VWVortex.com - 8v stroker kit ?
    Results 1 to 17 of 17
    Thread: 8v stroker kit ?
    1. 09-09-2004 02:59 PM #1
      i tryed the search function on this page and didnt come up with any info
      basically im wondering if they offer stroker kits for 8v's
      you have a certain ammount of displacement in your engine right?
      so im wondering if they offer a strocker kit that can offer you more,
      serious gains from doing something like this, let me all know if you have more information.
      p.s. about 2 more months tell i have my digi 2,
      when i get it, im so gonna be a post whore.
    2. Member Mortal_Wombat's Avatar
      Jan 28th, 2004
      Travelers Rest, SC
      91 L90E Jetta & 98 LY9G a4
      09-09-2004 03:02 PM #2
      no reason for it
      just swap a 2.0 aba or 3a under your head.
      N I N E - F O O T E R S
      @a2alpine WTB: OBD1 ABA short block, must have oil squirters.
    3. Banned GTi Punk's Avatar
      Jun 20th, 2002
      09-09-2004 03:07 PM #3
      theres no point in stroking it b/c we already have the 2.0, but you can go up to a 2.2 i believe if you have a 2L
    4. Member
      Dec 25th, 2003
      N. Phx, Az
      91 20vG60 GTi, 91 VR6T GTi, 12 Golf R
      09-09-2004 03:08 PM #4
      Quote, originally posted by GTi Punk »
      With a TDi crank and 144mm rods and cutsom pistons in an ABA yes...BUT theres serious work needin done in the piston dept.
    5. Banned GTi Punk's Avatar
      Jun 20th, 2002
      09-09-2004 03:11 PM #5
      Quote, originally posted by TwinScrew20v »
      yeah i would figure as much, i was thinking of doing this a while back but gave up on the idea. the power gain really wouldnt be all that great
    6. Member
      Dec 25th, 2003
      N. Phx, Az
      09-09-2004 03:17 PM #6
      No but itd sure give for low end grunt if you cant use the high end. Im gettin started on one shortly...Seeing as I cant spin past 6500rpm anyway
      But for the $$$ you wont see much in the way of a peak power increase. But there will be an increase in low end and mid range on the order of 10-20hp depending on what parts you use and mods you do.
    7. 09-09-2004 04:06 PM #7
      lol, well atleast the last post was helpful
      i was speaking of a 1.8L digi 2, not a 2.0L
    8. Member FuzzyDice's Avatar
      Jan 24th, 2001
      Portlandia
      GTI - 87 3.1 12v, 08 XB
      09-09-2004 04:08 PM #8
      Quote, originally posted by bryanmk2 »
      Yea... thats understood, its just that it is not worth the money and time to increase displacement via a stroker kit, when 2.0 bottom ends are so plentiful. They are cheap, and its a direct swap, which will achieve what you seek.
    9. 09-09-2004 04:12 PM #9
      do you have more information on this , im looking for tourqe and horse power gains in all ranges, and i dont wish to go turbo for now.
      tell me what to search, link me, or tell me what ill need to buy please,
      maybe a little bit of a deeper explenation please.
      thanks alot.
    10. Banned golf198's Avatar
      Apr 28th, 2003
      09-09-2004 04:12 PM #10
      earth to forum newbie
      Mk2= engine Swap lol
      1.8 8v ........ppl dont care unless a PG block unless u jus wanna drive it then ur ok but i dont think anyone here would tell u to dump $$ in a digi 2 8v
    11. Banned golf198's Avatar
      Apr 28th, 2003
      09-09-2004 04:13 PM #11
    12. 09-09-2004 04:14 PM #12
      Actually the second post was helpful....
      Basically what the other posters are TRYING to say is that
      YES there is a "stroker" avail for the 1.8L motor - its called a 2.0L motor.
      The 2.0L motor is essentaily a stroked 1.8L - and it bolts right up to yer existing head so for all practiacly purposes - its a "stroker" kit.
      The advantage - its all OEM stuff - so durability is great and parts are EASILY available.
      Thats why you dont see the aftermaket offering a stroker for the 1.8L - becuase VW makes one - and you can find one in the junkyard pretty cheap.
      Next Q - does anyone make a multi valve head for the 1.8L - maybe even a twin cam head - or btter yet - how about a cross flow head, or a twin cam cross flow head or like a 5 valve head
    13. Banned golf198's Avatar
      Apr 28th, 2003
      09-09-2004 04:17 PM #13
      Quote, originally posted by ewongkaizen »
      all u need is the short block
    14. Banned V_dubber03's Avatar
      Mar 11th, 2004
      09-09-2004 04:34 PM #14
      Quote, originally posted by golf198 »
      http://www.thepaty.plus.com/8v/ check out tops 10 8v normally aspirated
      8v can be fix up just take lil more time,money,effort and lookin for parts then droppin an 16v or a vr6
      8v can make power! someone on that website has 194hp!non forced induction either
    15. Member BigWaveDave's Avatar
      Aug 10th, 2004
      Tucson, Mexizona
      2014 Duramax
      09-09-2004 04:45 PM #15
      This 8v are awesome cars...You can do alot with a little. Do not go and spend money on the Autotech stroker 2.0 kit. Just go grab a ABA 2.0 bottom, swap it in, then go take your head(if you can afford the down time, or just buy one) and get one of those head jobs (so to speak) done. You can find one at tmtuning.com the have brand new heads for the 8v for 520.00, and there 6.2 cylinder head modification is 600. So you can either send yours in, or buy a new one. They will rebuild it for ya...I dont know how much though...
      I was quoted for the cylinder head mod, new cam, rsd throttle body, and match ported for about 1100 dollars...That is not bad considering the work they do to your stuff
      Then take the ABA bottom and get the crank lightened. Get the block honed and pistons blasted and faces recut. Throw on a header, hi flo cat a piper cam and a custom PVC intake then you should have a pretty decent N/A car...just a budget buildup...Under 2 grand if you find some pretty good dealers...or just piece it together over time...You can do it the easy way with just throwing the 2.0 block on there or the semi easy way and rebuild the whole block with performance in mind, or you can do it the bulletproof motor and room for more potential in the future. Here is the list
      Rebuild the head with HD springs and retainers, Match port and port and polish the head. Do a 3 angle valve job. Go get an RSD throttle body. A fab big bore intake. Take the ABA bottom end and go get some Newer pistons from JE. Bore it about 20 over. Don't push it and save some room for later with the 20 bore. Get forged rods and lighten and balance the crank. Throw some new rings and bearings in there.
      Go get a 16v tranny or if you can the tranny that came in the Xflow cars. I think it should bolt up right...The 16v will though.
      All that should take care of the engine if you want to keep it that way. If you get it all done at once, I say about 2500 to 3000 for the whole thing...Maybe more.
      People say they like doing this because it keeps the weight down and produces a substantial amount of torque with a good power band. You should have 160 to about 170 at the wheels...
      Go grab the details by using the search option or cruise the fixx for the http://www.vwfixx.com/forums/i...25575
      It has some pretty good info..
      Later
      Dave
    16. Senior Member skidplate's Avatar
      May 4th, 2004
      Beaverton, OR
      2012 Golf R 1990 Audi Coupe Quattro
      09-09-2004 05:59 PM #16
      Autotech has a 2.1L kit for both 16v and 8v's.
      Flickr
      Quote Originally Posted by Mr. Knappy View Post
      We really need breeding standards like they have with dogs.
      Quote Originally Posted by pete@blackforest View Post
      I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen? Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
    17. Banned golf198's Avatar
      Apr 28th, 2003
      09-09-2004 06:28 PM #17
      Quote, originally posted by V_dubber03 »
      yea too much of all of those!!!!!
