Results 1 to 2 of 2
Thread: Trouble code P0380 for Jetta TDI
  1. 05-04-2004 10:45 AM #1
    My check engine light is on and the code that comes up is P0380 (glow plug/ heater circuit A). Any ideas on how to repair?
  2. 05-05-2004 06:46 PM #2
    Get a digital multimeter set to measure "ohms" (resistance) in the lowest range (usually 0 to 200 ohms). Pull off the caps of all four glow plugs. Measure resistance between terminal on top of each glow plug and the engine block. Should be somewhere around 1 ohm more or less (most multimeters aren't very accurate in this range so don't be too fussy) but all four should be the same (+/- 0.1 ohm).
    If you find a bad one, that's the problem. Replace it, or all four if the car has more than (say) 50,000 km on the glow plugs.
    If you do NOT find a bad one, first make sure the glow plug fuse isn't blown, and if THAT isn't the case, replace the harness to the glow plugs including the four caps (not expensive - ask the dealer). Bad connections inside that harness are not uncommon.
