Page 1 of 30 1 2 3 ... LastLast
Results 1 to 35 of 1018
Thread: 16v Digfant II FAQ
  1. 10-08-2004 11:42 PM #1
    Since I have had good luck with my swap except for a few minor bugs I thought I would spend some time and do a writeup on the subject.
    Swap Motor = 2.0 16v Engine Code 9A Passat Motor.
    Older Pic that is missing the new intake pipe but good enough. The pipe on there is the plastic 16v stock pipe cut down.
    8v parts needed from old motor.
    Fuel Injector's
    Fuel Pressure Regulator
    Knock Sensor
    Blue Coolant Sensor ( this is a topic of debate more info below )
    Single Sensor Coolant Flange on side of cylinder head
    8v Throttle Body
    8v Coil
    8v Fan After Run Switch
    Digi2 Airbox
    Vanestyle Air Meter (VAM) (on airbox)
    Airbox to Throttle Body Tube
    Idle Stabilizer Valve (ISV)
    8v Tranny (optional see below)
    8v Lower Radiator Hose
    8v Heater Core Hoses
    All 8v Pulley's
    Digi2 Injector Cups
    Keep all of the 8v hoses and various bits until your done cause they come in handy for custom stuff.
    16v Parts to keep
    16v Motor Complete
    16v Tranny (optional see below)
    16v Alternator
    16v Rubber Throttle Body Elbow
    16v Brake Booster Vac Hose
    16v Throttle Cable (see below)
    16v Distributor
    16v Plug Wires
    16v Upper Radiator Hose
    16v Coolant Pipe
    16v Sensor's (keep them all for now)
    16v Oil Cooler and Filter Flange
    16v Exhaust Manifold and Gasket's
    Keep all of your 16v Hoses and bits for now too cause you never know.
    Things You Have to Buy
    The Bentley Manual (optional but highly recommended)
    Fuel Rail (Ross or BBM or Homemade whichever works for you)
    Fuel Pressure Regulator Mount (usually you can order it with your rail or use an aftermarket regulator)
    Replace all non reusable stretch bolts (refer to Bentley)
    Clutch Pressure Plate Bolts
    Flywheel Bolts
    Crank Pulley Bolt (if removing Pulley)
    CV Joint Bolts
    Cylinder Head Bolts
    Connecting Rod Bolts
    Things I Recommend You Replace or Buy
    Spark Plugs
    Plug Wires
    Dist. Cap and Rotor
    Timing Belt
    Timing Belt Tensioner
    Sensors (see below) Coolant Temp Sensor, Oil Pressure Sensors
    Water Pump
    Thermostat
    Vacuum Hoses
    V-Belts
    Fuel Filter
    Air Filter
    Oil Filter
    Oil
    Fuel Hoses
    Injector O-rings
    Motor Mounts (which ones you use depends on which brackets you keep, see below)
    Clutch Disc
    Change Tranny Fluid
    New Ground Wires
    New Power Wires
    O2 Sensor (8v)
    Every shifter bushing
    Air Fuel gauge
    CV Joint Gaskets
    CV Joint Grease
    Front Subframe Bushings
    Steering Rack Bushing
    Copper Exhaust Manifold and Cat. Nuts
    Magnetic Oil Drain Plug
    Oil Drain Plug Seal's
    Oil Pump
    Digifast Chip from VW_Pilot on the tex
    Special Tools
    Clutch Disc Centering Tool
    Shift Gate Alignment Tool (or print out its picture and make a cardboard one.
    8mm 12 Point wrench for CV joints
    12 Point Metric Sockets for clutch pressure plate bolts
    Timing Belt Tensioner Tool (can use snap ring pliers)
    17mm Hex Tool for Tranny Drain Plug
    OK just some basic stuff that I think you should do during this swap.
    Label all of your electrical connections and where they connect to before you unplug them.
    If you do not have the Bentley then draw diagrams of vacuum lines and other hoses.
    Replace EVERY corroded connector with a new one or clean them up shiny.
    Keep your eyes open for other problems and fix them now while the engine bay is empty and easy to work on.
    Shifter bushings replace them all while you can they make a huge difference.
    The Info
    Tranny
    Depending on your situation you can keep the 8 valve tranny or use the 16v tranny but some of the parts are not compatable. If you Notice any leaking gaskets or seals replace them now while it is easy. You may want to consider doing the Throw out bearing, clutch center plate and retaining ring. If you switch to a 16v Hydro tranny the process is beyond the scope of this write up please refer to the tranny forum for more help
    If you are keeping your 8v tranny then you need.
    8v Front Motor Mount Bracket
    8v Starter
    8v Flywheel
    8v Tranny Tin/Shields
    8v Clutch Disc
    16v Pressure Plate
    Fuel
    I recomend an air fuel gauge to keep track of the new motor since Digi2 was never meant to run this motor you wouldn't want to ruin it. A new o2 sensor will decrease the chance of this as well as a Digifast chip from VW_Pilot on the tex.
    You have to get a fuel rail cause the 8v one will not work. Be sure to replace Injector' O-rings and if you can swing it injector's. Sometimes the studs that hold the upper and lower manifold together stick out a little and interfere with fuel rails so you should grind them down.
    Good time to get new fuel lines while you are at it. The BLUE fuel hardline is the return and should go to the FPR.
    I am running the stock fuel pressure regulator and it is fine. Definitly replace your fuel filter cause it is cheap.
    See pic above for fuel rail and lines.
    Pic of the FPR
    Throttle Body
    The idle and wide open throttle switches on the 16v TB do not plug into the 8v harness without modification.
    The 16v throttle body that I had came with the restrictor plate on the butterfly and the vacuum connections were not ideal. There was also no idle adjust screw so I went with the 8v.
    When using the 8v TB however you have to modify the throttle cable by cutting it shorter and using a wire nut on it, also a piece of rubber hose over it will decrease chafing on the throttle lever.
    See the pic below of my intake tube for the wire nut on the throttle cable.
    Vacuum Hoses
    Definitly replace all of your vac hoses no point in not doing it now it will only give you trouble later. On the 8v TB there are 2 small ports on front and one on back. The front right port goes to FPR and splits off to the airbox as well. The front left goes to the EVAP Valve and so does the rear one. Refer to the Bentley for specifics.
    I replaced the 8v Brake booster hose which runs from the intake mani to the booster in favor of the 16v cause it fit better.
    Pic of brake booster vac hose from Passat
    Intake
    You will have to rig something for your intake tube. You can use the 8v rubber one but the fit is not ideal. I used the 16v rubber elbow and a piece of aluminum tube and a silicon turbo style boot to fabricate my own. The aluminum tube came from a turbo volvo for 5 $ I just cut it at one of the bends to give it the correct shape.
    Depending on how you run your ISV hoses you may need a port on it but I ran my ISV to the large TB port with a piece of old coolant hose.
    Pic of my new intake tube.
    ISV
    As far as I know the 16v and 8v ISV's are not compatable but you can simply swap one for the other and put the 8v one in the stock 16v location and use the same hoses. If I remember right one the hoses was a little big so I had to tighten the hose clamp really good but nothing major.
    Here is a pic
    This is the hose I used to connect the ISV to the TB, I used the stock 16v plastic pipe and the hose is an old coolant reservoir hose.
    Cold Start Injector
    I removed mine completely and threaded a large bolt into the hole with some sealant. A block off plate would work too or you could even just leave it there unplugged.
    See pic of ISV for the bolt in the cold start injector hole
    Hoses
    I used the 8v lower radiator hose with the 16v upper radiator hose and a Passat 16v coolant reservoir hose cause the 8v and 16v hoses were not long enough. I think the metal coolant pipe from the Passat is slightly different which is why. The rest of the hoses were 16v hoses except for the heater core hoses which were from the 8v however I had to cut the hose that goes into the side of the 16v head cause it was too long so maybe the 16v heater core hoses would have worked better.
    My crank case breather hose I decided to not reconnect to the intake stream cause I didn't want all that carbon build up in my freshly rebuilt motor so I put a minifilter on the end and capped off the vac lines from the manifold. I don't have much blowby in the new motor so oil spatter out the end of the filter is not a problem however I think there are some advantages in horse power when you create a vacuum in the crankcase so I am researching that further.
    You can see the K&N minifilter on my breather hose under the FPR pic above. UPDATE: This etup has proven to be messy even with my windage tray I still get oil vapor. I reccomend either a catch can or piping the crankcase vent hose back into the intake system.
    Sensor's
    There has been some debate over whether or not to use the stock Digi2 CTS vs. stock 16v CTS and I have run some tests to see for myself. According to the Bentley they are electrically compatable. I took both sensor's and heated them up in water with a thermometer and took readings off both. They gave the same readings as predicted. However if you wish to use the DIgi2 sensor you will have to use the single sensor coolant flange off the side of the 8v head and put it on the 16v head. Mine fit with no modification but I do not have the 16v thermotime switch installed so the hole is plugged and I had plenty of room for the flange.
    I also have the stock 16v CTS installed and when I take reading off of them while they are both in the car I get slightly different readings from one to the other which I attribute to there locations. The difference is not substantial and they both fall within the Bentley's specs so It is really up to you but they are compatable.
    The Temp sender for the temp gauge on the dash you should use the 16v one and just cut the digi2 connector off and use a spade terminal. The brown wire is ground so connect the other one or test for voltage when the key is on and use that one.
    Replace your oil pressure switches cause they are cheap insurance but I recommend moving the low pressure switch to the back of the cylinder head where the oil temp sender is located and moving the temp sender to the oil filter flange. The head will lose oil pressure earlier which is why I moved it.
    The radiator fan after run switch is located on a bracket on the back of the 8v valve cover just remove it and put it on the 16v vallve cover above the exhaust manifold.
    All the sensor locations including the digi2 single sensor coolant flange.
    Radiator fan after run switch mounted above header or exhaust manifold.
    Ground Wires
    Digi2 is really sensitive to bad grounds so replace all your ground wires and clean up or replace connectors. You should have grounds running from battery to body and then to tranny. I ran one from tranny to cyclinder head as well. There is also a ground from the coil bracket to the valve cover.
    O2 Sensor
    Digi2 is also sensitive to a failing o2 sensor so replace it atleast every 60k miles. Alot of Digi2 problems can be fixed by replacing the o2 sensor.
    Distributer
    Pretty much plug and play, the Digi2 connector plugs right in. I had an issue with a bad Hall sender when I originally did my swap but I think it was just bad so I swapped in the Hall sender from my 8v Dist. . It is possible that this has to be done on all of them cause I have heard other people having to do the same thing but I don't have any hard evidence to back it up.
    Fuel Injector Harness
    The old harness is not long enough to reach around to the front of the 16v so I soldered ina couple short length's of wire to make it reach. Be sure your connections are waterproof and don't bother with butt connector's cause this is not the place for them. If you do not know how to solder you can buy no crimp butt conector's that solder the wires for you with the help of a lighter. NAPA carries them but so do other auto parts stores.
    I chose to keep the plastic loom that covers the injector wires, I split it open and drilled a couple holes through one half of it that would line up with the holes in the bottom of my Ross Fuel Rail and mounted directly to the rail. Looks perfectly factory. Putting the connector's one the injector's can be a real bitch no matter how you do it so be patient.
    Here is a pic of how I mounted the injector harness loom to my Ross rail.
    Exhaust
    The 16v and 8v exhaust manifolds are not compatable, the Passat 16v manifold is different from the GTI 16v manifold as well. The dual downpipe from the GTI 16v is the same as the dual downpipe from the GTI 8v however the Passat 16v dual downpipe is not the same.
    According to a few other people here on the tex they have used the Passat manifold and downpipe without any problems.
    Another option of course is to use a header which should be for a GTI 16v.
    Everything else after the Manifold/Downpipe can be reused from the 8v.
    Alternator
    16v and 8v alternator's are not compatable because the mounting brackets are different. Use the 16v one.
    Pulley's
    Depending on whether or not you have AC determines which pulley set you use. They are completely different. To correctly remove AC you must change the small pulley on the crank, the waterpump pulley, and the alternator pulley and if I remember correctly the power steering pulley as well. The only one that stays the same is the large crank pulley. It is possible to make things work and many people have done it but since my 16v originally came with no AC I had to change them all in order to add it.
    Motor Mounts
    The motor mounts should all be replaced at this point since the 16v is a more powerful motor any questionable mount from the old 8v will be no good when the 16v starts pulling on it. Which mounts you use depends on the brackets you have. There are hydraulic front and rear mounts or solid mounts and they have different brackets so make sure you order the correct ones.
    Tuning
    Tuning is all done to the Digi2 specs so follow the procedure in the Bentley. The 16v does seem to like a slightly higher idle though.
    I have been experimenting with tuning the VAM spring but small adjustments really don't seem to make a difference. I am not sure how the idle mixture is or whether it should be asdjusted since I do not have access to smog equipment.
    That is all I can think of for the moment but I will be updating pictures soon as I take them.
    http://www.dubbase.2ya.com My Site
    Please add anything I have missed.
    **UPDATE** 9/3/2008
    I am sad to say that I will be moving away from the mkII world. My GTI has reached the end of its life due to rust issues that I simply do not have the time to fix. I have been through a lot with my GTI including a 16v engine build this Digi2 Swap and basically rebuilding the entire car over the course of the last 8 years. I am sad to see it go but I am itching to spend time restoring my 77 Westy that has been in storage for the past 6 years. In order to keep my spirits up during the daily commute I have also purchased myself a little known car called an .:R32 so don't feel too bad for me........
    Pic of the ride at the height of its glory.......
    I will keep up this FAQ and its pictures as long as I can but if any Vortex admin is willing to take over the maintenance of this FAQ please let me know.
    Before I go I just have one last little piece of technical info regarding this swap that I thought would help everyone out in their efforts to better tune their Digi2 swaps....
    ==== HOW TO INSTALL AN INNOVATE LC1 WIDEBAND O2 SENSOR AND CONTROL YOUR FUELING ====
    I exceeded the 20000 character post limit so follow the link and scroll down to the instructions.
    Modified by MBRACKLIFFE at 8:47 PM 1-1-2009
  2. 10-09-2004 12:36 AM #2
    Dude that pretty much sums it up. At least for a MKII. Great Job!!!
    For a MKI there are a few extra things to add to that. Yes, some MkI's were digi2. Mine for instance. 1993 VW rabbit Cabriolet.
    - Re-use all MKI mounts. They will all work.
    - Must use scirocco 16v manifold and downpipe. Passat or MKII manifold/downpipe will not fit.
    - It is easier to use scirocco upper intake manifold, as the intake hose and air box can remain on the driver side. However, a passat or MKII upper manifold will work, you just need to make some room on the passenger side.
    That is all I can think of that is different for a MKI right now. But I'm going to keep thinking.
    Pics of my digi2 16v MKI swap
    Modified by cdn20VALVE at 12:54 AM 10-9-2004
  3. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    1.6D, 16vT
    10-10-2004 02:02 PM #3
    can you explain (or even take some pics ) of that peice that blocks off the thermotime sensor on the side of your head. my new motor originally came with cis-e and ive had a couple people tell me to track down this elusive block off or plug for the thermotime but it seems its impossible to find. was there just no hole tapped in your head, or was there an actual threaded plug in there?
  4. 10-10-2004 03:21 PM #4
    some pics from poland , and polish faq
    http://vwgolf.pl/forum/viewtopic.php?t=672
  5. 10-10-2004 04:38 PM #5
    There was an actual threaded plug in the hole for the thermo time switch I believe it was plugged because the Passat had no AC. If I remember correctly the hole is just an M10 I am sure you could use some thread sealer and a bolt or find a metric alan plug.
  6. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    1.6D, 16vT
    10-10-2004 04:56 PM #6
    rad thanks for the help
  7. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    1.6D, 16vT
    10-10-2004 08:04 PM #7
    awesome, thanks again ill see if i can find one of those allen bolts that has threads all the way up the sides.
  8. 10-11-2004 04:53 PM #8
    yup. thats pretty much it! wow, and after months of bashing my head against my jetta.......... (me and my mechanic), great write up!
    '06 A4 2.0TQT S-Line (black)
    '08 Jetta S (black)
    FE ///Motorsports
  9. 10-14-2004 08:40 AM #9
    nice swap i have had the same swap completed for about 15,000kms now with no problems, looks and runs mint in an mk2. any questions just ask.
  10. Member 4valvemk2's Avatar
    Feb 14th, 2003
    Ballard
    10-15-2004 01:41 AM #10
    Modified by 4valvemk2 at 6:07 PM 10-22-2004
  11. 10-15-2004 06:26 PM #11
    would this swap be similar to swaping an 1.8 16v into and 1986 gti?if no the same what all do i need and if u can help me with anyother info let me know ....my email doesnt work so just post somthing after this...
  12. 10-15-2004 08:53 PM #12
    Ok so now that we have a Digi 2 FAQ. Let's talk modifying.
    My car runs rich low rpm, and lean high rpm. Typical Digi2. So how do I go about fixing this. Other than going standalone.
    I had my car on a 40,000.00$$ diagnostic machine at my tech school yesterday, and the air fuel ratio at idle was perfect at 14.8:1.
  13. 10-15-2004 09:05 PM #13
    the easiest is to use a relay triggered by the WOT that takes the coolant sensor wiring through a resistor - resulting in a richer fuel mixture.
  14. 10-16-2004 12:18 AM #14
    Richer is good, but it's already too rich at low rpm.
  15. 10-16-2004 08:12 AM #15
    what I described is the enrichment device - used ONLY at WOT - at which point the readings stated were lean - it does nothing at idle....
  16. 10-16-2004 12:33 PM #16
    I have never heard of this enrichment device for Digi 2, basically what you are saying is to use a 87/87a relay and have it connected to the WOT throttle switch. When WOT is not active the CTS signal is normal and when WOT is activated the CTS signal is rerouted through a resistor to trick the ECU into thinking the engine is colder than it is..?
    What do you do with the original WOT wiring..? it stays connected I would assume?
    Interesting idea have you tried it..?
    I have been toying with the idea of connecting some of the Digi2 sensors to variable resistance POT's in order to tune it better which is similar but I have not tried it yet so no results to report.
    Another trick which is much simpler is to get a big fat O-ring and put it on the lever that actuates the WOT switch so that it turns it on sooner.
  17. 10-17-2004 01:38 AM #17
    definitly bump for sticky.
    I like how you routed your isv. I had the engine alone with no bits and had to just hack vaccume hosefrom my 8v to my isv. I will be going out to get some stock 16v isv hoses and hooking them up, kudo's on the great work.
    Nowon with my problem. my digi2 16v died while i was driving, it was at 3500 rpm and just cut to 0 like i turned the key off. I thought it might be ignition coil . .be we tried a different one and its the same thing. one innitial spark when the key is moved forward and as the car turnes over nothing. Is this normal? I think now the only thing it can be is the dist. which is the used/weakest history part. I will try to change my hall sender form my 8v into it tomorrow. Can you maybe give a breif explanation on how that works? you mentioned you had to do the same. Thanks I'll try to post some pics for you to check out.
  18. 10-17-2004 05:02 PM #18
    I was getting the same thing when I first tried starting my car. It would spark once and then nothing, it was the hall sender. Taking the sender out of the 16v dist. was fairly easy jsut make sure when you put the dist drive gear back on that it is the correct way because it is possible to put it on 180 degrees out.
    The 8v hall sensder was a PITA I basically destroyed my 8v dist getting it out. I don't know why but it just didn't want to play nice.
    If you end up buying a new hall sender they are all the same for 8v or 16v so you may want to update to a newer one from an aba or something since I think they are like 50$ as opposed to a 16v one which is like 150$ or something crazy.
  19. 10-17-2004 08:33 PM #19
    Quote, originally posted by MBRACKLIFFE »
    This the same as the CIS-E enrichment device sold commercially by "namebrand" tuners.....for like $80!
    Since the blue temp sensor performs the same function as a CIS-E coolant sensor, an adjustable pot in the WOT position would let you tune how much enrichment. Using a 2 position relay the non-energized position routes the current through the "normal path"
    Currently one of my 16v projects is set up for Digi-1, however I have a 90 GLI that I'm looking at converting to Digi-2 using the BMW MAF housing for more flow..
  20. 10-17-2004 11:04 PM #20
    ya ive heard of the BMW MAF, which sounds like a nice mod for us digi 2 guys, what i have done is opened my stock maf up and loosened the spring tension by releasing it 3 clicks makes for better throttle response and runs a little bit richer. but i wanna find a BMW maf setup for increased airflow.
  21. 10-19-2004 12:04 PM #21
    ttt
    i got an 8v hall sender and its different, the pick up is on the opposite side and it has 4 mounting bolts and a disc on the bottom where the wires are run. Can it still be used?Or will everything be 180 deg off??????
    Modified by veedubinit at 5:06 PM 10-19-2004
  22. 10-19-2004 05:31 PM #22
    question. do i need to switch hall senders on my distributor (16v one) with the old one (the 8v one), or is this necessary only if the 16v one is bad? please clarify.
    '08 Jetta S (black)
    FE ///Motorsports
  23. 10-19-2004 06:07 PM #23
    the 16v one works fine but if your 16v one is bad then it is possible to switch in the 8v one, but chances are your 16v one is fine and is compatible, im using it.
  24. 10-22-2004 07:19 AM #24
    i do think that the BMW MAF upgrade is needed in order to flow enough air for a 16v...
    i picked one up recently and am going to see if I can swap guts from my spare Digi-2 MAF over. Maybe I'll try this Digi-2 swap on a future project.
    Has anyone compared it to a 2.0-16v CIS-E Motronic running a TT chip? I'm very pleased with the performance that setup has given me.
  25. Administrator Anthony@VMG's Avatar
    Aug 2nd, 2000
    Reston, VA
    92 Corrado VR6 S/C, 04 Porsche 911 C2, 08 BMW K1200S
    10-22-2004 02:01 PM #25
    Many thanks to MBRACKLIFFE for posting this.
    - Anthony
  26. 10-22-2004 03:28 PM #26
    Quote, originally posted by OhioBenz »
    I'd be curious to know this too. But when I went to the junkyard, I noticed that many v6 car srun the same size VAM as us. And this is on a 2.6L or bigger V6! So if it flows well enough for a V6 it should be more than enough for a 2.0.
    Modified by cdn20VALVE at 5:39 PM 10-22-2004
  27. 10-22-2004 04:36 PM #27
    Quote, originally posted by cdn20VALVE »
    I'd be curious to know this too. But when I went to the junkyard, I noticed that many v6 car srun the same size VAM as us. And this is on a 1.6L or bigger V6! So if it flows well enough for a V6 it should be more than enough for a 2.0.
    If I can find it back I'll post the link/data because the stock 16vhead flows more CFM than a ported VR6 head. One of my reasons for not bothering to mess with a VR
    here's the link - http://www.porttuning.com/Flow%20data.htm
    Modified by OhioBenz at 5:15 PM 10-22-2004
  28. Member 16V VW's Avatar
    Jul 31st, 2004
    Broke Down On Sides Of Roads
    460 brazillion hp Mk2 Vr6t, camry 24v 5sp
    10-24-2004 10:09 PM #28
    I have a few problems that i need help with.
    - At startup it dosen't idle unless the gas is held at 3k for 30 seconds.
    - Once warmed up, Idle will go up to 3k for 2 seconds then slowly to 1k, then to 3k for a few seconds then down to 1k, it will do it the whole time unless clutch is engauged.
    - A more recent problem is coolant is spitting out somewhere around the front of the head "coolant flange, hoses" or something.
    - My radiator fan WONT turn on for the life of it, i replaced the radiator sensor.
    - Temp gauge dosen't work.
    - Oil and Coolant buzzers are going off the walls.
    im about ready to blow this car up, i need it for school and i have missed 21 days cause of this piece of crap. save me from blowing it up. please.
    Eastwood Fender Roller For Rent in NEPA, 80 bucks for 4 supervised hours and you do it i will help, 35 bucks a corner, 120 for me to do a whole car, cars with flares 30 bucks more un installed + un cut, 50 bucks installed + cut. give me a call or text (570)332-4564
    Current e-bay auctions http://motors.shop.ebay.com/vwjettad...1&_from=&_ipg=
  29. 10-24-2004 11:55 PM #29
    Idle: Is it adjusted correctly, timing..? ISV working? If yes then have you checked for vacuum leaks..? A vacuum leak can cause this exact thing but so can an incorrectly adjusted idle. The fluctuating sounds like a dirty ISV so start there and clean it with carb cleaner until it shines. With the key in acc. position the ISV should hum and vibrate.
    Buzzers and lights : unplug the wires from the sensor's and see if they shut off. Check that they are wired to the correct sensor.
    Coolant temp guage: there should be two wires from the Digi2 wiring harness, if you are using the stock 16v sensor you only need one. Brown is usually the ground wire so use the other one for the sensor. or ground one wire at a time and whichever wire makes the temp guage go to full hot is the one you want to use.
    Radiator fan: Do you know the motor works..? if not unplug the fan and use jumper wires from the batt to see if it works. If it is working then check the wiring for anything obvious. After that I would refer to the wiring diagram and start testing with a multimeter.
  30. 10-25-2004 06:42 AM #30
    yeah digital multimeter and a Bentley is usually where you end up at.
    use the DMM to test which wire for the sensor is the ground (with the key off)....it should have continuity to any ground point on the chassis.
    pls remember that Digi does not like sparks, loose grounds etc.... they fry easily!
  31. Member 16V VW's Avatar
    Jul 31st, 2004
    10-25-2004 11:24 PM #31
    Well heres a good story that is good/bad. Today I got home from school and my friend was driving my jetta and i was driving his, anyway, i was outside fixin some crap on it and the cop pulls up and says, IM GOING TO IMPOUND YOUR CAR RIGHT NOW!!! YOUR AN IDIOT, {MIND YOU THIS IS THE 5TH TIME HE HAS PULLED ME "MY FRIEND OVER"} FOR NO REASON!!! then he says, "speeding in a school zone! "it was 4:30 LOL" you were like a bat out of hell "all my friend driving", then says, " your going to have citations in the mail, bla blah bla, then he gets in his car and pulls upto me after i walk over to my friend and says, " just busting your balls, and peels out and drives away."
    Nextime im going to have a box of donuts in my car.
    but i left and went with some girls and other of that good stuff, so ill check the car out tomorrow.
    True story by the way.
  32. 10-26-2004 11:36 PM #32
    Ok all you digi 2 knowledgable peeps. I have a problem.
    I put my digi2 setup in a while ago and i was running a copper t from the main vaccume on the back of the intake manafold. Now i have been having problems with it trying to compensate and stall out and i figured it was bad vaccume.
    Today i tried to re-route the ISV vaccume more stock ish, where i had a piece of metal blocking the lower intake for the 5th injector i took it off and ran the isv there and form the larger vaccume port on the 8v throttle body.
    When I did this my idle would sit at like 1300rpm so we figured it was a leak somewhere. So i pressureized the system and came up with absolutly nothing .. it was working great. So why is my idle messed up? I then decided to tear out everything and plug all the vaccume ports. i adjusted the idle manually witht he screw and wouldnt you knwo it .. . it works fine. WHAT IS GOING ON? on the 8v if you did that it would crap out in like 3 seconds.
    Also. . my downpipe is sitting on my swap bar making a really bad vibration and noise. should i just rip out the sway bar??? thanks in advance guys
    Modified by veedubinit at 4:41 AM 10-27-2004
  33. 10-27-2004 12:04 AM #33
    Did you try readjusting your idle when it was idling at 1300 ? If your idle was holding steady at 1300 it sounds like everything was working just needed readjustment.
  34. 10-27-2004 12:11 AM #34
    nope we tried that .. it was fully closed ont he adjustment side is it just me or is this weird???? i mean . .does the isv effect fuel curves? I'm sure with it unplugged it just puts the computer to a default .. .but should i just leave it all ripped out?
    also when it was hooked up it was hickuping and kinda miss firing a bit sometimes. . . and when it was all hooked up it would surge to 1500, then 500, then 2000 then 250 then 2500 or 3000 then stall. But if you helped it with a gas tap when its on its way down it will fix itself and idle.
    Modified by veedubinit at 5:14 AM 10-27-2004
    Modified by veedubinit at 5:18 AM 10-27-2004
  35. 10-27-2004 03:15 PM #35
    The 9A from a 91 GTI would work the same right?
