VWVortex.com - Replenishing G12 coolant with off-the-shelf products.
    Results 1 to 22 of 22
    Thread: Replenishing G12 coolant with off-the-shelf products.
    1. 09-28-2004 11:36 PM #1
      Hi all. After 3 blazing summers in Arizona (never mind the spring and fall too... ) the coolant level in my '01 GTI VR6 is approaching the min level. I wanted to know if you guys and girls have had any experiences replenishing it with off-the-shelf products (ie Valvoline, Prestone) that seem to be similar to VW's G12.
      From what I've read, both manufacturers make compatible products, but I'm not sure if 'topping off' with them will have a negative effect similar to mixing it with other types of non-OAT coolant, or it will be ok as long as the products are 'compatible'.
      Thanks!
    2. Member eurowner's Avatar
      Jan 25th, 2002
      The Syncro Ranch, Salida CO
      1982 VW Golf GTi 1600 '85 GMC K3500 6.2 Diesel '94 Chevy Suburban K2500 6.5 Turbo Diesel
      09-29-2004 12:18 AM #2
      DO NOT MIX NON-VW COOLANT WITH VW COOLANT!!!!!!!!!!!!!!!!!
      You will kill the motor, plane and simple.
      Go to the Champman, Camelback, or North Scottsdale VW dealers and buy the correct stuff.
      Come on over to here and have fun!! http://forums.vwvortex.com/zeroforum?id=93
    3. Senior Member
      Mar 24th, 2001
      09-29-2004 02:02 AM #3
      For emergency top-off, use water, preferably distilled.
      Generally, stay with G12 coolant (mixed with water in the proper ratio) in VWs that already have G12 coolant in them. Mixing is not a good idea.
    4. 09-29-2004 06:21 AM #4
      I may be going against the grain here but...
      The G12 is similar to the "Dexcool" stuff? You should be safe with dexcool equiv products.
      This is unlike the older G11 coolant that was special to VW and others.
      But yes, NEVER mix the newer G12/dexcool (red/orange) stuff with the older prestone or G11 (yellow-green/blue) stuff! It will sort of turn to jello...
    5. Senior Member
      Mar 24th, 2001
      09-29-2004 12:31 PM #5
      G12 is not the same as Dexcool, although the color may be superficially similar. But note that the new G12 is purple, rather than red / pink.
    6. Member eurowner's Avatar
      Jan 25th, 2002
      09-29-2004 11:09 PM #6
      Again
      Quote, originally posted by eurowner »
    7. Member Fahrvergnugen's Avatar
      Apr 30th, 2002
      '86 Volvo 245, '82 Caddy, '83 GTI
      10-04-2004 06:12 PM #7
      I called the techline on this some time back...
      He's right, you cannot mix brands. VW with VW only... However, if you have drained the stuff, you can put any brand EXCEPT GM, as in Dexcool. It can be Dexcool compatible (IE any brand), but it cannot be DEXCOOL...
      ---For other VW folks--- If you currently have the blue, you can upgrade to the G12 (redy-pink), but you have to flush it Completely. If you do not, the two will turn to a gel, and it will cause the engine to overheat. The same goes for your coolant choices, you can use ANY brand, BUT GM...
      ---If you have green coolant--- in your car, get it out! It does not belong in there! It will cause damage by eating the water outlets and/or the headgasket...
      Distilled water is not necessary on any VW EXCEPT the Vanagon, however it is a very good idea, as the fewer particulates of matter in the water, the lower incidence of damage by corrosion. Also, the coolant will last longer with distilled water. Particulates cause 'fallout' of the good chemicals in the coolant over time...
      Hope that helps,
      David
    8. Member eurowner's Avatar
      Jan 25th, 2002
      10-04-2004 07:12 PM #8
      Thank you for your research!!
      Oct 9th, 2000
      FL
      01 GMC Sonoma
      10-05-2004 02:09 AM #9
      For the little bit you need, just use distilled water. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Member Fahrvergnugen's Avatar
      Apr 30th, 2002
      10-06-2004 03:52 PM #10
      You are welcome sir...
    11. 10-10-2004 09:09 PM #11
      i have had my 91 passat since april and its been leaking coolant all summer. when i got it, it had green coolant in it. since then ive done nothing but add water. water comes out the exaust all the time. my understanding is that it has a head leak, but no water getting into the oil. has anyone else dealt with this before?
    12. Member Fahrvergnugen's Avatar
      Apr 30th, 2002
      10-11-2004 01:26 AM #12
      Yep...
      Headgasket is bad. It will need replacing. This car is not safe to drive on long trips, overheating will be more and more likely... If you drive it, drive with an eye on the temp guage or you will have more to pay for than the headgasket...
      David
    13. 10-11-2004 07:31 AM #13
      oh trust me my eyes never leave that gauge, however it has never had a problem with over heating unless the cooling fans dont come on.... its very interesting.... i love the 16v......
    14. Member JimmyD's Avatar
      Apr 30th, 2001
      Chicagoland
      10-12-2004 02:04 AM #14
      Quote, originally posted by tjl »
      Can the newer purple G12 be mixed with the red/pink G12?
      Why was the color changed? Does it have different ingredients?
      ....or did VW just want to switch from strawberry flavored to grape flavored?
      please advise
    15. Member Fahrvergnugen's Avatar
      Apr 30th, 2002
      10-12-2004 10:41 AM #15
      Yes, those two can be mixed. ZVW-237-G12 (pink), superceeds to the G-012-A8F-A4 (purple). The two can be mixed with no problems...
      TSB C-19-02-01
      David
    16. 10-13-2004 10:05 AM #16
      Since San Diego County tap water is extremely hard, I would not consider putting it in the windshield washer reservoir, let alone the battery or engine coolant system!
      I have a 2001 Passat with the pink stuff, which I still cannot believe is truly "lifetime." (I generally keep my cars 15-20 years.) Of course, water pumps and hoses are not lifetime, and I would put in new coolant when replacing them, but I am seriously considering replacing the coolant every 5 years, as well. Other thoughts on this?
      We need a poll: How often, if ever, do you change or plan to change your pink coolant?
    17. Member Fahrvergnugen's Avatar
      Apr 30th, 2002
      10-13-2004 11:48 AM #17
      Hmm, I myself would keep an eye on it. If it looks okay at 3 years, I would do no more than 4... With distilled water...
      BTW, if you are looking for a true lifetime coolant, look into Evans Coolant...
      Look here...
      http://evanscooling.com
      The site is a bit difficult to navigate, and they do have a product that you can install without modifying the cooling system at all... BUT, you should consult with them first about it, as the coolant temperature is actually higher (and yes, in this case it is actually a good thing) and that may confuse your EFI computer. I have run the stuff for nearly two years and love it, as I am getting more power and higher fuel economy than with normal coolant. Read the site if you doubt me, and look for the article that Techtonics wrote almost ten years ago...
      HTH
      David
    18. 10-13-2004 01:07 PM #18
      All my VWs coolants has always been the green stuff....never any problems...
    19. Member Fahrvergnugen's Avatar
      Apr 30th, 2002
      10-13-2004 02:07 PM #19
      Wait a while...
      Every A3 car that calls needing a water outlet has green coolant in it... Also, about 2 out of 3 of those cars that need a head gasket have the green in it... Besides, this is VWs recommendation. And you do not have to buy stuff from them to get safe coolant...
      To each his own...
      David
    20. 10-27-2004 08:39 AM #20
      Message received on not mixing coolants.
      Here's my dilmna: my mechanic ( a "VW specialist" nontheless ) topped off my reservoir with PEAK glycol based/phosphate free coolant - red stuff just like the G12 in there.
      Should I flush my system?
    21. Junior Member
      Aug 15th, 2012
      st louis
      01 jetta
      09-02-2012 02:52 PM #21
      So I have senerio... My coolant level dropped completely... (reservoir empty) so I basically had none I'm my car... My mechanic (who I'm not going to now) did not flush but put the standard orange in it... Am I okay since it was basically empty? (before I brought it to him I had refilled with water several times) or if not what do I need to do... I have been driving it like this for like a week and a half
    22. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      '03 BMP 20th GTI, '84 TD Jetta
      09-02-2012 03:12 PM #22
      There is still a lot more coolant in the system besides whats in the reservoir. I'd drain and fill with G12.
      Quote Originally Posted by TM87 View Post
      VW-making mechanics out of owners since 1957.
      The project - '84 Jetta 1.6TD
      The Wheelbarrow - '82 Rabbit Pickup
      Hers - '03 BMP 20thAE GTI
      His - '16 GLI SE
