VWVortex.com - GUIDE: How to adjust your timing
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 65
    Thread: GUIDE: How to adjust your timing
    1. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      Q7 4.2 V8 , Smart 451 Turbo
      10-29-2004 08:54 PM #1
      Many people wonder how to adjust both their camshaft and ignition timing.
      Its very easy. Just say..... Thanks Black_cabbie and here is 5 bux for you!
      So,
      Suppose everything is messed up or you are rebuilting your engine so I will start from scratch.
      The Camshaft pulley has 2 important marks on it. A little notch on the engine side and a OT mark on the other side.
      The flywheel. it has 2 marks. One notch showing the 6 degrees BTDC (Before Top Dead Center) and a little dot showing the TDC.
      The dizzy. It has a notch.
      Removing the spark plugs (if they are not out already) helps a lot.
      Turn the engine BY HAND until you get this mark in the flywheel.
      The little 0 mark in the center of the Hole in the gearbox. Thats the TDC mark. It means the No1 piston is in TDC position and both inlet and outlet valves are closed. maximum compression in the chamber.
      That means that the spark plug is supposed to fire when the piston is at that point.
      You might also have this type of flywheel.... it has only the 6 degrees BTDC mark.
      If you are not sure about the flywheel, insert a long screwdriver in No1 cylinder through the spark plug hole and check while slowly turning the engine if the scredriver is moving. That will give you an idea if the piston is at TDC.
      Go to the dizzy and check if it points to the little notch. If it doesn't you have to loosen the belt, get it off the camshaft pulley and turn the rotor by hand until it points to the notch. Put the belt back and make sure the rotor doesn't move.
      Now check the camshaft pulley marks.
      If you have a late Digifant engine you have a plastic cover which doesn't allow you to see any marks on one side of the pulley.
      So you have the OT mark which is supposed to allign with the mark on the plastic cover. This mark is in the top center of the plastic cover. There is also a little arrow pointing down. The mark on the pulley should be under this arrow. If its not you have to loose the belt again and turn the camshaft until the marks allign. Make sure you don't move the dizzy rotor! The angle is a bit funny.... I know. Its supposed to be right under the arrow.
      If you have an older CIS engine, you probably have the metal belt cover which exposed both sides of the crank pulley. You should be able to see this mark (Its a notch just like the previous photo, don't worry, the photo is borrowed) at that exact point.
      Thats another shot of the mark. It is supposed to be level with the belt cover and the valve cover (under the holdown bars).
      Tight the belt tensioner according to specs and make sure the belt is not too tight. You should be able to twist by hand 90 degrees. No more, no less.
      The cam timing is finished. You have adjusted everything to VW spec which is 0 advance for the camshaft.
      For the ignition timing you need a timing light to fine tune it. If you don't have one you can do it by "feeling" the engine.
      So, Suppose that everything is correct, all the marks are alligned and you have tuned the engine a couple of times BY HAND to see if anything interfears. Everything should be ok. Put the dizzy cap on and start the engine. Normally the engine should start immediately.
      Take your timing light (if you have one) and point it into the gearbox hole where the flywheel is. If you have a digifant motor, unplug the blue sensor (CTS sensor) and rev the engine 3 times over 3k to clear the ECU memory. Have someone hold the engine at 2250 rpm and observe the mark in the hole as the engine turns and the light flashes. The strobo light will flash only when No1 spark plug is fired which is when the piston it at the Top Dead Center, meaning the little notch on the flywheel should appear still.
      For CIS timing is at idle speed (850 rpms). Make sure that all the accesories are switched off.
      If it doesn't appear, loose the 13mm nut on the dizzy and slowly turn the whole dizzy while still keeping the revs at 2250. As you turn it you will probably hear the engine sound change. You will also "feel" the engine running rough or smooth. Normally as you get closer to the notch the engine should feel smoother, with no missfires and with higher more clean rpm. Turn the dizzy until you get the little notch in the center of the hole. Thats the 6 Degrees BTDC timing everybody has been talking about and you read it in all the manuals. Your engine is supposed to produce its peak power (if its standard).
      Once you are happy with the timing, tight the 13mm nut on the dizzy again and check one more. if everything is still ok, plug the CTS sensor back and rev it 3 times again over 3K. Let it idle and observe. Chances are your idle might need some adjusting to get it to arround 850/900 rpm.
      Thats it! You did it! You can now brag to your friends that you don't need a specialist to do it!
      Modified by Black_cabbie at 8:11 AM 5-9-2005
      Chip Tuning for a living @ www.microchips-tuning.com
    2. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      10-29-2004 09:07 PM #2
      Thanks Black_cabbie and here's for ya
      That's excellent! Did you add it to the FAQ sticky?
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    3. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      10-29-2004 09:11 PM #3
      Not yet..... I want to get some more pics. Too bad I don't have my camera here with me right now. I could go down to the parking lot and get some.
      I got the pics in the tex and in some UK sites.
      And wth is that??????
      I only accept Paypal donations
    4. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      10-29-2004 09:14 PM #4
      Oz money!
      And I just got an email from PayPal saying that I was ousted and not allowed to return so you'll have to accept my Aussie $5...
      (p.s. the email was a scam)
    5. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      10-29-2004 09:17 PM #5
      ousted???????? hahahahahaha thats one of the most funniest things I've ever heard!
      So, regarding the guide. Do you think I need to add something for CIS ignition timing? I have no idea if its the same/similar procedure.
    6. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      10-29-2004 09:20 PM #6
      Yeah, it ended up being a scam 'cuz it said at the bottom: If you don't want your account to be terminated click the link and give us the info we want.
      A CIS guide would be awesome! I don't know the procedure myself; I know Bentley has some little blurb about it.
    7. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      10-29-2004 09:21 PM #7
      Quote, originally posted by kamzcab86 »
      Gather all the info missing from my guide and together we can make it a Digi/CIS guide!
    8. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      10-29-2004 09:27 PM #8
    9. 10-29-2004 11:39 PM #9
      Quote, originally posted by Black_cabbie »
      Actually, you have the CIS guide pretty close. The timing mark on the cam should actually be level with the top of the valve cover. The pic on the tranny hole showing dimple at TDC and groove at 6BTC are virtually perfect...but I have two rabbits and neither one has that cool pointer thingy in the hole. 1984 and 1981.
      On the later CIS (after my 1981!) you can pull the belts and timing covers and then put the crank pulley back on and the notch on the crank pulley will line up perfectly with the notch on the intermediate pulley with the crank pulley notch at 12:00.
      Also, on all of these, once you get the timing all set up at TDC here's a trick: Move the crank until your 6BTDC groove is lined up in the hole. Now move the dizzy until the rotor points at the line. That will get you much closer than the TDC before you start the car, and the car will be easier to start and will run better. You still need a light.
      The CIS should be timed at idle with all electrical loads off.
      My 1981 doesn't have the right kind of crank pulley, so not all CIS are equal.
      My 2 cents on the CIS!
      Thomas
    10. 10-29-2004 11:41 PM #10
      Great guide, George ... thanks, as always! I presume this procedure would be the same for a Digi I (CA-version) engine, right?
      A few n00b questions for you, then...
      By "dizzy" you mean distributor, right? That's where I get lost - I didn't think that there was a belt connecting the camshaft pulley to the distributor?? So why does the camshaft/timing belt need to be loosened to adjust the rotor?
      Quote »
      If you have a late Digifant engine you have a plastic cover which doesn't allow you to see any marks on one side of the pulley. So you have the OT mark which is supposed to allign with the mark on the plastic cover. This mark is in the top center of the plastic cover. There is also a little arrow pointing down. The mark on the pulley should be under this arrow.
      Hmmmm...well, I have a late Digi engine, and _used_ to have the plastic cover and timing mark of which you speak - but after the ABA swap the shop modified a nice metal cover to fit there instead, so I think that plastic side cover is no more ... any alternatives to setting the camshaft properly, then? I thought there was a way to do this with the timing light as well?
      And finally, how does one turn the engine by hand ... long wrench on the crankshaft??
      2008 Audi A3
      1992 VW Cabriolet
    11. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      10-29-2004 11:52 PM #11
      Quote, originally posted by netarc »
      The basic cam timing should be the same.
      As for the ignition, I have no idea but I think its the same. Bentley mentions it but don't remember right now.
      The distributor... The intermediate shaft is what connects the cam belt with the dizzy and the oil pump.
      The ABA..... On one side of the pulley you have the OT and on the other side you have the little notch. make sure the notch is near the valve cover as in the photo.
      Yes, the long socket will work fine on the crankshaft.
    12. 10-29-2004 11:56 PM #12
      Oh, forgot my last question - do I understand correctly then that w/this procedure, each spark plug is firing 6deg before TDC?
    13. 10-30-2004 12:00 AM #13
      You mean in this picture? I see what looks like a dimple on the side of one of the teeth, just even with/above the valve cover ... is that what you're referring to?
    14. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      10-30-2004 12:15 AM #14
      Yes, you are supposed to have a notch there.
    15. 10-30-2004 09:47 PM #15
      That picture actually does not show a CIS at TDC. The dimple will be exactly aligned with the top of the valve cover when the cam is at TDC. If you try to put the belt on with the dimple in the position shown it won't match up.
      Hey, Black Cabbie...I found my pointers now that I know where to look! Thanks for the awesome pics! That's the first time I've seen a really good pic of the timing hole!
      Do you want a pic of the timing notch for the 1981 cabbie? I just went and looked today and it's totally different from the one you've shown.
      Thanks!
      Thomas
    16. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      10-30-2004 10:00 PM #16
      Quote, originally posted by Thomas_covenant »
      Thanks!
      Thomas
      Sure! The more the better! I have been receiving PMs from CIS users asking me about this. Email: maxkoutsis at hotmail.com
    17. 10-31-2004 04:08 PM #17
      Cool. I'll try to get one today. The one you showed (groove at 6 degrees before the dimple) is correct for my 1984. But the older ones it's way different. Well, you'll see. I'll get a pic and try to post it today!
      FWIW I bought a new lower timing cover on my 1984. It turns out that there's an arrow on it that points right to the crank TDC notch. (There wasn't one on the old lower cover). I'll try to get pics of that as well. Makes it a lot easier to TDC the crank because you can do it while you're turning the crank instead of having to lay across the engine to look in the hole while turning the crank!
      Thomas
    18. 10-31-2004 08:15 PM #18
      OK. Here is the first pic. Came out really nice, if I do say so myself (and, of course, I do!). It's the pic of my 1981 'vert's 6BTDC timing mark. It's way different than the on on my '84 (which is the one you've shown).
      Hope I did this right!
      Thomas
    19. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      10-31-2004 08:16 PM #19
      So, How do you adjust the static timing on the Cis? Which mark do you use?
      I have people asking me this through PMs
    20. 10-31-2004 08:20 PM #20
      OK. Here's what the cam dimple should look like at TDC. Notice that my valve cover has the little hold-down bars. The dimple should be sitting right at the level of the actual valve cover, not the top of the hold-down bars, though if you just get it close you can get the belt to go into all the teeth and after you crank the cam through one full turn it'll all straighten itself out. If you look just to the left of the dimple (I used white-out on it) you'll see the top of the inside timing cover. You can also use that, as it's exactly the same height at the top of the valve cover. When I'm doing mine I just put a ruler across the inner timing cover and turn the engine until the dimple lines up.
      Thomas
    21. Member Moljinar's Avatar
      Sep 20th, 2001
      Indianapolis, IN
      87 Cabriolet, 85 Cabriolet, 90 JettaGL
      11-01-2004 10:24 AM #21
      For the sake of those not following this well, T.C. means not the top of the valve cover but the top of the valve cover gasket flange (where the bolt is).
    22. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      11-01-2004 10:35 AM #22
      Quote, originally posted by Moljinar »
      Update...
      anything else?
    23. 11-01-2004 11:37 AM #23
      You are a good man blacky...haha thanks! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. Member Black_cabbie's Avatar
      Jul 16th, 2003
      Athens Greece
      11-01-2004 12:21 PM #24
      Quote, originally posted by ciTy_goLf »
      You should check your since you have idle problems.
    25. Member Moljinar's Avatar
      Sep 20th, 2001
      Indianapolis, IN
      11-01-2004 03:44 PM #25
      Update...
      anything else?
      Well, I might mention that aligning the flywheel up with the pointer gives you the position of TDC for cylinder 1 AND cylinder 4!!! So merely lining up the pointer does not guarantee that the distributor is ready to fire on cyl. #1. It's as likely to be eady to fire on #4. Merely spin the crank around again and you should be ready to fire #1.
