Results 1 to 13 of 13
Thread: darn whistle
  1. 09-29-2004 12:49 AM #1
    Ive searched for the cause of my whistle all through the boards and i havent come to any conclusion. My whistle/whine comes on at about 3100RPM and stops around 4000RPM it use to only whistle when it was cold now it whistles all the time it seems to be comming from the left side of the engine it is not my idle screw, my car is stock except ive removed the CC and gutted the airbox. all vacuum lines are new and ive disconnected the Boost tube from the TB to see if it was boost related and it doesnt change. im gonna replace the serpentine belt this weekend to see if thats the problem. thanx for the help in advance
  2. 09-29-2004 01:01 AM #2
    Quote, originally posted by frescoG60 »
    gutted the airbox.
  3. 09-29-2004 02:07 AM #3
    but it made that sound before i gutted it
  4. 09-29-2004 09:17 AM #4
    any nipple that is undone will whistle. hell i think my alternator is whistling these days, but if its WOT only it sure sounds like a boost issue since the theory of a whistle is BLOWING (though sucking can work) out of an orifice makes the whistle.
    i think i got some bad bearings in my alternator (or sigh g-lader) because i hear a small whirr. Then again i have been caught with a boost leak too.
    Even though my mechanic did a wonderful job on the !Carbon Canister mod, i have noticed a small whirr ever since.
    Lemme tell you theres an unnamed shop that i'll never go to down here again, they tightened down my cam belt so tight that it sounded like a V1 vortec. Thank god the next mechanic fixed it up or i'd have had some sorry ass bearing right quick.
    Can you localize the noise to a specific area perhaps? that might help us help you.
  5. 09-29-2004 07:13 PM #5
    it seems to be comming from the rear passenger side maybe even the alternator
    how can i localize the problem anyone have any tips
  6. 09-29-2004 11:12 PM #6
    I have a whistle too. But mine whistles depending on how far down I hold the gas pedal. Barely it whistles a LITTLE BIT harder like barely and its gone I have no idea what it is but I think its from my TB cause ever since I put in my new one it does that. I think its a bad TB gasket.
  7. 09-30-2004 03:36 PM #7
    mine whistles too, right after removing the CC and repairing a fpr vaccum line, did not whistle when my CC was there
    i can really hear mine well since i removed the boost recirc system
    from what i can tell, it seems to be a resonance in the tb since it goes away if i floor it, only at part throttle it will whistle
    with recirc system removed, 68pulley, and CC still in car, it did not whistle
  8. 05-27-2011 12:38 AM #8
    i have an annoying whistle as well, also only at part throttle, and it will be gone at WOT. my whistle isnt clean though it sounds more like a wet whistle, seriously lol, like if you just picture a whistleing sound with a little water, yeah. and i have a huge 10psi boost leak (only making 5psi now) and this also happened after i deleted the CC.
    take it easy, relax.
  9. Member ThatsNotStock's Avatar
    Dec 30th, 2004
    S.E. Wisconsin
    81 Rabbit Diesel AKA The Smoke Monster
    08-13-2011 06:06 PM #9
    I removed the CC and now have a vacuum like whistle. Ive checked the idle screw and it's ok. It seems to be coming out of the charger intake. I can take off the air filter and mute the whistle by putting my hand over the inlet. Could it be coming back thru the Return boost?
    "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former"
    (Albert Einstein)
  10. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat
    08-13-2011 10:56 PM #10
    Haha, mine started doing this last year. It does seem to be coming from the alternator area.
    My cruise control is not working (3-4 yr's ago).
    My a/c air flow decreases as rpm go up.
    Kinda thought I might have cracked a hose somewhere. There's also the area behind the fender wall that may have lost a seal. I'm not looking forward to tracking this down.
    ¡¡ opɐɹɹoɔ ǝɥʇ!!!ƃuıʇɔǝdsǝɹ !!!
    !! odarroɔ ǝht gnitɔepser !!
  11. Member ThatsNotStock's Avatar
    Dec 30th, 2004
    S.E. Wisconsin
    09-03-2011 01:04 PM #11
    I found it!!!! I thought it was the APEX strips in the charger. so I took the charger belt off and the whistle diminished but was faintly there. Put belt back on and started looking at the IC hoses and the Throttle Body. I pulled a rubber cap from a vacuum connection on the TB below the intake hose. the whistle stopped. Boost comes out of that line. I think that was connected to the Charcoal canister that I removed. Can I use that port for a Boost gauge?
    (Albert Einstein)
  12. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    09-07-2011 12:55 AM #12
    Kewl,
    I'm checking mine out tommor!!
  13. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    05-10-2012 12:12 PM #13
    ** X POST ***
    More on this started in the Corrado Forum
    http://forums.vwvortex.com/showthrea...1#post77325374
