VWVortex.com - THe famous 01314 code.. help please
    Results 1 to 14 of 14
    Thread: THe famous 01314 code.. help please
    1. 09-30-2004 07:44 PM #1
      car started fine, I had the vag pluged in, fired up the soft ware and was setting up a few blocks to log, and the car died, I cannot connect to the engine block anymore, it times out.and asks to retry or cancel
      here are the codes
      VAG-COM Version: Release 311.2-N
      Chassis Type: 1J - VW G/J/B Mk4
      Scan: 01,02,03,08,15,17,19,22,35,46,56
      Address 03 -------------------------------------------------------
      Controller: 1C0 907 379 K
      Component: ASR FRONT MK60 0103
      Coding: 0018945
      Shop #: WSC 00066
      1 Fault Found:
      01314 - Engine Control Module
      004 - No Signal/Communication
      Skipping Address 15-Airbags
      Address 17 -------------------------------------------------------
      Controller: 1J0 920 906 J
      Component: KOMBI+WEGFAHRSP VDO V62
      Coding: 07232
      Shop #: WSC 00000
      3VWRE69M13M001593 VWZ7Z0B5152329
      2 Faults Found:
      01177 - Engine Control Unit
      64-10 - Not Currently Testable - Intermittent
      49-00 - No Communications
      Address 19 -------------------------------------------------------
      Controller: 6N0 909 901
      Component: Gateway K<->CAN 0001
      Coding: 00006
      Shop #: WSC 00066
      1 Fault Found:
      Address 46 -------------------------------------------------------
      Controller: 1C0 959 799 C
      Component: 1H Komfortgerát HLO 0003
      Coding: 00258
      Shop #: WSC 00066
      1 Fault Found:
      00849 - S-contact at Ignition/Starter Switch (D)
      25-10 - Unknown Switch Condition - Intermittent
      Address 56 -------------------------------------------------------
      Controller: 3B7 035 180
      Component: Radio 001 0010
      Coding: 00401
      Shop #: WSC 00066
      1 Fault Found:
      01305 - Databus for Infotainment
      37-10 - Faulty - Intermittent
      End -------------------------------------------------------
      Modified by BMFJETTA at 8:56 PM 9-30-2004
    2. 09-30-2004 07:47 PM #2
      should I try disconnecting the battery/
      oh also , the asr light is on, and it turns over but wont start
      03 Jetta 1.8T
    3. 09-30-2004 08:04 PM #3
      the asr flashes once when i turn the key on.... i disconnected the battery Im going to try that next.
    4. 09-30-2004 08:06 PM #4
      please, help somebody!
    5. 09-30-2004 08:18 PM #5
      heloo???
    6. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      10-01-2004 05:12 PM #6
      Since your ECU isn't talking to anything in the car, it's no real surprise that it's not talking to VAG-COM either.
      Check all fuses.
      If your ECU is chipped, I'd look there there next (especially if it's socketed).
      The other clue is the fault code from 46: 00849 - S-contact at Ignition/Starter Switch (D) You might need an ignition switch.
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
    7. 10-01-2004 06:05 PM #7
      well as it turns out the ecu plug was loose, I just took out the ecu to check my chip, plugged it back in, and boom, started right up, cleared the codes, no problems so far. wow i freaked out about that!! my first day messing with vag com....
    8. 10-01-2004 06:07 PM #8
      fixed it, it was a bad fuse.
      Modified by BMFJETTA at 11:30 AM 10-2-2004
    9. 10-19-2004 09:58 AM #9
      what fuse was it that was bad cuz i'm having the same problem..thanks
    10. Member atoson's Avatar
      Dec 28th, 2002
      San Jose, Ca. South Bay Area
      12 Golf TDI, 00 GTI, 00 NB, 84 Scirocco, 80 Dasher
      12-16-2004 03:43 AM #10
      Quote, originally posted by vjettaw03 &raquo;
      29, 10.
    11. Member chaugner's Avatar
      Jul 13th, 2002
      Miami
      Audi TTQ, Touraeg, Passat
      07-09-2005 01:54 PM #11
      so sure this was a fuse? I just tested a used spare ecu and its giving me
      01177 ECU - Not currently testable
      01314 ECU - No Communications
      if I disconnect battery it starts up and its fine, stop the car, try to start again it won't start and VAG will not even connect.
      any ideas?
    12. 07-09-2005 02:48 PM #12
      hey BMFJETTA, you got a PM from me
    13. 07-09-2005 07:45 PM #13
      Quote, originally posted by chaugner &raquo;
      any ideas?
      Did you adapt the new ECU to the cluster/immobilizer? I think you might have problems unless you do so.
    14. Member chaugner's Avatar
      Jul 13th, 2002
      Miami
      07-10-2005 09:04 AM #14
      Quote, originally posted by joako &raquo;
      Immo disabled ..
      the odd thing is that the car starts when ecu reset (battery disconnected) - however once the car is turned off the ECU appears dead (unable to connect using VAG) - lights and all work, radio. Just cranks without starting.
