VWVortex.com - lets get a ABA 16v Parts List/FAQ Thread going
    Page 4 of 91 FirstFirst 123456781454 ... LastLast
    Results 76 to 100 of 2275
    Thread: lets get a ABA 16v Parts List/FAQ Thread going
    1. 09-28-2004 10:16 PM #76
      Quote, originally posted by all-starr-me »
      Are you going turbo or N/A? The 9A pistons will give you an 8.5-9:1 compression ratio, great for turbo, but you still won't gain much from keeping it N/A. If you aren't going for a charger then factor in some good cams, or at the very least a euro intake cam.
      If you are OBD 1 you should be able to use the g-60 or auto 16v throttle body, otherwise you will need an adapter plate to fit your aba throttle to the manifold.
      You left out a 16v fuel rail, bbm or ross machine racing have them. you will need digi injector cups to make your injectors fit.
      If you are staying N/A then get the ABF pistons that I posted on the previous page. The distributor block off plate comes from a 16v engine, the one TT sells is to block off your breather, not your distributor.
      Use you A3 accesories, but you will need 6mm shaved from the serpentine pulley. I have seen some people weld or machine the 16v intermediate timing gear to fit on the 8v intermediate shaft, saves having to change the oil pump and intermedait shaft, but leaves you with an extra distributor.
      For N/A gains try and get a 50mm euro manifold or an ABF with fuel rail and throttle body. for turbo a short funner will be better.
      You could do this swap with 400, but it wouldn't either A.) be turbo and B.) gain you very much if any real power.
      aaahhhhhhhhhhhhhhh F*ck it. I just bought the TT kit - adj cam, camshaft, valve springs, arp studs, giac 268 chip, and gasket set all for $225 so that will keep me happy until i sell the golf and buy a S13 240sx and turbo it for 240+hp [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by LouderLowerFaster at 10:20 PM 9-28-2004
    2. Member Chris164935's Avatar
      Jan 9th, 2004
      Orange Park, FL
      2016 Audi A3. 2001 Audi A4.
      09-29-2004 03:31 PM #77
      Quote, originally posted by Chris164935 »
      Also, does anyone make adapters to use the ABA throttle body with the 9A intake manifold? And will the ABA fuel injectors fit in 9A manifold as well?
      "You know you have a bad idea when Ford guys are making fun of you."
      Spice Rubs: Rick's Rubs
    3. 09-29-2004 08:41 PM #78
      yes, any machine shop should be able to make an adapter to fit the ABA throttle body on the 16v manifold, Get some gaskets from both to use as templates. The injectors will fit if you put digi injector cups in the manifold.
    4. Member A3dOUde's Avatar
      Dec 22nd, 2002
      Canada
      09-30-2004 03:21 PM #79
      I know Trac Racing sells a pulley for 1.8T in mk3 conversion pulley that will fit our need [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      09-30-2004 04:05 PM #80
      Guys, I have a full ABA/16v setup ready to be put together:
      HERE
      Just in case anyone wants the easy way out.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    6. Member A3dOUde's Avatar
      Dec 22nd, 2002
      Canada
      10-01-2004 08:43 AM #81
      for a bolt on turbo setup... there will still be some missing parts... so imagine in a n/a setup...
      but officially, it's a good start at a fair price
    7. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      10-04-2004 08:00 AM #82
      Quote, originally posted by A3dOUde »
      Thanks.
      -Paul
    8. Member urspeedracer's Avatar
      Mar 6th, 2002
      Bloomfield, NJ
      2001 Audi A4 1.8T 2001.5 VW Passat V6 2012 VW Beetle
      10-04-2004 06:01 PM #83
      has anyone tried this 16v conversion on a 2002 avh 2.0 engine? can it be done?
    9. Member Chris164935's Avatar
      Jan 9th, 2004
      Orange Park, FL
      10-05-2004 12:55 AM #84
      I was looking into doing that. I used to have a 2003 AVH motor. The thing is that that motor uses coil packs. Not sure if you can go from coil packs to distributor, or vice versa. If you can, I'm pretty sure it won't be cheap.
    10. 10-05-2004 04:09 AM #85
      With the later 2.0 from 99 on (engine code AEG, AVH, etc.) you are better off going with a 20v head as it will need much less work, all the oil passages line up perfect. That will be a whole new beast altogether and I haven't taken an AEG block apart yet so I'm not sure what it needs, besides a 20v head and timing gears. Using an AEB 20v head you can use the internals over from a 16v block, but some later 20v's have a different size timing gear and I'm not sure how they would work. Also that is going to be much costlier to do as the 20v heads are 500+ where i can get a 16v head for 50, have it rebuilt and ported for less than a stock 20v. Personally I like the ABA blocks because of the rod/stroke ratio is so good. the AEG/AVH 2.0's have went back to the shorter 144mm rods like a 9A or 3A block. If you were going to do it cheap I would get an ABA block as they are cheap and build it up to swap in. otherwise start your own thread on how to build a 20/20 and ask lots of people or experiment on your own to find what works.
    11. 10-05-2004 01:28 PM #86
      this may help out with the 20v swap
      http://www.race101.com/project_2020.html
    12. 10-25-2004 02:09 AM #87
      up
    13. 10-31-2004 02:25 PM #88
      Ok I need some help guys. I should be coming across around $800, and I want to do a 16v swap. However, Im going to be running it NA. Ive read this thread but its confusing because I never know if people are talking about parts for a FI setup or NA, so could somone give me a complete list of parts within an $800 range that would give me worthy gains while staying naturally aspirated. I offered Paul ("i need a vr6") the $400 for his kit. So with the additional $400, what should I buy, besides the needed belts and gaskets, that would give me better gains? Also, how difficult is it to do this swap? The extent of my vw experience only goes as far as installing my own shocks/struts, replacing my starter and alternator, etc. I also reasembled a smashed 240sx front end.
    14. Member Chris164935's Avatar
      Jan 9th, 2004
      Orange Park, FL
      10-31-2004 06:28 PM #89
      Hmm...Not sure if you'd be able to do it with $400. After getting the head, you'll probably (well, you should, anyway) have to get the head cleaned up, decked, and the valves reseated. That ran me about $300 for parts and labor to do my head (they also installed a cam). And, because the chamber volume on the 16v head is bigger, you'll have a lower compression. So, to do NA, you'll need new high compression pistons (or, if you want, you could use like-new 9a pistons. Without the higher compression pistons, the gains won't be very high (unless you turbo).
      Okay, my turn to ask a question: Will a different ECU be needed for this swap or will the stock ECU for ABA motors be okay? Or rather, what would be the best choice (price and performance-wise) without going stand-alone?
    15. 10-31-2004 11:33 PM #90
      [QUOTE=Chris164935]Hmm...Not sure if you'd be able to do it with $400. After getting the head, you'll probably (well, you should, anyway) have to get the head cleaned up, decked, and the valves reseated. That ran me about $300 for parts and labor to do my head (they also installed a cam). And, because the chamber volume on the 16v head is bigger, you'll have a lower compression. So, to do NA, you'll need new high compression pistons (or, if you want, you could use like-new 9a pistons. Without the higher compression pistons, the gains won't be very high (unless you turbo).
      [QUOTE]
      Yea Im getting 9A pistons included in the $400 kit, and the head is said to be "clean" as it is already. So again I ask, what are some extra parts that would be ideal to get with a $400 budget?
    16. 10-31-2004 11:41 PM #91
      here is the changes you need to make for the following
      1) High Boost Forced Induction-----------ABA pistons/ABA Rods
      2) Mild Boost Forced Induction-----------9A pistons/ABA Rods
      3) NA + Extreme Nitrous------------------See # 1
      4) NA + Mild Nitrous-----------------------See # 2
      5) High Compression---------------------ABF Pistons/ABA Rods
      6) Stroker----------------------------------9A Pistons/TDI Crank
      If anyone has a diff setup they had in mind post up and ill tell you what piston/rod combo you need
      Modified by German_Muscle at 12:46 PM 11-2-2004
    17. 11-01-2004 12:30 AM #92
      where can I get ABF rods for cheap? and what will the rods and 9A pistons bring my C/R to?
    18. 11-01-2004 03:30 PM #93
      you want ABF pistons, ABA and ABF rods are the same. I posted links in this thread on where to get ABF pistons for $289. Also I would budget in the near future for some cams, autotech or techtonices sport cams, or at the very least a euro intake cam.
    19. Member Chris164935's Avatar
      Jan 9th, 2004
      Orange Park, FL
      11-01-2004 09:24 PM #94
      But what about the ECU? Can this setup be run without a stand-alone?
    20. 11-01-2004 10:15 PM #95
      yes it can be done with the stock ecu, although I would get a 3.5 bar FPR and a custom chip at the least, or a piggy back to adjust it yourself. You will need to drill/tap your manifold for the intake air sensor and use injector cups from a digi setup for the injectors. Part of the reason why to do this swap is the aba bottom end allows you to use the crank trigger wheel built into the block that the stock management uses. standalone may be better and more aggresive but for those saving your pennies, motronic 2.9+ makes good power, gets good milage and is a huge advantage over CIS/Digi.
    21. 11-02-2004 12:45 PM #96
      My bad, i fixed the post above. I dont think you can use the ABF pistons with the TDI crank can you?
      Modified by German_Muscle at 12:58 PM 11-2-2004
    22. 11-02-2004 08:32 PM #97
      Eurospec sports has ABF cast pistons to use with both the 2.0L (92.8mm) and the TDI (95.5mm) cranks and keep a 10:1 CR. I would say the 9A pistons could be used with the TDI crank and would come pretty close to 10:1 if not higher. You can always deck the block or the head for more compression.
    23. 11-03-2004 01:00 AM #98
      Updating the Main list. Check it out. I added the above info and MK3 accessory conversion info to the list. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. Member Chris164935's Avatar
      Jan 9th, 2004
      Orange Park, FL
      11-04-2004 07:45 PM #99
      Custom chip? Like an Autotech chip (just an example)? One designed for the ABA motor right? ...And just replace the stock unit?
    25. 11-04-2004 10:44 PM #100
      The only stock engine management system id use with this setup is Digifant 1 with a completely custom burnt chip, or OBD1 ABA Motronic with a completely custom chip. But for those who are saving pennies, just get Megasquirt N Spark, using stock engine management for such a hybrid engine is most likely going to cost you in the long run. Megasquirt is a extremely good stand alone engine management system for the cost. Megasquirt is the way to go if you have a low budget. so IMHO stand alone is the only way to go with this setup. You can get away with chipped stock systems but stand alones will do the same and much much more. In other words what i am saying is....Dont Cut any Corners, do it the right way! The only way id use a stock management system is if i already had all of the stuff laying around, like if i was doing this to a car that came stock with or was already running ABA Motronic or Digi1 systems. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
