Results 1 to 11 of 11
Thread: Brake caliper bolt size
  1. 04-05-2004 09:43 AM #1
    Hi! Need to change front pads on my 2002 Jetta GLS TDI with FS III calipers. What size and type of wrench do I need to take the caliper off? It looks like a hex key of some sort.
    TIA!
  2. Senior Member ROCKnRLR's Avatar
    Oct 30th, 2000
    Your mom's bed!
    2010 CC Sport
    04-05-2004 09:57 AM #2
    7mm allen wrench
  3. 04-05-2004 09:59 AM #3
    Cool! Thanks!
    It isn't one of those wacky star allen wrenches, just an allen wrench, right?
  4. Senior Member ROCKnRLR's Avatar
    Oct 30th, 2000
    Your mom's bed!
    2010 CC Sport
    04-05-2004 10:01 AM #4
    Correct it is not a torx bolt, it is an allen bolt.
  5. 04-05-2004 10:15 AM #5
    Thanks again!
  6. Member
    Jan 15th, 2002
    Brooklyn, NY
    04-05-2004 10:18 AM #6
    First time you won't be able to get it off with just an allen key, you'll need to buy one of those allen bit shapes on a socket bit.
  7. Senior Member ROCKnRLR's Avatar
    Oct 30th, 2000
    Your mom's bed!
    2010 CC Sport
    04-05-2004 10:21 AM #7
    Yeah, an allen bit socket to be used with a rachet wrench, good call!
  8. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    04-05-2004 10:31 AM #8
    you can also just slip a box wrench over the allen for extra length (more torque)
    Dave
  9. Senior Member ROCKnRLR's Avatar
    Oct 30th, 2000
    Your mom's bed!
    2010 CC Sport
    04-05-2004 10:40 AM #9
    I have an allen socket bit already, I hadnt thought of that
  10. 04-05-2004 10:46 AM #10
    Thanks all for the suggestions! I will be running to Sears at lunch and getting a socketed 7 mm allen wrench. Probably cheaper to buy a set so I'll probably do that.
    Thanks again!
  11. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    04-05-2004 11:05 AM #11
    Quote, originally posted by ROCKnRLR »
    Yeah, i have a big arse SAE (15/16 or something) open end/box wrench that acts as my breaker bar or more appropriatley what I like to call my "torque rod". Works well with allen wrenches, smalled combo wrenches, and even ratchets.
    Dave
