OK...
So, here's the update with lots and lots of pictures....
My water pipe (aka "crack pipe") broke so I had to install a new one.
Here's a pic of me cleaning off the thermostat housing:
I installed my waterpipe (shown here attached to the thermostat housing with some grease sprayed around the outside by the seals...
before I re-installed the thermo housing:
I actually had to pull the waterpipe back out again b/c it was easier to do what I did in the picture above this one and hook them together then push the assembly in as one. This way I was able to line up the "nipples" and stuff with the thermo housing...
Oh yea, had my oil pan welded today from my buddy. It looked like it would never leak any oil but I am a freakin pessimist so I threw some atv sealant around the outside just to be sure
I installed my nice and clean (but old) thermostat housing:
Just snapping the thermo housing back into place along with the waterpipe in one motion:
This shot shows everything back together AND also gives you an idea of how I routed the oil feed line...You could probably do it a million different ways but since I had a long line I figured this would be the best way...
Just another shot:
Ok,
So, I'm ready to start my i/c install...
I put my bumper/rebar back on (by accident). I realized after the fact that I should probably have left it off...But it was nice starting to see the car look like a car again
I started to cut but using my recip saw I effin cut into my a/c condensor...
Here's what happens when you aren't careful with your sawzall:
No a/c now...was thinking of just pulling it all out but I'll just replace my condensor at a later point...
Did a crapload of cutting and here's what I ended up with:
Now it's starting to take shape!!!
I actually almost have the bumper back on but forgot to take pics (was in a serious groove with the dremel tool).
This part is a PITA and I think I've cut too much in a couple spots. To me, it looks pretty bad...but we'll see. I'll post up pics of the bumper once I get the entire thing put together...
Thanks for looking guys...
Will continue to post up on this thread as my project progresses!!!!
Later,
Modified by nater at 11:03 PM 5-7-2004
