VWVortex.com - DIY - Pressure testing your intake - Find Vacuum Leaks
    Page 2 of 3 FirstFirst 123 LastLast
    Results 26 to 50 of 51
    Thread: DIY - Pressure testing your intake - Find Vacuum Leaks
    1. Member 1pt8t's Avatar
      Mar 13th, 2007
      Hermosa Beach, CA
      2003 Jetta 1.8T
      12-11-2007 05:12 PM #26
      Do these pics still exist somewhere?
      [IMG]http://*****************.com/smile/emgift.gif[/IMG]
      Need VAG-COM / VCDS near So-Cal / Redondo Beach? Hit me up!
      Also have boost leak tester with PRV for 2.75-3" TIP!
    2. 03-04-2009 09:23 PM #27
      Picture's still around?
    3. Member dckeener's Avatar
      Jan 10th, 2005
      02.5 Gti 24v. 85 Golf 1.8t.
      04-27-2009 05:02 PM #28
      This seems to be happening alot now, I find a perfect diy but no pics so it's pretty much worthless.
    4. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      2003 TTq coupe, 2005 Outback XT, 2014 Soul!, 2004 A6 3.0
      04-27-2009 05:26 PM #29
      Broken links = fail
      Audi TT FAQ --- Maintenance, Misfires, and a XT Spec-B swap --- Great Lakes TCL Registry
      Quote Originally Posted by LG6R View Post
      The Lincoln was like floating down a river made of flowing chocolate; the Buick was like riding a drunk horse up a cobblestone hill.
    5. Member bink_420's Avatar
      Jul 11th, 2008
      Hamilton, ON
      Jetta awp-RIP. 01 Golf tdi
      07-19-2009 09:23 PM #30
      Quote, originally posted by l88m22vette »
      Broken links = fail
      x2
    6. Member aadosx's Avatar
      Aug 24th, 2008
      Auburn
      MkIV BMP .:R32
      08-01-2009 01:03 PM #31
      qq this still works fine w/out pics.
      .:R32 : flickr : vimeo
      Quote Originally Posted by Redapex View Post
      The 599 GTO runs on leaded liquified platinum and the only by product of the exhaust is $100 bills... And whats that glorious sound coming from the tailpipes? Why its Kanye West telling you that your Merc is scrub status.
    7. Member DowNnOuTDubin's Avatar
      Jun 21st, 2006
      Portland, Oregon
      20th AE 3366
      09-14-2009 12:28 AM #32
      Hope this helps the noobs wanting pics. I can work on getting more pics when I have some time to test everything.
      You need a...
      2'' ABS Plug
      2'' ABS Female Adapter
      I needed a 1/4 pneumatic plug (what ever size or style you need, make sure you get one with a male fitting so you can tap it into the ABS plug).
      This is what everything looks like what you will have to buy. You will find all the ABS stuff in the plumbing section.
      Modified by DowNnOuTDubin at 9:31 PM 9-13-2009
    8. Member mcgyver7923's Avatar
      Oct 16th, 2003
      North Ridgeville, OH
      2012 RB APR Stage 3 Golf R
      07-20-2011 09:42 PM #33
      Subscribed!
      _________________________________________________
      12 Golf R RB 4-Door Sunroof - APR Stage 3
      HS Tuning - www.hstuning.com
    9. Junior Member arthur_russell's Avatar
      Jul 9th, 2006
      Southern Tier, Upstate NY
      2012 Chevrolet Volt; 2007 Toyota RAV4
      08-18-2011 01:47 PM #34
      Another entry in the FAQ on this topic still has pics...
      http://forums.vwvortex.com/showthread.php?2692757
    10. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      09-01-2011 03:20 AM #35
      Quote Originally Posted by erevlydeux View Post
      Did this for the first time ever tonight. Ended up finding two leaks that were making my car idle like ****: bumpy idle, engine shaking, all as the ECU/TB hunted for the optimum amount of air.
      Things to note:
      - A B&M's Baked Beans cans works great. It takes a little squeezing, but it fits perfectly in a Forge TIP... no need for a clamp.
      - If you have a big compressor, like a standup 25 gal or something, without an accurate regulator, just give it enough air until you hear the tubing pressurize. Give it slightlyyy more if you don't hear anything, but not much more. You'll blow off your tester.
      - Make sure you clamp the hose coming from the PCV port/hockey puck so you don't pressurize the crank case. If you already have done the SAI/EVAP/PCV delete, folding your catch-can-to-hockey-puck hose in half and using a pair of vice grips works great.
      I ended up having a ripped vacuum cap on one of the nipples on the underside of the intake manifold: tightened the worm clamp too much. I just put a cap that fit veryyy snug and omitted the worm clamp. We'll see how it holds up. I also had a small leak from one of the vacuum lines that goes to the bottom of the TIP near the turbo inlet. I used a screw and clamp at the open end and the screw was too small so it was leaking out. Got a bigger nut, screwed it in and snugged the clamp down tight... voila, no more leaks!
      FYI...the tiny worm clamps like to tear little hoses and stuff. For those, the one-use crimp ear clamps are much better. Alternatively, these are good clamps too (and are reusable)
      http://www.mcmaster.com/#hose-and-tube-clamps/=dvag21
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    11. 03-26-2012 09:35 AM #36
      I know you posted this in 2000, however, it still very good. I have a basic question and I am knew to this forum and how to search thru it for the possible.
      I rigged up a very good pressure adapter, complete with a shrader valve and gauge. However, without a picture or better description, I am having difficulty with " Clamp off the PCV line from the block/valve cover to the intake boot."
      I have tried several hoses clamped, to no avail, as I keep the oil cap on but loose and it chatters from the pressure in the crankcase. I have just about given up but thought I would give this a try, asking the original person who wrote it up.
      I have a 2002, 1.8l Turbo Jetta, GLS. Can you help or anyone else?
      Thanks,
      grake05
    12. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      03-26-2012 09:56 AM #37
      Quote Originally Posted by grake05 View Post
      Thanks,
      grake05
      Use a pair of hose pliers right behind the prv ( hockey puck)
      My Build
    13. 03-26-2012 10:01 AM #38
      Here is the original write-up with pics....
    14. 03-26-2012 11:24 AM #39
      Thank you, I give it a go.
    15. Member
      May 30th, 2006
      Mesa, Arizona
      '04 R32 w/ HPA FT400 w/ UM tune - '95GTIVR6 - '02 TTQuattro
      05-20-2012 03:03 AM #40
      I just made one of these pressure testers for my 2002 audi tt quattro. I found three leaks, cracked hoses all connected to the intake manifold which caused a check engine light, all small splits, Replaced the hoses, cleared the code, car runs great, no check engine light.
      Thanks for this thread !
    16. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      05-20-2012 03:33 PM #41
      this should be a sticky
      Sent from my SPH-D710 using Tapatalk 2
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    17. Member DMVDUB's Avatar
      Jan 10th, 2010
      NOVA
      German, American, Jap'erican
      10-21-2012 04:10 PM #42
      Decent little video by Eric the car guy on how to find a vac leak. I think many people could benefit from watching his videos, They cover many, many things we talk about here.
      Here's the video
      PROTECTED BY SMITH & WESSON
      *THE PANDIT PROJECT(click me!)
    18. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      11-27-2012 06:33 PM #43
      Nice boost leak tester
      http://www.turboboostleaktesters.com...%22/Categories
      Choose the appropriate size for your MAF
      My Build
    19. Member All_Euro's Avatar
      Jul 19th, 2008
      Calgary, AB
      05' VW GLI 4motion, 04’ A4 Avant quattro
      12-08-2012 11:55 PM #44
      ^^ nice tester - same price as the ones from frozenboost but has a gauge
      I finally made time to pressure test my intake system today & didn't find any bad hoses or connections but I could hear a bubbling sound through the open oil cap… like when a kid blows through his chocolate milk straw.
      Background: full EVAP delete with crankcase and valve covers VTA - no catch can at the moment as it was filling up faster than I burn through a tank of gas. Engine oil is the proper colour and I don't have to add any between changes…
      Seems pretty weird, any ideas
      Work - Houzz / linkedin
      Play - Haldex Swap
    20. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-09-2012 01:20 AM #45
      Fyi.
      People, use regulated pressure. Not bottle pressure
      My Build
    21. Member All_Euro's Avatar
      Jul 19th, 2008
      Calgary, AB
      12-09-2012 09:05 AM #46
      Quote Originally Posted by groggory View Post
      Fyi.
      My compressor has two regulators - one for the tank and one for the lines.
      Play - Haldex Swap
    22. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      12-09-2012 12:33 PM #47
      Quote Originally Posted by All_Euro View Post
      Exactly.
      One gauge will say let's say... 150 PSI. That's bottle/ tank pressure.
      One gauge you will adjust to say... 10 PSI. That's regulated pressure.
      My Build
    23. Member All_Euro's Avatar
      Jul 19th, 2008
      Calgary, AB
      12-09-2012 04:07 PM #48
      Exactly.
      Haha - I didn't mean to give the impression that I was using an unregulated air source… or that I didn't know which each regulator on the compressor was for… good review for anyone who's unsure though
      Judging by how fast my CC was filling up - I'm thinking the bubbling sound may be from water in the side-mount IC… I'll head over to my friend's garage and see what I can find.
      Edit: Well that was wishful thinking… got a little oil out of the side-mount but that's it. The search continues...
      Play - Haldex Swap
    24. Member Russjameson's Avatar
      Dec 18th, 2004
      Virginia Beach
      07' S6 5.2L V10, 83' Rabbit 1.8T swap (for sale), Bagged 05' GLI (sold)
      09-06-2013 05:33 PM #49
      I am having this same bubbling from the valve covers oil cap opening when i test mine.
      Did you ever find out what it was?
