VWVortex.com - DTC 01314 ??
    Results 1 to 24 of 24
    Thread: DTC 01314 ??
    1. 07-19-2004 07:07 PM #1
      Car Golf 01 TDI, after short trip wont start, then 2 hrs later starts just fine. No faults in Engine but 1 stored in Instrument cluster:
      VAG-COM Version: Beta 403.1-S
      Control Module Part Number: 1J0 920 826 C
      Component and/or Version: KOMBI+WEGFAHRS. BPV V07
      Software Coding: 06402
      Work Shop Code: WSC 00000
      Additional Info: XXXXXXXXXXX VWZXXXXXXXXX
      1 Fault Found:
      01314 - Engine Control Module
      49-10 - No Communications - Intermittent
    2. 07-19-2004 10:45 PM #2
      problem solved, it was relay 109.
    3. 09-30-2004 12:33 AM #3
      This is somewhat related. Maybe you can point me in the right directions. thanks
      1 Fault Found:
      013 - Check DTC Memory
    4. 09-30-2004 07:24 PM #4
      acording to Bentley:
      01314
      Engine Control Module (ECM)
      - No communication
      Data reception from Engine Control Module (ECM) via CAN Bus is not OK.
      Functions of systems connected to CAN-Bus not OK
      - Read measuring value block Page 01-170
      - Check DTC memory of Engine Control Module (ECM) and repair malfunction if necessary
      - Check for open or short circuit in CAN Bus wiring using wiring diagram.
      Check plugs on the back of your instrument cluster, if you need more data emal me ele28@gmx.net
    5. 09-30-2004 07:46 PM #5
      where is relay 109? i dont have a bently???
    6. 09-30-2004 08:50 PM #6
      Relay 109 is in TDI main relay, all relays are below stering column. I will check diagram in my Bentley what relays are in your car. Do you have VAG-COM? What year is your car?
    7. 09-30-2004 08:54 PM #7
      03 1.8T ... no bently,... here is my codes
      VAG-COM Version: Release 311.2-N
      Chassis Type: 1J - VW G/J/B Mk4
      Scan: 01,02,03,08,15,17,19,22,35,46,56
      Address 03 -------------------------------------------------------
      Controller: 1C0 907 379 K
      Component: ASR FRONT MK60 0103
      Coding: 0018945
      Shop #: WSC 00066
      1 Fault Found:
      004 - No Signal/Communication
      Skipping Address 15-Airbags
      Address 17 -------------------------------------------------------
      Controller: 1J0 920 906 J
      Component: KOMBI+WEGFAHRSP VDO V62
      Coding: 07232
      Shop #: WSC 00000
      3VWRE69M13M001593 VWZ7Z0B5152329
      2 Faults Found:
      01177 - Engine Control Unit
      64-10 - Not Currently Testable - Intermittent
      49-00 - No Communications
      Address 19 -------------------------------------------------------
      Controller: 6N0 909 901
      Component: Gateway K<->CAN 0001
      Coding: 00006
      Shop #: WSC 00066
      1 Fault Found:
      Address 46 -------------------------------------------------------
      Controller: 1C0 959 799 C
      Component: 1H Komfortgerát HLO 0003
      Coding: 00258
      Shop #: WSC 00066
      1 Fault Found:
      00849 - S-contact at Ignition/Starter Switch (D)
      25-10 - Unknown Switch Condition - Intermittent
      Address 56 -------------------------------------------------------
      Controller: 3B7 035 180
      Component: Radio 001 0010
      Coding: 00401
      Shop #: WSC 00066
      1 Fault Found:
      01305 - Databus for Infotainment
      37-10 - Faulty - Intermittent
      End -------------------------------------------------------
    8. 09-30-2004 08:55 PM #8
      Did about an hours worth of logging today. Several hours later, plugged up to do some more, car was running, I was setting up what blocks I wanted logged. Car shut off. asr light is on , car will turn over , but wont start.
      03 JEtta 1.8T AWP. Please offer some advice!
    9. 09-30-2004 09:15 PM #9
      Before I will go any further, was your car recently chipped or radio was replaced?
    10. 09-30-2004 09:15 PM #10
      it was chipped about 2000 miles ago.. so far 0 problems.... uh oh, is that thr problem? the chip?
    11. 09-30-2004 09:26 PM #11
      Using VAG go to Instrument cluster (17), read Block 125 and write down what values are in there. If the chip was done via OBD its a chance that only plug from ECU is loose, but if was soldered its a chance that its a problem with ECU.
    12. 09-30-2004 09:29 PM #12
      ok will do, it will take me a few mins. thanks for you help, I will post up those results shortly. do you want to get on aol im to make this easier?
    13. 09-30-2004 09:33 PM #13
      I dont have AOL, but I do have MSN Mess.or we could use vortex PM
    14. 09-30-2004 09:42 PM #14
      ok my msn sn is vwbax
      I got the following from 17 block 125
      engine 0 abs 1 is that what you wanted?
    15. 09-30-2004 09:54 PM #15
      yes, that is what I was looking for, here is what is in the Bentley:
      1
      Engine 1 = OK
      Data recieved from ECM
      Engine 0 = not OK,
      No data recieved from ECM
      - Visually check CAN Bus wire routing
      - Check harness connectors of the appropriate electrical circuit for proper and secure seating and simultaneously observe display
      - If the display content does not change during operation, repair malfunction
      - Erase DTC memory
      - Perform functional check
      - Check DTC memory again
      Have you removed Instrument Cluster recently? Its on the path of CAN_BUS, if any conector is loose then it will show the same DTC.
    16. 09-30-2004 09:56 PM #16
      can you describe to me what the can bus wires is? is that the obdII plug thing? or is that the actual plug the goes into the ecu?
    17. 09-30-2004 09:57 PM #17
      could you check block 130 ?
    18. 09-30-2004 09:57 PM #18
      Quote, originally posted by tdi28 &raquo;
      will do I will be right back.. did you get my msn screenname? vwbax
    19. 09-30-2004 10:05 PM #19
      ok BLock 130 is as follows
      2- Wire Central 1 Dr. Door 1 Pass Door 1
    20. Member atoson's Avatar
      Dec 28th, 2002
      San Jose, Ca. South Bay Area
      12 Golf TDI, 00 GTI, 00 NB, 84 Scirocco, 80 Dasher
      12-13-2004 10:28 PM #20
      Dick from DSR replaced my GIAC Chip today, hooked up my ECM and it's talking with my VAG 1552 and DTC 01314 is stored in DTC and other DTC's are now visible. It's the Chip.
    21. Member atoson's Avatar
      Dec 28th, 2002
      12-13-2004 10:31 PM #21
      Quote, originally posted by BMFJETTA &raquo;
      CAN Bus wires are colored orange with black stripe and solid orange which are twisted together. Ther are always 2 of this twisted wires, 1 Hi 1 Lo, in and out.
    22. 02-20-2005 09:47 PM #22
      How did you fix this? I am getting
      and also pulling a code for MAF signal too high.
      2002 1.8t GTI Apr chip, samco tip, ghl tb, CAI
    23. 08-17-2011 11:30 PM #23
      I have the same codes and I dont know what to do, I was thinking in replaced the relay 109, can you please help me, thanks a lot and best regards.
    24. 08-23-2012 03:51 PM #24
      funny, I got chipped from DSR and now I am throwing the same code.
