VWVortex.com - p1296 code,whats it all mean? 2001 jetta vr6,glx,auto trans
    Results 1 to 19 of 19
    Thread: p1296 code,whats it all mean? 2001 jetta vr6,glx,auto trans
    1. 10-11-2004 09:46 PM #1
      Bentley shows it as cooling system malfunction,but I dont have any cooling problems.Went to auto zone to pull up the code with an Actron Meter,it said fuel air metering on the Actron.When they looked it up (p1296) it says 'multi-faults-bank 2-with low side shorts.'
      OK,gentlemen,what gives?Will this affect smog testing if this code shows?I erased it with the Actron.
      Thanks a lot,
      CC
    2. 10-11-2004 09:58 PM #2
      According to the Bentley CD ...
      P1296
      17704
      Malfunction in cooling system
      - Check Engine Coolant Temperature (ECT) sensor.
      - Check thermostat.
      If smog testing is like OBDII testing in other states, then you'll fail if there are any codes stored in memory.
      Gary
    3. 10-11-2004 10:23 PM #3
      I think that is the code I got when my engine temp sensor was bad...
      If you clear it... it might come back in a few days like mine did.
      serched and found this...
      http://forums.vwvortex.com/zerothread?id=1166170
      Modified by drli at 3:28 AM 10-12-2004
    4. 10-12-2004 01:06 AM #4
      OK,off to replace that temp sensor,should have checked archive first,duh!
      160,000 plus miles,hope I get the same.Got 65,000 and doing a wheel bearing today,a couple sensor repairs under warranty,and window fix under warranty,all in all not too shabby so far
    5. 08-29-2005 11:36 AM #5
      I have the same issue currently and want to replace the sensor. Where exactly is the sensor? A photo would be great.
    6. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      08-29-2005 11:41 AM #6
      there is a full write up on replacing the cts in the diy/faq thread stickied at the top of the forum. please check there first in the future.
      Dave
    7. 08-29-2005 12:54 PM #7
      I looked and couldn't find the thread. Any suggestions?
    8. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      08-29-2005 01:05 PM #8
      couldn't find the faq thread of the cts thread. the cts thread is in the vr6 section of the faq. The faq thread is stickied at the top of the mkiv forum on page 1.
      Dave
    9. 08-29-2005 07:17 PM #9
      any update on this? I have the EXACT same problem right now...???
    10. 08-29-2005 08:04 PM #10
      Simple. Just replace the coolant temp sensor - http://forums.vwvortex.com/zerothread?id=828493.
      Gary
    11. 08-30-2005 01:11 AM #11
      thanks a lot... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. 08-30-2005 03:30 PM #12
      i replaced the coolant temp sensor but now my gas mileage is really bad. im pretty sure i put it in right. the code i got off of the obd 2 was p1296 but it said the fuel air metering, etc as you all already know. do you think its possible that it was my MAF all along? or is there a problem with the installation?
    13. 01-05-2007 12:51 AM #13
      i have the same problem, i replaced the cts and am still throwing p1296(fuel air metering), and my gas mileage sucks. wondering if and how you fixed your problem.
    14. Member NoWtHaTzBoSs's Avatar
      Aug 11th, 2007
      07093/07047, NJ
      2001 1.8t WOLFSBURG PEARLY WHITE
      05-21-2008 11:50 AM #14
      p1296 code not only comes when the temp sensor is bad, it also puts out this same code when your coolant sensor is bad as well....
    15. 05-27-2008 09:58 AM #15
      I have this code right now but I'm already running on the grren top sensor which i replaced give or take about a year ago ...so about 13,000 miles ago...???? could I have had gotten a bad sensor?
    16. Member borline's Avatar
      Nov 3rd, 2003
      Germantown, MD
      02-21-2009 06:20 PM #16
      Bringing this one back...
      Quote, originally posted by brus6286 »
      I just got this code today and also have green top sensor already. Could it have gone bad? I've had it in there for ~3 years. My car was stuttering before the CEL showed up. After reading the code, I unplugged the MAF and the car ran better. In a book I have for OBD2, it shows "No 5v to MAP" for P1296. What is MAP?
      1991 VW Jetta Carat Calypso then 2001 VW Wolfsburg Galactic Blue then 2013 VW GLI Autobahn Tornado Red
    17. Member borline's Avatar
      Nov 3rd, 2003
      Germantown, MD
      02-22-2009 12:32 PM #17
      bump up!
    18. 02-22-2009 12:53 PM #18
      Replace the Thermostat.... had the same prob a year ago.
    19. Member azntaiji's Avatar
      Jan 3rd, 2008
      The sticks
      '99 Miata
      02-22-2009 02:36 PM #19
      bump
