VWVortex.com - Mk3 Single Chamber headlights to Dual Chamber headlight conversion
    Results 1 to 12 of 12
    Thread: Mk3 Single Chamber headlights to Dual Chamber headlight conversion
    1. 11-04-2004 04:28 PM #1
      I was wondering how the people who have done this did it?
      Did you buy the proper harness? Did you splice your wiring? Did you custom make a harness?
      Any help, or especially HOWTO links on how to do this would be great.
      Essentially I have Mk3 Hella Dual Rounds, but i have a golf CL w. OE Single chamber lights. I need to convert from 45Watt single to a 55watt dual
      Thanks
    2. Member Kei78's Avatar
      Oct 8th, 2001
      Canada
      11-04-2004 04:53 PM #2
      Good question...ill be doing this soon, so ill need this info as well!
    3. Member 1VR62NV's Avatar
      Sep 13th, 2003
      Toronto
      '99 Mk3 GTi VR6, '12 CC (Pre-Facelift)
      11-04-2004 11:35 PM #3
      change the harness for the headlights
      Eurotuner 02/10
      @1vr62nv
    4. 11-04-2004 11:49 PM #4
      Quote, originally posted by 1VR62NV »
      how?
    5. 11-05-2004 07:23 AM #5
      i'm positive if you bothered to search throught the mk3 FAQ you'd find the answer to this and a bucketload more.
      2016 Discount Brand S3
      1987 Peugeot PB-18 – Manual Power
      1986 Mid-Engine Supercar
    6. 11-05-2004 12:38 PM #6
      use the european headlight wirring harness and splice it into your existing wiring. plug and play after that [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member chaoticvr6's Avatar
      Aug 7th, 2002
      Oakville, Ontario, Canada
      '66 VW MicroBus -=- '03 GLi 24V 6-speed -=- '00 GTi 1.8t -=-
      11-05-2004 12:52 PM #7
      Quote, originally posted by Steve Pell »
      how?
      Directly above your rad, you will see a ROUND plug/adapter. Get a VR headlight harness and unscrew the CL harness, and plug in the VR one.
      Total install time - 15 mins tops. No cutting, no splicing, nothing.
      I have one, if you need it. I can do it for you if you like.
      Get in touch with me Steve, I have done this 1,000 times....
      -=] '66 Splitty Bus [=- -=] '03 Jetta GLi 24V 6-Speed [=- -=] '00 GTi 1.8t [=- -=] '08 Harley Davidson Night Train Custom [=- -=] '05 Suzuki GSXR600+ [=-
    8. Member 1VR62NV's Avatar
      Sep 13th, 2003
      Toronto
      11-06-2004 02:15 AM #8
      exactly
      Eurotuner 02/10
      @1vr62nv
    9. 01-11-2005 12:12 AM #9
      I want to do the same.
      What is involved in doing this??
    10. 01-11-2005 12:13 AM #10
      Quote, originally posted by K2Golf1.8 »
      then you should read this thread.......
      Modified by independent77 at 12:19 AM 1-11-2005
    11. 01-11-2005 12:44 AM #11
      opps....only quickly read thread...but still vague direction. is there a proper DIY?
    12. Banned PrupleGTI's Avatar
      Feb 1st, 2002
      01-11-2005 07:08 AM #12
      Try Asking Red Baron Golf he did a damn fine job on his MKIII
