VWVortex.com - DTC P1426,Any Input?
    Results 1 to 6 of 6
    Thread: DTC P1426,Any Input?
    1. Member RPTOFNDR's Avatar
      Jan 15th, 2003
      Stuart, FL
      RS 5
      08-27-2004 09:53 PM #1
      Pulled a P1426 with a Generic OBD2 Scanner today.
      Manufacturer Controlled Auxiliary Emissions
      WTF does this mean?
    2. 08-27-2004 10:47 PM #2
      What car is this on?
      The MKIV Bentley CD says ...
      P1426/17834 - Tank Vent.Valve, Open
      - Check Evaporative Emission (EVAP) canister purge regulator valve -N80- output Diagnostic Test Mode (DTM), Page 01-68 .
      Gary
    3. Member RPTOFNDR's Avatar
      Jan 15th, 2003
      Stuart, FL
      RS 5
      08-28-2004 10:12 PM #3
      MK3,Its a 97 Passat VR6 Driveline,In a 94 Corrado.
      Full OBD 2 Swap & Diagnostics..I'm thinking the harness is shorted somewhere,or the solenoid is bad.
      Dont have Fuel tank Purge system on the 97 Passat,Just on the 98-99 Mk3's. I do have the EVAP Canister & Solenoid valve though.
    4. 08-29-2004 07:55 PM #4
      I'd post this in the MKIII forum and see if anyone there has a MKIII Bentley CD. I don't think my MKIV Cd is going to be much help.
      Gary
    5. Member RPTOFNDR's Avatar
      Jan 15th, 2003
      Stuart, FL
      RS 5
      08-30-2004 08:09 AM #5
      Gary,Ended up being a cut wire leading to the EVAP canister solenoid valve.
    6. 08-30-2004 08:31 AM #6
      That would do it! Glad you figured it out.
      Gary
