '99 Lupo 1.4TDI-S | '82 Caddy | '90 Jetta 8v | '96 Volkswagen LT35D | '02 GTI 337 | '03 GTI 20v |
    | '09 Aprilia RS125 | '81 Kawasaki AR80 | '78 Honda CB125 | '59 NSU Quickly | '64 Honda Cub C65 | '65 Honda Cub C105 |
    | Trek Madone 6.9 |
  5. Member Spankins 6's Avatar
    Sep 30th, 2005
    mk5 GLI, 84 Rabbit Gti, 71 Squareback, 1/3 of a 81 Caddy Diesel
    05-06-2009 09:24 AM #5
    sorry to bring this back from the dead, but I found this site, its pretty BA.
    http://www.wheelsmaster.com/rt_specs.jsp
    School Haus- Because its not a club
    WTB: Audi Cabriolet - PM me
    "I haven't got a carbon footprint because we drive everywhere"
    ~Jeremy Clarkson
  6. Member QuantumSyncro's Avatar
    Apr 28th, 2000
    Des Moines, IA
    97 Jetta TDI, 89 Fox diesel, 92 300SD turbo, 82 GS1100E
    05-07-2009 11:42 PM #6
    there's always the powerdog tiresize calculator, i use it regularly and it's so easy.
    http://www.powerdog.com/tiresize.cgi
    Gir - "won't the sploding hurt?" Zim - "Silence!"
  7. Member konkomania's Avatar
    Apr 18th, 2007
    Rochester, NY
    1996 Saab 9000 CSE
    01-13-2010 07:16 PM #7
    I use this one and I find it pretty helpful.
    http://www.motoringexposure.co...lator
  8. 01-14-2010 04:53 PM #8
    Cool
    I use this: http://www2.uol.com.br/bestcars/ct/pneu16.htm (But are in Portuguese )
    Modified by gus_quadrado at 1:54 PM 1-14-2010
  9. Member AudiUrPnts's Avatar
    Apr 11th, 2011
    Newark, De
    B6A4, MK1 Rabbit
    11-30-2011 08:54 PM #9
    very helpful, thanks.
  10. Member sippin.fnordies's Avatar
    May 22nd, 2011
    Portland, OR
    1989 VW Fox 2-door, 1979 VW Dasher 4-door
    12-01-2011 11:02 PM #10
    I use this one:
    http://www.willtheyfit.com
    In combo with this one:
    http://www.rimsntires.com/specs.jsp
    the first one is good for visualizing the details and numbers found on the second one.
  11. n00b ironjose's Avatar
    Oct 7th, 2008
    Guatemala
    2002 vw Golf 2.0
    12-08-2011 02:39 PM #11
    i got a question...
    recently i change my tires... i was using the oem size 195/65-15... and i change it for 195/50-15 i know its not a big change
    but i have the dubt if i've made the right choice??? it does look a lot cooler but now im worry if the new tires can handle the weight of my car...
    i know that the speedometer can change but that doesnt worry me at all...
  12. Member sippin.fnordies's Avatar
    May 22nd, 2011
    Portland, OR
    12-09-2011 03:14 PM #12
    Quote Originally Posted by ironjose View Post
    i got a question...
    That is a pretty big change...about 10% on the calculator. I can't imagine you would have any problems with them supporting the car, but the speedo and odo will be VERY off. About 6mph@60 and your odometer will say that you have put quite a few more miles on the car than you actually have. Not only that, but unless you lower the car too you are going to have a bit more than an inch of extra wheel well gap.
