VWVortex.com - How to program the Homelink Garage Door Opener
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 38
    Thread: How to program the Homelink Garage Door Opener
    1. 07-20-2004 05:29 PM #1
      Silly question, but I can't seem to get homelink to work in my car. After resetting the codes (pressing 1 and 3 for some 20secs), I point my remote to the homelink unit, press both 1 and the remote button, and keep on holding. The lights in the homelink wiill blink slowly, but they don't speed up. I tried holding the buttons for over a minute, and no dice. Anyone with similar problems? I tried moving the remote to different distances, too, and it doesn't seem to help.
      BTW, I wish that whoever wrote the manual could have been a bit more clear in certain parts and/or knew that there are differences in the Phaeton and other VW models. Under the homelink section, the manual says that one should press the 1 and 3 buttons to reset the codes until the light above 2 blinks...well, although there is a light above 2 in a Touareg, in the Phaeton there are lights BEHIND every button. I also noticed a couple of words in German that were not translated here and there, as well as somewhat ambiguous descriptions. Oh well.
    2. 07-20-2004 07:38 PM #2
      Quote, originally posted by agnos »
      If your Garage door opener has a rolling code remote you will need to find the button on the Garage door unit and press it before attempting to code the Homelink buttons.
      Just be sure to clear the Homelink buttons first.
      I parked my car under the door opener so that I could jump into the car after pressing the button on the Garage door motor. Once you press that button it only stays active for like 30 seconds.
      You have to make sure you can get into the car and link the hand held remote to the Homelink button.
      Hope this helps.
    3. 07-20-2004 09:49 PM #3
      i also have a question. does homelink work even when the engine is not running? i tried homelink in my dad's passat when the engine was not tunning and it didn't work but when the engine is running, it works.
    4. 07-20-2004 11:34 PM #4
      It is tricky and took me several times to program utlizing the button on the door opener (mine is rolling code too). I parked it under the opener as well. The same was true for my Toyota Sienna I bought at the same time.
      I programmed it with the engine on. However, the transmitter works without the engine on.
    5. 07-22-2004 01:06 PM #5
      Thanks for the tips...I don't think I have a rolling code garage opener (it is an older model), but I'll give it a shot.
    6. Junior Member
      Jul 24th, 2004
      Hoover, AL
      2004 Phaeton v8, 2008 Carrera S
      07-24-2004 10:10 PM #6
      Well Agnos, when you figure it out PLEASE let us know.
      I have had the Phaeton for a week and have tried holding my opener in numerous different places to no avail. I even manage to get the lights to flash in the fast mode and it still won't open the $%$#%$# door . Of course if I can never get it to work it still would be the best ride ever!
    7. Former Advertiser
      Feb 15th, 2001
      07-24-2004 10:14 PM #7
      Try going to:
      http://www.Homelink.com
      They may be able to help...Have Garage Door Opener Mfgs. name and model
      handy....
    8. 07-26-2004 11:56 AM #8
      I did figure out what I was doing wrong - I was pointing the remote towards the homelink buttons (123) rather than the unit itself, which is the base of the rearview mirror (i.e. the part from which the rearview mirror is attached to the car). It worked like a charm!
      PS The manual really needs to be improved. The descriptions are too vague and confusing at times.
    9. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      10-18-2004 12:40 AM #9
      Thanks to Agnos for sharing all the information above.
      I also had difficulties at first when trying to program the garage door opener. Turns out there were three problems, one my fault, two due to small errors in the VW documentation:
      1) You have keep the two buttons on the roof of the car (buttons 1 and 3) depressed for 20 seconds before the Homelink device goes into the learning mode. 20 seconds might not seem like much when you read it, but it seems like it takes forever when you are holding the buttons. I was a bit impatient, and kept giving up before the lights started to flash. Moral of the story - look at your watch when you hold the buttons, after 20 seconds, the lights will flash.
      2) As Agnos pointed out in his first post, the Phaeton does not have an indicator light above the Homelink control unit, as stated in the VW documentation - what happens after 20 seconds is that the illuminated numbers (1, 2, and 3) will all begin to flash slowly.
      3) As Agnos also pointed out, you have to aim your existing handheld garage door opener at the front of the mirror base (see photo below), and not at the Homelink buttons on the roof of the Phaeton, as the VW manual suggests.
      Anyway, once you get the numbers flashing slowly, release buttons 1 and 3, then press and continuously hold the button that you want to program, while frantically pressing and releasing your (existing) garage door opener - holding it in the correct position (see photo). When the Homelink unit finally gets the message from your existing opener, the three lights (1, 2 and 3) in the Homelink unit will begin to flash at twice the speed that they were flashing at when you first put the Homelink device into learning mode (end of step 1, above).
      I also found out that it is handy to drive about a block away from your house before you begin the programming, otherwise, your garage door goes crazy from all the button-pushing.
      I don't know if it is necessary to have the ignition of the car turned on in order to put the Homelink device into learning mode - Homelink suggests that the ignition should be turned on during this process.
      There is an excellent illustrated, step by step guide available at the Homelink web site, at this link: http://www.homelink.com/program/gdo.html Note that if you purchased your pre-existing garage door opener transmitter (the 'clicker') in Canada, the last step of the programming technique is slightly different, because Canadian regulations limit the RF transmission from the handheld 'clicker' to a 2 second burst, regardless of whether you keep the button depressed longer than that or not.* Here is the link to the additional programming instructions for Canada: http://www.homelink.com/program/canada.tml
      The Homelink website instructions suggest that the transmitter in the Phaeton can be put into learning mode by simply holding any single button depressed for 20 seconds or more. I tried doing this, and sure enough, after 20 seconds, the 1-2-3 lights all started to blink, suggesting that the device was ready to learn a new signal. I didn't bother completing the task, though, to see if it worked or not - I was grateful enough that I got it working according to VW's instructions (depressing buttons 1 and 3 for 20 seconds).
      * If your Phaeton has been set up for Canadian operation by your dealer, then the Homelink transmitter is automatically limited to a 2 second transmission burst. This does not affect the programming (learning) process discussed here.
      PanEuropean
      Where to hold the 'clicker' when programming the Homelink device:
    10. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      11-21-2004 12:22 AM #10
      I removed the cover assembly that surrounds the inside rear view mirror bracket today, and discovered that the Homelink transmitter is located on the passenger side of the rear view mirror, well forward of the cabin dome lights in the front overhead control panel.
      I suspect that it would also be located on the passenger side of RHD vehicles as well, because there was provision on the windshield to mount the rainsensor on either side of the mirror. On LHD vehicles, the rainsensor is on the driver side, and the Homelink transmitter is on the passenger side.
      Anyhow, hopefully this photo will help you figure out where to hold your own garage door opener when you are programming the Homelink device in your Phaeton.
      Michael
      Location of Homelink Transmitter on cover that surrounds Inside Rear View Mirror bracket
      Another view of the Homelink transmitter, showing its location when the cover is installed
      Corrected Version of page 58, booklet 3.1.1, Phaeton Owner Manual version Nordamerika 10/2004
    11. 11-21-2004 06:57 PM #11
      What I found finally worked was to continuously press the Homelink button I was trying to program, while pressing the corresponding button on my remote for two seconds on, release, two seconds on, release, two seconds on, release and so forth until the light on Homelink flashed quickly. For some reason some of the new remotes only trasmit for about 2 seconds, which is too short a duration for Homelink to pick up the signal. Give that a try. It worked for me on my W8.
      Nov 14th, 2004
      Indianapolis, IN
      11-21-2004 07:52 PM #12
      Remember, if you have a garage door opener with a learning mode, you must first program the Homelink button to put out the same signal as a working remote. This works the same way as setting up an opener that does not have the learning mode. Then, AFTER you complete this step, you TEACH the opener the code coming from you Homelink.
      Missed this step and spent the last hour setting it up. And of course every other home linke an opener I have on the learning opener as I managed to clear it in the process. Happens every time! This time I made myself notes in the manual, which of course means I will never need this info again!
    13. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      11-21-2004 10:18 PM #13
      Quote, originally posted by Rex Flash »
      ...For some reason some of the new remotes only trasmit for about 2 seconds...
      The "some reason" you refer to is Industry Canada, specifically the Radiocommunication regulations. Homelink transmitters in Canada are only permitted to function for a 2 second maximum burst. They can be recycled as often as you want, but will only transmit for up to 2 seconds on one button press. The Americans don't have this restriction.
      The Phaeton (or, in your case, Passat) knows what country it is being operated in from the software coding assigned to the instrument cluster. If it is coded for Canada, then the Homelink transmitter is limited to a 2 second burst. Homelink provides slightly modified programming instructions for Canadian transmitters (that say, in effect, exactly what you have discovered) at this URL: http://www.homelink.com/program/canada.tml.
      Michael
    14. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      01-26-2005 10:05 AM #14
      VW has released a training CD to their North American dealer network that explains how to program the Homelink transmitter in the Phaeton and the Touareg. This audio CD is not intended for end users (Phaeton owners), but it should be available for listening to at your dealership if you inquire.
      I guess VW must read our forum - they released three CD's that address the three main documentation deficiencies in the Phaeton owner manual - Homelink, Memory Seat Programming, and operation of the MultiFunction Indicator.
      Michael
      Training CD - Programming the Homelink Transmitter
    15. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      10-17-2005 11:40 PM #15
      Here is an updated (fall 2005) version of the Volkswagen Customer Brochure that explains how to program the Homelink garage door opener transmitter in the Phaeton.
      Although VW is making progress towards describing the correct location of the transmitter in the Phaeton (the text is substantially correct), the photos in the brochure show the person holding the portable garage door opener under the buttons on the cabin roof of the Phaeton. As you can see from the photos above, the Phaeton transmitter is remote from the buttons - it is located way up at the front of the roof console, on the passenger side of the rear view mirror. If you don't have success programming your car when you follow the VW instructions, try moving the portable garage door opener forward, and holding it under the Phaeton Homelink transmitter (not the Phaeton Homelink buttons).
      Michael
    16. 02-13-2006 10:41 PM #16
      I had an awful time trying to program this until an executive of Lift Master told me to do the following, which worked immediately:
      Here is the easiest way to program the Homelink opener to your garage opener that has a rolling code. You may want to copy this down before going out to the garage. It makes it much easier.
      1. Have the car out of garage running, with the garage door open.
      2. Unplug your garage door opener, and remove the light lens cover if necessary to see the "learn button".
      3. Go back to the car and hold the button on the Homelink down for about 20 seconds and at the same time hold and press the button on your garage door opener near the front of the rearview mirror assembly. (this will put the Homelink and transmitter on the same frequency)
      4.Go back into the garage, plug the opener back into the outlet and press the learn button long enough to see the little light next to it come on.
      5. Go back in your car and while it is still running press the Homelink button you have programmed twice in succession. You should see the lights on your garage door opener blink to indicate everything is working.
      6. Your Homelink should now be programmed.
    17. Member
      May 29th, 2004
      East Haddam, CT
      More than I need
      02-14-2006 08:00 AM #17
      VW12,
      With keyless option my home link will work if I am in the car and the engine is off.
      RB
    18. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      02-14-2006 11:05 AM #18
      I believe it is set up that way on all VW products - the HomeLink transmitter has access to battery power all the time, regardless of ignition terminal status.
      Attached below is a brochure from VW of America explaining how to program the Homelink opener. The brochure covers all VW models, but includes Phaeton-specific information.
      There is an error in the instructions given for the Phaeton - the photos show the person aiming their garage door opener control at the Phaeton overhead control panel when transferring the code - the garage door opener actually has to be aimed at the Phaeton transceiver that is forward of the overhead control panel, as show in the pictures posted above.
      Michael
    19. 03-21-2007 02:25 PM #19
      I just spent an hour trying to program one of my homelink buttons and here's what I learned.
      Before destroying your shoulder trying to do the "simultaneously hold down buttons 1 & 3 for two hours and then release and push.....etc..", try this: (I believe this is listed as the "single button programming method" or something like that in the manual)
      Just press and hold whatever button you want to program and count to 20 real slowly (don't release this button at all during the process), then hold your remote/garage door opener/etc. up to the area behind the rear view mirror and start holding down that button as well. As soon as the light on the homelink button begins flashing quickly, you're done.
      I'm not going to say this will work for everyone, but after trying the "push buttons 1 & 3 simultaneously..." method about 60 times without success, I tried this other method and it worked the first time.
      Good luck.
      -Mike
    20. Member chrisj428's Avatar
      Feb 26th, 2005
      Vernon Hills, IL
      '15 Ford C-Max Energi
      03-21-2007 02:41 PM #20
      Pressing 1 & 3 together doesn't program the HomeLink, it wipes out anything that may have been in there previously. After you've done that, then you press & hold the button you're trying to program along with activating the transmitter in the correct position.
      Truly the best source for HomeLink programming is http://www.homelink.com.
      --Chris
    21. 10-28-2007 09:59 PM #21
      Quote, originally posted by murphybaileysam »
      Following an hour of frustration time.. your procedure WORKED. I would have never figured in ladder work to access the door opener motor box "learn button" was the key. Many Thanks!! Great Post. - Bryan
    22. 03-21-2008 03:45 PM #22
      Hi all,
      First time poster here. Just last week purchased an '04 V8 here in Austin through VW's Pre-Cert program so I have the comfort of a 2 year warranty. Mostly the car has been in the garage since I had knee surgery 2 days after purchase but wanted to say thanks for this great forum. I'm waiting on some replacement manuals so until then have been scouring as much info as possible off this site. My first conquest was to get the garage door opener to work, which I was only able to do after the most recent post.
      I have a small amount of work to get done immediately that VW agreed to, namely fixing one headlight washer whose door won't retract and the other to replace at least one speaker that isn't functioning. This car has the standard sound system in it but I'm wondering if someone could fill me in on how many speakers are supposed to be active and where they are located?
      Thanks again!
    23. Member chrisj428's Avatar
      Feb 26th, 2005
      Vernon Hills, IL
      03-21-2008 03:53 PM #23
      Matt,
      Congratulations on the purchase and sorry about the knee surgery! Hope your recovery's swift and complete and you're able to enjoy the car again!
      --Chris
    24. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      03-21-2008 11:06 PM #24
      Quote, originally posted by jst2see »
      ... fixing one headlight washer whose door won't retract ...
      Hi Matt:
      Welcome to the forum, and congratulations on your purchase.
      FYI the little doors that cover the headlight washers are designed such that if you hyper-extend them, they will lock into the open position. This is intentional, to facilitate headlight alignment (which is done through that door). If a washer door ever sticks in the fully open position, just give it a gentle push closed and it will go back to normal operation.
      This assumes, of course, that the washer jet is not sticking up out of the hole...
      Michael
    25. Member paddyh's Avatar
      Mar 14th, 2008
      Erie, CO and Königstein im Taunus, Germany
      2004 VW Phaeton W12
      03-30-2008 04:32 PM #25
      Please re-host the pictures
      Colorado Fleet:
      1960 MGA | 1999 Ford Ranger XLT | 2007 Audi TT Quattro Coupe 3.2 | 2009 Jaguar XJ Portfolio | 2014 Jaguar F Type V8 S |
      Germany Fleet:
      Coming Soon
