Page 8 of 8 FirstFirst ... 4 5 6 7 8
Results 246 to 274 of 274
Thread: lets just brag and show our circle track vw pics submit yours
  1. Junior Member
    Nov 13th, 2001
    lutz,fl
    mk3 golf(racecar)
    07-17-2011 06:43 PM #246
    my mk3 golf 2.0 aba holley carb racing @ citrus county speedway in florida
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    let me know what you think...
    Oct 13th, 2004
    Frankfort, IL
    1980 Rocco S Race Car, 1982 Rabbit Race Car, 1980 Caddy Outlaw Race Truck, 1983 Jetta Coupe, more
    07-20-2011 06:04 PM #247
    how does it run with the intake modified like that?
    looks more like a holley carb than a weber...
    Oct 13th, 2004
    Frankfort, IL
    07-20-2011 06:09 PM #248
    Quote Originally Posted by 05GTIMarine View Post
    it will be next season, we are thinking about a mk2 gti with a 2.0l 16v. going ot try to do alot of research before starting this venture. the honda kids are saying that vw's dont belong on a dirt track and that all we will do is go backwards against the 9k rpm asian cars.
    get a second generation scirocco (if you can't find an earlier one)....way lighter than a MK2 chassis (200lbs) and the parts were made in the cabriolets' for years afterward so they are cheap and abundent.
    gearing is KEY.... check out the VW Gear Chart that i made up.
    http://racefx.net/Images/VW%20Gear%20Chart.pdf
  4. Junior Member
    Nov 13th, 2001
    lutz,fl
    mk3 golf(racecar)
    07-22-2011 11:40 PM #249
    Quote Originally Posted by Shrttrackr View Post
    it is a holley iam not sure what i was thinking when i wrote that. it runs great it turns about 7300-7400RPM on a good night
    here is a video
    http://youtu.be/lIER5n-M9bA
    Oct 13th, 2004
    Frankfort, IL
    07-25-2011 08:34 PM #250
    looked good in the heat race.
    how bad did you crash it in the feature?
    looks like there are some squirrels in that class....
  6. Junior Member
    Nov 13th, 2001
    lutz,fl
    mk3 golf(racecar)
    08-07-2011 11:15 PM #251
    had to cut up both horns and do a lot of pulling to get it back. here are a couple of pics from after the crash.
    Photobucket
    Photobucket
    but its all good now the car ran great this past weekend. here is a video from sat http://youtu.be/aLBvLdi8fj8
  7. Member 16racer's Avatar
    Nov 29th, 2005
    Washington State
    Early Roccos
    08-29-2011 12:13 AM #252
    Kinda fuzzy, but you get the idea.
  8. Banned 05GTIMarine's Avatar
    Nov 10th, 2008
    Pittsfield, Massachusetts
    2005 gti, 2010 gti (RIP)
    08-29-2011 12:31 AM #253
    Quote Originally Posted by 16racer View Post
    i think you just need a lil jb weld and some nevr sieze and youll be back up and running
  9. Junior Member
    Oct 22nd, 2007
    Montgomery, AL
    82 Scirocco Dirt Track Race Car
    08-29-2011 03:29 AM #254
    I don't know what your rules are but if you want to be bad ju ju for them this is what your build should be...
    9A Bottom, JH Head engle DG550 cam has 102 center ( solid head btw) GP tranny,
    Go with TT 42mm intake 35mm exhaust TT adj timing gear to zero it out ( use flat peice of metal then measure on the top of cylinder 1 intake exhaust with tape measure make sure its the same distance on each side to the top of head)
    Holly 350 or 500 with 68+ size jets wouldn't hurt to throw lighter pistons in because the pistons in a 9A are heavy and the poor rod ratio doesn't help, if you want some security throw in some good h beam rods IE Carrillo or Scats ( i run scats cause i'm a cheap bastard)
    Oh yeah with this cam you must run under bucket shims and grind out around the bucket's so the cam will pass.
    And for the love of god do not buy a high volume oil pump your asking for alot of trouble with it.
    Oh and if you run the 9A you know the oiling hole to the head.... Plug it and make it alot smaller these engines at 8k+ (which i hit 1/4 way down the straight) Pump all the oil out of the oil pan and can't drain back fast enough... If you need to have your crank turned make sure to get them to turn it 11 under and get 10 under bearings loosens up the motor plus more oil for it to ride on..
    I was running 83.5mm postive decks wiseco's but i whent to a 9.1 wiseco which runs around 13.4 compression with the jh head it runs better with the small dish in them its alot freeier feeling..
    With this setup i promise those cars would get lapped by you.. and the bonus is it still looks stock besides the TT gear =P ( i run Super pony dirt so this is all legal for me or as most call it mini mods)
    And if you can't run a big header grab a corrado g60 exhaust and modify it a little to fit its not as free flowing but its better then a normal exhaust on a scirocco or rabbit.
    Yeah i run a Scirocco II
    later guys trying to get my beast back together for the KMSA event this week ( don't buy the high volume oil pump trust me two new oil pumps 2 complete failures including the first time locked the intermediate shaft broke the belt bent every valve in the head)
  10. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    08-31-2011 07:54 AM #255
    Here is a link to photos of the progress on my scirocco racer;please take a look & tell me what you think:
    http://s775.photobucket.com/albums/yy32/junkyardjockey/
  11. Member flyinglizard's Avatar
    Aug 6th, 2006
    Spring Hill, FL. USA
    FSP. ITB,wide body,Chumpcar
    09-10-2011 10:50 AM #256
    New mission for the old cars. [IMG]http://gallery.oracool.net/v/album82/protech/autox/max_++topline+009.jpg.htm
    wont load the pic.
    http://gallery.oracool.net/d/240837-...opline+009.jpg
    Mike and Michael Ogren, Protech Racing,25 yrs of Racing VWs. mogren@tampabay.rr.com, 352.428/8983 "Home of the world famous Turbo Jett"
    www.fwdracingguide.com
    Money back guarantee!, You can go100$ faster with this 20$ guide to all racing VWs, and oval track/Road race/Chumpcar/ FWD cars.
  12. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    09-12-2011 05:55 PM #257
    wow that looks pretty cool Mike....did u take a look at the progress on my car yet?
  13. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    09-14-2011 07:55 AM #258
    hey shrttrackr..I tried to PM you but your inbox is full.....pls send me pics of the tower tops to:
    speedracer13440@yahoo.com
    thanks!
  14. Member
    Oct 13th, 2004
    Frankfort, IL
    09-14-2011 02:02 PM #259
    hey Ken
    sent you an email with pics. my inbox is cleared out now...
  15. Member flyinglizard's Avatar
    Aug 6th, 2006
    09-15-2011 11:28 PM #260
    Hey Junk, Iwill take a look next week. I have the 2 Chumpers running the Sept 24 race. Gotta finish the watered cooled brakes and swap all of the axles, front bearings etc. One car is done the other just went inside today.
    MM
  16. Member
    Oct 13th, 2004
    Frankfort, IL
    12-22-2011 10:57 AM #261
    this thread needs a recent bump....
    just a couple pics of my rabbit in action at Rockford Speedway, Rockford, IL at the Bahama Bracket Nationals. Started 21st in the feature and finished 4th....Qualified 6th out of 60...
  17. Member Scirocco_Kind_of_Guy's Avatar
    Oct 6th, 2010
    845 NY
    84 scirocco 8v, 79 porsche 924
    01-15-2012 11:03 AM #262
    no tracks near me allow foreign cars. if they did i would have a vw to run but we are only allowed to run american made cars
    -Austin
    1984 scirocco
  18. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    01-16-2012 09:35 AM #263
    that rly sucks german..here in central NY we have no such problem.we just have to compete aginst the hondas....right now Im working on getting a 84 Rocco ready for this year...
  19. 01-18-2012 09:03 AM #264
    Quote Originally Posted by German auto is #1 View Post
    run a dodge omni/horizon. very similar to a rabbit, vw stuff bolts right in
  20. Member
    Oct 13th, 2004
    Frankfort, IL
    01-18-2012 12:36 PM #265
    VW supplied the motors/Trans in the omni from 78-83 (the 1.7L model). you can easily drop in a VW 1.8 or 2.0L motor.
  21. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    01-18-2012 08:47 PM #266
    Quote Originally Posted by flyinglizard View Post
    MM
    did u ever get the chance to take a look at the progress pics of my rocco Mike?
  22. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    01-18-2012 08:53 PM #267
    The only real difference I found out is that the cranks in the motors for dodge supplied by VW have one end machined differently(for clearance and/or for crank pulley issues) and thus there will be clearance issues.I guess the rabbits have a slightly wider engine compartment;so maybe a rabbit 1.7 may not fit w/o work into a dodge...I could also have this story reversed,but I do know there is a difference in the cranks between a 1.7 that was originally in a VW versus a 1.7 supplied by VW for Dodge.I dont remember where I read or saw this but I do know this story to be true..one way or another...lol...
  23. Member flyinglizard's Avatar
    Aug 6th, 2006
    02-18-2012 11:16 AM #268
    Alittle slow here. last weeks pic,
    https://lh6.googleusercontent.com/-R...0/IMG_0598.JPG
    MM
    Gapless rings,005 PTW clearance. Some compression, good cam, 1.8, 100% steel body so far with 100% glass. About 40# over right now. @ 1940 empty.
    locked diff, , 3mm toe out rear, 550 front springs, 350 rear , no bars. Goodyear SRF tires @36# PSI front 40 PSI rear .
    The little hoosiers are 2 sec lap faster@ Sebring, but these wil work @ Daytona @ 40psi and the car should roll past the Honda by 8mph. Ihope.
    MM
  24. 02-23-2012 07:34 PM #269
    Sorry I have not posted in a while...been living in Germany. Did make it back to Texas to race a couple times last year. Here is a short video I made to hype up the last race of last season.
    http://youtu.be/vovDY7botfo
  25. 03-01-2012 04:35 PM #270
    Taken last year
  26. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    07-03-2012 07:50 AM #271
    wow very nice looking 1st gen rocco u have there...props on the racer!...hopefully I can get my 2nd gen rocco done sometime this year....
  27. 07-14-2012 12:12 AM #272
    we raced in Corpus Christi last week. this is video from my roof mounted gopro camera.
    http://youtu.be/dSPyu0LVwVQ
  28. Member junkyardjockey's Avatar
    Nov 11th, 2001
    Utica,NY
    07-29-2012 09:47 PM #273
    hey does anyone here have any extra wheels to sell? I need at least 4 13" or 14" rims with a 4" backspacing;anywhere from 5 1/2 wide to 7" wide..I kinda prefer the 13"s...thanks!
  29. Member Tucked's Avatar
    Jun 12th, 2007
    Iowa, USA or PEI, Canada
    Mk1\Mk2
    07-30-2012 10:28 PM #274
    How easy\hard is it to hook up that holley carb? Looks like a 2 barrel based on the single float, would a 4 barrel work any better?
    CustomObsessions.com
    I'm sheep as hell.
