Results 1 to 14 of 14
Thread: how do you properly set timing on a 16V with digi-1?
  1. 07-07-2004 05:40 PM #1
    ignition timing that is
    i have heard to warm up the car to operating temp, unplug the coolant temp sensor and set timing to the mark on the flywheel, i have also heard of setting it with the engine at 2500 rpm.
    what is the proper way to do it?
    Kyle
  2. Member GTIMan82's Avatar
    Jul 8th, 2002
    Virginia
    1987 Scirocco 1987 GTI 2006 Jetta TDI 2006 Honda Odyssey *sigh*
    07-08-2004 09:03 AM #2
    You have to set it at idle, but because you have digi-1 Im not sure what RPM would be proper. As the RPMS increase your ignition system also advance the timing. So settin the timing at improper RPM can cause you to set the timing incorrectly.
    For a stock 16v the timing is to be set to 6* advanced at I think around 950 RPMS when idling. Its in the bentley, I cant recall the exact RPM.
    For Digi-1 I would assume you would have to set the timing according to a regular digi-1 car because the ignition maps are different. A good place to start would be to find a corrado manual and look it up in there. However, because its a different motor you may need to adjust the timing settings accordingly and I have no clue what those may be... but I am sure someone on here will come on who does!
    Typically all ignition timing is adjusted at idle, and you check for proper advance at higher RPMS such as 2500.
  3. 07-09-2004 11:36 AM #3
    TTT
    Anyone? if i disconnect the coolant temp sensor plug while the engine is idling it just dies.
  4. 07-09-2004 06:14 PM #4
    you rev the car to 2500 and unplug the coolant sensor, it dies because it goes full rich, (this is why you rev it up). unplugging the coolant sensor prevents the ECU from adjusting the timing, this is all theoretical though, i dont even have my digi 1 wired up yet... do a search in the g60 forum.
  5. 07-10-2004 01:25 AM #5
    Go drive the car for ten mintues
    Hook up timing light
    Rev engine to 2500 rpm
    unplug coolant sensor (blue)
    set timing on flywheel
    done
  6. 07-12-2004 11:34 AM #6
    thanks guys
  7. Member laychooba's Avatar
    Mar 2nd, 2001
    montreal
    scirocco 16v, audi A8Q
    03-28-2012 10:04 AM #7
    i just got my digi 16v setup running, but i set my timing
    standard 16v way at idle, so when i did my first initial test
    run the other night i was getting pinging.
    so i found this, but just to make sure, you gotta get someone to
    HOLD the engine at 2250-2500 rpms while you dial in the timing?
    thanks
  8. Member Smiff's Avatar
    Jan 4th, 2011
    Something about Buckeyes I think
    89 GLi dead atm, 00 B5 ATW Wagon, 86 Audi 4ks daily
    03-31-2012 10:29 PM #8
    use something to shim the throttle lever, like stacked feeler gauges or a couple of washers. That way you're not dependent on someone else and their ankle precision....
  9. Member weejunGL's Avatar
    Feb 2nd, 2005
    Norwegen
    MKII G60 Syncro
    04-01-2012 05:44 AM #9
    if you run digi1, you have to do it as described in the faq in the G60 section
    digi 1 is digi 1, no matter what so ignition timing setting is the same
  10. Member Smiff's Avatar
    Jan 4th, 2011
    04-02-2012 07:11 AM #10
    Unless he's running Digi-1 Cali, in which case Digi-1 is dressed up Digi-2. Tell me that's not confusing.
  11. Member laychooba's Avatar
    Mar 2nd, 2001
    montreal
    04-02-2012 11:21 AM #11
    beautiful!
    i had someone hold the throttle while i dialed it in, worked
    like a charm. now i just gotta figure out why it's running so
    hot!
  12. Member Smiff's Avatar
    Jan 4th, 2011
    04-02-2012 05:16 PM #12
    Coolant yo!
  13. Member weejunGL's Avatar
    Feb 2nd, 2005
    Norwegen
    MKII G60 Syncro
    04-03-2012 04:32 AM #13
    Quote Originally Posted by Smiff View Post
    DaFuq.. then why even call it digi-1? why not call it something else?
    i knew there was a digi-1 cali edition, but it never touched my mind while answering
    should have called it Digi-goddamnmofo edition 9000
  14. Member laychooba's Avatar
    Mar 2nd, 2001
    montreal
    04-03-2012 10:58 AM #14
    Coolant yo!
    yeah, turns out i am retarded. there was still air in the
    system, but i still find it runs kinda hot. before i used to
    always be below halfway, now it was just hovering a little
    bit past halfway.
    i only have 17kms on this new setup just cruising around
    my house area. i'm gonna pull a highway rip soon, see how
    she rolls.
