Page 31 of 31 FirstFirst ... 21 27 28 29 30 31
Results 1,051 to 1,076 of 1076
Thread: 16v Digfant II FAQ
  1. 04-22-2011 10:39 PM #1051
    did 16v swap and bbm rail and injectors , i extended fuel rail wire and now when i turn car over everything is working but the injectors , im getting fuel to the injectors. got spark , motor kinda turns slow but i have new battery and i checked grounds and put new starter in . maybe a ground isnt good enough im stumped and need to get it goin any help would be awesome
  2. 04-22-2011 10:48 PM #1052
    ok your the one i need to talk to ... so i swapped a 16v into my jetta and bought bbm fuelr rail and fpr adapt. and 30 pound injectors. i extended my fuel wire to reach . after done with swap went to start car and engine rotated slow so i found that my starter was bounding up so i replaced that then i checked spark and gas and had that but no fire so then i pulled rail connected to injectors to see if they were squirting and no there not any ideas on what might be going wrong all i did was extend that wire . i took ur advice on some other things u talked about in the thread like swappin the 8v tb was helpfull so any other thing u know whould help thanks
  3. Member aaronmcadoo's Avatar
    Mar 4th, 2007
    Granite Falls WA
    88 jetta digi 16v coupe, 05 gli 1.8t 6 speed
    04-23-2011 08:02 PM #1053
    I have issue develope over the last few months of daily driving my digi2 16v car. i have noticed a surge under heavy acceleration it feels like it momentarily looses power then comes right back (not a miss) keeps pulling then does it again.
    motor specs
    1.8 16v rebuilt 3500 miles ago
    tt down pipe
    tt cat back (gutted cat for now)
    only does this above 4000 rpms at wot. no other time
    any thoughts?
    my first one is a knock sensor is taking a dive.
    maybe my VAM causing my issue. I might pick up a bmw one this week also
    injectors to small? stock digi2 injectors
    wot/idle switches test out (might try another tb from the wrecking yard next week)
    cts tests out
    o2 is newer and tests fine
    next swap for me will be CE2 in this car. so i can use this digi2 engine harness in my mk1 coupe
    Edit
    Fixed my issue it was timing
  4. Member
    Jun 21st, 2008
    PA
    87 Jetta Coupe
    04-24-2011 02:54 AM #1054
    Just did a 2.0 16v 9a into my 90 G60 corrado. Running a chipped Digi I ECU
    Ran into a problem. Idles fine but at 1300 (too High) and smokes to high heaven. Tried to adjust the idle but its all the way down. I might have a vacuum leak? What else might do this? Should I try unplugging the ISV?
  5. Junior Member GTIINSIDE's Avatar
    May 16th, 2008
    SD CA, TJ BC
    MK2 GTI, GLI
    05-09-2011 03:38 PM #1055
    Quote Originally Posted by VDub2506 View Post
    I am also having same problem mine is also 16V 9A but ported head , DIGI 1 , ECU stock chipped w/ G60 Injectors and smell a lot of gas & black smoke a friend told to change G60 injectors to DIGI 2 injectors do this will help ?
  6. Member getamongst-it's Avatar
    Oct 5th, 2005
    Rockfall, CT
    1987 Jetta Pirelli Edition Coupe
    05-16-2011 12:05 PM #1056
    Quote Originally Posted by MK2JettaGL View Post
    Just finished my Digi2 16v swap.
    REALLY happy with it! thing rips!! only a few minor issues to sort out. so i have a few questions.
    the configuration i used:
    -ross fuel rail
    -8v tranny
    -8v clutch
    -16v pressure plate
    -lightened eurospec flywheel
    -8v throttle body
    -8v hall sender in the Dizzy
    -Toywagen A/C delete pulley for 16v alternator
    -black CTS in flange on side of head
    -blue plug into 16v CTS
    -left side knock sensor
    -oil pressure sensor moved to back of head
    If anyone has any questions let me know. it was really straightforward the only thing i'm dealing with right now is an issue where my idle surges up and down sometimes. Im running the 8V ISV right now and whether its plugged in or not doesnt seem to effect this. The idle screw is backed all the way down so that it clicks the "idle circuit" switch at rest fine. Keep in mind this has been a flawless running Digi2 car for the past 5.5 years that I've owned it.
    when idling properly it sits at about 900-950, when surging it rests at 1100 and goes up to about 2000RPM then comes back down. if you load the car up (letting the clutch out till it almost stalls) you can sometimes stop this.
    I think that is has to do with the fact my crankcase breather is run to a catch can. I have blocked off the small breather on the left side of the head above the intake mani. I'm going to try recirculating the crankcase breather to the intake tube so it's stock-ish and see if that fixes my idle surge. Does anyone think its worth blocking off the crankcase breather and running one of those ABD vented oil cap adapters?
    just an overall update on this. car is still running solid besides the idle issues and i will be putting on a BMW AFM soon and 3.5bar FPR. i have plans for autotech cams and most likely the 7k TT chip.
    one thing i did though which helped/hurt the car is put additional piping on the intake. i added about 10" in overall length so the AFM/filter are sitting up near the headlight. this helped because before i had an issue with my AFM literally falling off the intake tube. this has seemed to hurt performance tho and the car doesnt pull nearly as hard at high RPMS. i'm going to remove the extension and run it before i make the switch to the BMW afm to confirm this however. the 8V AFM seems to like roughly the stock length of intake.
    -87 Pirelli Edition Jetta Coupe
    R.I.P. Alexi
  7. Junior Member
    May 22nd, 2011
    Langley BC
    97 VW JETTA
    05-23-2011 03:24 AM #1057
    I need serious Advice on some serious engine mods ( 97 Jetta 2.0)
    Langley BC
    Iam brand new to VORTEX , but a real Dub enthusiast. Iam a mechanic by trade but now venturing into my first import engine build and swap.... Currently running a 2.0 8 valve in my 97 Jetta. But have just purchased a 1991 2.0 16 valve. My plans are to strip the 16v and build it. Although i want to make this thing STRAIGHT RETARDED, if ya know what i mean, yet street legal.I have many questions and need guidance from guys that know.
    For example there 2 different fuel injection systems, do i go all new fuel management, stand alone or just piggy back off my stock system.
    head work..... ported and polished??? how much can i port?
    Valves and seat????? CAMS ?? i want 9 thousand RPM out of this thing, don't really need a crazy top speed, more just in town or quarter mile... throttle body ??what works best with a 16v
    As you can see i need serious advice. Hope to here some feedback.
    thanks Wil..............
    Anyhow this what i posted just recently.. after reading what you wrote about your conversion, i realized that you most defiantly know what my concerns are. I hope that we can talk.
  8. Member montanagreenmk2's Avatar
    Dec 31st, 2010
    nc
    1991 montana green mk2 gti, 1987 16v gli
    06-12-2011 06:15 PM #1058
    thinking bout swaping my 8v to 16v this should come in handy
    Aug 27th, 2008
    Winnipeg, Canada
    1987 Scirocco 16V
    06-12-2011 07:55 PM #1059
    Have done a swap using the G60 digi 1, it starts but when I tried to rev it up it will stall and only idle when ISV is disconected.
    Need help.
  10. 06-26-2011 07:05 PM #1060
    Hello, how to move the limiter on ~7000 for free?
    Change quartz ?
  11. Semi-n00b
    Jun 25th, 2011
    eugene or
    1983 rabbit GTI
    06-28-2011 03:19 PM #1061
    im doing a 16v swap on my 1983 gti rabbit and the donor motor was already swapped to digi 2, my question is what wire do i give switched power to on the digi harness?
    and is there anything else i need to do wiring wise?
  12. Member Gede Nimbo's Avatar
    Aug 13th, 2004
    Chesepeake / Metro NJ
    W126's, W124 V8's, W201s, OE-16V Cab, Rovers.
    08-18-2011 09:07 AM #1062
    So my Digi conversion has been done around 2 years ago but I have kept the car in the garage.. Ever since I completed the full conversion, I have had problems with the oil level light blinking in the cluster and the Coolant temp light flickering.. Is there a way to go through this or a remedy for it? I used the Dig 2 sensors as recommended in the initial install diagram..
    Thanks,
    Chris
  13. Member DumpdDirTEEDubZ's Avatar
    Sep 28th, 2006
    RDG, pa
    ~95vrWagen~90 2dr vr~
    10-02-2011 03:48 PM #1063
    so have few questions. have a 88 gti 16v (ce1) and po swapped to digi2(ce2) but still has the ce1 fuse/relay blocks. had spark,fuel etc. tried to get started and lost spark....changed ecu, distributor w/ hall sender, and coil also checked all grounds still no spark.battery is relocated to trunk if that means anything. anyone have any ideas? must i swap new ce2 fuse block and harness and start new?
    DGAF DUBZ
    www.CBtuning.net
    RDG/PREMIUM euros
  14. Member mexvdubr91's Avatar
    Nov 25th, 2009
    Chitown, IL
    86 16v cabby(project), '91 318ic e30, 00 tdi bug
    10-30-2011 04:59 PM #1064
    Hi guys,
    I'm the process of swapping a 2.0 16v into my 86 cabriolet, I rebuilt the engine and added some small mods like autotech cams, raceland headers and solid mounts. As of today, the engine is already in the car but I am having trouble with the digifant 2 wiring harness. Ive seen a picture of a labeled wiring harness but I think that is from a digi 1, and from what I can see, it is a little different.
    So what I need is a picture of a labeled Digi 2 wiring harness or something that could help me identify the pins.
    Thanks for reading this. Any help would be very appreciated.
  15. Member laychooba's Avatar
    Mar 2nd, 2001
    montreal
    scirocco 16v, audi A8Q
    03-01-2012 03:58 PM #1065
    question.
    that hole to the left of my CTS, does it need to be blocked
    off, or can i just run it open like that?
  16. Junior Member
    Feb 21st, 2011
    binghamton
    92 Golf GL
    03-24-2012 01:42 PM #1066
    i have the older 1.8 16v and can i use the 8v computer and harness and jus chip it??????????
  17. 05-25-2012 04:15 PM #1067
    Is there anybody still using this thread?
  18. Junior Member D727's Avatar
    Jun 6th, 2012
    mk4 2003 gti 1.8t, and mk2 1990 gli 2.0 16v
    06-08-2012 07:36 AM #1068
    i have a problem with my 1990 gli with the midtroic system i was thinking of putting a carb on but want to keep fuel injection system could you send me step by step t help me with this conversion plz respond back
  19. Junior Member
    Aug 13th, 2012
    TN
    2008 Built Mitsu EVO X GSR, 92 240SX, 92 GTI
    08-18-2012 03:06 PM #1069
    Why would you not use 16v injectors for a 16v engine and ecu?
  20. 12-20-2012 09:38 PM #1070
    hey folks, read almost the entire thread, good stuff, hoping someone has some insight here.
    I did a 16v 2.0 turbo install running Digi I from a Corrado. Almost everything is new, except the coil and 16v coolant temp sensor. The car starts and idles fine all day long, but boggs and bucks under load and sometimes when trying to hold revs in neutral.
    the only major difference in install procedure is that I opted to not use the ISV. I'm in texas, we see 32deg F maybe two days out of the year (like tonight) so I don't mind warming the engine up a few min before leaving the house which is what I read people do when they do an ISV delete. Since the OBD2 throttlebody I'm using has no idle adjustment mechanism, I'm running a 1/8NPT bypass hose from the intake pipe just before the t-body to the intake manifold. I do have a ball valve inline but it seems to idle at a sweet 850-900 rpm with the valve fully open (so I prob don't need it, but it's there in case idle rises after being run a long time and I need to choke it a bit)
    It's not turbo related, as I've disconnected the plumbing after the IC so it's basically like a N/A digi setup. The digi1 (corrado) co-pot aka. MAF is located 9" from the t-body and it ohms out good, set to 500.
    gas goes form new fuel cell to new cis fuel pump to new inline filter to injector rail for 3.5bar fpr to return line/tank. I see a constant 48psi on my gauge at the end of the rail before the FPR during idle, but can't monitor it during driving. I'll try to rotate it and run w/o a hood or maybe install a pressure sensor/gauge later but I have no reason to believe it's starving for fuel. Running the pump to a bucket, it does surge which I know is bad for CIS but from what I read it's ok for Digi due to the lack of a diaphram/distributor.
    And spark shows up nice when I use a timing light, and no arcing as i did a water mist test at night. again everything is new, brand new dist, cap, rotor, wires, plugs, o2, knock. Grounds are solid, running dual Optimas in the trunk and alt is putting out ~13.8. No vacuum leaks that I know of as I only have vacuum lines running to brake booster, ecu, fpr, boost gauge, and bov
    I'm contemplating using the ISV, but I would rather not try to figure out how to custom fab it into the already diminishing space under the bonnet, so I'm hoping aomeone would have a say or other ideas to check.
    ps. i also tried 2 diff chips in the ECU and the car performs the same using both a stock and stage4.
  21. Member
    Sep 14th, 2005
    VA
    88 GLI 16V
    12-29-2012 12:52 AM #1071
    Can you use a 16V TB if you plan on not running an ISV?
  22. Member weejunGL's Avatar
    Feb 2nd, 2005
    Norwegen
    MKII G60 Syncro
    12-29-2012 08:52 AM #1072
    Quote Originally Posted by big_hot_tamale View Post
    hopefully these chips are made for the engine? (2.0 16vt)? and not the 1.8 8v g60 engine?
    engine destruction will be the result of using a G60 chip with a turboed 16valver
  23. 01-20-2013 05:14 PM #1073
    Quote Originally Posted by weejunGL View Post
    That statement you made is a little misleading...
    A 16vT, or any car for that matter running Digi I/II will run safely, forever, using -any- chip, as long as you aren't flooring it everywhere and esp if you drive it without building any boost. It just won't run very well.
    It did not run excellent, but there was no engine destruction. air/fuel was reporting safe numbers at all times. Digi I runs simple maps between idle and WOT due to the lack of a TPS.
    I have the BBM one in there now, and the car runs better, still working out problems at upper rpms... :/
  24. Member lil_squeeker's Avatar
    Nov 17th, 2003
    Glenside, PA
    03 ranger, 92 cabriolet carat
    01-21-2013 10:08 PM #1074
    Quote Originally Posted by Turbo3 View Post
    doesnt matter.
    im using the 1.8 16v tb from a rocco with no issues, besides having to rewire the throttle switches.
    first start up was with no isv (plugged), and it ran fine.
    "subculture refuses to let this model vw fade away......they are cherished and preserved in spite of logic and economics."
  25. Member oopseyesharted's Avatar
    Mar 2nd, 2005
    South Euclid (Cleveland), OH
    1997 Passat GLX Vr6
    02-17-2013 01:31 PM #1075
    Ok. Here is a curve ball. I have an 85 cabby that is all stock. I want to convert it to digi 2.
    How much of this 16v is going to apply to me?
  26. n00b
    Feb 19th, 2013
    serbia
    90` passat limousine
    05-19-2013 07:10 PM #1076
    Hello, all!
    build 16v on digifant 2 PB
    I want to use the intake manifold from the engine ABF. Fuel rail from him, too.
    The question remains on the Throttle Body. From 8v will not run.
    this throttle body from abf
    whether it is suitable for wiring digi
    i am sorry for my english
