Page 51 of 52 FirstFirst ... 41 47 48 49 50 51 52 LastLast
Results 1,751 to 1,785 of 1806
Thread: 20V Hybrid - How To
  1. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    12-19-2011 12:32 PM #1751
    If anyone is interested I have a few of the 90* distributor caps.
    Guys,
    It took a long time for me to complile this information in a clear and concise form for all to read. Sending me a PM asking me to explain to you what is allready very clear will only get you referred back to this thread. If you can not understand what is going on in the 1st post of this thread then maybe the task at hand is too much for you currently and you should seek help before continuing. If a portion of this thread is unclear , tell me where it is unclear and I will do my best to expand on it.
  2. Junior Member mk 2.5 fatman's Avatar
    May 6th, 2011
    maricopa az
    2005 BL-Gli
    12-20-2011 08:42 AM #1752
    Will this swap work with digi II? How critical is it to not have a obd I Aba block? How much for a 90 degree cap?
  3. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    12-20-2011 09:09 PM #1753
    Quote Originally Posted by mk 2.5 fatman View Post
    1. Yes but I wont recommend it considering what Digi-II came standard with. Highly recommend a cheap standalone at that point.
    2. ABA block is the most desired VW827 block available. You can use whichever you wish though
    3. $25
  4. Junior Member mk 2.5 fatman's Avatar
    May 6th, 2011
    maricopa az
    2005 BL-Gli
    12-21-2011 12:29 PM #1754
    Quote Originally Posted by Issam Abed View Post
    Which standalone would you recommend? It's going in a mk2
  5. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    12-21-2011 12:42 PM #1755
    megasquirt
    The Professor
    Melbourne, FL
    M & L EFI Performance
  6. Member 4cedboost's Avatar
    Jul 16th, 2006
    Poland, Ohio
    2008 FSI GTI (daily) 1991 GTI (work in progress)
    12-21-2011 04:04 PM #1756
    does anyone make a custom piston for a 144mm rod for on an 8v setup? turbocharging my PG block and using an AEG head from a mkIV 2.0
  7. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    12-21-2011 10:35 PM #1757
    Quote Originally Posted by 4cedboost View Post
    What crankshaft? 86.4mm or 92.8mm?
    we make custom pistons for all different applications.
  8. Junior Member Roman5400's Avatar
    Jun 21st, 2011
    avondale, az
    2003 Bora Turbo, 1985 GTI 8v
    01-22-2012 04:09 PM #1758
    What if I have an AZG block? Does all the AEG stuff apply still?
  9. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    01-22-2012 06:32 PM #1759
    Quote Originally Posted by Roman5400 View Post
    Yes
  10. Member fox-16v's Avatar
    Jun 30th, 2009
    Spring Lake NC
    2001 B5 S4
    06-22-2012 09:35 PM #1760
    Alright ppl I am bringing this back from the dead. I want to build a 20v/lysholm. There is no real rush on building this HOWEVER with so many ways of doing this listed in this thread can someone please make a down and dirty parts list for me to acquire everything. I will use/already have a PG/PL/ and can get a ABA block. I would use the AEB cylinder head. Also, pictures are dead for drilling the new oil passage required for the new cylinder head as well as the guide to deal with the cam chain tensioner inside the AEB head.
    I will also do this using the stock digi 1 management coupled with a sns chip. So just a basic list for me to get the motor straight would be very helpful. I can figure out manifolds/accessories etc.
    In my Corrado, I live my life a quarter mile at a time.. for those 18 seconds or less, I'm free
    Quote Originally Posted by 206929rr View Post
    nice find. sell me your foha. im not asking. "this isnt the foha you were looking for" (waves hand jedi like)...
  11. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    06-22-2012 11:19 PM #1761
    Quote Originally Posted by fox-16v View Post
    Forget this completely. The G60 engine comes in chassis's over 20 years old...get standalone
  12. Member fox-16v's Avatar
    Jun 30th, 2009
    Spring Lake NC
    2001 B5 S4
    06-23-2012 12:09 AM #1762
    Well like I said I'm in no rush. I just have a large abundance of random vw parts from all walks of life and would like to build something unique.
  13. 07-12-2012 07:18 AM #1763
    Hi good day all
    just a quick one
    why cant the normal 8v pulleys work on the 20v setup?
    As far as i know the cam and dist also turns 2-1
  14. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    07-12-2012 11:34 AM #1764
    Quote Originally Posted by dielynton View Post
    Hi good day all
    just a quick one
    Finding 8V timing belts for custom lengths are a bit hard because the pitch is extremely specific. Also the 20V gears/pulleys are 25mm wide.
  15. Member
    Jun 15th, 2011
    Kitchener, Ontario
    1999 Beetle TDI, 2002 GTI 1.8T, 1999.5 GTI VR6
    08-03-2012 03:07 PM #1765
    building a DD and have been planning it for months now, was planning on swapping blocks and upgrading rods and pistons.
    came on here to see if anyone has used a TDI crank in an AEG hoping to see how easy it would be to make a 2.1 or 2.2L.
    then i hear about this oil squirter issue, i thought the AEG had oil squirters. i just read that pete from IE doesnt reccomend the swap because the lack of the squirters.
    what are people doing about this ? anything ? what happens if i use the aeg block with out them.
    GT3076 around 28 PSI. (High RPM - 9k)
    or would i use a AVH, AZG, BGD block, they had oil squirters right ?
    i need it to be somewhat realiable
  16. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-03-2012 10:59 PM #1766
    Quote Originally Posted by 1999.5GTIVR6 View Post
    Do you have a 1.8T block?
  17. Member
    Jun 15th, 2011
    Kitchener, Ontario
    08-04-2012 02:05 AM #1767
    yeah, its going into a 2002 awp car
  18. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-04-2012 11:01 AM #1768
    Then use that block with the AEG crankshaft
  19. Member
    Jun 15th, 2011
    Kitchener, Ontario
    08-07-2012 08:59 AM #1769
    my 1.8 block has a mount sheererd off the back, aswell i would rather not bore out the 1.8 to much (im also DDing it)
  20. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-07-2012 12:06 PM #1770
    There is no difference between a 1.8T and 2.0 block...
    one has an M14 tap @ the rear and is 81mm bore and the other has no M14 tap and is 82.5mm bore.
    You can safely take either block to 83mm's.
    That being said , I have a whole bunch of 82.5mm bore blocks that are brand new. Send over a PM for further details.
  21. Member
    Aug 28th, 2011
    MD 21703
    08-13-2012 03:01 PM #1771
    Do you sell a parts kit for this (minus management)? I already have an AEB head and can easily get an obd1 bottom end.
  22. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-14-2012 01:08 AM #1772
    Quote Originally Posted by harlequin80 View Post
    since the creation of this thread I have sort of "modified" the advice I give people. Are you running digifant 1 or going straight to standalone?
  23. Member
    Aug 28th, 2011
    MD 21703
    08-14-2012 08:19 AM #1773
    The motor is goin into my harlequin so I'm guessing standalone?
  24. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-15-2012 12:33 AM #1774
    Then stay away from the ABA blocks. No real benefit to having them with 06A motors becoming so readily available.
  25. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    08-15-2012 05:47 AM #1775
    Gotta disagree with you there. While it is more work to build a 20/20 with an ABA the long rod/ tall deck bottom end has it's advantages. The biggest advantage is torque. Tons and tons of torque.
    The Professor
    Melbourne, FL
  26. Member
    Aug 28th, 2011
    MD 21703
    08-15-2012 11:00 AM #1776
    I have a complete AEB motor. Someone said that I could run the motronic system on the 20v hybrid. What are the benefits/downsides to that? I know it is possible to wire the AEB motor into the factory mk3 system so I'm guessing there isn't much difference if it's NA vs FI
  27. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    08-15-2012 12:23 PM #1777
    Just about anything can be done with enough time, patience, and cash. The question is, is it worth it? In my opinion NO. Standalone is very much the way to go. It can be done quite inexpensively and if you decide to make change to the motor once it's in (big turbo, cams, injectors, etc....) you don't have to get the ECU reflashed.
    The Professor
    Melbourne, FL
  28. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-15-2012 08:56 PM #1778
    Quote Originally Posted by Prof315 View Post
    ...and the amount of work needed to do an ABA block he might as well do an ALH block and be done with it.
    Unless you are running digifant-I or another block mounted distributor system , there is no need to use any of the old 827 blocks.
    06A is the future , has been for sometime now.
  29. Member
    Aug 28th, 2011
    MD 21703
    08-15-2012 10:18 PM #1779
    So what is the ideal setup to use to throw it in a mk3 chassis? I have an 058 block that I was going to use when I wanted a BT 1.8T.
    Also where can I find ITB's ?
  30. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-17-2012 09:07 PM #1780
    MKIII + 058 = correct combination. No modifications needed to the AEB motor to make it fit in the MKIII chassis.
    There was a guy on here selling a set of ITB's recently. Search and it should be the first hit.
  31. Member
    Aug 28th, 2011
    MD 21703
    08-18-2012 10:40 AM #1781
    I know you can use the AEB block as it uses the same mounts and stuff as the ABA block. So basically what you are saying is to just build the motor I have to be N/A instead of turbo.
    I just sold off the rods I had for it
    I think Im going with the obd1 aba block anyways. Id still have to find a crank for the AEB motor and I can get a complete obd1 for less than a crank
  32. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-18-2012 11:26 AM #1782
    Why would it matter if you sold the rods? N/A motors do not need forged rods , just ARP hardware on them. Get an OBD-I ABA crankshaft and throw it in the AEB block.
    2.0 20V AEB
  33. Member
    Aug 28th, 2011
    MD 21703
    08-18-2012 01:13 PM #1783
    Because now I need rods again.
    What rods/pistons would I use with an ABA crankshaft? Are they direct fit into the AEB block no mods needed?
  34. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    08-19-2012 04:27 AM #1784
    You will need to grind the inside of the crankcase of the block to clearance the full swing of the connecting rod (actually the connecting rod bolts) but yes it can be a direct fit into an AEB block.
    ABA Crankshaft + 144/20mm connecting rods + Mahle 92.8mm stroke pistons + AEB block = 2008cc AEB motor.
    I would only attempt this if you absolutely want to stay with the 827 motors.
  35. Member wolfens_golf's Avatar
    Dec 29th, 2009
    Armpit Of Ontario..Hamilton
    Corrado G60, MK3 Jetta, MK3 Golf, MK2 Golf N/A 1.6
    09-02-2012 02:12 AM #1785
    FIRST OFF....BUMP TO A GREAT THREAD. second id just like to say thanks for all the great advice. unfortunatly im noobish to the engine game so i do have some questions. yes i have read the majority of this thread but it can get alittle confusing.......on with the questions and my plans with the engine set up
    91 corrado g60 planning to 20valve head swap...keeping dizzy & gladder
    g60 block (PG)
    AEB cly head
    PG crank shaft(FORGED=BETTER)
    AEB cyl head studs
    AEB pistons & connecting rods
    ABA OBD1 head gasket
    AEB 20V camshat gear
    PL intermediate shaft
    AEB 20v gear(intermediate shaft)
    16v wires
    16v crankshaft pully
    16v timing belt tensioner
    honda preude timing belt 2.2 vtec 92-98
    is this list correct? would i need a 16v dizzy?
    also if i used a audi tt manifold what throttle cable do i need?
    raising the compression....can i plane the head..if so how much?
    i would require a chip for the digi 1?
    the gladder is getting rebuilt....would one run a stock pully to "break in" then move to the 68 mm?
