Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 74
Thread: VW Coil Pack/Ignition Coil Guide
  1. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    08-31-2004 10:30 AM #1
    Coil Packs
    Fist off, the term "coil packs" is generally misused when referring to VW applications. A true coil pack contains the coils for all cylinders in one block, or pack (who would have thought?). When referring to the commonly discussed VW-coil-pack-failure issue the correct terminology should be coil-on-plug ignition as each spark plug has its own coil, located on the top of the plug. For various reasons people have taken to referring to this type of ignition system as a "coil pack" system. I am not trying to change the naming convention, just trying to make you aware of it.
    Engines that use a coil pack
    2.0
    12v VR6 (pre 2002.5)
    Engines that use individual coils (coil-on-plug)
    All 1.8t's
    24 VR6 (post 2002.5)
    Issues with coils and coil packs
    The problem here is that both systems are failure prone (not in general, it just seems to affect VW's choice of components). The issues are outlined below.
    12v VR6
    -Issue
    The issue with VR6 coil packs actually predates the issues with coil-on-plug systems as it started with the MKIII VR6s. The problem comes when the actually casing of the coil pack cracks. Whether from heat, vibration, or something else the cause is not really known, but they will crack. Coil packs generate high voltages, when the coil are exposed (by cracks in the casing), the spark can actually jump to either ground, or another plug wire. This causes engine misfires.
    -Symptoms
    As mentioned above engine misfires, a flashing check engine light, reduced power and bucking are all symptoms of a cracked pack. The behavior is usually exaggerated in wet or foggy conditions as the moisture in the air provides an easier path for the spark to jump.
    -Diagnosis
    An easy way to check if your coil is causing your check engine light is to fill a spray bottle with water, start your car somewhere dark (or at night), and spray water onto the coil pack (a black brick like object on the drivers side of the engine (the spark plug wires end on the pack)). If you see sparks, your pack is cracked.
    -Is VW aware?
    Yes, as noted earlier this issues goes back to the transition of VR6's from distributors to coil packs. HOWEVER VW has never made any official recall of these coil packs, 12v VR6 engines are not included in the recall that went out in 2003 for 1.8t's and 24v Vr6's.
    -Fixing the problem
    One solution is to buy a new coil pack, they are expensive however. Many of our vendors sell 12v VR6 coilpacks. Another solution is to fix it yourself. This involves filling the cracks (basically coating the pack) with a heat resistant epoxy product. The process is easy, cheap ( under 5 bucks for the epoxy), and it works. It is often referred to buy the name of the product most commonly used, "JB Weld". Three threads that can help you with the process (which anyone can do, it is not difficult)-
    http://forums.vwvortex.com/zerothread?id=763654
    http://www.gti-vr6.net/library....html
    http://forums.vwvortex.com/zerothread?id=585374
    http://chris.quietlife.net/passat/coilpack.html
    a 12v VR6 coilpack
    24v VR6 and all 1.8t's
    -Issue
    VW has had serious problems with its individual (coil-on-plug) ignitions. For whatever reason, the actual coils (the little boxes on top of your spark plugs), died, and died frequently. This causes loss of power, misfires, crappy throttle response, etc.
    -Symptoms
    Check engine lights, power loss, complete engine shutdown, misfires, basically you should check your coilpacks (if they have not been replaced) anytime you have engine problems.
    -Diagnosis
    A scan of the engine codes by the dealer, a friend, or someplace that does it for free can give you insight into the problem. Anything relating to misfires or the ignition system can probably be attributed to the coils. Many times the car will not be able to be driven at all, in this case your best bet is to just have it towed to the dealer. Users in the 1.8t forum and the 24v Vr6 forum are particularly adept at diagnosing coil pack related problems.
    -Is VW aware?
    Yes they are, and they have issued a recall. At this point in time the earlier supply issues are gone, and your dealer should have plenty of the revised coils in stock. It seems that the newer cars (late 2003's and later) have received the new packs during manufacture, and therefore are not affected (although that is not a rule). Contact your dealer if you think you have coil pack problems. In addition, at this point most dealers will replace all the packs if one goes out and they are an earlier revision.
    -Fixing the problem
    The coils available now (J and L revisions) seem to have dealt with the problems. Once again contact your dealer.
    This thread http://forums.vwvortex.com/zerothread?id=575535, is an account (some 50 pages long) of the entire saga chronicled on the Vortex.
    2.0's
    2.0's use two coils in what is called a wasted-spark ignition system. The coil fires two cylinders at once, but since only one of the cylinders is on the compression stroke, the other spark is "wasted". Coil pack problems on 2.0s are extremely rare as they share no components with either of the above two systems.
    TDI's
    Diesels are compression-ignition engines, no spark plugs, no ignition system. (lucky you!)
    Modified by rs4-380 at 8:08 AM 1-12-2005
    Dave
  2. Moderator rs4-380's Avatar
    Dec 12th, 2000
    Maine
    VWs & Audis
    08-31-2004 10:31 AM #2
    Anyone have a picture of a 24v or 1.8t coil that will be around for awhile and you don't mind being added to this?
    Modified by rs4-380 at 1:13 PM 7-13-2007
    Dave
  3. 08-31-2004 10:47 AM #3
    24V Ignition Coils (pic borrowed from the 24V FAQ)
    Updated coil on top, defective version on bottom.
  4. Member
    Nov 21st, 2005
    2001 VW jetta GLX
    11-22-2005 03:53 AM #4
    Where can I buy a coil pack from for a 01 Jetta GLX? Can you point me to a vendor as well as to a site that has a photo (s) of a coil pack
    THx
    Michael
  5. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    11-22-2005 05:08 AM #5
    nice writeup Dave.. added to the DIY/FAQ
    Current: 2011 Jeep Grand Cherokee 5.7 Hemi 4x4, 2013 BMW 650GS Sertao, BMW 1150RT
    Gone: 2010 Audi S4; 2008 GTI; 2007 Audi A6; 2004 Audi allroad 2.7T; 2001 Audi A6 2.7T; 1999.5 Mk4 Jetta VR6; 1991 Jeep Cherokee 4.0 4x4
  6. 11-22-2005 08:29 AM #6
    i have a 2002 1.8T... with just about 100k miles
    if my coilpacks go bad, did VW place a mileage limit on recieving a new part? like am i gunna have to pay for em or will they take care of it?
  7. 03-31-2006 03:55 AM #7
    I'm on the lookout for coil pack retainers...are these a good idea and where can I find them? I have seen them on heavily modded 1.8Ts, but the search term comes up empty. Please help!
  8. Geriatric Member Bora_Azul's Avatar
    Dec 8th, 2002
    Hartford, CT / Porto de Mos, Portugal
    01 Sand pail, shovel not included
    03-31-2006 10:13 AM #8
    Quote, originally posted by VMI 02 GTI »
    brackets that go over the individual coilpacks? They're mostly custom, although i believe the Audi TT's have a form of them. You can try making your own. Also the banner advertiser John@20squared (or whatever the name is) is going to be making a few sets to sell. Talk to him if you'd like
  9. 03-31-2006 12:31 PM #9
    Dave- You migh want to mention that the VR6 also uses a "wasted spark"-type coilpack. I posted the Bentley description of how it works a while back, along with the Bentley instructions for testing the coilpack.
    http://forums.vwvortex.com/zerothread?id=793322
  10. Member ianacole's Avatar
    Aug 11th, 2003
    Colorado
    2002 VW GTI, 1997 Audi A8
    03-31-2006 01:03 PM #11
    PM enginerd (I think that's his SN). He had a bunch made up and was selling some awhile back.
  11. Member tojones's Avatar
    May 5th, 2006
    Dallas, TX
    12-22-2006 04:40 AM #12
    I called VW customer relations on my 03 which was manuf. in late 02. This year was clearly on the recall, but for whatever reason they told me it was not on recall. hmm...I wonder why. My freakin packs are failing
    03 VR6 24v JET
    The Elite 24v VR6 Club: Member #225
  12. 12-29-2006 03:59 PM #13
    looking to see if i can upgrade my ignition system for a 2.0 8v jetta; also have a big ass sound system: already have yellow top optima battery and upgraded ground wires. was told i can't respool alternator. (can i put 120A version of alt. on my car since it came stock with a 90A?? ) 120a is from a 00golf 2.0L thanks for any help
  13. 03-22-2007 02:35 PM #14
    Does repairing the coil pack make it work perfectly normal? Will you still get the correct amount of voltage?
  14. Banned
    Nov 24th, 2001
    03-22-2007 02:49 PM #15
    Quote, originally posted by smrf010 »
    yes.
  15. 06-27-2007 03:13 PM #16
    I am working on a 98 Beetle (Wasted spark system). I am getting missfire codes for cylinder 2 and 3. Are 2 and three common on the coil pack? If so I could be able to swap 2 and 3 with 1 and 4 to prove or eliminate the coil as the culprit.
  16. 07-01-2007 06:31 PM #17
    Is there a way to test a coil pack to see if it's bad without a vag com. I suspect I might have a bad coil pack, but I don't have a vag com, and the shop down the road can't fit me in tomorow, and I really need my car for my job
  17. 07-02-2007 03:33 PM #18
    you can check the secondary winding of the coils with a multimeter (resistance)
    Measure between terminals for cylinder 1 and cylinder 4, and cylinder 2 and cylinder 3. should read 4.0 k to 6.0 k Ohms.
    This may not catch a coil that is breaking down under load or from heat. But it the basic go/nogo test.
    while your at it check you ignition leads 8k to 14k Ohms.
    Good luck
  18. Member reeze03gli's Avatar
    Nov 20th, 2006
    Olympia, WA
    03 GLi
    09-09-2007 02:39 PM #19
    how long are they suppost to last?? i just rolled over 100k in my 24v...send me a PM if you got info..
  19. Member
    Feb 17th, 2008
    Nashville Tn
    89 GLI
    02-03-2009 10:26 AM #20
    why not get bolt down coilpacks.......... pn 06B905115E
    80 Scirocco
    01 A6
    86 COUPE
    91GLI
    97 BT A4
  20. Member billymeister's Avatar
    Sep 23rd, 2008
    Highland Mills, NY
    02 24v vr6 jetta
    03-31-2009 08:12 PM #21
    this helped me
  21. 04-09-2009 06:02 PM #22
    This is a great thread! I just had one go out on me and I've only had the car for 6 days. Replaced it with a friend and 20 miles later another just went, ha.
    Oh well, thank God it isn't anything major and that there is such great information out there on this site from all of you! Trying to land a set of BERU off a member, God-willing get them overnighted and the A4 back to normal!
    i thank GOD a lot
    Quote Originally Posted by ArminT View Post
    How are these with "Spirtual Driving"?
    Idon'tfruitbootman
  22. 05-11-2009 07:41 PM #23
    To make a story short, and have a happy ending like me , just buy the 1.8 T coilpack (coil-on-plug x 4) manufactured by Hitachi (Japan). They have the top of the plug filled with some ceramic epoxy-like stuff that seems really sturdy and heatproof.
    I bought them at ECSTuning.com over a year ago, and they haven't failed not even once. My engine is a brazilian AUQ block (180hp), that works perfectly in the hot Caribbean sun and still makes 15.3s @ 1/4 mile with no mods whatsoever. The kit bought at ECS was marketed for an AWP engine code, so it's OK to use them on AUQ.
    The OEM's are italian-made (?) Bremis, and the third and last one I bought at the dealer (before the Hitachi kit) failed in a record time of just 10 days . They sucked big time (and money).
  23. 06-29-2009 11:08 PM #24
    i got a gti mk4, ignition coil replaced.... new one lasted 2 days.... not even, exactly 40 hours.
    gosh....
    are the R ones the same as L ones? i checked it with the multimeter, the new r one got 79 ohms and the other L ones have 49.....
    help please?
  24. Member scrilla's Avatar
    Mar 28th, 2006
    2001 2dr Golf/1992 GLi
    12-27-2009 01:36 PM #25
    Quote, originally posted by rs4-380 »
    Just thought Id mention that I had my coilpack fail in my 2001 2.0 golf. When I pulled it out, there were 3~4 visible cracks in the case. Dealer initially wouldnt do anything as there was no recall for the 2.0. I took the coil pack in and handed it to the service manager and he offered me a $100 inhouse credit, so that atleast helped. Symptoms were rough idle and occasional misfire under load.
    "Tell me that's not oil. It's a VR6, of course it's oil"
    Doin' Your Mom
  25. Member Brake_Dust's Avatar
    Sep 23rd, 2001
    West Chester, PA
    R32/GTI 12V
    12-27-2009 05:16 PM #26
    -Invisible-
  26. 12-27-2009 06:41 PM #27
    I just replaced the coils and plugs in my 1.8t and im getting misfires and CEL and all that but i dont know what the hell it is
  27. 01-13-2010 03:43 PM #28
    That there is no info on the firing order on VW GTI 1.8T???????
    This needs to be updated or I'm totally blind.
    Well I guess I should've added this:
    1-3-4-2
    Modified by DGOMDK at 12:46 PM 1-13-2010
  28. Junior Member alwarnecke's Avatar
    Jan 19th, 2010
    West Lafayette, IN
    '01 Jetta Wolfsburg
    01-19-2010 02:50 PM #29
    My cylinder 3 coilpack went out on me ('01 Jetta 1.8T), and I'm trying to decide between two replacements:
    - one is the stock VW coilpack, or OEM I guess
    - the other is NAPA brand
    Both are about the same price. Since VW's are known to fail, should I go with the NAPA brand? Anyone else know anything about NAPA?
  29. 01-19-2010 07:01 PM #30
    Go with OEM....There may be a recall already or in the near future. Ask your local VW dealer/Service to see what they can do.
    I just replaced all 4 per the future recall. When compared with old "new" coils are a totally different part number. Good luck!
  30. 01-21-2010 08:27 PM #31
    Great post!! This saved me about $800 to replace the Coil Pack on my 2001 Jetta GLX (94k miles).
    I used JB Weld ($6 at Ace Hardware). The key for me was sketching out which plug wired went on which ports. The Coil Pack is easy enough to take out and put back in.
    Check out these posts as well:
    I'm savoring this victory over overpriced parts/labor!!
  31. Member Sonic303's Avatar
    Nov 13th, 2009
    '98 PBM Vento GLX
    01-26-2010 12:43 AM #32
    So 24v VR6 are issued a recall?? I had them check my vin number to see if mine applied and they said NO!!
    Should I try going to another dealer... Or...?? I just replaced 2 like a week ago, and another 2 fakd up just this Saturday. Those $50 could've went into my gas tank
  32. Member Kiddie Rimzo's Avatar
    Feb 20th, 2008
    MD
    AP1
    01-26-2010 12:47 AM #33
    Quote, originally posted by Sonic303 »
    not recalled http://www.vwcoils.com/Page1.aspx
    I'm not a star. Somebody lied.
  33. Member xspeedracer's Avatar
    Sep 23rd, 2002
    Davis
    2003/VW/GTI1.8T 91/VW/GTI VR6
    02-18-2010 08:01 PM #34
    http://www.034motorsports.com has both types of coil packs and hold downs.
    2003 MK4 Coil-over suspension, Camber plates, Shine Racing rear swaybar, 3"TB Forced-motion exhaust, APR 91, 100 race, S3 strut bar, Baily DV, Modified Factory Airbox, VF engineering Motor mounts, TT front Brakes, H2Sport Control arms.
    1991 MK2 GTI with VR6 Conversion with a Vortec Super Charger, Bilstein Sport Suspension, 5 lug conversion, big brakes, Liguid to Air intercooler still a project car
  34. Member xspeedracer's Avatar
    Sep 23rd, 2002
    Davis
    02-18-2010 08:07 PM #35
    Most likely are re-boxed oem coilpacks if you have any friends with access to Worldpac they have them really cheap
