SPC Install Notes:This guide can be used to install any top strut mount including OEM mounts, camber plates, lowering caps, etc. Check out the: strut tool guide as well.
References:
# Noah's guide
# http://forums.vwvortex.com/zer...27185 (I basically used this guide and added the step of disconnecting the front swaybar from Noah's guide. This makes it easier to get in there for folks with oem length springs.
Install Prep:
# Loosen wheel lugs one turn
# Safely jack up car
# Remove wheel lugs and wheel
# Raise control arm slightly with a bottle jack
# Remove lower swaybar end-link bolt (16mm) (swaybar may be under tension so be careful - it may pop out and hit your hand when you remove the bolt.)
# Raise bottle jack all the way
# Use a strut spring compressor to safely hold the spring in place
# Remove outer nut and top strut plate
# Lower the bottle jack all the way
# Remove the old strut mount. Pay attention to the Bentley manual. The strut mount can come out without having to remove the inner strut nut first. (Mine was mushed together with the bearing so it was really hard to get it off. But it was even harder trying to get the nut off with the strut mount still in place.)
# loosen inner strut nut and remove donut-shaped bearing cartridge.
Install:
# If you are installing OEM mounts, follow the Bentley shop manual for the proper stacking order of the OEM components. Install is the reverse of removal. Here is a pic to get you started: http://peterpyce.com/Shine/Sap...1.jpg Note the 10mm spacer piece which may or may not come on your car depending on model year/options.
# If you are installing SPC camber plates continue on:
# Install the SPC plates and a new OEM bearing in place of the old strut mounts as described in the instruction sheet. Make sure the square holes are lined up! Note, you do not need to remove the strut to do this! Just get a friend to help if you have short arms.
# Raise the bottle jack all the way again and guide strut into the strut tower opening
# Install a rachet extension into the square holes - make sure it engages all the way
# Torque the inner nut to 44 ft-lbs. Some folks have reported better results when torquing slightly less than this
# Remove the ratchet extension
# Remove the strut spring compressor
# Install SPC top plate and make sure the peg is lined up with the square hole.
# Install and slowly torque outer nut to 30 ft-lbs ensuring that peg is still inside the square hole. Rubber surround for the top plate should cover the strut tower evenly. If it is slanting off to the side, loosen the nut and try again. If slanting continues, inspect the plate bottom and make sure it is flat. If it is bent, you may need to flatten it or get a replacement from SPC. Applying pressure to to opposite side of the plate will help keep it flat as you are torquing the nut.
Finishing up:
# Lower the bottle jack until the swaybar is aligned with the control arm
# Replace swaybar bolt and torque to 44 ft-lbs
# Lower bottle jack all the way
# Replace wheel & torque lug bolts to 89 ft-lbs using alternating star pattern
# Lower car off jack stands
Adjusting the alignment
# setup alignment rig
# record current alignment settings
# loosen top nut and remove top plate
# take load off of suspension with lift, but keep all 4 tires in contact with the ground
# loosen inner nut 1-2 turns
# use 3/8" ratchet extension in the square pegs to rotate plates to get desired caster/camber on each side
# torque inner nut to 44 ft-lbs
# remove ratchet extension
# lower lift and re-seat the springs by pushing on the 4 corners of the car a few times
# Install top plate and ensure peg engages the square hole.
# Re-check alignment settings
Special Tools
# 16mm socket
# 13/16" spark plug socket with 15/16" crowfoot wrench or equivalent
# 7/8" oxygen sensor socket with 1" crowfoot wrench or equivalent
# 7mm long hex key
# strut spring compressor
Regular tools
# ratchet
# torque wrench
# sockets, adapters, ratchet extensions, etc
# jack stands
# bottle jack
# floor jack
# latex gloves
First impressions
# Turn-in is definitely improved - even without an alignment
# Ride is a bit noisier
# Ride height appears unaffected
Alignment specs
Before:
LF: -0.3° camber +7.5° caster, -0.08° toe
RF: +0.2 camber, +8.1° caster, -0.08° toe
After:
LF -1.2° camber, +7.6° caster, -0.08° toe
RF -0.9° camber, +7.8° caster, -0.08° toe
With me in the car, camber was more equal at -1.1° & -1.0° camber.
