Page 1 of 2 1 2 LastLast
Results 1 to 35 of 48
Thread: Interior FAQ
  1. 08-09-2004 09:31 PM #2
    Bumpin this, if you guys have anymore of these feel free to add them
  2. 08-19-2004 01:54 PM #3
    BUMP!
  3. 08-23-2004 02:57 PM #4
    sticky. nice brian
  4. Member a_grl_n_her_rado's Avatar
    Aug 2nd, 2003
    Baltimore, MD
    2008 Audi A3
    08-31-2004 02:00 PM #5
    can ya sort them by mark? I know not all of them are mark specific but alot of people are gonna get thrown off if they're trying to take out their a2 headliner based on a4 directions.
    I have a few to add for Corrados if you do.
  5. Senior Member CapeGLS's Avatar
    Aug 2nd, 2002
    Connecticut
    01 Golf GLS 1.8T, 02 Jetta WGN 2.0, 11 JSW 2.5SE (Wifes)
    11-17-2004 11:28 PM #6
    Brian: Great post!
    Chamber: My Wheels Rub on the Inside|Forgeline Wheels|WRDusa.com|
    FlickR
  6. 11-23-2004 06:01 PM #7
    Brian,
    I come to this forum to learn about cars, not about your personal opinions regarding women. What did you intend to gain by posting a derogatory quote like that here?
  7. 12-29-2004 09:48 AM #8
    TT pedal install page not found...
    Jun 3rd, 2003
    SF Bay Area
    2011 VW GTI DSG Autobahn
    06-22-2005 03:01 AM #9
    2013 Dodge Charger SRT8 Superbee
    LastHumansGarage
  9. 02-12-2006 11:18 PM #10
    NewSouth Performance Column Pod + VDO Gauge install on 99 B5 Passat
    http://forums.vwvortex.com/zerothread?id=2444372
  10. 02-19-2006 06:08 PM #11
    I need assistance with removing rear door parts on an 06 GLI
  11. 06-20-2006 05:00 PM #12
    Quote, originally posted by djsatan667 »
  12. 08-08-2006 10:31 PM #13
    Do It Yourself Car Seat Cover Removal
    Step one: Remove seat cushions from the vehicle in question, these came out of a VW Golf MK 4 if you need assistance in removing the actual seats, its fairly easy. I'm a petite girl and I had zero issues. The rear cushions basically pop off with one pull at the front tab and then unhinge from the rear. The actual rear top cushions need to be unbolted from the back. Same goes for the front seats. There are two bols in the front on the floor in the center .Once you remove the caps from the rear of the side rails, they just slide off.
    Step two: Flip the cushions over and find the black plastic that is tucked underneath the metal framing. The easiest way to do this is start at the exposed section and with a screwdriver
    pull a small peice out and then pull towards you. Do this all the way around and the metal frame basically falls off. It looks like this:
    Step Three:/ Starting at one side GENTLY pull the cover from the foam. As you start to do this you come to some channeling in the foam and those dreaded metal bars with the upside down bent into itself hook at both ends. I reccomend finding a good tool to pull with. I DO NOT reccomend undoing the hooks via manual distortion as you will need these again. This part requires PATIENCE. If you dont have the patience dont attempt this get someone to help you as you could destroy the foam cushion. I used a variety of tools until i figured out that a paint can opener of the metal variety works best. It has a little hook at the top and a bottle opener thing at the top and I think cost me $1 at Home Depot. It looks like this:
    Step four: Using the tool of your choice, hook into the metal loop at the top and pull slightly out note that I said out and not UP. This requires a little manipulation of the foam part but is pretty hands on, theres no real way to explain it, when you see it you'll understand. Try from a few angles I promise it just takes a little manipulation and not sheer force. I am a small girl and once I got the technique down it required very little actual force. I did not bend any of the metal rods in any way. They do not need bending to come off. I promise.
    Step five: Once you get the metal rod out of the channel flip it over and do the other side. I highly reccomend doing the two sides first and then the centers top, bottom, then middle as
    it makes the foam easier to manipulate. The rods just slide out of this little fabric pouch and can be set aside. Once you have these off you can wash the covers or reupholster them as you like. DO NOT PUT THE COVERS IN THE DRYER. Leave them out to air dry as it will probably warp the foam if it goes in the dryer.
    Replacement of covers is basically the same but backwards. I reccomend patience. I did it in a short amount of time. Once you get the hang of it, it is really quite a simple task.
    Ms. AlinaSquid signing off.
  13. Member dmf2442's Avatar
    Sep 21st, 2006
    Rochester, NY
    2005 TDi
    10-04-2006 04:03 PM #14
    Anybody know how decent the red or blue color match is on lit reiger gear shift knobs? I've got an '05 TDi and don't want a gear shift that lights up different from my instrument panel. Anyone?
  14. Member alpha_omega's Avatar
    Nov 11th, 2006
    Akron, OH
    04.5 BL Stg 2+ GLI - 01 Jetta GLS VR6 (SOLD) - 00 JTI VR6 (SOLD) - 00 Jetta VR6 (DEAD)
    11-13-2006 12:09 AM #15
    Hey.... I need to replace the vent on the passenger side of my 2001 Jetta GLS. The flaps that control the up/down angle of the air flow are broken. Know where I can get a replacement and how to install it?
    04.5 Blue Lagoon GLI - Gonzo Stg 2+, APR TIP, EuroJet Discharge Pipe, 42DD 3" DP w/ HiFlow Cat, Forge 008 DV, Audi 2.0t Coilpacks, Upgraded SMIC
  15. Member alpha_omega's Avatar
    Nov 11th, 2006
    Akron, OH
    11-13-2006 11:00 PM #16
    anybody?
  16. 01-15-2007 11:09 PM #17
    COOLWATER! <~ AL
  17. Member DaddyOfPayton's Avatar
    Feb 24th, 2004
    Hilliard/Columbus, OH
    06-05-2007 11:33 AM #18
    The link to the Mk3 gauge cluster removal is LONG dead (S3 designs went away nearly 2 years ago)
    My name is...Shake-Zula. The mic-rula, The old schoolah, Ya wanna trip? I'll bring it to ya. Frylock and I'm on top Rock you like a cop Meatwad you up next with your knock-knock. Meatwad make the money, see. Meatwad get the honeys, G. Drivin in my car, livin' like a star. Ice on my fingers and my toes and I'm a Taurus. Check it. Check, check it. 'Cuz we drive the Cabrios, make the homies say ho! and the girlies wanna scream.
  18. 06-05-2007 07:45 PM #19
    Quote, originally posted by DaddyOfPayton »
    removed it, if anybody else has any good links, PM me and I can throw them in the original post
  19. Member Rockstar24's Avatar
    Aug 2nd, 2005
    Montana
    '89 GTI, 03 Tundra
    02-23-2008 10:51 AM #20
    Anyone have some information installing a kneebar into an 89 GTI? Do I have to have a center console? Or can I run open?
  20. Member Justaviper's Avatar
    Jul 24th, 2007
    Fort Bragg - North Carolina
    1983 VW Golf II 16v
    05-05-2008 01:14 AM #21
  21. 05-13-2008 10:37 AM #22
    Mk 4 four spoke steering wheel removal?? anyone know the nut size...
  22. 05-31-2008 02:33 AM #23
    I think it 24MM nut that hold the steering wheel. It the same for all MK3, MK4 Vdubs. Good luck.
  23. Member Bens00VW's Avatar
    Feb 16th, 2008
    Bummville
    MKV GLI
    06-04-2008 07:13 PM #24
    alright so i was cleanign out the interior of the car, and found two random springs under the seats. i have an 00 mrkiv with cloth seats. what are they and do i need them?
    Unghhhh Uhhhh
  24. 07-13-2008 01:41 PM #25
    Do you know a link that shows you how to remove the gauge cluster plastic lens cover without breaking it for the MK3 Jetta? I want to paint the bezel. Tnx
    Modified by jmj5150 at 10:47 AM 7-13-2008
  25. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    08-18-2008 01:27 PM #26
    What happened to the head unit install link?? Just bought a '96 Jetta & wanted to read before I tore it apart... I also would like some info on Vent repair. Searching... Searching... Searching...
    Modified by macanic21 at 10:29 AM 8-18-2008
    96 Jetta 5pd
    worked head w/276
    C2 Stg2 (works like crap)
  26. 09-23-2008 12:57 PM #27
    i have a question...my 1990 vw gti 8 valve has a leak on the passenger side right against the door panel under the dash. i have traced it to some sort of vent that is on the top left end of the hood. when i purchased the car, there was a window screen there which led me to believe it was rigged lol, but what is missing there and whats is causing so much water to end up on the passenger side floor?????
    thanks nolan
  27. Member DaddyOfPayton's Avatar
    Feb 24th, 2004
    09-27-2008 03:20 AM #28
    Hey nolan, I am not a mk2 expert, but most VW's have a fresh air intake at that point. the screen was likely replacing the raised cover that prevents water from entering the heater box. I would start by checking under that part of the windshield. Then you will probably see where the water is entering the car.
    HTH
  28. Member maxslug's Avatar
    May 22nd, 2005
    sf
    mk3 3.0 vrt, n55 135i
    04-12-2009 02:36 AM #29
    DIY - Install Recaro seats w/ Wedge Engineering Brackets and Schroth Harnesses on a MK3 GTI : http://www.gti-vr6.net/wiki/in...stall
    I'm the host of the GTI-VR6 List and Wiki
    I drove in the 24 Hours of LeMons at : Altamont:2006, 2007, 2008 Fernley:2009 and Sears Point:2010 and am looking for a new team in the Bay Area... hit me up!
  29. 05-14-2009 04:50 AM #30
    Hi
    Damaged the upper air vent trim on my Golf GTI MK V. Managed to buy a new one but am having difficulty removing the hazard light button and airbag warning light from the old unit.
    Do they just unclip (with a bit of force) of are special tools required?
    Thanks for any help.
  30. Member dudeman08's Avatar
    Feb 22nd, 2009
    Philadelphia, PA
    1998 VW Jetta, 1967 Buick Sportwagon, 1972 Plymouth Valiant 4dr (F/S), 2009 VW Jetta GLI
    09-21-2009 04:50 PM #31
    anyone kno how to relocate the radio from the dash to the center console in a mk3? all help would b greatly appreciated.
  31. 11-11-2009 09:46 AM #32
    I have a 98 Jetta GLS and my turn signal (either side) is stuck. the light comes on, but it doesn't blink. I can see that the outside lights come on and stay on as well. any suggestions?
    Modified by 98Jettaisbetta at 6:48 AM 11-11-2009
    Modified by 98Jettaisbetta at 8:16 AM 11-11-2009
  32. Member harleybrown4160's Avatar
    May 1st, 2009
    The Lou
    2000 VR6 Jetta 1990 G60 Rado Mega Mod 2002 225 Quatro TT and some bikes
    11-12-2009 10:59 PM #33
    beauty is in the eye of the beholder and quotes like that are funny unless they hit close to home its a hazzard of a primarily male dominated hobby and site but dont worry I bet there are some swishes around who fit in there too. Its like T.V. dont like the show dont gripe change channels. just my .02
  33. Junior Member [BOPE]96GTi's Avatar
    Jul 21st, 2009
    96 MkIII black GTI "Shirlei" 89 W201 black 190E 01 White Nissan Frontier
    01-26-2010 11:04 PM #34
    I think that a sunroof could count as interior work...my sunroof jammed then when attempting to fix...broke. Anywho, need some info on removal of sunroof and frame, and info on any possible frames for a mk3 GTi...thanks
  34. 02-13-2010 02:22 AM #35
    Dose anyone know or have pictures how to remove the front pillars, middle and rear pillars on a mk4 gti?? please i can not find it anywhere.
    Thank you!!!!!!
