Page 3 of 3 FirstFirst 1 2 3
Results 71 to 102 of 102
Thread: A2 1.8t AWP swap tech Wiring Made Easy
  1. 03-07-2005 08:23 PM #71
    hey gtiboy66, i was wondering how the alternator is hooked up, I no how to hook it to the battery but how is the field and indicator hooked up, I am wondering because I did a 1.8t swap into my a2 with a tec3 and I am running a the alternator from my old engine and I wanna convert to the serp belt,
    and I cant find my bentley anywhere, From what I can tell is that the main post goes to the battery/starter, and then their is a 2 pin plug with small 18 or so awg wire, I think the one is for the indicator light and the other is for switched ign to charge the field
    the back of the alternator looks like this, but mine is a 90amp not 120amp
  2. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    1978 Rabbit, 82 Jetta, 58 AH Sprite, 67 Morris Woody
    03-08-2005 11:27 PM #72
    Quote, originally posted by vwdriver92 »
    Sorry But I do not know. Once its installed you should be able to test it with a mulitmeter. I did not take that part of the wiring apart.
  3. 03-14-2005 01:12 AM #73
    wow. lots of info...
    i know i'm a n00b at swaps, so please bear with me: how many hours of labor should this take for a competent mechanic? i'm looking at having a swap done for me, because this is WAY over my head... just wondering how many limbs it's gonna cost me to have it done.
  4. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    03-14-2005 07:52 AM #74
    it took me 2 weeks from start to finish done very nicely. I have never touched it since I did the swap. I was working after work and on the weekends only.
  5. 03-14-2005 01:23 PM #75
    how much $ would that translate to? i guess i'm trying to figure out how much, minus parts, the swap could cost me..
  6. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    03-14-2005 02:14 PM #76
    I probably have 60 hours into it. From start to finish. So figure a shop would charge roughly 1500-2500 in labor.
  7. 03-14-2005 04:29 PM #77
    sweet man, thanks i think you posted a lot of good info if i knew wtf is meant if you were closer, i'd pay you to do the swap
  8. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    04-14-2005 04:07 PM #78
    Bump for anyone who needs the info
  9. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    04-14-2005 04:07 PM #79
  10. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    08-01-2005 11:04 PM #80
    Dec 9th, 2003
    '92 VR6 Syncro Variant, '98 Boxster 3.4L, '09 Smart ForTwo, '06 A3 2.0T
    08-02-2005 09:32 AM #81
    Please post more pics of your ride!! Nice swap! I'd love to do this in a high mileage MKIII VR
  12. 08-17-2005 01:08 PM #82
    gtiboy how much would u charge for doing the swap i live in bergen co
  13. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    08-17-2005 01:14 PM #83
    probably like 12-1500 plus parts
  14. 08-17-2005 02:02 PM #84
    so what would i exactly have to buy for u to do this or maybe u know somewhere i could buy the engine exc
  15. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    08-17-2005 02:23 PM #85
    you need motor, wiring, ECU with REVO immobilizer defete. Whatever trans you want. If converting to hydrolic then you need all cable shift stuff. you need turbo and piping and couplers. Its not cheep by any means. I might sell mine if interested,
  16. Member
    Jun 13th, 2002
    Spofford New Hampshire
    Corrado tdi project Tdi passat wagon and a few other projects hanging around
    08-17-2005 11:06 PM #86
    Still sorting out the wiring on my swap I figured some of the t14 connector wires out and spliced them in to the ce2 harness like temp gauge and some other stuff the only thing left is the main ecm harness wires from the brown plug which I`ve narrowed down but I`m unsure of where they should be spilced into the ce2 harness I`m using to power them When you did the outline of the 20v harness plugs you didn`t give where you spliced it into the ce2 harness to make it power up do you have that info or could you break down where for example brown plug pin# 1 goes to ce2 plug d 6 I hope this make sense to you it what I think makes people shy away from the idea of swapping this engine in being able to get the splice info is what most people are after.I know if my wiring was done I would have the car back together sooner.Jay
  17. Member
    Jul 3rd, 2003
    Stafford, Va.
    96 glx b4v tdi
    08-18-2005 07:42 PM #87
    I'm not into gasser swaps, but I stumbled acrossed this somewhere. Maybe it might help you 1.8t swappers. http://users.snip.net/~gajewsk....html
  18. Member OldSkoolDubbin's Avatar
    Jun 17th, 2004
    Federal Way, WA
    93 Corrado SLC, 92 Jetta GL
    08-21-2005 03:50 AM #88
  19. 08-27-2005 06:47 PM #89
    Dont know what your ce2 cars are like over there but here in the uk we have got spare wires on the back of one of our plugs for accericores which are all ign lives. You can use these out puts for the lives that you need on the brown plug and on the t14. Off the top of my head im sure that theres 7 ign lives needed when you run with the donar clusters and 5 when you run with a revo immbz defeat.
  20. Member
    Jun 13th, 2002
    08-29-2005 01:27 AM #90
    Pictures of the splicing the harness to the ce2 fuse box and wiring with a rough diagram like brown plug pin 1 red with green spilced to ce2 red with black g1 plug.that the way I`m thinking so there isn`t any factory smoke coming out of the ecm or fuse box or harness for that matter.I think some people that do the swap just keep the info to themselves which makes it complicated for other people to perfom the swap or swaps.Jay
  21. 09-03-2005 07:28 AM #91
    You dont want much do you....
    The reason that people dont give out info like this is because some lame ass mofo will put all the info onto CD and sell it on ebay for a tidy profit.
  22. Member 155VERT83's Avatar
    Aug 1st, 2000
    Alexandria, VA
    '11 MBZ C300 4MAT Sport, '99 Audi A4 2.8Q
    06-11-2006 10:52 AM #92
    Good info.
    Signature blank...
  23. Member Space9888's Avatar
    Mar 18th, 2002
    Connecticut
    MK V GTi
    06-16-2006 01:45 AM #93
    sleeper?? watch out for this guy on your local highway!!
    wait......... oh yeah that was a viper we just passed..........
    Modified by Space9888 at 12:46 AM 6-16-2006
    2006 GTI oem stock
  24. Member Space9888's Avatar
    Mar 18th, 2002
    Connecticut
    MK V GTi
    06-16-2006 01:50 AM #94
    you are insane w/ revo this car would be retardedly fast
    2006 GTI oem stock
  25. 06-16-2006 11:41 AM #95
    This should work nicely for my AWW swap. thanks
  26. Member hyperformancevw's Avatar
    Mar 14th, 2007
    Ocean City, MD
    Euro Turds and an '08 Kawi zx10
    05-15-2008 10:31 AM #96
    bringing it back from the dead! i just need to know what pin or wire is constant ecu power and which one is switched on an awp.
    -87 Golf GT, built BT 1.8t 12.02@119 1.96 60' HX35@18psi pump gas (sold/parted out)
    -64 ratty bus "the slamper"
    -91 Jetta ALH TDI swap
    -80 diesel caddy
    -89 merkur xr4ti
  27. 06-17-2009 01:59 PM #97
    Imed ya man, just need clarification a bit
  28. Member lo41moneypit's Avatar
    Aug 10th, 2007
    mk2, B6
    06-20-2009 12:06 AM #98
    how did you wire for the vss?
    Modified by project91gli at 10:08 PM 6-19-2009
  29. Member bansheelos's Avatar
    Nov 29th, 2004
    Dirty Jer-Z
    94 Golf VR, 78 Bay Bus VR under const.
    08-22-2011 09:30 AM #99
  30. Member notldubber's Avatar
    May 3rd, 2008
    Niagara on the Lake, Canada
    1987 vw scirocco, 2001 golf gti/glx, 2001 AWP Revo 2 Golf GL, 1991 golf 16v
    04-02-2012 08:55 PM #100
    Great info
  31. Member
    Aug 17th, 2011
    london,ONT
    92 8v jetta
    04-09-2012 08:42 PM #101
    So for the brown orange blue harnesses do i just snip them(the ones in the cab side ) and splice them into ky ce2,, like the ones that run into my interior i can just cut them right cause there just gunna be spliced into the ce2 harness....im in this boat right now with wiring and cant find a diagram what wire gets spliced into where in thr ce2 harness cause its all aeb sh!t..... lmao please help me out here lol....
  32. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    windsor 2.0, ginster 1.8t
    01-15-2013 03:03 AM #102
    this is old but very useful to me
    Quote Originally Posted by ZACHER3tuning View Post
    only on vortex, could this turn into a argument.
    http://forums.vwvortex.com/showthrea...Project-molest
