Results 1 to 25 of 25
Thread: Am i Digi 1 or Digi 2???
  1. 03-31-2004 11:38 PM #1
    how can i tell if my 90 cabbie is digi 1 or digi 2???
    what can i look at to tell? would the VIN give it away?
    thanks...
  2. 04-01-2004 04:14 AM #2
    Quote, originally posted by gordinho80 »
    thanks...
    I Think it's like this: if your fuel injector only have 2 wires (brown and red) it's a digi 2 if it have more than that is a digi 1 .
    Digi 1 it's only for California car's
    In Portuguese now:
    penso que a diferença entre digi 1 e digi 2 é que o digi 1 controla individualmente cada injector e que só saiu na California, devido às restrições ambientais.
    É bom ver alguem neste forum que também e de Portugal.
  3. 04-01-2004 07:56 AM #3
    thanks for the quick reply...i will take a look, where is my fuel injector?
  4. 04-01-2004 08:26 AM #4
    in the back side of the engine head, there is 4 injector
  5. 04-01-2004 01:45 PM #5
    Also, I noticed that my ECU (near firewall, driver side) was labeled DF-1, meaning Digi1 (92 Cabriolet). Presumably Digi2 ECUs will be labeled DF-2, then?
    Check out the pix of my ECU here for reference:
    http://forums.vwvortex.com/zerothread?id=1307297
    2008 Audi A3
    1992 VW Cabriolet
  6. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    Q7 4.2 V8 , Smart 451 Turbo
    04-01-2004 05:38 PM #6
    Both of them say DF-1 but both of them are Digi2.
    The pins are different in digi1 ECU.
    Chip Tuning for a living @ www.microchips-tuning.com
  7. Member exboy99's Avatar
    May 14th, 2002
    Long Island
    2004 TT 225 quattro coupe
    04-01-2004 08:11 PM #7
    now you guys have me thinking.... I'd better
    check and see... I'm sure I"m Digi I
    but my car in in NY..... how could this be
    did my engine swap and parts come all
    the way from the golden state?
    I'll report back... and a pic of the injectors....
    just in case you weren't kidding.
    ... yes I'm embarassed of how cruddy
    it is in there but .... well here's the pic
    the injectors are under the guly square
    metal rail with the paint flaking off of it.... and all
    the mess of wires under it....
  8. Member exboy99's Avatar
    May 14th, 2002
    Long Island
    04-01-2004 08:53 PM #8
    well I just looked an my ECU case says I'm Digi II!
    how'd I get that wrong?
    hmmmm.
  9. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    04-01-2004 09:37 PM #9
    Quote, originally posted by exboy99 »
    how could this be did my engine swap and parts come all the way from the golden state?
    Considering my '86 was bought in SoCal in '89 but was originally bought off a VW dealer lot in New York back in '86.... it's quite possible
    Remember, 1990 model-year Cabriolets sold in California have Digifant II with unique features and specifications. Beginning in 1991, Cabriolets sold in California have Digifant I. All other 1990-1993 Cabriolets have Digifant I.
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  10. Member exboy99's Avatar
    May 14th, 2002
    Long Island
    04-01-2004 09:59 PM #10
    Sadly I'm digi II
    I'm still learing about what's better digi this or that
    and it seems that the 16v forum is torn.
    many of em are on digi 2 or taht Cis-e
    and some are Digi I
    I understand that Digi I has a less restrictive
    or maybe No MAF on it? At least the story seems
    to be that the Digi II suffers with some limitations
    like the intake with it's restrictive airflow sensor thing.
    and something like digi I can't run a forced induction
    setup... but digi I can? sigh.... so much to learn
    but I'm soo sleepy must sleeeeep.
  11. Member exboy99's Avatar
    May 14th, 2002
    Long Island
    04-01-2004 10:01 PM #11
    .... well that is what mine looks like.....
    go take a look... that's what I did... and what a surprise!
  12. Member Black_cabbie's Avatar
    Jul 16th, 2003
    Athens Greece
    04-01-2004 10:13 PM #12
    So you should have knock sensor, 02 sensor and cat on your car as well right? Do you know if somebody did a custom map on the fuelling for this engine?
  13. Member exboy99's Avatar
    May 14th, 2002
    Long Island
    04-02-2004 04:23 PM #13
    well I think there's an O2 sensor somewhere down there.....
    Im pretty sure there's a cat but I only peek at bits of my
    exhaust and seeing how I forgot if I was dig I or II
    I'd better go check before I say anything about my car!
    ay-yay-yay!
    I'm thinking aboot performance chips though.... since
    I think I can slip on in there.... she's pretty quick
    but couldn't she be a little faster? I bet she can.
  14. 04-03-2004 03:39 AM #14
    Quote, originally posted by kamzcab86 »
    You mean "have Digifant II," right?
    2008 Audi A3
    1992 VW Cabriolet
  15. 04-05-2012 12:03 PM #15
    i'm curious about this too. i have a 93 cabby and i always read that the 93 was digi 2.
  16. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    '86 Cabriolet G60, '82 280ZX Turbo, '06 325i Problem Child
    04-05-2012 12:14 PM #16
    Most 90-93's are Digi II, unless it was an original Cali car, or swapped to Digi I during it's life.
    Just check the ECU, it'll say.
    It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark... and we're wearing sunglasses.
    -Hit it.
    RooflessVW
  17. Member tolusina's Avatar
    Oct 18th, 2004
    '95 Ranger, '74 Gitane Pista
    04-05-2012 12:38 PM #17
    DigiFant I, boxy, transformer looking coil with integral power stage; DigiFant II, old school looking cylindrical coil.
    DigiFant I, throttle position SENSOR (variable resistance); DigiFant II, two throttle position SWITCHES (on/off devices).
    DigiFant I, check engine light on the dash ; DigiFant II, no CEL.
    DigiFant I, 38 pin ECU ; DigiFant II, 25 pin ECU.
    DigiFant I, 5 wires in the injector harness near the fuel rail, separate circuits for each injector plus one common; DigiFant II, 2 wires, injectors all wired in parallel on the same circuit.
    I think there are a few other differences, these are all that come to mind right now. There are plenty visual clues here for an owner to identify which system is on their car.
    Note that this info is about bass ackwards regarding G60 (supercharged, nor factory on Cabbys) Digi I and II, I gets me a headache when I try thinking about those variations.
    Quote Originally Posted by kamzcab86
    I hate reading: "But I bought this car for $500 and don't want to put another dime into it."
    _____________________(hey, it's VW AND it's electrical, what's not to fail?)
    neoBentley+
  18. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    04-05-2012 12:49 PM #18
    Quote Originally Posted by tolusina View Post
    Any idea why the naming was all screwy, why there are two different versions of Digi. or why the Cali cars had them? Was it really that much cleaner running?
    -Hit it.
    RooflessVW
  19. 04-05-2012 12:56 PM #19
    DIGI 2 for me then. i have no cel light and a normal cylinder style coil.
  20. Member
    May 16th, 2004
    1986 16v Rocco
    04-05-2012 01:43 PM #20
    whats the difference between cali digi-1 and g60 digi-1 I know the difference between digi-1 and 2
    but not the cali digi-1
    digi-1 is map based not maf
  21. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    04-05-2012 01:52 PM #21
    Quote Originally Posted by kamzcab86 View Post
    Not quite, My 90 was Digifant II and my 92, and 93 are DigifantII but then again are you talking Californiated cars or FreeUSA.
    The easist way to tell is if you have a old fashioned looking coil, or a coil pak on the firewall.
    Coilpack Digi I old timey Digi II
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  22. Member tolusina's Avatar
    Oct 18th, 2004
    04-05-2012 02:08 PM #22
    Quote Originally Posted by euroteknique View Post
    I told I get a headache About Digi I, II, NA and G60.
    Best I know, which may be completely wrong, G60 I = NA II as far as ECU pins etc.. I'm pretty sure all G60 versions use a MAP, CO pot, etc., etc..
    NA DigiFant I & II both use a MAF, no MAP at all. Confused yet? I am.
    neoBentley+
  23. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    04-05-2012 02:21 PM #23
    Quote Originally Posted by briano1234 View Post
    Check the post date: 2004. I got that info out of the Bentley.
    Cabby Info now says:
    "Digifant is Volkswagen's in-house variant of the Bosch L-Jetronic fuel management system. There are two types: Digifant I and Digifant II. Digifant I uses adaptive controls to comply with California emissions requirements and has OBD I diagnostics. Digifant I was installed only in Cabriolets initially sold in California; all other Cabriolets use Digifant II.
    Additional info: If the 5th digit in the VIN is "B" it's Digifant II, if it's "C" it's Digifant I and should have a check engine light on the dash."
  24. Member tolusina's Avatar
    Oct 18th, 2004
    04-05-2012 02:40 PM #24
    Quote Originally Posted by s2kvondeutschland View Post
    VW Screwy Naming™? You mean like why an A1 Golf was a Rabbit in the U.S., Caddys were never sold in the U.S. as Caddys, rather, Pickups ('Pickups', their body stamping dies etc. first made and used in the U.S.), Cabrios are A3s in the U.S., A1 Golf Convertibles are Golf Cabrios in Europe.
    VW likes to confuse end users with VW Screwy Naming™, that must be why.
    California required On Board Diagnostics before the lagging rest of the States, California does sometimes take the lead in good things, pretty often actually, never mind that California also leads in Nanny State implementations.
    Since CA cars had to have OBD, VW likely decided to use most of the rest of the next generation of technical advances short of a full switch to Motronic.
    As Digi II injectors are all wired in parallel, there's no way for computer diagnostics (on, or off board) to isolate individual injectors for open/short monitoring or cylinder disabling. Digi I has individual circuits for each injector making isolation possible, it even allowed for sequential injection though I don't think Digi I went quite that far though Motronic (some versions at least) most likely did.
    Sequential injection is actually a very small increment in engine power and fuel efficiency.
    Consider how well CIS worked with fuel being constantly sprayed on intake valves, open or closed, the real time that fuel sat waiting for a valve to open being very very short.
    Digi II (along with all earlier versions of L-Jetronic, and probably Digi I) also pulse sprayed fuel on closed and open valves, no big gain from pulsing rather than spraying there either.
    D-Jetronic, the very first mass produced EFI at least pulsed alternating injector pairs, they obviously found little or no gain there because they abandoned that beginning with L-Jetronic.
    neoBentley+
  25. Member tolusina's Avatar
    Oct 18th, 2004
    04-05-2012 02:43 PM #25
    ..... Digifant I uses adaptive controls to comply with California emissions requirements.....
    And there you go, I had forgotten (I'm old, forgetting is allowed, even expected) about the adaptive business.
    Once again, Kamz 1, Ron 0.
    neoBentley+
