Page 4 of 155 FirstFirst 1 2 3 4 5 6 7 8 14 54 104 ... LastLast
Results 106 to 140 of 5421
Thread: A2 VR6 FAQ
  1. 01-19-2005 09:18 PM #106
    is there anyone close to New Jersey that know what they are doing and will like to help me finish up my swap
    Jan 26th, 2002
    NYC
    01-22-2005 04:42 PM #107
    I'm using an engine harness out of a GLX and have a G60 radiator with the rectangular plug, but my harness has the round connector. Will the fan switch for the VR6 radiator fit in the G60 rad?
  3. Member GTi_94's Avatar
    Oct 9th, 2002
    Calgary, Alberta, Canada
    2013 CW 2DR GTi 6spd
    01-23-2005 11:46 PM #108
    The holes in the rad have been virtually the same from '76-present...
    Both Rad themal switches should fit.
    Bryan
    2013 CW 2dr GTi 6spd
    LED Tail Lights, w/ euro switch and rear fog
    Rear View Camera
  4. Banned jetta88a2's Avatar
    Jul 26th, 2001
    01-28-2005 04:22 PM #109
    I didnt see this posted in here and figured it might help those of you without bently's...
    http://www.3dzubehor.com/pages/howto2.html
  5. 01-29-2005 11:57 AM #110
    how do i bolt on the 92 corrado steering col. to the corrado rack the right way
  6. Member
    Jan 26th, 2002
    NYC
    01-30-2005 04:21 PM #111
    Quote, originally posted by wildout »
    Make sure you have the right u-joints and it should bolt right up.
    Now for my question
    I'm not getting power to my gauge cluster. Its a mkIII cluster, I made the jump from D8 to E2 and still nothing. The LCDs are on without the key turned but as soon as I turn the key....nothing. Please help, seach is down and I want to figure this thing out. Any help, as always is much appreciated.
    Edit: Search is back up. Turns out I was using the original cluster harness. I got the mkIII cluster harness and should be good to go. Move along, nothing to see here.
    Modified by darren p. at 11:40 PM 1-30-2005
  7. 02-02-2005 08:27 AM #112
    what do i have to do to bolt the column inside of the car
    i have a corrado ster. colu.
  8. 02-02-2005 08:30 AM #113
    do anybody know where to plug the rubber hose that comes from the back of a corrado cluster
  9. 02-03-2005 09:26 AM #114
    can i use the corrado sleeve or do i have to use a different sleeve
  10. Member
    Jan 4th, 2002
    northern nj
    81 rabbit, 02 mini cooper s
    02-03-2005 04:52 PM #115
    i dont know man, but maybe you should just get in there and look. thats an easy way to find out.
  11. Member Tire_Marx's Avatar
    Mar 3rd, 2004
    Winnipeg, MB
    02-05-2005 01:47 AM #116
    does the mk3 kframe make the engine sit a little higher on one side? how do you prevent that?
    2002 Lexus IS300 - Trac off is just Japanese for sideways on
  12. Member A2brb's Avatar
    May 29th, 2003
    Louisville, Ky
    91 GTi VR6-t, 91 Jetta Carrat
    02-05-2005 05:58 PM #117
    Quote, originally posted by Tire_Marx »
    Yes, It sits a little higher and will give it a little tilt.
    I don't know about Adjustment for the A3 K-frame but....
    To avoid this you can use a Corrado Vr6 K-frame which will allow the engie to sit a little lower and more level in the Engine Bay than the A3 K-frame.
    This is what I'm using in my swap just because of this issue.
  13. Member
    Jan 4th, 2002
    northern nj
    02-05-2005 09:33 PM #118
    you can also cut the rear motormount down. i dont know how much but its very simple. maybe someone who knows for sure will post.
    forgot to mention, but i have the corrado rear subframe and the rear mount still had to be cut down.
    Modified by ArpyArpad at 9:34 PM 2-5-2005
  14. 02-06-2005 12:58 AM #119
    why use the mk2 frame?
  15. Member EuroRabbit's Avatar
    Aug 4th, 2003
    Vermont
    86 Cabby, 90 VR Jetta, 86 GTI
    02-06-2005 02:47 AM #120
    Why dosent the front cross member for the motor mount work from MK3 VR's?
    Also can I use the MK2 cat and exhaust?
    Modified by Jetta90WB at 2:48 AM 2-6-2005
    Thanks VWvortex for the hard work!
  16. Member Tire_Marx's Avatar
    Mar 3rd, 2004
    Winnipeg, MB
    02-07-2005 09:50 PM #121
    when using a g60 speedo cable, does it do anything funky with the vss stuff? like does it hamper the revs, cap the speed, anything wonky like that?
    i'm intending to use my original cluster with a futrell/MMP tach converter
  17. 02-08-2005 01:41 PM #122
    I checked futrell's site for this and I can only see the 1.8 & 2.0l converters on there. Anyone have a link? I am in need of one of these as well.
  18. Member Tire_Marx's Avatar
    Mar 3rd, 2004
    Winnipeg, MB
    02-08-2005 05:27 PM #123
    Quote, originally posted by 92vr6Jetta »
    i emailed futrell, they dont have them listed, but they DO have em. they are $300 us. canadians can get the same thing from MMP, same price
    but, yesterday i think i found a BETTER option
    email sales@fastforward.ca
    canadian based company, they can integrate harnesses and such, and he said for about 250 canadian, he can configure the tach AND set up a VSS sensor at the speedo (meaning, you need the g60 cable, BUT you can send the ecu a VSS signal)
    this looks the most promising, and its a DAMN good price
  19. 02-12-2005 05:25 PM #124
    can G60 spindles work with 'plus' control arms? and if you can what axles would be best
  20. Member A2brb's Avatar
    May 29th, 2003
    Louisville, Ky
    02-14-2005 08:52 AM #125
    Compliments of Jeffrey B:
    Here is some good Info that may help you guys Sort through some of the parts you can use.
    To keep your car 4 lug you can go a couple of different ways.
    1. Use the A3 ('93-99 Golf/Jetta) K frame with A-arms, axles, spindles, PS, etc. and add G60 or VR6 calipers, and G60 11.0" rotors. This will result in a little wider track on the front than what you have with A2 stuff on the car now. (this is what the white car had.
    2. Use the A3 or Corrado K-frame, but use A2 A-arms and axles. Use Corrado or A3 power steering rack with A2 tie rod assemblies. Use the A3 4 cyl. spindles, and Corrado G60 or Vr6 calipers, and G60 rotors. Use the A2 sway bar as well.
    The Corrado K-frame will sit the engine a little lower, and a little more level in the engine bay.
    To do the AC, you will need to pull the dash. This will also make it much easier to swap the pedal cluster. Pull the dash, and pull the Ac blowerbox out. exchange the R12 evaporator core out for an R134 one. Use the R134 expansion valve. Use the Corrado VR6 AC lines. You can use the Corrado VR6 or a regular A2 condenser. Use passat VR6 or Corrado VR6 cooling fans. If you use passat , you will have to trim the bottom of the fan shroud to fit the height of the G60 or Corrado Vr6 radiator that you will use.
    If you are buying suspension for the car, A3 4cyl stups work well in the A2's. The A3 is a heavier car, and the heavier VR6 motor makes up for the weight difference in the chassis of the cars.
    To hook up the AC, if you use a '92 Corrado for wiring it is a plug and play affair. If you use anything else , it will be a "get both bentleys out and compare affair."
    Here is a basic rundown on what you can use:
    front motor mount carrier - Passat VR6 or Corrado VR6
    K-frame -A3 4 cyl or 6 cyl, and Corrado VR6. (just remember that you have to use 6 cyl. A-arms with 6 cyl. axles, and vice versa.
    Rotors - Corrado G60 for 4 lug, and VR6 rotors for 5 lug.
    PS lines - VR6 A3, passat, or Corrado. Corrado VR6 work best.
    PS rack - A3 , 4cyl or 6, Corrado VR6 , or Passat VR6. Just remember that you will match up the tie rod assemblies with the A-arms that you are using.
    Spindles - A3 4 cyl., Late A2 with 10.1 brakes, Passat 16v, or Corrado G60 for 4 lug. Any thing VR6 for 5 lug.
    Calipers - G60 or VR6 (they are the same in 11.0" )
    Swaybar - match up the swaybar with the A-arms.
    Shifterbox - Corrado G60, anything VR6
    Pedalbox- Corrado (Vr6 or G60), Passat (16v or VR6)
    Brake Booster and Backing plate - Corrado G60 non ABS, or passat 16v
    Clutch slave and Master - Corrado G60 or VR6, Passat VR6 or 16v
    Instrument cluster - Early A2 with MFA (86-89 Golf 16v's, or 85-87 GTI or GLI 8v) (Have to make hybrid harness for it to work)
    Exhaust - TT for A2 VR6 conversions
    Rear Axle beam - Any A2 with rear discs, or A3, or Corrado.
    Gas tank and pump - Use the one in the car, or swap the one from your A3 or Corrado Donor car.
    Speedo Cable - Corrado G60
  21. Member
    Jan 26th, 2002
    NYC
    02-15-2005 07:36 PM #126
    My Auxilery Coolant Pump isn't coming on, nor are my fans. I've checked the fuses in the fan control module and the one in the fuse box and they are all good. I've done the tests in the Bentley and I get nothing. I'm thinking the FCM isn't getting power. The engine came from a 96 GLX and so did the wiring. Do these things go bad or is it possible I didn't hook something up? Any wiring I should specifically check other than what the Bently says? Any help is appreciated. Thanks.
  22. 02-18-2005 12:17 PM #127
    can antone tell how i can find a diagram to hook up the rear ce1 harness to a ce2 harness at the fuse box
  23. Member mack73's Avatar
    Jan 2nd, 2002
    Seattle
    '08 LR3 HSE, '04 A4 3.0Q, '94 Golf Rally Car
    02-21-2005 10:19 PM #128
    I've got a complete MKIII OBDII GLX that was totaled (rearended)
    What parts would I need to swap into a MKII (I plan to use everything from the MKIII, dash, wiring, fuseblock, engine, 5 lug suspension. I see most parts need modification which I'm ok with, but is there anything I would need to source from a corrado/B3?
    '08 LR3 HSE: The Daily/Off-Roader
    '04 A4 3.0Q: The Wife's Ride
    '94 Golf Rally Car: Watch The Build
  24. Member white86gti's Avatar
    Feb 19th, 2005
    Denver,CO
    06 EVO IX, 82 Caddy 1.8T
    02-23-2005 09:47 PM #129
    so the only readon you go with the mk3 pedal cluster (if your not going abs) is for the clutch?
    I thought i read on here some where that you could buy a bracket or housing to convert the VR6 tranny?.
  25. Member carpathianwolf's Avatar
    Jul 9th, 2003
    Vancouver
    92 GTi VR6, 04 Touareg
    02-24-2005 05:59 PM #130
    ok I'm having some issues understanding the list on the first page.
    Need some clarification on the Front Cross members (radiator half)
    I have original A2 cross member, I have a A3 VR rad/rad fan assembly, and I also have a Passat 16v front cross member (rad)
    What are my options? or what should I go and buy?
    thanks
  26. 02-25-2005 10:40 AM #131
    you need the part with the motor mount from a corrado or passat VR6 or you need to use a solid front mount.
    the passat 16v radiator half will work very well with the MK3 VR6 rad/fan setup... it puts it in square across the car and gives you some extra engine clearance
  27. 02-25-2005 11:20 AM #132
    The engine and harness is out of a 97 jetta glx OBD II
    I need help with my mk2 VR6, I need to reconnect my both O2 sensors, the secondary air pump and the combi valve, I was just told that they were disconnected on my car, and I'm thinking about legalizing the car, so need to put those back, the problem is, I don't have those items, nor I think the wiring that goes to those items is there. I'll probably have to rewire it or something, I'll have to look a little further,
    I think I found the O2 sensor wires, but not sure which one goes to which O2 sensor, there are 2 stacks, but both are 5 wire, one goes to precat one post cat, but which is which?
    Does the wiring for the secondary air pump and combi valve come with all the other wires that come to engine and connect to it with a big round harness or they are seperate?
    I also need help on the canister, what carbo canister can I use? Can I use a canister off of a 92 8v mk2 gti on my VR6?
  28. Member carpathianwolf's Avatar
    Jul 9th, 2003
    Vancouver
    02-25-2005 12:56 PM #133
    are there any mods I need to do to the 16v cross member or will it just bolt in. Reason I'm asking I was looking at it and looks very different compared to a stock mk2 or corrado. Thank you
  29. 02-25-2005 03:03 PM #134
    you have to cut off the tow hook area and the same part on the other side, other then that it will fit right on top of the other half with no problems
  30. Member carpathianwolf's Avatar
    Jul 9th, 2003
    Vancouver
    02-25-2005 03:22 PM #135
    My original bolts bumper are too short, they do not reach the rail, do i need longer bolts? also noticed that the cross member has holes for the mk2 style rad (pegs on the rad) compared to the mk3 rad has holes. Can you give me some info on that.
    thanks
  31. 02-25-2005 07:00 PM #136
    Well... all I can say is it is not a direct it, nothing is when you are swaping parts that are not from the car originally.
    You just have to deal with the problems as they come up, you should not need longer bolts. As for the holes you just need to put bolts through the grommets on the MK3 rad and secure them from underneath with a nut.... again nothing is perfect, you have to figure it out but it is close
  32. Member white86gti's Avatar
    Feb 19th, 2005
    Denver,CO
    02-26-2005 08:06 PM #137
    I have an a3 vr6 available to me. should i gother taking the struts off of the car?
  33. Member Tire_Marx's Avatar
    Mar 3rd, 2004
    Winnipeg, MB
    02-28-2005 06:35 PM #138
    what needs to be done for the brakes/proportioning valve with a mk3 vr6 rear beam being swapped?
  34. 03-01-2005 01:17 AM #139
    Ok I'm missing a few things the reverse light switch wiring and the wiper motor wiring. I'm using a 97 passat engine harness and a 90 g60 headlight harness. Do I have to add these or am I missing something?
  35. Banned Blue Boost's Avatar
    Jun 15th, 2004
    03-01-2005 05:51 PM #140
    Any vr swap pics / progress pics
