So i'm a bit confused on the front cross member set up for both the motor mount and lower rad support.
I am planning on running my MKIII VR Rad and fans... from my research I bough the Passat 16V cross member both the radiator half and motor mount half.
It doesn't seam to line up... the tow bar on the rad support hits the tow bar of the MKII frame... and I haven't played with it yet, but It doesn't appear that the motor mount is going to work.
Can anyone verify if the pictures below are indeed from a 16V Passat and if this setup is supposed to work... or am I all screwed up.
My Dub, So does your girl.
