Page 11 of 62 FirstFirst ... 7 8 9 10 11 12 13 14 15 21 61 ... LastLast
Results 351 to 385 of 2138
Thread: lets get a ABA 16v Parts List/FAQ Thread going
  1. 07-25-2005 09:07 PM #351
    uhm...well the block, and head, and throttle bodies....access to a machine shop (or deep pockets) and probably want a higher compression since the low c/r are good for boost....
  2. Member Chris164935's Avatar
    Jan 9th, 2004
    Orange Park, FL
    2001 Audi A4. 2001 Audi A4.
    07-26-2005 02:34 PM #352
    And some sort of stand-alone management, I believe.
    "You know you have a bad idea when Ford guys are making fun of you."
    FS: Autronic SM2, 500r CDI, Misc. Related Parts.
  3. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    2001 Dodge Ram 2500 CTD 6speed, 82 ABA-swapped Caddy
    07-26-2005 02:54 PM #353
    Off-Topic:
    Chris - I read you signature and had a hard time believing that the '05 GLI weighs 3800 lbs.. That's what my '85 BMW 745i Turbo weighed 3800 and it's way bigger and more solid than the Jetta.. So this is what I googled..
    Vehicle Dimensions
    4-door sedan 4-door wagon
    Wheelbase, in. 98.9 99.0
    Overall Length, in. 172.3 173.6
    Overall Width, in. 68.3 68.3
    Overall Height, in. 56.7 58.5
    Curb Weight, lbs. 2895 3034
    Cargo Volume, cu. ft. 13.0 51.9
    Standard Payload, lbs. -- -- -- --
    Fuel Capacity, gals. 14.5 14.5
    Seating Capacity 5 5
    Front Head Room, in. 38.6 38.6
    Max. Front Leg Room, in. 41.5 41.5
    Rear Head Room, in. 36.9 38.1
    Min. Rear Leg Room, in. 33.5 33.5
    Unless you've got 1000lbs of stereo equipment
    Edit: link for reference: http://auto.consumerguide.com/...Specs/
  4. 07-26-2005 05:40 PM #354
    Quote, originally posted by Chris164935 »
    what is the best one to use and want do i need to get high compression... and i am pretty posive that the 05 jetta weights about that much... just look on the door
  5. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    07-26-2005 08:35 PM #355
    Quote, originally posted by 18T MKIV »
    hi compression and boost = boom..
    door weight is gross weight (car + cargo/occupants)
  6. Member Chris164935's Avatar
    Jan 9th, 2004
    Orange Park, FL
    07-26-2005 10:41 PM #356
    Whoops. Fixed it. Hey, quick question: How can I run a 15 flat at 94 mph? My fastest (as you've seen) is 14.6, but at 92 mph...
    Anyway, one good (and cheap) stand alone management would be Megasquirt/Megaspark. You have to pretty much build the whole setup yourself, but it's still way cheaper than other kits.
    Modified by Chris164935 at 10:42 PM 7-26-2005
  7. 08-10-2005 06:51 PM #357
    launch and accel. would be my guess, your 15 flat at 94mph probably had a bad launch compared to your 14.6 at 92mph
    someone correct me if wrong
  8. Member hasnfefr's Avatar
    Sep 25th, 2002
    Elyria, OH
    75' scirocco, 80' caddy, 84' rabbit gti w/callaway stg2, 87' 16v scirocco, 93' corrado
    08-23-2005 10:53 AM #358
  9. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-23-2005 11:04 AM #359
    Rule of Thumb:
    Torque gets you e.t.
    Horsepower gets you mile per hour
    14.6 @ 92 would calculate to 188hp in a 3000 pound car (using RWD calculations, though..) Either way, this is an accurate measurement, mph vs. ET..
  10. Member pozer's Avatar
    Dec 21st, 2001
    Madison Wi
    08-23-2005 04:00 PM #360
    Quote, originally posted by qwikxr »
    Rule of Thumb:
    IS this WHP or Crank? I have allways wondered what to use when doing this calculation.
  11. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-23-2005 04:26 PM #361
    Generally speaking (with RWD cars, as I am most used to), it is related to whp. I know there are multiple variances when calculating fwd figures..
  12. 08-28-2005 03:39 PM #362
    wondering if anyone knows the stock c/r for the 1.8 acc motor.
    i'm thinking of doing a 16v or 8v turbo.
    since the aba and acc blocks are almost identicle, i was thinking it should be a lower c/r since the acc is a mono-motronic, and built for fuel economy.
    what do you guys think about this idea?
  13. 08-28-2005 07:51 PM #363
    i havent read the whole 10 pages....
    but what do you do about the crank pulley? isnt the 16v belt wider?
    can you run aba accessories?
  14. 08-28-2005 09:13 PM #364
    there's an adapter pulley for the swap or you can shave the 8v pulely
  15. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-28-2005 09:14 PM #365
    waterneck on the front of the 16v head will interfere with the tensioner spring section of the accy bracket.. you'll need to mod the filler neck a little..
  16. Member ubergolfgl's Avatar
    Oct 11th, 2004
    Melbourne, FL
    08-28-2005 10:22 PM #366
    theres a lot of info to go through in here, but in the first post it said an OBD1 ABA block. what is the difference between the OBD1 and OBD2 blocks? can i use an OBD2 block instead, because i have access to one i can rebuild. thanks guys.
  17. Member ROBHARMER's Avatar
    Aug 26th, 2004
    Long Island
    95 GTi, 98 Grand Cherokee
    08-28-2005 11:48 PM #367
    Im putting together my ABA 16v right now and i slid the Int Shaft into the block, slid the oil pump into the block, and put the Oil pump Drive gear onto the shaft of the oil pump. My problem is that it doesnt even touch the gear on the Int shaft?? it just doesnt seem to line up at all. I have the 16V int. shaft, Oil Pump and Drive gear but for some reason nothing lines up.....I also had a bit of trouble fitting the TDI crank it was tapping the oil sqirters a little bit, that problem is resolved but did anyone else run into anything like that installing the 95.5 crank? So basically i diddnt get very far tonight and ive been here for like 4 hours.
  18. Member pozer's Avatar
    Dec 21st, 2001
    Madison Wi
    08-29-2005 01:53 AM #368
    Did you get the 1.8 or the 2.0 IM shaft. from what I have heard the 1.8 shaft don't fit...
  19. Member ROBHARMER's Avatar
    Aug 26th, 2004
    Long Island
    08-29-2005 08:18 AM #369
    not sure if its 1.8 or 2.0, i thought the diffrence was thickness of the shaft, i thouht the 2.0 skinnier, to clear the bigger crank. can someone confirm?
  20. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-29-2005 08:26 AM #370
    No, more to it than that.
    THe actual bearing race areas are larger on the 2.0 16v Int. shaft, than the 1.8L 16v. That I do know. The 2.0 will not fit in a 1.8 block, and the 1.8 fits sloppy - and short, i think..
  21. Member ROBHARMER's Avatar
    Aug 26th, 2004
    Long Island
    08-29-2005 09:15 AM #371
    It has to be 2.0 shaft now that i think about it, the crank spins freely no interference from the int. shaft. and if your saying the 1.8 would fit sloppy then it definatly cant be wrong because the shaft fits nice and tight, no slack in either of the races. Is there a part i need to install other than just the drie gear, is there a spacer or something thatmight make the gear itself fit? i have to say im pretty confused right now.
  22. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-29-2005 09:19 AM #372
    do you have the cover piece and stuff to compensate for the lack of distributor? you are using the 16v dizzy ?
  23. Member ROBHARMER's Avatar
    Aug 26th, 2004
    Long Island
    08-29-2005 10:43 AM #373
    no i dont have a block off or anything, and yes im using the dizzy from the 16v.
  24. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-29-2005 10:55 AM #374
    what are you replacing the ABA distr. with, then? What are you using to compensate for the now missing block dizzy?
  25. Member The Hater's Avatar
    Jun 23rd, 2003
    Dirrrrty Dirrrrty Jersey
    08-29-2005 11:09 AM #375
    the aba distributor hole gets blocked off with the 16v block off plate...
    and then you run the 16v distributor in the head..
    all you gotta do is read read read...
  26. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-29-2005 11:19 AM #376
    Quote, originally posted by The Hater »
    chill, dude.. I wasnt asking as a group.. I was asking ^^ is efforts to ANSWER or HELP RESOLVE HIS issue..
    friggin relax., read read read
  27. Member ROBHARMER's Avatar
    Aug 26th, 2004
    Long Island
    08-29-2005 12:13 PM #377
    I was planning on getting the block off, just diddnt have acces to one just yet, is it critical? could that be why this whole thing isnt lining up?
    I knew what you meant, I do appriciate the replies.
  28. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-29-2005 12:23 PM #378
    Detrimental to get all the related parts from the 16v.
  29. Member The Hater's Avatar
    Jun 23rd, 2003
    08-29-2005 12:37 PM #379
    maybe you should have quoted him then...
    in any event, this thread has pretty much every bit of info one could need to do an aba/16v but noone reads the thread...how is someone going to build a motor if you can't read?
  30. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-29-2005 12:46 PM #380
    if you'd followed the last 4-5 posts of the thread, you could have figured that out.
    I'll ensure I quote from now on to appease the masses.
    I agree with your statement, as well, but is definitely needs cleaned up a bit. This thread is getting long in the tooth and is cumbersome to sort through, anymore.
  31. Member
    Jan 23rd, 2004
    Seattle
    1986 GTI ABA16VT
    08-29-2005 12:54 PM #381
    What kind of mod do you have to do on the water thingy from the head and where do you get the modded aba crank pulley cause i figure it will be cheaper to run aba accesories than finding 2.0 16v pulleys and gear... thanks
  32. Member The Hater's Avatar
    Jun 23rd, 2003
    08-29-2005 01:10 PM #382
    Quote, originally posted by eurotuner-a2 »
    Qwikxr - see what i'm talking about? people don't even bother to read the first page anymore...the first post gives his crank pulley answer...
  33. 08-29-2005 01:22 PM #383
    i spent a good 45 minutes reading the whole thread last night.
    it contains every thing you need to know about the aba 16v swap
    it's well worth the read. it's just the last few pages that get messy
    i j ust wish i could find out what the stock c/r is for the acc block.
    i'd love to do this but i need to figure out if it's gonna be an easy job of a tonne of machining
    Modified by mrkil at 10:24 AM 8-29-2005
  34. Member qwikxr's Avatar
    Feb 9th, 2003
    Virginia
    08-29-2005 01:35 PM #384
    werd
  35. Member ROBHARMER's Avatar
    Aug 26th, 2004
    Long Island
    08-29-2005 02:05 PM #385
    Yea i see that but how can a plug stop two stationary gears from lining up. I have all the other necesary parts but that was left off when i bought them, I diddnt forget it i just dont have it.
    By the way, i spent all morning pretending to work but really i was reading this thread, It says nothing about IM shaft/Drive gear lining up. I know the list of parts needed for the swap, i could rattle them off in my sleep. the thread does need to cleaned up if was patient enough id cut and paste all the relevant info into a new thread but im just not patient.
    Modified by ROBHARMER at 11:09 AM 8-29-2005
