Page 51 of 61 FirstFirst ... 41 47 48 49 50 51 52 53 54 55 ... LastLast
Results 1,751 to 1,785 of 2133
Thread: lets get a ABA 16v Parts List/FAQ Thread going
  1. 06-03-2009 04:16 PM #1751
    the 2e is same as ABA.
  2. Member hasnfefr's Avatar
    Sep 25th, 2002
    Elyria, OH
    75' scirocco, 80' caddy, 84' rabbit gti w/callaway stg2, 87' 16v scirocco, 93' corrado
    06-20-2009 07:11 PM #1752
    ttt
  3. 06-21-2009 11:41 PM #1753
    so, anybody got some pictures of a aba16v completed and in a car?
    is there any jimmy riggen that has to happen? I also have a q about the 1.8t fuel rail. is that possible to use or did I read wrong
    Modified by slim-jim at 1:09 PM 6-22-2009
  4. Member speed51133!'s Avatar
    Aug 5th, 2002
    alexandria va/milwaukee wi
    02 audi tt 225 / mk3 jetta /audi 5000s turbo
    06-22-2009 05:38 PM #1754
    coolant lines will need some "jimmy rigging"...
    nobody ever mentions thoes.
  5. 06-22-2009 06:15 PM #1755
    ok well thanks man
  6. Member daneek155's Avatar
    Apr 22nd, 2008
    Harrisonburg,VA
    2002-a4/92 GTI/95 Dakota
    06-22-2009 11:40 PM #1756
    so im confused, you cant just put the 2.0 16v heaD on a 2.0 obd1 aba block, used for a turbo mk2
    HE HE
  7. Member 16vtblackjetta's Avatar
    Jan 13th, 2007
    WV
    98 porcelain vr
    06-23-2009 03:40 PM #1757
    Quote, originally posted by daneek155 »
    No read atleast the first 20 pages carefully. Its not hard and there are many combinations.
  8. Member Greengt1's Avatar
    Aug 27th, 2006
    Lansing IL
    92 Monty Green GTi 16vt
    06-23-2009 04:39 PM #1758
    my 16v/aba is running now turn key,.. i love it... i will get some pics real soon
    Plenty of parts for sale!
  9. 06-23-2009 05:11 PM #1759
    are you turbo and what comp. to you have
  10. Member Greengt1's Avatar
    Aug 27th, 2006
    Lansing IL
    06-23-2009 08:31 PM #1760
    i am turbo and im running digi 1 with 60# chip
  11. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    94 gti aba16v stroker
    06-27-2009 04:21 PM #1761
    follow the link below for pics of working aba16v in a mk3. if you are considering doing the swap? DO IT. you will love it.
    http://www.customobsessions.co...24348
  12. 06-27-2009 10:11 PM #1762
    cool, I am gonna do it just need a couple more parts
  13. 06-30-2009 04:32 PM #1763
    do I need the crank gear also not just the pulley. the gear that the crank pulley bolts up to thanks in advance I couldn't find anything about that and I don't know what that would be called
  14. Member speed51133!'s Avatar
    Aug 5th, 2002
    06-30-2009 04:36 PM #1764
    you need the crank timing belt gear from a 2.0 16v, and also the crank pulley aka harmonic balancer (needs modification milling 6mm off crank side and ring pressed in)
  15. 06-30-2009 07:26 PM #1765
    thank you, what kind of ring, is it to make the lip of the pulley. I am gonna be runnin aba acc.
  16. Member vwpat's Avatar
    Oct 25th, 2000
    ATL
    06-30-2009 09:21 PM #1766
    Quote, originally posted by slim-jim »
    To centre it after you machine the 6 mm off.
  17. Member
    Sep 12th, 2008
    Williamsport PA
    1997 VW Jetta 2.0T
    07-11-2009 07:56 PM #1767
    ok well im kinda new to the whole 16v forum. but this is what i want to do cause i need more power in my jetta.
    i have a 1996 jetta OBDII. i want to do a 16v headswap. is it possible to do to an OBDII. i read the first page and it says about OBDI but nothing about OBDII???
  18. Member shwagondawheels's Avatar
    Jun 17th, 2004
    Richmond, VA
    94 ABA Golf RIP, 96 ABA GTi RIP, 98 Jetta TDI DD
    07-15-2009 09:53 PM #1768
    Quote, originally posted by bonesaw »
    Idler/Tensioner Pulley: 2.0L16 or 1.8 16v but you really should be buying a new one
    Oil Pump: MUST BE 2.0 16v
    Oil Pump Drive: 2.0L 16v or 1.8 16v must go with approprite int shaft. the gear is alot smaller for a 1.8 16v
    Water Pump: 2.0L 16v or 1.8 16v or ABA
    Water Pump Pulley: 2.0L 16v or 1.8 16v or ABA or vr6 wapter pump if you want serp setup
    Crank Pulley: 2.0L 16v or 1.8 16v or shaved ABA
    Alternator: 2.0L 16v or 1.8 16v or ABA
    Alternator Pulley: 2.0L 16v or 1.8 16v or ABA
    Alternator Belt: 2.0L 16v or 1.8 16v or serp belt
    Intermediate Shaft: 2.0L 16v or 1.8 16v
    so you can use a 1.8 16v PL IM in an ABA no clearance issues?
    i was told it wont work.. i don't see why not..
    because owning a VW is a LOVE/HATE thing, so drive the piss out it....
  19. Member shwagondawheels's Avatar
    Jun 17th, 2004
    Richmond, VA
    07-17-2009 12:51 AM #1769
    Quote, originally posted by shwagondawheels »
    So I answered my own question today and tried a mock up with the PL intermediate in my 94 ABA bottom end and the crank interferes with the gear on the intermediate... the connecting rod of cylinder #4 hit the gear on the end of the intermediate
    Note: PL or 1.8 16v intermediate will not clear in an ABA bottom
    I missed the page that stated this, if there is one.
    9A intermediate. oil pump gear, and block dizzy block off cap anyone?
    I will be buying new 9A oil pump...
    Todays mock up, pics for kicks
    ABA on stand, 1.8 16v head on bench in the back, pl block on ground (for parts) and two counterflows from prior 16v swaps
    Modified by shwagondawheels at 6:50 AM 7-17-2009
  20. 07-27-2009 02:20 PM #1770
    I'm thinking about doing this swap has anyone used this kit before, and did is it worth it?
    http://www.bahnbrenner.com/vw_...n_Kit
  21. Member shwagondawheels's Avatar
    Jun 17th, 2004
    Richmond, VA
    07-29-2009 11:04 AM #1771
    yeah a lot have and I am not one of them but it will save you a lot of trouble...
  22. 07-30-2009 01:08 AM #1772
    Modified by lowlevelowl at 11:15 PM 7/29/2009
  23. 07-30-2009 05:33 PM #1773
    very nice moded 1.8t mani how was that did you do it yourself or I am thinkin a doin that but there still alot more important parts I need.
    I want to use my aba oil pump and int shaft and I am wantering if I can put a spacer on that shaft to get the sprocket on. I really need to get my motor on the stand so I can stop imaginin and see it for real.
    By the way what pistons you got in there and is that a 9a block. cr
  24. 07-30-2009 08:35 PM #1774
    It's running an approximate 10.5:1 compression ratio using ABF pistons from Bahn Brenner Motorsports.
    The motor is a freshly rebuilt 1.8L 16v head mated to a OBD1 2.0L ABA bottom end.
    I'm using a 1.8t intake manifold with HKS air filter modified to fit a 16v cylinder head and a stock dual outlet downpipe from a MK2 GTi that is fit to a 2.25" TT exhaust system (deleted cat).
    The ECU is 034efi Stage Ic running waste spark and 24lb/hour injectors also from BBM.
  25. 07-31-2009 08:25 PM #1775
    very nice and those pistons don't get a dropped compression because of the 16v on a aba block or are they 11.5>1 cr
  26. 07-31-2009 08:39 PM #1776
    They are replica oem ABF pistons and bring the compression ratio up to approximately 10.5:1
  27. 08-01-2009 10:40 AM #1777
    very nice, the only problem I am looking at is the pistons I have 9a ones but I don't know how to tell the weear and think that they need replacement. great success
  28. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    08-02-2009 06:48 PM #1778
    This engine is a hole nether level.
    I am currently rebuilding with H beam rods. i was afraid the OEM rods at 430whp wouldn't last.
    new H beam rods 8.5:1 JE up from 8.0:1 Wossners and water/ meth
    kit will be making 475-500 whp soon.
    500HP 1990 Cowrado
  29. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    08-06-2009 06:52 PM #1779
    Quote, originally posted by lowlevelowl »
    have you ever dyno'd this set up, or 1/4 miled it? if so, what #'s.
    i have aba16v in a mk3 with a t.t. chip & euro cam. it runs 15.2 on street tires. never dyno'd, but should be over 140whp
  30. 08-06-2009 07:09 PM #1780
    I have seen similar setups and they said 170hp. I think that the head on a aba starts out higher than stock 9a not sure but I hope so.
  31. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    08-06-2009 08:23 PM #1781
    170hp would be at crank. & yes aba16v combo is about 150hp @ crank with no mods
  32. Member 8vlove12's Avatar
    Jan 8th, 2008
    Houston Texas
    1980/Volkswagen/Golf
    08-12-2009 10:18 PM #1782
    what kind of ecu's are you guys running. im almost done with my car and thats the only thing that im trying to figure out. if i should run a 16v ecu or g60
  33. Member leon whalen's Avatar
    May 27th, 2007
    truro n.s.
    08-14-2009 12:51 PM #1783
    stock aba ecu with techtonics chip (aba16v) works great, no complaints
    Modified by leon whalen at 1:58 PM 8-14-2009
  34. Member pozer's Avatar
    Dec 21st, 2001
    Madison Wi
    08-17-2009 09:30 AM #1784
    A few paged back I made a statement that I have no valve contact with TT sport cams and I was wrong.
    Finally I have the blown engine apart and I have more factual details.
    Pictures say it all.
  35. 08-23-2009 01:45 PM #1785
    ouch dam that's bad. sorry to see that man.
    I saw somethin on this once now I can't find it.
    Are aba and abf wrist pins the same size 21 mm right.
    Also does anybody know if the piston rings would be the same.
    Modified by slim-jim at 9:11 AM 8-24-2009
