Results 1 to 19 of 19
Thread: white smoke-burning oil?
  1. Member HiTdAtSiT's Avatar
    May 4th, 2004
    98 GTI VR6, 04.5 Jetta GLI 1.8T, AP1 S2000
    08-04-2004 12:58 PM #1
    hey guys , i notice that when i floor it my boy tells me he sees white smoke blow out of the exhaust only when im flooring it ..what could this be ? if i drive hard during the day i notice it burns a good amoutn of oil and need to put in a quart or two after like 2-3 days of hard driving ..do any of you guys have to refill the oil after a couple of days of hard driving??? i haev 256 cams in the car. anybody know anythign of this to help me out?
  2. Member Eric D's Avatar
    Feb 16th, 1999
    Tragic Kingdom, CA
    1943 Flugkreisel, 1945 VRIL-7
    08-04-2004 01:19 PM #2
    Over-rich mixtures burn black.
    A motor with bad valve guides and/or rings gives off blue.
    White is indicative of water. Could need a new headgasket, but white steam at startup is water condensation in the exhaust pipes.
    Assuming that you are using antifreeze in the radiator (and not straight water), the glycol in it has a distinctive sweet smell after it passes out through the exhaust pipe (same smell as when an engine overheats and "spews" coolant).
    The original Dub and Dubber.
    Manche VWs sind einfach schneller als andere.
  3. Member HiTdAtSiT's Avatar
    May 4th, 2004
    08-04-2004 01:28 PM #3
    tx...btu wat about burning oil?? do you guys haev to put in a quart or two after a couple days of hard driving...liek drivin alot in 2nd or 3rd in high rpms..
  4. Member Maflagulator's Avatar
    Sep 7th, 2001
    Boca Raton, Florida
    2013 Mercedes C250, 2011 BMW X5 Diesel / 2008 VW Passat 2.0t / 2004 Nissan 350Z (for sale)
    08-04-2004 02:31 PM #4
    every couple of days? geez, is this a track car?
    my VR normally burns off one quart between oil changes.
  5. 08-04-2004 02:37 PM #5
    [QUOTE=Eric D]
    [QUOTE]
    unfortunatly this is probably your problem, vr's are known for having week head gaskets. check your coolant before it becomes a bigger problem
  6. 08-04-2004 03:01 PM #6
    good call all_driver,
    my vr was not a fan of its original head gasket either, watch coolant levels like a hawk. you could always put the mkIV head gasket on, it'll bump compression four tenths = bit more power and a nice compliment to your cams.
    Nov 30th, 2002
    Berlin, CT
    08-04-2004 03:19 PM #7
    its most likely the head gasket, u could always do a compression/leak down test to see if thats the problem
    Connor
    Getlow
  8. Member MoTown-VW's Avatar
    Oct 8th, 2002
    Westland, MI
    1982 Rabbit Pick-Up LX; 2007 Rabbit 2.5L
    08-04-2004 03:41 PM #8
    I agree with everyone above. White smoke is probably coolant. Blue is oil.
    I go through about 1/4 quart through my 5,000 miles between synthetic oil changes. I don't drive very hard though. But topping off the oil every couple days seems to indicate a problem of some sort.
  9. Member HiTdAtSiT's Avatar
    May 4th, 2004
    08-04-2004 04:34 PM #9
    check my coolant level ?? my coolant is to the max..recently flushed and added in fresh coolant wit water wetter..and how much do headgaskets go for ?? for the mk4 one ..if you guys say it will compliment my cams more ..and how much would a compression test run around???
  10. 08-04-2004 04:47 PM #10
    HEY I GOT 98 GTI VR6 .. SAME PROBLEM JUST FIXED IT .. ITS YOUR VALVE STEMS.. THERE A BUCK APIECE BUT YOU HAVE TO TAKE YOUR HEAD APART.. I PORTED MY HEAD PUT HIGHER COMPRISON HEAD GASKET AND A 256 CAT CAM WITH BIG LIFT ON IT PORTED MANIFOLD.. I HAD A CHIP TUNED FOR IT .. AND RAM AIR. NOW IT PUT DOWN 192WHP.. AND 182WTQ.. ITS FAST I WAS NECK TO NECK WITH E46 M3 FROM 35-110 MPH BEFORE WE HAD TO BRAKE...
  11. Member HiTdAtSiT's Avatar
    May 4th, 2004
    08-04-2004 04:58 PM #11
    still tho ..am i supposed to check my coolant level your sayin?? and how much does a compression test run?
  12. Member COSitsWORTHit's Avatar
    Nov 25th, 2002
    www.teamkproductions.com
    96 Jetta, 01 focus, 00 focus, 85 LTC, 11 CR-V
    08-04-2004 05:06 PM #12
    Quote, originally posted by gsvr »
    1. Please stop yelling
    2. That M3 driver sucks
  13. 08-04-2004 05:11 PM #13
    WHOSE YELLING
  14. 08-04-2004 05:16 PM #14
    my car runs 13.7 1/4 and weight is down to 2550-2600.. i dont know what m3 runs in the 1/4 mile but.. i am pretty sure its around that..
  15. 08-04-2004 05:18 PM #15
    you shouldnt be burning any collant unless you have a bad headgasket.. then your car should be blowing white smoke not blue..
  16. Member barns20's Avatar
    Mar 30th, 2007
    Pacific, WA
    1997 Jetta Coupe, 1982 caddy, 2000 Subaru imprezza, 2004 Yamaha r6
    06-01-2007 10:52 PM #16
    i think i am having the same problem with mine what does a head gasket cost to replace??
  17. 05-24-2009 07:05 AM #17
    when you do a head gasket you need more than just a head gasket itself. buy a whole gasket set and head bolts which will be around $150. if you dont know how to do it yourself a shop will charge you anywhere from 1000-2000$ in labor. its actually a pretty easy job and i can do one in about 10 hours. but ive taken my motor apart like that many many times. if youve never even removed your intake manifold dont even try it. just take it somewhere. also you'll only have a bad head gasket if you have white foam or gel on your oil cap or if your coolant is starting to turn black and your car is smoking like a mofo. you can have a slow leak which will be less noticeable and harder to diagnose but if its leaking its doomed so just drive it till it pops so you know it was the HG for sure or replace it now.
  18. 05-24-2009 01:53 PM #18
    At age 29 one would hope you'd have the internet thing figured out, but judging by your boy racer bull**** you're still sucking at life.
    WHOSE YELLING
  19. Member jorge r's Avatar
    Apr 27th, 2006
    Los Angeles, 5&110
    vw
    05-25-2009 03:58 AM #19
    Quote, originally posted by HiTdAtSiT »
    Pull spark plugs out and see what they look like, try reading them. Surely burning that amount of oil will leave traces on the plugs.
    I've seen and conclude that a sudden WOT (wide open throttle) will produce white smoke in the exhaust, raw fuel. I know a rich mixture is lack smoke but a gush of fuel comes out like a white cloud, not quite flooded.
    I'd suggest a leak down test to the cylinders, see where the air comes out, you may have a tight engine still, or not.
    Modified by jorge r at 1:01 AM 5-25-2009
