Page 5 of 26 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 878
Thread: MKIV door locks explained - why you're having problems!!! :(
  1. 06-14-2005 01:41 PM #141
    It looks like the F6 switch. I have a picture of the 4th micro somewhere that we should be able to compare it to.
    Gary
  2. 06-23-2005 08:28 PM #142
    Gary,
    I've successfully taken my door apart and removed the door lock module and taken that apart. However, I'm scratching my head now trying to figure out what to do about that 4th microswitch to fix it. Am I supposed to take that apart and resolder those 2 wires?
    update:
    Upon removing the main circuit board, I noticed that a protective coating has been applied over the solder joints, probably to prevent any solder joint issues that have come up with earlier model cars. I'll upload a picture of it later tonight.
    Modified by GTIinTHErye at 5:44 PM 6-23-2005
    Modified by GTIinTHErye at 5:45 PM 6-23-2005
  3. Senior Member Turtle20vT's Avatar
    May 23rd, 2003
    Miami
    2012 Jetta SE
    06-24-2005 10:53 AM #143
    Quote, originally posted by Der Kommissar »
    Awesome write up-it seems that the 99.5 cars have a lot of problems with this.
    Thanks
    yeah .. mine work whenever it wants
  4. 06-24-2005 01:48 PM #144
    In my experience, when the 4th micro fails, it's the actual switch that's the problem and not the wires/solder. Since we don't have a replacement switch for it yet, the only way to fix it in this case is to replace the whole module. If I were you, I would test the operation of the 4th micro with a multimeter to see if the problem is in the switch or contacts. If it's just the contacts, then resoldering should help in this case.
    Gary
  5. 07-01-2005 01:11 AM #145
    Both of my front door lock sensor switches (on my 2002 Jetta TDI wagon) have been not
    working right, for several months. I took apart the lock module on the passenger side, and
    not only didn't fix anything (the solder joints looked o.k. and I got tired), but when reconnecting
    the lock release cables, etc. did something wrong so that the inner release handle doesn't
    work, and the outer handle works all the time (doesn't lock i.e. the outer handle always
    opens the door). I decided to just buy 2 lock modules (from Impex). But here's a pretty good
    price that I found (from 1stvwparts.com) --
    Body hardware - Door - Front door - Lock
    p/n 3B1837015AK LOCK, Golf, GTI, R32, Left 1999 - 2004 $91.30 each
    p/n 3B1837016BH LOCK, Golf, GTI, R32, Right 1999 - 2004 $69.11 each
    Hope that helps someone; Larry.
  6. 07-01-2005 01:14 AM #146
    Quote, originally posted by LC »
    thanks great info
  7. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    2006 GLI, 2008 Rabbit
    07-01-2005 01:15 AM #147
    Fantastic! The one I need is actually the cheaper unit!
    Ride In: 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
    Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    Future: 2015 Audi S3
  8. 07-01-2005 01:16 AM #148
    Quote, originally posted by BRM10984 »
    damn you Brian! I need both
  9. Global Moderator Dan Halen's Avatar
    May 16th, 2002
    Dougal County
    07-01-2005 01:19 AM #149
    Quote, originally posted by golfhm472 »
    Shut up. I will as well if you start talking all that nonsense.
    I've actually gotten used to it not working. If it weren't for the fear of accidentally locking the key in the car, I'd not even bother fixing it.
    That, and my girlfriend doesn't seem to know how to put the right amount of pull on the door to close it, so the interior lights give a nice visual confirmation for her.
  10. Member dasGolf01's Avatar
    Aug 23rd, 2004
    Virginia
    2004 Audi Allroad Quattro
    07-04-2005 11:01 AM #150
    Mine started with my trunk and it's an early 02. Unlocked the trunk.. now the trunk won't lock when I close it. Can't manually lock it and the remote doesn't register to lock/unlock the doors. If I manually lock them, they both unlock then I can lock the driver door and have to press down the passenger door to lock it. Apparently the windows and sunroof have failed too.. but the power locks "work" if I engage the switch on the door, then they unlock again, I'm assuming due to the trunk not locking. Doesn't seem to be quite the same problem but perhaps similar. Checked all the fuses including the two above the relay panel. Any ideas/clues/hints or is it dealerland for me..
    2004 Audi Allroad 2.7T
  11. Junior Member
    Feb 18th, 2003
    Carlsbad, CA
    2008 GTI 4D
    07-09-2005 08:28 PM #151
    My 2000 Golf (4-door) has been having lots of issues with the alarm randomly going off and not beeping when I lock the doors, but none of the more commonly mentioned issues in this thread. Does anybody have any recommendations for what to check first (even using Vag-Com) so I don't have to take apart all four doors to figure out which is broken?
    Thanks for the awesome threads by the way! Very helpful.
    Aug 9th, 2000
    Fham, MA
    2k1 1.8t gti, 2k10 CR-V
    07-23-2005 08:27 PM #152
    Well, that was a fun afternoon of innerdoor exploration, thanks a lot for this writeup. My issue was the driver's door lock stopped working two weeks ago unless you used the key in the door. I took it all apart and found the soldered points to be fine, touched them up just in case and managed to melt the pad of one finger in the process, ouch. Got it back together and found that the lock was moving now so went ahead and buttoned it all up only to find now that the door unlocks, the alarm arms, but the car never actually locks and the pin doesn't move as it should (just goes up and down halfheartedly/not as much as when it all worked) Decided I should stop setting off my alarm and gave up for the night.
    Anyways, looks mostly like I'll need a new module or 4th switch, but also a strong chance I just didn't put it together properly so we'll see what my motivation is like tomorrow.
    Oh, fun stuff in the door, found that when the dealer replaced my window regulator parts, they left the broken window clip inside the door, two of the bolts holding the inner panel were missing along with two of the plastic clips holding the door panel, figures.
  13. Junior Member
    Mar 11th, 2004
    NJ
    2000 GTI 1.8t
    07-23-2005 09:44 PM #153
    you would think a problem like this would be recalled.. no?
    Like the window falling. Both my doors had the windows fall due to poor supports (made of plastic) and they replaced it for free (with some stronger material) because of recalls that gave us 7 years on the window supports.
    Modified by darkd at 9:51 PM 7-23-2005
  14. 07-23-2005 11:59 PM #154
    I wonder what it would take to get this listed by VW as a warranty repair, from what I understand the window clips were not actually a recall, but a fix they would do for free if it failed, or you asked them to.
  15. Member
    Aug 9th, 2000
    Fham, MA
    07-24-2005 10:22 PM #155
    Took it apart again, and found as I sorta figured that I put part of it together incorrectly. It was a connection between the 'mechanical' and the 'electronic' sides, I didn't line the pawl up properly so it wasn't engaging, thus the door pin moving in a funky manner. It's all back together again and working and I'm happy to not have to buy a new module... yet.
  16. Member georgekelp's Avatar
    Aug 15th, 2005
    Arizona
    1998 Volkswagen Golf
    08-15-2005 12:59 PM #156
    OK here is the deal. I own a 98 Golf. I have the remote and i cannot lock the doors using the remote, all the other buttons work fine. Also sometimes if i leave the doors unclocked the alarm will just set by itself and lock the doors. Does this door lock module problem apply to MK3's as well? And would I be able to follow the same procedures to solve it? Also how do I know which door to take apart?
  17. 08-21-2005 06:34 PM #157
    I did this procedure, and now I'm having a much bigger problem - when I lock the car with the button, I can still open the driver's door just by pulling on the exterior handle! The alarm goes off, of course, but still a big concern. Any ideas what I did wrong? Thanks in advance!
  18. 08-21-2005 09:52 PM #158
    It sounds to me like you probably put the two portions of the lock module back together incorrectly.
    And this problem does not apply to the MKIII cars, at least not to the same magnitude that it does with the early MKIV cars.
    Gary
  19. 08-21-2005 09:58 PM #159
    Eh, nevermind. Still don't know exactly what was wrong, but redoing the whole job fixed it.
  20. 08-21-2005 09:59 PM #160
    Thanks, VgRt6 - didn't see your reply before I posted my "nevermind".
  21. 08-21-2005 10:20 PM #161
    Gary
  22. 08-21-2005 11:11 PM #162
    I've got a 2001 (it sounds like lockdown when I hit 15mph - so I'm most likely in this boat) and I've not had this problem yet, but I would much rather know before it happens then freak out when it does! Thanks a ton to all the contributors of this excellent bit of information. I can't imagine how much money & headache your write ups have saved my Gary!
    I second the nomination!
    BETTER YET, GARY FOR PRESIDENT OF VW!
    Early Mk.IV owners:
    Modified by rocketPack at 8:15 PM 8-21-2005
  23. Member jdob's Avatar
    Apr 22nd, 2002
    Winston Salem, NC
    2000 VW Golf GLS 1.8T
    09-03-2005 02:26 PM #163
    My symptoms:
    Driver's side would not lock unless I first un-locked all the doors and then re-locked.
    Lower courtesy light on drivers door would not illuminate.
    If I un-locked and opened the drivers side door and did not insert the key or close the door the alarm would go off after a very short period of time - not sure if this is normal or not???
    I could not lock/unlock all doors or roll up/down all windows with the key.
    My alarm LED would not illuminate.
    My Fix:
    Broken solder joint...Resoldered and everything is just like new again!
    I think my alarm LED was not illuminating because the connector had been pulled apart/broken when VW Service replaced my window regulators because of the recall...???
    Also the two little plastic "drift pins" that secure the mounting of the door lock module to the inner window carrier assembly had either been removed and not replaced (again by VW Service???) or fallen out (they were hanging out down in the bottom the door rolling around) - as hard as it was to press them back into place - I don't see how they could have worked loose all by themselves!
    Just wanted to express my experiences and say MANY, MANY, MANY thanks for the great write up above!
    One last thing - make sure you have the M8 12-Point Triple Square bit for removing the actual door lock module from the door. I though my set of 6-Point bits would be good enough - WRONG...I went everywhere to find the 12-Point bit: Auto Zone, Advance Auto, Ace Hardware, Sears, Lowes, Home Depot, the VW Dealer, by friends house, everywhere with NO LUCK. After my exhaustive dead end search I found a set of four 12-Point Star Bits on-line from http://www.toolking.com for $3.99 and paid about $12.00 to have them delivered Second Day....
    Anyways that's my story...Thanks again for the GREAT DIY!
  24. 09-03-2005 02:33 PM #164
    In case anyone is interested, I bought a brand new driver's side door lock module on ebay for $20. That's about $100 less than what the dealer is charging.
  25. 09-07-2005 10:45 PM #165
    with regards to the last edit of the very first post... the link to TDIclub.... since there are no pixorz there, I just did this dirty lil job and I took some pics along the way. dear moderator, feel free to add those pics to your post as you see fit since they prolly won't be seen here on the last page.
    assuming you read the rest of the thread.... you can get this far. so this is the mechanical portion of the latch, and the switch is at the bottom there.
    the culprit removed by way of using a knife to cut the melted plastic off
    replacement part as explained in the tdi link
    I used #2-56 machine screws to attach the new switch. Use your trusty Dremel tool to elongate the holes down and outward.
    this is how it looks attached
    now I used some plumbers metal epoxy putty to fill the elongated part of the holes so it doesn't start to creep up over time.
    and this is the end result after the epoxy putty
    and the wires get soldered on to the C (common) and NO (normally open) terminals. I don't think it matters which wire goes where, since it's just a simple switch.
    Thanks to the dude at TDIclub for the part number, and to VgRt6 for this awesome thread!!!
  26. 09-08-2005 10:06 PM #166
    Awesome info!
    Gary
  27. 10-02-2005 06:16 PM #167
    Thanks for the excellent instructions with pictures.
    Fixed UK 2001 Jetta/Bora drivers door not seen as open (system locks after 30s if key not in ignition, interior light not illuminating etc) by replacing external microswitch, switch 5, internal pcb has 4 switches. Extra one seems to be to detect for deadlocking. Note also that pcb coated with varnish to protect against damp. Fitted a Burgess X4 microswitch after filing the holes.
    Problem with the original (a custom Burgess microswitch probably based on the V4NCSK2. Why not use a standard part) appears to be the mounting pegs flexing and allowing actuator to miss the cam.
    Modified by Eljay at 3:21 PM 10-2-2005
  28. 10-10-2005 08:52 AM #168
    Hey Gary,
    You really are a vw driver's advocate to stay involved with this topic for so long and by continuing to add new observations and advice.
    I want to list the symptoms I've been experiencing for sometime on my '00 golf and confirm which ones we think are more than likely to be from the cracked soldering or a mechanically issue with that 4th micro-switch. Then there's a couple of other symptoms I want to run past you and anyone else that has experienced this.
    symptom 1;
    Alarm auto-arms after the front driver or passenger door is open 20secs or so, but does not if either rear door is opened as well or by themselves. Interestingly; when it faultily rearms this way the alarm led also does not light.
    -typically intermittent, sometimes it will work correctly and not auto-arm if either front door is opened.
    symptom 2;
    Red /white lower lights do not light on either front door at anytime.
    symptom 3;
    Opening the rear doors lights the dome but opening either front door does not.
    symptom 4;
    The pin on the front driver side does not go down while alarm is arming unless I press unlock twice and then lock/ arm quickly on the remote. It also does not go down very often while it is faultily auto-arming.
    -although occasionally it goes down like it should.
    symptom 5;
    Occasionally the windows do not go up with the key from the outside.
    ^^^^^^ I think these first 5 we've seen so often that its pretty certain it would be cleared up by repairing or replacing the locking module but what about these?;
    symptom 6;
    The pin on the front passenger side does not go down at all unless you push it, it doesn't goes up unless you pull the handle from the inside. Does not change, never works period.
    -I did see a few other people talk about this but from reading the thread I couldn't completely confirm that this fix worked for that symptom.
    symptom 7;
    Nothing works on the front passenger door actually, no lights, no mirror, no pin, no window.
    -not intermittent, never works. I haven't seen anyone else mention that they have experienced this.
    I'm suspecting that I've got an issue with power not getting to that passenger door and this is causing an otherwise non-faulty module not to work.
    Each thing that stopped working happened 1 at a time though, it didn't go down all at once, the first thing was the pin not going down.
    Any suggestions on how to check for power to the door -all the fuses seem fine etc.
    Then finally; what is the locking module we are talking about here labeled in the Bentley wiring diagrams? F221 (driver) F222 (pass) locking unit for central locking? or J386 (driver) J387 (pass) door control module? or are one of these part of the other?
    Thanks for any further input you can give to this topic!
  29. 10-10-2005 09:16 AM #169
    ok Im going to take a stab at my own question now that I've found even more info;
    The lock module and control module are 2 differeent parts
    My drivers door has a bad lock module and my passenger door has a bad control module
    Does anyone have the part #s for these?
    I've seen 3B1 837 016 D and 3B1 837 016 R for the locking module. I think one is the older (loud version) and one is the newer (quiet) version. Are these for either 2 or 4 door cars?
    Then I saw someone list 3B1 837 015 AK????
    I can't find a # for control modules
  30. 10-12-2005 04:23 PM #170
    Thank. Great job. I hate to bug you after so many months and so much detail, but I can NOT figure out how to split the lock module into its pieces. Please point the way to a link or let me have it: ...the info.
    Thx
  31. Member VR6 Seige's Avatar
    Sep 8th, 2004
    east college ave 16801
    12v GTi
    10-12-2005 05:36 PM #171
    to the faq/diy!
    VRSOCIETY #180
  32. 10-12-2005 08:27 PM #172
    So, I guess it's safe to say that VofA has not issued a tech service bulletin/repair for this issue? I have a 99.5 new GTI and i have recently been experiencing weirdness with my door locks...
  33. 10-13-2005 10:31 AM #173
    I went through this list and found nothing.
    VWvortex Forums The Official VgRt6 MKIV-VR6 DIY Thread Master List.htm
    Is there another place to look?
  34. 10-13-2005 11:08 AM #174
    Adding to my watched topics list so I can do this repair!
  35. 10-13-2005 12:04 PM #175
    WOW!!
    Fantastic write up!! All write ups should be this detailed!!
    Great work!
